Bonjour BelZéButh .
merci de ta réponse. pour info le test ping fonctionnait correctement a la mise en place de la redirection .suite a un souci de config sur apache j’ai désinstallé purgé apache et php. ce matin je suis allé chez un pote la page index.html c’est affiché en tappant le nom de domaine dans l’url. retour chez moi j’ai essayer d’une tablette que dalle.
Voici les réponses a tes tests :
donne : dpkg -l | grep -E "apache2|php|mysql"
ii apache2 2.2.22-13+deb7u4 amd64 Apache HTTP Server metapackage
ii apache2-mpm-prefork 2.2.22-13+deb7u4 amd64 Apache HTTP Server - traditional non-threaded model
ii apache2-suexec 2.2.22-13+deb7u4 amd64 Standard suexec program for Apache 2 mod_suexec
ii apache2-utils 2.2.22-13+deb7u4 amd64 utility programs for webservers
ii apache2.2-bin 2.2.22-13+deb7u4 amd64 Apache HTTP Server common binary files
ii apache2.2-common 2.2.22-13+deb7u4 amd64 Apache HTTP Server common files
ii dovecot-mysql 1:2.1.7-7+deb7u1 amd64 MySQL support for Dovecot
ii libapache2-mod-php5 5.4.39-0+deb7u1 amd64 server-side, HTML-embedded scripting language (Apache 2 module)
ii libdbd-mysql-perl 4.021-1+b1 amd64 Perl5 database interface to the MySQL database
ii libmysqlclient18:amd64 5.5.41-0+wheezy1 amd64 MySQL database client library
ii mysql-client 5.5.41-0+wheezy1 all MySQL database client (metapackage depending on the latest version)
ii mysql-client-5.5 5.5.41-0+wheezy1 amd64 MySQL database client binaries
ii mysql-common 5.5.41-0+wheezy1 all MySQL database common files, e.g. /etc/mysql/my.cnf
ii mysql-server 5.5.41-0+wheezy1 all MySQL database server (metapackage depending on the latest version)
ii mysql-server-5.5 5.5.41-0+wheezy1 amd64 MySQL database server binaries and system database setup
ii mysql-server-core-5.5 5.5.41-0+wheezy1 amd64 MySQL database server binaries
ii php-pear 5.4.39-0+deb7u1 all PEAR - PHP Extension and Application Repository
ii php5 5.4.39-0+deb7u1 all server-side, HTML-embedded scripting language (metapackage)
ii php5-cgi 5.4.39-0+deb7u1 amd64 server-side, HTML-embedded scripting language (CGI binary)
ii php5-cli 5.4.39-0+deb7u1 amd64 command-line interpreter for the php5 scripting language
ii php5-common 5.4.39-0+deb7u1 amd64 Common files for packages built from the php5 source
ii php5-curl 5.4.39-0+deb7u1 amd64 CURL module for php5
ii php5-dev 5.4.39-0+deb7u1 amd64 Files for PHP5 module development
ii php5-gd 5.4.39-0+deb7u1 amd64 GD module for php5
ii php5-imagick 3.1.0~rc1-1+b2 amd64 ImageMagick module for php5
ii php5-imap 5.4.39-0+deb7u1 amd64 IMAP module for php5
ii php5-intl 5.4.39-0+deb7u1 amd64 internationalisation module for php5
ii php5-mcrypt 5.4.39-0+deb7u1 amd64 MCrypt module for php5
ii php5-memcache 3.0.6-6 amd64 memcache extension module for PHP5
ii php5-ming 1:0.4.4-1.1 amd64 Ming module for php5
ii php5-mysql 5.4.39-0+deb7u1 amd64 MySQL module for php5
ii php5-ps 1.3.7-1 amd64 ps module for PHP 5
ii php5-pspell 5.4.39-0+deb7u1 amd64 pspell module for php5
ii php5-recode 5.4.39-0+deb7u1 amd64 recode module for php5
ii php5-snmp 5.4.39-0+deb7u1 amd64 SNMP module for php5
ii php5-sqlite 5.4.39-0+deb7u1 amd64 SQLite module for php5
ii php5-tidy 5.4.39-0+deb7u1 amd64 tidy module for php5
ii php5-xmlrpc 5.4.39-0+deb7u1 amd64 XML-RPC module for php5
ii php5-xsl 5.4.39-0+deb7u1 amd64 XSL module for php5
ii phpmyadmin 4:3.4.11.1-2+deb7u1 all MySQL web administration tool
ii postfix-mysql 2.9.6-2 amd64 MySQL map support for Postfix
donne: [....] Reloading web server config: apache2[Sat Mar 28 11:46:03 2015] [warn] The Alias directive in /etc/postfixadmin/apache.conf at line 3 will probably never match because it overlaps an earlier Alias.
