Il ne manquerait pas des paquets *-dev ?
Effectivement, l’installation de libdrm-dev a changé le message d’erreur de l’autogen:
[quote]Package libomxil-bellagio was not found in the pkg-config search path.
Perhaps you should add the directory containing `libomxil-bellagio.pc’
to the PKG_CONFIG_PATH environment variable
No package ‘libomxil-bellagio’ found
checking for RADEON… yes
configure: error: LLVM is required to build Gallium R300 on x86 and x86_64
root@kmcs:~/mesa# dpkg -l llvm
Souhait=inconnU/Installé/suppRimé/Purgé/H=à garder
| État=Non/Installé/fichier-Config/dépaqUeté/échec-conFig/H=semi-installé/W=attend-traitement-déclenchements
|/ Err?=(aucune)/besoin Réinstallation (État,Err: majuscule=mauvais)
||/ Nom Version Architecture Description
ii libllvm3.5:amd64 1:3.5-10 amd64 Modular compiler and toolchain technologies, runtime l
ii libllvm3.5:i386 1:3.5-10 i386 Modular compiler and toolchain technologies, runtime l
un llvm (aucune description n’est disponible)
ii llvm-3.5 1:3.5-10 amd64 Modular compiler and toolchain technologies
ii llvm-3.5-dev 1:3.5-10 amd64 Modular compiler and toolchain technologies, libraries
un llvm-3.5-doc (aucune description n’est disponible)
ii llvm-3.5-runtime 1:3.5-10 amd64 Modular compiler and toolchain technologies, IR interp
llvm a pourtant l’air installé…
Le paquet [mono]llvm[/mono] lui-même ne semble pas installé.
[Edit : je n'avais pas copié la bonne ligne]
[Edit : je n’avais pas copié la bonne ligne]
Ca avance
./autogen
checking for XCB_DRI2... yes
checking for llvm-config... /usr/bin/llvm-config
Perhaps you should add the directory containing `libomxil-bellagio.pc'
No package 'libomxil-bellagio' found
checking for RADEON... yes
Package libva was not found in the pkg-config search path.
Perhaps you should add the directory containing `libva.pc'
No package 'libva' found
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
Pourtant:
N’oublie pas que pour compiler tu as besoin du paquet -dev qui contient les en-têtes de chaque bibliothèque nécessaire.
Je ne vois pas quel -dev manquerait:
kmc@kmcs:~$ sudo dpkg -l *llvm*
ii libllvm3.5:amd6 1:3.5-10 amd64 Modular compiler and toolchain tech
ii llvm 1:3.5-25 amd64 Low-Level Virtual Machine (LLVM)
ii llvm-3.5-doc 1:3.5-10 all Modular compiler and toolchain tech
ii llvm-3.5-runtim 1:3.5-10 amd64 Modular compiler and toolchain tech
ii llvm-runtime 1:3.5-25 amd64 Low-Level Virtual Machine (LLVM), b
kmc@kmcs:~$ dpkg -l libdrm*
ii libdrm-amdgpu1: 2.4.65-3 amd64 Userspace interface to amdgpu-speci
ii libdrm-dev:amd6 2.4.65-3 amd64 Userspace interface to kernel DRM s
ii libdrm-intel1:a 2.4.65-3 amd64 Userspace interface to intel-specif
rc libdrm-intel1:i 2.4.58-2 i386 Userspace interface to intel-specif
un libdrm-nouveau1 <aucune> <aucune> (aucune description n'est disponibl
ii libdrm-nouveau1 2.4.40-1~deb amd64 Userspace interface to nouveau-spec
rc libdrm-nouveau1 2.4.40-1~deb i386 Userspace interface to nouveau-spec
ii libdrm-nouveau2 2.4.65-3 amd64 Userspace interface to nouveau-spec
rc libdrm-nouveau2 2.4.58-2 i386 Userspace interface to nouveau-spec
ii libdrm-radeon1: 2.4.65-3 amd64 Userspace interface to radeon-speci
rc libdrm-radeon1: 2.4.58-2 i386 Userspace interface to radeon-speci
ii libdrm2:amd64 2.4.65-3 amd64 Userspace interface to kernel DRM s
rc libdrm2:i386 2.4.58-2 i386 Userspace interface to kernel DRM s
kmc@kmcs:~$ dpkg -l libomxil*
ii libomxil-bellag 0.9.3-2 amd64 implementation of OpenMAX IL, run-t
un libomxil-bellag <aucune> <aucune> (aucune description n'est disponibl
D’après les messages, libomxil-bellagio-dev et libva-dev.
J’ai réussi à compiler. maintenant c’est le make install qui bloque:
# make install
Making install in src
make[1]: Entering directory '/root/mesa/src'
Making install in .
make[2]: Entering directory '/root/mesa/src'
make[3]: Entering directory '/root/mesa/src'
make[3]: Nothing to be done for 'install-exec-am'.
make[3]: Nothing to be done for 'install-data-am'.
make[3]: Leaving directory '/root/mesa/src'
make[2]: Leaving directory '/root/mesa/src'
Making install in gtest
make[2]: Entering directory '/root/mesa/src/gtest'
make[3]: Entering directory '/root/mesa/src/gtest'
make[3]: Leaving directory '/root/mesa/src/gtest'
make[2]: Leaving directory '/root/mesa/src/gtest'
Making install in util
make[2]: Entering directory '/root/mesa/src/util'
make install-recursive
make[3]: Entering directory '/root/mesa/src/util'
Making install in .
make[4]: Entering directory '/root/mesa/src/util'
CCLD libmesautil.la
ar: .libs/libmesautil_la-debug.o: No such file or directory
Makefile:846: recipe for target 'libmesautil.la' failed
make[4]: *** [libmesautil.la] Error 1
make[4]: Leaving directory '/root/mesa/src/util'
Makefile:999: recipe for target 'install-recursive' failed
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory '/root/mesa/src/util'
Makefile:1325: recipe for target 'install' failed
make[2]: *** [install] Error 2
make[2]: Leaving directory '/root/mesa/src/util'
Makefile:672: recipe for target 'install-recursive' failed
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory '/root/mesa/src'
Makefile:616: recipe for target 'install-recursive' failed
make: *** [install-recursive] Error 1
root@kmcs:~/mesa# dpkg -l *libmesautils*
dpkg-query: aucun paquet ne correspond à *libmesautils*
root@kmcs:~/mesa# apt-cache search libmesautils*
