re,
Oui je suis bien sur mon plug. je le fait en ssh en root en tant que simple utilisateur ça marche pas.
J’ai fait un dpkg -l, il m’affiche Failed-cfg et err (error)
[quote]| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)[/quote]birare.
guruplug-debian:/home/serveur# dpkg -l
Desired=Unknown/Install/Remove/Purge/Hold
||/ Name Version Description
ii adduser 3.110 add and remove users and groups
ii alsa-base 1.0.17.dfsg-4 ALSA driver configuration files
ii alsa-oss 1.0.15-1 ALSA wrapper for OSS applications
ii alsa-tools 1.0.16-2 Console based ALSA utilities for specific hardware
ii alsa-utils 1.0.16-2 ALSA utilities
ii apache2 2.2.9-10+lenny11 Apache HTTP Server metapackage
ii apache2-mpm-prefork 2.2.9-10+lenny11 Apache HTTP Server - traditional non-threaded model
ii apache2-utils 2.2.9-10+lenny11 utility programs for webservers
ii apache2.2-common 2.2.9-10+lenny11 Apache HTTP Server common files
ii apt 0.7.20.2+lenny2 Advanced front-end for dpkg
ii apt-utils 0.7.20.2+lenny2 APT utility programs
ii aptitude 0.4.11.11-1~lenny2 terminal-based package manager
ii atftp 0.7.dfsg-6 advanced TFTP client
ii autoconf 2.61-8 automatic configure script builder
ii automake 1:1.10.1-3 A tool for generating GNU Standards-compliant Makefiles
ii automake1.4 1:1.4-p6-13 A tool for generating GNU Standards-compliant Makefiles
ii autotools-dev 20080123.1 Update infrastructure for config.{guess,sub} files
ii base-files 5lenny10 Debian base system miscellaneous files
ii base-passwd 3.5.20 Debian base system master password and group files
ii bash 3.2-4 The GNU Bourne Again SHell
ii binutils 2.18.1~cvs20080103-7 The GNU assembler, linker and binary utilities
ii bluez 4.60-1~bpo50+1 Bluetooth tools and daemons
ii bluez-alsa 4.60-1~bpo50+1 Bluetooth ALSA support
ii bsd-mailx 8.1.2-0.20071201cvs-3 A simple mail user agent
ii bsdmainutils 6.1.10 collection of more utilities from FreeBSD
ii bsdutils 1:2.13.1.1-1 Basic utilities from 4.4BSD-Lite
ii build-essential 11.4 Informational list of build-essential packages
ii bzip2 1.0.5-1+lenny1 high-quality block-sorting file compressor - utilities
ii coreutils 6.10-6 The GNU core utilities
ii cpio 2.9-13lenny1 GNU cpio -- a program to manage archives of files
ii cpp 4:4.3.2-2 The GNU C preprocessor (cpp)
ii cpp-4.3 4.3.2-1.1 The GNU C preprocessor
ii cron 3.0pl1-105 management of regular background processing
ii dbus 1.2.1-5+lenny2 simple interprocess messaging system
ii dbus-x11 1.2.1-5+lenny2 simple interprocess messaging system (X11 deps)
ii debconf 1.5.24 Debian configuration management system
ii debconf-i18n 1.5.24 full internationalization support for debconf
ii debian-archive-keyring 2010.08.28~lenny1 GnuPG archive keys of the Debian archive
ii debianutils 2.30 Miscellaneous utilities specific to Debian
ii defoma 0.11.10-0.2 Debian Font Manager -- automatic font configuration framework
ii dhcp3-client 3.1.1-6+lenny6 DHCP client
ii dhcp3-common 3.1.1-6+lenny6 common files used by all the dhcp3* packages
ii diff 2.8.1-12 File comparison utilities
ii dnsmasq 2.45-1+lenny1 A small caching DNS proxy and DHCP/TFTP server
ii dnsmasq-base 2.45-1+lenny1 A small caching DNS proxy and DHCP/TFTP server
ii dpkg 1.14.31 Debian package management system
ii dpkg-dev 1.14.31 Debian package development tools
ii e2fslibs 1.41.3-1 ext2 filesystem libraries
ii e2fsprogs 1.41.3-1 ext2/ext3/ext4 file system utilities
ii ed 0.7-3 The classic unix line editor
ii esound-clients 0.2.36-3 Enlightened Sound Daemon - clients
ii esound-common 0.2.36-3 Enlightened Sound Daemon - Common files
