Raisonnablement, aurais-je pu définir une priorité maxi ?
J’y songerai la prochaine fois.
Je pensais avoir dénicher une partition viable de 8 Go, [mono]badblocks[/mono] : 10 passes sans bloc défectueux détectés/détectables(?).
En vain et sans appel après installation.
Oct 30 13:56:37 main-menu[558]: INFO: Menu item 'live-installer' selected
Oct 30 13:56:37 base-installer: info: Using squashfs support for /cdrom/live/filesystem.squashfs
Oct 30 13:56:37 anna-install: Installing squashfs-modules
Oct 30 13:56:37 anna[8849]: DEBUG: resolver (kernel-image-3.2.0-4-486-di): package doesn't exist (ignored)
Oct 30 13:56:37 anna[8849]: DEBUG: retrieving squashfs-modules-3.2.0-4-486-di 3.2.63-2
Oct 30 13:56:38 kernel: [ 239.760296] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Oct 30 13:56:38 kernel: [ 239.773157] loop: module loaded
Oct 30 13:59:49 kernel: g (device sda1): ext4_end_bio:250: I/O error -5 writing to inode 130068 (offset 0 size 4096 starting block 74002938)
Oct 30 13:59:49 kernel: [ 431.128834] Buffer I/O error on device sda1, logical block 602362
Oct 30 13:59:49 kernel: [ 431.128841] Buffer I/O error on device sda1, logical block 602363
Oct 30 13:59:49 kernel: [ 431.128850] EXT4-fs warning (device sda1): ext4_end_bio:250: I/O error -5 writing to inode 130002 (offset 0 size 8192 starting block 74002940)
Oct 30 13:59:49 kernel: [ 431.128859] Buffer I/O error on device sda1, logical block 602364
Oct 30 13:59:49 kernel: [ 431.128866] Buffer I/O error on device sda1, logical block 602365
Oct 30 13:59:49 kernel: [ 431.128872] Buffer I/O error on device sda1, logical block 602366
Oct 30 13:59:49 kernel: [ 431.128879] Buffer I/O error on device sda1, logical block 602367
Oct 30 13:59:49 kernel: [ 431.128885] Buffer I/O error on device sda1, logical block 602368
Oct 30 13:59:49 kernel: [ 431.128894] EXT4-fs warning (device sda1): ext4_end_bio:250: I/O error -5 writing to inode 130004 (offset 0 size 20480 starting block 74002945)
Oct 30 13:59:49 kernel: [ 431.128903] Buffer I/O error on device sda1, logical block 602369
Oct 30 13:59:49 kernel: [ 431.128910] Buffer I/O error on device sda1, logical block 602370
Oct 30 13:59:49 kernel: [ 431.128916] Buffer I/O error on device sda1, logical block 602371
Oct 30 13:59:49 kernel: [ 431.128923] Buffer I/O error on device sda1, logical block 602372
Oct 30 13:59:49 kernel: [ 431.128929] Buffer I/O error on device sda1, logical block 602373
Oct 30 13:59:49 kernel: [ 431.128938] EXT4-fs warning (device sda1): ext4_end_bio:250: I/O error -5 writing to inode 130005 (offset 0 size 20480 starting block 74002950)
Oct 30 13:59:49 kernel: [ 431.128947] Buffer I/O error on device sda1, logical block 602374
Oct 30 13:59:49 kernel: [ 431.128953] Buffer I/O error on device sda1, logical block 602375
Oct 30 13:59:49 kernel: [ 431.128960] Buffer I/O error on device sda1, logical block 602376
Oct 30 13:59:49 kernel: [ 431.128969] EXT4-fs warning (device sda1): ext4_end_bio:250: I/O error -5 writing to inode 130006 (offset 0 size 12288 starting block 74002953)
Oct 30 13:59:49 kernel: [ 431.128978] Buffer I/O error on device sda1, logical block 602377
Regrettable : mon amie a égaré les justificatifs d’achat (Asus Eee PC 1015 BX du xx Janvier 2012) lors de son déménagement, dont une garantie sur le disque (Sata Western Digital) de 3 ans.
Mémoire RAM soudé, pour bien faire ...Pour l’heure, avec une clef usb faisant office de disque, j’ai une installation (Wheezy-7.7 firmware non-free/Xfce4) fonctionnelle depuis deux semaines, hormis les touches spéciales (Fn + F1 à F9) qui sont inopérantes.
Un investissement à venir de 45 € (hors taxes et frais d’envois).
Merci pour le coup de main.
Elargis la zone avec l’option -L de fsck. Tu récupères la liste actuelle par l’option -b de dumpe2fs, puis tu l’élargis (franchement) et tu la donnes en argument à -L pour fsck. Il réarrangera les fichiers en essayant de récupérer les choses. Tu peux assi effacer les fichiers puis faire l’installation. Impératif: Ne pas reformatter.
