http://mail-archives.apache.org/mod_mbox/httpd-users/200902.mbox/%3C4991DAD8.5010606@post.io%3E
bon … allez … ne cherchons pas plus loin.
J’ai désinstallé apache2-mpm-itk et installé apache2-mpm-prefork
# perl /usr/share/doc/libapache2-mod-evasive/examples/test.pl
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 403 Forbidden
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
Bon, c’est bien d’avoir trouvé le fautif! ![]()
ça sert à quoi apache2-mpm-itk ?
apache2-mpm-itk (just mpm-itk for short) is an MPM (Multi-Processing Module) for the Apache web server. mpm-itk allows you to run each of your vhost under a separate uid and gid — in short, the scripts and configuration files for one vhost no longer have to be readable for all the other vhosts.
There are already MPMs available that do this; however, I am not aware of any besides mpm-itk that are actively developed. (If you only run CGI scripts, suexec will probably solve most of your problems with any MPM.)
mpm-itk is based on the traditional prefork MPM, which means it’s non-threaded; in short, this means you can run non-thread-aware code (like many PHP extensions) without problems. On the other hand, you lose out to any performance benefit you’d get with threads, of course; you’d have to decide for yourself if that’s worth it or not. You will also take an additional performance hit over prefork, since there’s an extra fork per request.