ii exim4 4.69-9+lenny4 metapackage to ease Exim MTA (v4) installation
ii exim4-base 4.69-9+lenny4 support files for all Exim MTA (v4) packages
ii exim4-config 4.69-9+lenny4 configuration for the Exim MTA (v4)
ii exim4-daemon-light 4.69-9+lenny4 lightweight Exim MTA (v4) daemon
ii fam 2.7.0-13.3+lenny1 File Alteration Monitor
ii file 4.26-1 Determines file type using "magic" numbers
ii findutils 4.4.0-2 utilities for finding files--find, xargs
ii fontconfig 2.6.0-3 generic font configuration library - support binaries
ii fontconfig-config 2.6.0-3 generic font configuration library - configuration
ii g++ 4:4.3.2-2 The GNU C++ compiler
ii g++-4.3 4.3.2-1.1 The GNU C++ compiler
ii gcc 4:4.3.2-2 The GNU C compiler
ii gcc-4.2-base 4.2.4-6 The GNU Compiler Collection (base package)
ii gcc-4.3 4.3.2-1.1 The GNU C compiler
ii gcc-4.3-base 4.3.2-1.1 The GNU Compiler Collection (base package)
ii gnupg 1.4.9-3+lenny1 GNU privacy guard - a free PGP replacement
ii gpgv 1.4.9-3+lenny1 GNU privacy guard - signature verification tool
ii grep 2.5.3~dfsg-6 GNU grep, egrep and fgrep
ii groff-base 1.18.1.1-21 GNU troff text-formatting system (base system components)
ii gzip 1.3.12-6+lenny1 The GNU compression utility
ii hicolor-icon-theme 0.10-1 default fallback theme for FreeDesktop.org icon themes
ii hostname 2.95 utility to set/show the host name or domain name
ii ifplugd 0.28-12 configuration daemon for ethernet devices
ii ifupdown 0.6.8+nmu1 high level tools to configure network interfaces
ii info 4.11.dfsg.1-4 Standalone GNU Info documentation browser
ii initscripts 2.86.ds1-61 Scripts for initializing and shutting down the system
ii iproute 20080725-2 networking and traffic control tools
ii iptables 1.4.2-6 administration tools for packet filtering and NAT
ii iputils-ping 3:20071127-1+lenny1 Tools to test the reachability of network hosts
ii libacl1 2.2.47-2 Access control list shared library
ii libapache2-mod-php5 5.2.6.dfsg.1-1+lenny15 server-side, HTML-embedded scripting language (Apache 2 module
ii libapr1 1.2.12-5+lenny2 The Apache Portable Runtime Library
ii libaprutil1 1.2.12+dfsg-8+lenny5 The Apache Portable Runtime Utility Library
ii libasound2 1.0.16-2 ALSA library
ii libatk1.0-0 1.22.0-1 The ATK accessibility toolkit
ii libatk1.0-data 1.22.0-1 Common files for the ATK accessibility toolkit
ii libattr1 1:2.4.43-2 Extended attribute shared library
ii libaudiofile0 0.2.6-7+lenny1 Open-source version of SGI's audiofile library
ii libavcodec51 0.svn20080206-18+lenny3 ffmpeg codec library
ii libavformat52 0.svn20080206-18+lenny3 ffmpeg file format library
ii libavutil49 0.svn20080206-18+lenny3 ffmpeg utility library
ii libblkid1 1.41.3-1 block device id library
ii libbluetooth2 3.36-1 Library to use the BlueZ Linux Bluetooth stack
ii libbluetooth3 4.60-1~bpo50+1 Library to use the BlueZ Linux Bluetooth stack
ii libbz2-1.0 1.0.5-1+lenny1 high-quality block-sorting file compressor library - runtime
ii libc6 2.7-18lenny7 GNU C Library: Shared libraries
ii libc6-dev 2.7-18lenny7 GNU C Library: Development Libraries and Header Files
ii libcaca0 0.99.beta14-1 colour ASCII art library
ii libcairo2 1.6.4-7 The Cairo 2D vector graphics library
ii libcap1 1:1.10-14 support for getting/setting POSIX.1e capabilities
ii libcdparanoia0 3.10.2+debian-5 audio extraction tool for sampling CDs (library)
ii libcomerr2 1.41.3-1 common error description library
ii libconsole 1:0.2.3dbs-65.1 Shared libraries for Linux console and font manipulation
ii libcucul0 0.99.beta14-1 low-level Unicode character drawing library
ii libcups2 1.3.8-1+lenny10 Common UNIX Printing System(tm) - libs