. ok
Syntax OK
Syntax OK
VirtualHost configuration:
wildcard NameVirtualHosts and _default_ servers:
*:80 is a NameVirtualHost
default server nom.du.serveur (/etc/apache2/sites-enabled/000-default:1)
port 80 namevhost nom.du.serveur (/etc/apache2/sites-enabled/000-default:1)
port 80 namevhost nomdedomainequiposesouci.fr (/etc/apache2/sites-enabled/webmin.1427448945.conf:1)
Syntax OK
donne : [code]::::::::::::::
/etc/apache2/sites-available/.conf
Listen 80<VirtualHost *:80>
DocumentRoot "/var/www/dossierdomainequiposesouci"
ServerName nomdedomainequiposesouci.fr
<Directory “/var/www/dossierdomainequiposesouci”>
allow from all
Options +Indexes
ServerAlias nomdedomainequiposesouci.fr
Log pour les erreurs
ErrorLog ${APACHE_LOG_DIR}/error.log
LogLevel warn
Log des connexion au site
CustomLog ${APACHE_LOG_DIR}/access.log combined
/etc/apache2/sites-available/default
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
/etc/apache2/sites-available/default-ssl
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/ssl_access.log combined
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2.2-common/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
# Set the CA certificate verification path where to find CA
# certificates for client authentication or alternatively one
# huge file containing all of them (file must be PEM encoded)
# Note: Inside SSLCACertificatePath you need hash symlinks
# to point to the certificate files. Use the provided
# Makefile to update the hash symlinks after changes.
#SSLCACertificatePath /etc/ssl/certs/
#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
# Certificate Revocation Lists (CRL):
# Set the CA revocation path where to find CA CRLs for client
# authentication or alternatively one huge file containing all
# of them (file must be PEM encoded)
# Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath /etc/apache2/ssl.crl/
#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
# Client Authentication (Type):
# Client certificate verification type and depth. Types are
# none, optional, require and optional_no_ca. Depth is a
# number which specifies how deeply to verify the certificate
# issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
# Access Control:
# With SSLRequire you can do per-directory access control based
# on arbitrary complex boolean expressions containing server
# variable checks and other lookup directives. The syntax is a
# mixture between C and Perl. See the mod_ssl documentation
# for more details.
#<Location />
#SSLRequire ( %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
# and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \
# and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \
# and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
# and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20 ) \
# or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/
#</Location>
# SSL Engine Options:
# Set various options for the SSL engine.
# o FakeBasicAuth:
# Translate the client X.509 into a Basic Authorisation. This means that
# the standard Auth/DBMAuth methods can be used for access control. The
# user name is the `one line' version of the client's X.509 certificate.
# Note that no password is obtained from the user. Every entry in the user
# file needs this password: `xxj31ZMTZzkVA'.
# o ExportCertData:
# This exports two additional environment variables: SSL_CLIENT_CERT and
# SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
# server (always existing) and the client (only existing when client
# authentication is used). This can be used to import the certificates
# into CGI scripts.
# o StdEnvVars:
# This exports the standard SSL/TLS related `SSL_*' environment variables.
# Per default this exportation is switched off for performance reasons,
# because the extraction step is an expensive operation and is usually
# useless for serving static content. So one usually enables the
# exportation for CGI and SSI requests only.
# o StrictRequire:
# This denies access when "SSLRequireSSL" or "SSLRequire" applied even
# under a "Satisfy any" situation, i.e. when it applies access is denied
# and no other module can change it.
