# Bj, je voudrais adapter du code python en c++
**URL:** <https://www.debian-fr.org/t/bj-je-voudrais-adapter-du-code-python-en-c/32326>\
**Category:** Programmation\
**Created:** [Février 21, 2016, 2:17 UTC](https://www.debian-fr.org/t/bj-je-voudrais-adapter-du-code-python-en-c/32326 "2016-02-21T02:17:48Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![conatic](https://www.debian-fr.org/user_avatar/www.debian-fr.org/conatic/32/3563_2.png) [@conatic](https://www.debian-fr.org/u/conatic)\
**Post date:** [Février 21, 2016, 2:17 UTC](https://www.debian-fr.org/t/bj-je-voudrais-adapter-du-code-python-en-c/32326/1 "2016-02-21T02:17:49Z")
</div>
Bonjour à vous,
J’ai déjà commencé mais ces 2 fonctions posent problème
def neighbors\_coords(self):
def find\_neighbors\_with\_walls
Comment puis-je adapter cela en sachant que vais utiliser le framework qt afin d’afficher le labyrinthe ? Quelqu’un a t il une idée ?
```auto
#!/usr/bin/env python
# maze.py
# Generating Maze using Python
# http://mornie.org/blog/2007/08/02/Generating-Maze-using-Python/
# Copyright (C) 2007 Daniele Tricoli aka Eriol <eriol@mornie.org>
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
import random
class Cell(object):
    '''A square cell'''
    def __init__ (self, x, y):
        self.walls = [1, 1, 1, 1]
        self.x = x
        self.y = y
    def has_all_walls_intact(self):
        if 0 in self.walls:
            return False
        else:
            return True
    def find_adjacent_wall(self, cell):
        if cell.x == self.x:
            if cell.y < self.y:
                return 0 # left
            else:
                return 2 # right
        else:
            if cell.x < self.x:
                return 1 # above
            else:
                return 3 # below
    def destroy_wall(self, cell=None, wall=None):
        if cell is not None:
            wall_to_destroy = self.find_adjacent_wall(cell)
            self.walls[wall_to_destroy] = 0
            cell.walls[(wall_to_destroy + 2) % 4] = 0 # The opposite wall
        elif wall is not None:
            self.walls[wall] = 0
    def neighbors_coords(self):
        return ((self.x - 1, self.y), # above
                (self.x + 1, self.y), # below
                (self.x, self.y - 1), # left
                (self.x, self.y + 1)) # right
class Maze(object):
    def __init__ (self, width, height):
        self.width = width
        self.height = height
        self.cells = [[None for x in range(self.width)]
                            for x in range(self.height)]
        self.total_cells = self.width * self.height
        for i in range(self.height):
            for j in range(self.width):
                self.cells[i][j] = Cell(i,j)
        self.current_cell = self.cells[0][0]
        self.visited_cells = 1
    def find_neighbors_with_walls(self, cell):
        coords = self.cells[cell.x][cell.y].neighbors_coords()
        all_neighbors = [self.cells[i][j] for i, j in coords
                                                 if self.isinside(i, j)]
        return [neighbors for neighbors in all_neighbors
                                         if neighbors.has_all_walls_intact()]
    def isinside(self, x, y):
        if (0 <= x < self.height) and (0 <= y < self.width):
            return True
    def create(self):
        cell_stack = []
        while self.visited_cells < self.total_cells:
            neighbors = self.find_neighbors_with_walls(self.current_cell)
            if neighbors:
                new_cell = random.choice(neighbors)
                self.current_cell.destroy_wall(cell=new_cell)
                cell_stack.append(self.current_cell)
                self.current_cell = new_cell
                self.visited_cells += 1
            else:
                self.current_cell = cell_stack.pop()
    def draw_ascii(self):
        canvas = []
        for x in range(self.height):
            line = []
            line2 = []
            for y in range(self.width):
                cell = self.cells[x][y]
                line.append(' -'[cell.walls[1]] * 2)
                line2.append(' |'[cell.walls[0]] + ' ')
            canvas.append('+' + '+'.join(line) + '+\n')
            canvas.append(''.join(line2) + '|\n')
        canvas.append('+--' * self.width + '+\n')
        return ''.join(canvas)
if __name__ == ' __main__':
    x = Maze(10,6)
    x.create()
    print x.draw_ascii()
J’ai presque réussi mais le programme ne fonctionne pas. Voici le début du programme qui ne fonctionne pas [http://www.fulgor-it.info/dl/maze04.tar](http://www.fulgor-it.info/dl/maze04.tar) il utilise le framework Qt 4.7
**Author:** ![MisterFreez](https://www.debian-fr.org/letter_avatar_proxy/v4/letter/m/bb73d2/32.png) [@MisterFreez](https://www.debian-fr.org/u/MisterFreez)\
**Post date:** [Février 21, 2016, 2:17 UTC](https://www.debian-fr.org/t/bj-je-voudrais-adapter-du-code-python-en-c/32326/2 "2016-02-21T02:17:50Z")
</div>
Je refuse de lire du python non indenté, met ton code entre les balises : ``
**Author:** ![M3t4linux](https://www.debian-fr.org/letter_avatar_proxy/v4/letter/m/5daacb/32.png) [@M3t4linux](https://www.debian-fr.org/u/M3t4linux)\
**Post date:** [Février 21, 2016, 2:17 UTC](https://www.debian-fr.org/t/bj-je-voudrais-adapter-du-code-python-en-c/32326/3 "2016-02-21T02:17:51Z")
</div>
Oui sur le pastebin de lol ![:mrgreen:](https://www.debian-fr.org/uploads/default/original/1X/cc83e9b583138e48ff45f96609046b06d06c7f9d.gif "Mr. Green")