ii libcwidget3 0.5.12-4 high-level terminal interface library for C++ (runtime files)
ii libdaemon0 0.12-2lenny1 lightweight C library for daemons - runtime library
ii libdatrie0 0.1.3-2 Double-array trie library
ii libdb4.5 4.5.20-13 Berkeley v4.5 Database Libraries [runtime]
ii libdb4.6 4.6.21-11 Berkeley v4.6 Database Libraries [runtime]
ii libdbd-mysql-perl 4.007-1+lenny1 A Perl5 database interface to the MySQL database
ii libdbi-perl 1.605-1 Perl5 database interface by Tim Bunce
ii libdbus-1-3 1.2.1-5+lenny2 simple interprocess messaging system
ii libdevmapper1.02.1 2:1.02.27-4 The Linux Kernel Device Mapper userspace library
ii libdirectfb-1.0-0 1.0.1-11 direct frame buffer graphics - shared libraries
ii libdrm2 2.3.1-2 Userspace interface to kernel DRM services -- runtime
ii libedit2 2.11~20080614-1 BSD editline and history libraries
ii libept0 0.5.22 High-level library for managing Debian package information
ii libesd0 0.2.36-3 Enlightened Sound Daemon - Shared libraries
ii libexpat1 2.0.1-4+lenny3 XML parsing C library - runtime library
ii libfaad0 2.6.1-3.1 freeware Advanced Audio Decoder - runtime files
ii libfam0 2.7.0-13.3+lenny1 Client library to control the FAM daemon
ii libffi5 3.0.7-1 Foreign Function Interface library runtime
ii libfontconfig1 2.6.0-3 generic font configuration library - runtime
ii libfontenc1 1:1.0.4-3 X11 font encoding library
ii libfreetype6 2.3.7-2+lenny8 FreeType 2 font engine, shared library files
ii libfribidi0 0.10.9-1 Free Implementation of the Unicode BiDi algorithm
ii libgcc1 1:4.3.2-1.1 GCC support library
ii libgcrypt11 1.4.1-1 LGPL Crypto library - runtime library
ii libgd2-xpm 2.0.36~rc1~dfsg-3+lenny GD Graphics Library version 2
ii libgdbm3 1.8.3-3 GNU dbm database routines (runtime version)
ii libgif4 4.1.6-6 library for GIF images (library)
ii libgl1-mesa-glx 7.0.3-7 A free implementation of the OpenGL API -- GLX runtime
ii libglib2.0-0 2.16.6-3 The GLib library of C routines
ii libglib2.0-data 2.16.6-3 Common files for GLib library
ii libgmp3c2 2:4.2.2+dfsg-3 Multiprecision arithmetic library
ii libgnutls26 2.4.2-6+lenny2 the GNU TLS library - runtime library
ii libgomp1 4.3.2-1.1 GCC OpenMP (GOMP) support library
ii libgpg-error0 1.4-2 library for common error values and messages in GnuPG componen
ii libgsm1 1.0.12-1 Shared libraries for GSM speech compressor
ii libgtk2.0-0 2.12.12-1~lenny2 The GTK+ graphical user interface library
ii libgtk2.0-bin 2.12.12-1~lenny2 The programs for the GTK+ graphical user interface library
ii libgtk2.0-common 2.12.12-1~lenny2 Common files for the GTK+ graphical user interface library
ii libhtml-template-perl 2.9-1 HTML::Template : A module for using HTML Templates with Perl
ii libiw29 29-1.1 Wireless tools - library
ii libjack0 0.109.2-5 JACK Audio Connection Kit (libraries)
ii libjpeg62 6b-14 The Independent JPEG Group's JPEG runtime library
ii libkeyutils1 1.2-9 Linux Key Management Utilities (library)
ii libkrb53 1.6.dfsg.4~beta1-5lenny MIT Kerberos runtime libraries
ii libldap-2.4-2 2.4.11-1+lenny2.1 OpenLDAP libraries
ii liblircclient0 0.8.3-3 infra-red remote control support - client library
ii liblocale-gettext-perl 1.05-4 Using libc functions for internationalization in Perl
ii liblockfile1 1.08-3 NFS-safe locking library, includes dotlockfile program
ii libltdl3 1.5.26-4+lenny1 A system independent dlopen wrapper for GNU libtool
ii libltdl3-dev 1.5.26-4+lenny1 A system independent dlopen wrapper for GNU libtool
ii liblzo2-2 2.03-1 data compression library