# o OptRenegotiate:
# This enables optimized SSL connection renegotiation handling when SSL
# directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
# SSL Protocol Adjustments:
# The safe and default but still SSL/TLS standard compliant shutdown
# approach is that mod_ssl sends the close notify alert but doesn't wait for
# the close notify alert from client. When you need a different shutdown
# approach you can use one of the following variables:
# o ssl-unclean-shutdown:
# This forces an unclean shutdown when the connection is closed, i.e. no
# SSL close notify alert is send or allowed to received. This violates
# the SSL/TLS standard but is needed for some brain-dead browsers. Use
# this when you receive I/O errors because of the standard approach where
# mod_ssl sends the close notify alert.
# o ssl-accurate-shutdown:
# This forces an accurate shutdown when the connection is closed, i.e. a
# SSL close notify alert is send and mod_ssl waits for the close notify
# alert of the client. This is 100% SSL/TLS standard compliant, but in
# practice often causes hanging connections with brain-dead browsers. Use
# this only for browsers where you know that their SSL implementation
# works correctly.
# Notice: Most problems of broken clients are also related to the HTTP
# keep-alive facility, so you usually additionally want to disable
# keep-alive for those clients, too. Use variable "nokeepalive" for this.
# Similarly, one has to force some clients to use HTTP/1.0 to workaround
# their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
# "force-response-1.0" for this.
BrowserMatch "MSIE [2-6]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
# MSIE 7 and newer should be able to use keepalive
BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
/etc/apache2/sites-available/roundcube
ServerAdmin test@test.com
ServerName webmail.adresseduserveur
DocumentRoot /var/www/webmail
# SuexecUserGroup roundcube roundcube # on verra ça plus tard
AllowOverride All
Options FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
# alert, emerg.
LogLevel warn
/etc/apache2/sites-available/webmail.adresseduserveur.conf
DocumentRoot "/var/www/webmail"
ServerName webmail.ns374667.ip-37-187-173.eu
allow from all
Options None
/etc/apache2/sites-available/webmin.1427448945.conf
ServerAlias www.nomdedomainequiposesouci.fr
DocumentRoot /var/www/nomdududossierquiposesouci
donne :
[code]<VirtualHost *:80>
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
ServerAlias www.domainequiposesouci.fr
DocumentRoot /var/www/dossierdomainequiposesouci
ServerName domainequiposesouci.fr
[code]apachectl -t -D DUMP_MODULES[/code]
donne: [code][Sat Mar 28 12:04:31 2015] [warn] The Alias directive in /etc/postfixadmin/apache.conf at line 3 will probably never match because it overlaps an earlier Alias.
Loaded Modules:
core_module (static)
log_config_module (static)
logio_module (static)
version_module (static)
mpm_prefork_module (static)
http_module (static)
so_module (static)
alias_module (shared)
auth_basic_module (shared)
authn_file_module (shared)
authz_default_module (shared)
authz_groupfile_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
cgi_module (shared)
deflate_module (shared)
dir_module (shared)
env_module (shared)
mime_module (shared)
negotiation_module (shared)
php5_module (shared)
reqtimeout_module (shared)
setenvif_module (shared)
status_module (shared)
Syntax OK
[code]ps aux | grep apache[/code]
donne :
[code]root 8218 0.0 0.0 341732 21976 ? Ss mars27 0:01 /usr/sbin/apache2 -k start
www-data 19265 0.0 0.0 341956 11116 ? S 11:46 0:00 /usr/sbin/apache2 -k start
www-data 19266 0.0 0.0 341956 11116 ? S 11:46 0:00 /usr/sbin/apache2 -k start
www-data 19267 0.0 0.0 341956 11108 ? S 11:46 0:00 /usr/sbin/apache2 -k start
www-data 19268 0.0 0.0 341956 11108 ? S 11:46 0:00 /usr/sbin/apache2 -k start
www-data 19269 0.0 0.0 341956 11108 ? S 11:46 0:00 /usr/sbin/apache2 -k start
root 22604 0.0 0.0 8340 888 pts/0 S+ 12:05 0:00 grep apache
ping sur l'ip du serveur --> ok
ping sur le nom du serveur --> ok (en renvoyant l'IP)
ping sur le nomdedomaineasouci.fr --> ko vérifié le nom et essayé de nouveau.
Par contre ping sur [nomdedomaineasouci.fr](http://www.nomdedomaineasouci.fr) --> ok !!
probleme d’alias ??
Par avance merci