ii libmagic1 4.26-1 File type determination library using "magic" numbers
ii libmcrypt4 2.5.7-5 De-/Encryption Library
ii libmpcdec3 1.2.2-1 Musepack (MPC) format library
ii libmpfr1ldbl 2.3.1.dfsg.1-2 multiple precision floating-point computation
ii libmysqlclient15off 5.0.51a-24+lenny5 MySQL database client library
ii libncurses5 5.7+20081213-1 shared libraries for terminal handling
ii libncurses5-dev 5.7+20081213-1 developer's libraries and docs for ncurses
ii libncursesw5 5.7+20081213-1 shared libraries for terminal handling (wide character support
ii libnet-daemon-perl 0.38-1.1 Perl module for building portable Perl daemons easily.
ii libnewt0.52 0.52.2-11.3+lenny1 Not Erik's Windowing Toolkit - text mode windowing with slang
ii libnl1 1.1-2 library for dealing with netlink sockets
ii libntfs-3g31 1:1.2531-1.1 ntfs-3g filesystem in userspace (FUSE) library
ii libogg0 1.1.3-4 Ogg Bitstream Library
ii libopenal1 1:1.4.272-2 Software implementation of the OpenAL API (libraries)
ii libpam-modules 1.0.1-5+lenny1 Pluggable Authentication Modules for PAM
ii libpam-runtime 1.0.1-5+lenny1 Runtime support for the PAM library
ii libpam0g 1.0.1-5+lenny1 Pluggable Authentication Modules library
ii libpango1.0-0 1.20.5-6 Layout and rendering of internationalized text
ii libpango1.0-common 1.20.5-6 Modules and configuration files for the Pango
ii libpcap0.8 0.9.8-5 system interface for user-level packet capture
ii libpci3 1:3.0.0-6 Linux PCI Utilities (shared library)
ii libpcre3 7.6-2.1 Perl 5 Compatible Regular Expression Library - runtime files
ii libpcsclite1 1.4.102-1+lenny4 Middleware to access a smart card using PC/SC (library)
ii libpixman-1-0 0.10.0-2 pixel-manipulation library for X and cairo
ii libplrpc-perl 0.2017-1.1 Perl extensions for writing PlRPC servers and clients
ii libpng12-0 1.2.27-2+lenny5 PNG library - runtime
ii libpopt0 1.14-4 lib for parsing cmdline parameters
ii libpostproc51 0.svn20080206-18+lenny3 ffmpeg video postprocessing library
ii libpq5 8.3.16-0lenny1 PostgreSQL C client library
ii libreadline5 5.2-3.1 GNU readline and history libraries, run-time libraries
ii libreadline5-dev 5.2-3.1 GNU readline and history libraries, development files
ii libsasl2-2 2.1.22.dfsg1-23+lenny1 Cyrus SASL - authentication abstraction library
ii libsdl1.2debian 1.2.13-2 Simple DirectMedia Layer
ii libsdl1.2debian-alsa 1.2.13-2 Simple DirectMedia Layer (with X11 and ALSA options)
ii libselinux1 2.0.65-5 SELinux shared libraries
ii libsepol1 2.0.30-2 Security Enhanced Linux policy library for changing policy bin
ii libsigc++-2.0-0c2a 2.0.18-2 type-safe Signal Framework for C++ - runtime
ii libslang2 2.1.3-3 The S-Lang programming library - runtime version
ii libsmbclient 2:3.2.5-4lenny15 shared library that allows applications to talk to SMB/CIFS se
ii libspeex1 1.2~rc1-1 The Speex codec runtime library
ii libsqlite3-0 3.5.9-6 SQLite 3 shared library
ii libss2 1.41.3-1 command-line interface parsing library
ii libssl-dev 0.9.8g-15+lenny16 SSL development libraries, header files and documentation
ii libssl0.9.8 0.9.8g-15+lenny16 SSL shared libraries
ii libstdc++6 4.3.2-1.1 The GNU Standard C++ Library v3
ii libstdc++6-4.3-dev 4.3.2-1.1 The GNU Standard C++ Library v3 (development files)
ii libswscale0 0.svn20080206-18+lenny3 ffmpeg video scaling library
ii libsysfs2 2.1.0-5 interface library to sysfs
ii libt1-5 5.1.2-3+lenny1 Type 1 font rasterizer library - runtime
ii libtalloc1 1.2.0~git20080616-1 hierarchical pool based memory allocator
ii libtasn1-3 1.4-1 Manage ASN.1 structures (runtime)
ii libterm-readkey-perl 2.30-4 A perl module for simple terminal control
ii libterm-readline-perl-p 1.0302-1 Perl implementation of Readline libraries
ii libtext-charwidth-perl 0.04-5+b1 get display widths of characters on the terminal
ii libtext-iconv-perl 1.7-1+b1 converts between character sets in Perl
ii libtext-wrapi18n-perl 0.06-6 internationalized substitute of Text::Wrap
ii libthai-data 0.1.9-4+lenny1 Data files for Thai language support library
ii libthai0 0.1.9-4+lenny1 Thai language support library
ii libtheora0 1.0~beta3-1+lenny1 The Theora Video Compression Codec
ii libtiff4 3.8.2-11.5 Tag Image File Format (TIFF) library
ii libtimedate-perl 1.1600-9 Time and date functions for Perl
ii libtool 1.5.26-4+lenny1 Generic library support script
ii libts-0.0-0 1.0-4 touch screen library
ii libusb-0.1-4 2:0.1.12-13 userspace USB programming library
ii libuuid1 1.41.3-1 universally unique id library
ii libvolume-id0 0.125-7+lenny3 libvolume_id shared library
ii libvorbis0a 1.2.0.dfsg-3.1+lenny1 The Vorbis General Audio Compression Codec
ii libvorbisenc2 1.2.0.dfsg-3.1+lenny1 The Vorbis General Audio Compression Codec
ii libwbclient0 2:3.2.5-4lenny15 client library for interfacing with winbind service
ii libwrap0 7.6.q-16 Wietse Venema's TCP wrappers library
ii libx11-6 2:1.1.5-2 X11 client-side library
ii libx11-data 2:1.1.5-2 X11 client-side library
ii libxapian15 1.0.7-4 Search engine library
ii libxau6 1:1.0.3-3 X11 authorisation library
ii libxcb-render-util0 0.2.1+git1-1 utility libraries for X C Binding -- render-util
ii libxcb-render0 1.1-1.2 X C Binding, render extension
ii libxcb-xlib0 1.1-1.2 X C Binding, Xlib/XCB interface library
ii libxcb1 1.1-1.2 X C Binding
ii libxcomposite1 1:0.4.0-3 X11 Composite extension library
ii libxcursor1 1:1.1.9-1 X cursor management library
ii libxdamage1 1:1.1.1-4 X11 damaged region extension library
ii libxdmcp6 1:1.0.2-3 X11 Display Manager Control Protocol library
ii libxext6 2:1.0.4-2 X11 miscellaneous extension library
ii libxfixes3 1:4.0.3-2 X11 miscellaneous 'fixes' extension library
ii libxfont1 1:1.3.3-2 X11 font rasterisation library
ii libxft2 2.1.12-3 FreeType-based font drawing library for X
ii libxi6 2:1.1.4-1 X11 Input extension library
ii libxinerama1 2:1.0.3-2 X11 Xinerama extension library
ii libxml2 2.6.32.dfsg-5+lenny5 GNOME XML library
ii libxmuu1 2:1.0.4-1 X11 miscellaneous micro-utility library
ii libxpm4 1:3.5.7-1 X11 pixmap library
ii libxrandr2 2:1.2.3-1 X11 RandR extension library
ii libxrender1 1:0.9.4-2 X Rendering Extension client library
ii libxv1 2:1.0.4-1 X11 Video extension library
ii libxvmc1 1:1.0.4-2 X11 Video extension library
ii libxxf86dga1 2:1.0.2-1 X11 Direct Graphics Access extension library
ii libxxf86vm1 1:1.0.2-1 X11 XFree86 video mode extension library
rc lighttpd 1.4.19-5+lenny3 A fast webserver with minimal memory footprint
ii linux-libc-dev 2.6.26-27 Linux support headers for userspace development
ii linux-sound-base 1.0.17.dfsg-4 base package for ALSA and OSS sound systems
ii locales 2.7-18lenny7 GNU C Library: National Language (locale) data [support]
ii lockfile-progs 0.1.11-0.1 Programs for locking and unlocking files and mailboxes
ii login 1:4.1.1-6+lenny1 system login tools
ii logrotate 3.7.1-5 Log rotation utility
ii lsb-base 3.2-20 Linux Standard Base 3.2 init script functionality
ii lsof 4.78.dfsg.1-4 List open files
ii lzma 4.43-14 Compression method of 7z format in 7-Zip program
ii m4 1.4.11-1 a macro processing language
ii mailx 1:20071201-3 Transitional package for mailx rename
ii make 3.81-5 The GNU version of the "make" utility.
ii makedev 2.3.1-88 creates device files in /dev
ii man-db 2.5.2-5 on-line manual pager
ii manpages 3.05-1 Manual pages about using a GNU/Linux system
ii mawk 1.3.3-11.1 a pattern scanning and text processing language
ii mime-support 3.44-1 MIME files 'mime.types' & 'mailcap', and support programs
ii mktemp 1.5-9 tool for creating temporary files
ii module-assistant 0.10.11.0 tool to make module package creation easier
ii module-init-tools 3.4-1 tools for managing Linux kernel modules
ii mount 2.13.1.1-1 Tools for mounting and manipulating filesystems
ii mplayer 1.0~rc2-17+lenny3.2 movie player for Unix-like systems
ii mplayer-skin-blue 1.6-2 blue skin for mplayer
ii mtd-utils 20080508-1 Memory Technology Device Utilities
ii mysql-client 5.0.51a-24+lenny5 MySQL database client (metapackage depending on the latest ver
ii mysql-client-5.0 5.0.51a-24+lenny5 MySQL database client binaries
ii mysql-common 5.0.51a-24+lenny5 MySQL database common files
ii mysql-server 5.0.51a-24+lenny5 MySQL database server (metapackage depending on the latest ver
ii mysql-server-5.0 5.0.51a-24+lenny5 MySQL database server binaries
ii nano 2.0.7-5 free Pico clone with some new features
ii ncurses-base 5.7+20081213-1 basic terminal type definitions
ii ncurses-bin 5.7+20081213-1 terminal-related programs and man pages
ii net-tools 1.60-22 The NET-3 networking toolkit
ii netbase 4.34 Basic TCP/IP networking system
ii netcat-traditional 1.10-38 TCP/IP swiss army knife
ii nmap 4.62-1 The Network Mapper
ii ntfs-3g 1:1.2531-1.1 read-write NTFS driver for FUSE
ii ntp 1:4.2.4p4+dfsg-8lenny3 Network Time Protocol daemon and utility programs
ii openssh-blacklist 0.4.1 list of default blacklisted OpenSSH RSA and DSA keys
ii openssh-blacklist-extra 0.4.1 list of non-default blacklisted OpenSSH RSA and DSA keys
ii openssh-client 1:5.1p1-5 secure shell client, an rlogin/rsh/rcp replacement
ii openssh-server 1:5.1p1-5 secure shell server, an rshd replacement
ii openssl 0.9.8g-15+lenny16 Secure Socket Layer (SSL) binary and related cryptographic too
ii openssl-blacklist 0.4.2 list of blacklisted OpenSSL RSA keys
ii passwd 1:4.1.1-6+lenny1 change and administer password and group data
ii patch 2.5.9-5 Apply a diff file to an original
ii pciutils 1:3.0.0-6 Linux PCI Utilities
ii perl 5.10.0-19lenny5 Larry Wall's Practical Extraction and Report Language
ii perl-base 5.10.0-19lenny5 minimal Perl system
ii perl-modules 5.10.0-19lenny5 Core Perl modules
ii php5 5.2.6.dfsg.1-1+lenny15 server-side, HTML-embedded scripting language (metapackage)
ii php5-cli 5.2.6.dfsg.1-1+lenny15 command-line interpreter for the php5 scripting language
ii php5-common 5.2.6.dfsg.1-1+lenny15 Common files for packages built from the php5 source
ii php5-dev 5.2.6.dfsg.1-1+lenny15 Files for PHP5 module development
ii php5-gd 5.2.6.dfsg.1-1+lenny15 GD module for php5
ii php5-mcrypt 5.2.6.dfsg.1-1+lenny15 MCrypt module for php5
ii php5-mysql 5.2.6.dfsg.1-1+lenny15 MySQL module for php5
ii phpmyadmin 4:2.11.8.1-5+lenny9 MySQL web administration tool
ii portmap 6.0-9 RPC port mapper
ii procps 1:3.2.7-11 /proc file system utilities
ii psmisc 22.6-1 Utilities that use the proc filesystem
ii python 2.5.2-3 An interactive high-level object-oriented language (default ve
ii python-bluez 0.15-1.1 Python wrappers around BlueZ for rapid bluetooth development
ii python-central 0.6.8 register and build utility for Python packages
ii python-gobject 2.14.2-2 Python bindings for the GObject library
ii python-minimal 2.5.2-3 A minimal subset of the Python language (default version)
ii python-support 0.8.4lenny2 automated rebuilding support for Python modules
ii python2.5 2.5.2-15+lenny1 An interactive high-level object-oriented language (version 2.
ii python2.5-minimal 2.5.2-15+lenny1 A minimal subset of the Python language (version 2.5)
ii readline-common 5.2-3.1 GNU readline and history libraries, common files
ii rsyslog 3.18.6-4 enhanced multi-threaded syslogd
ii samba 2:3.2.5-4lenny15 a LanManager-like file and printer server for Unix
ii samba-common 2:3.2.5-4lenny15 Samba common files used by both the server and the client
ii sed 4.1.5-6 The GNU sed stream editor
ii sgml-base 1.26 SGML infrastructure and SGML catalog file support
ii shtool 2.0.7-3 portable shell tool from the GNU project
ii ssl-cert 1.0.23 simple debconf wrapper for OpenSSL
ii sudo 1.6.9p17-3 Provide limited super user privileges to specific users
ii sysv-rc 2.86.ds1-61 System-V-like runlevel change mechanism
ii sysvinit 2.86.ds1-61 System-V-like init utilities
ii sysvinit-utils 2.86.ds1-61 System-V-like utilities
ii tar 1.20-1+lenny1 GNU version of the tar archiving utility
ii tasksel 2.78 Tool for selecting tasks for installation on Debian systems
ii tasksel-data 2.78 Official tasks used for installation of Debian systems
ii tcpd 7.6.q-16 Wietse Venema's TCP wrapper utilities
ii time 1.7-23 The GNU time program for measuring cpu resource usage
ii traceroute 2.0.11-2 Traces the route taken by packets over an IPv4/IPv6 network
ii ttf-dejavu 2.25-3 Metapackage to pull in ttf-dejavu-core and ttf-dejavu-extra
ii ttf-dejavu-core 2.25-3 Vera font family derivate with additional characters
ii ttf-dejavu-extra 2.25-3 Vera font family derivate with additional characters
ii tzdata 2011k-0lenny1 time zone and daylight-saving time data
ii ucf 3.0016 Update Configuration File: preserve user changes to config fil
ii udev 0.125-7+lenny3 /dev/ and hotplug management daemon
ii udhcpd 0.9.8cvs20050303-2.1 very small DHCP server
ii update-inetd 4.31 inetd configuration file updater
ii usbmount 0.0.14.1 automatically mount and unmount USB mass storage devices
ii usbutils 0.73-10lenny2 Linux USB utilities
ii util-linux 2.13.1.1-1 Miscellaneous system utilities
ii vim-common 1:7.1.314-3+lenny2 Vi IMproved - Common files
ii vim-tiny 1:7.1.314-3+lenny2 Vi IMproved - enhanced vi editor - compact version
ii wget 1.11.4-2+lenny2 retrieves files from the web
ii whiptail 0.52.2-11.3+lenny1 Displays user-friendly dialog boxes from shell scripts
ii wireless-tools 29-1.1 Tools for manipulating Linux Wireless Extensions
ii wpasupplicant 0.6.4-3 Client support for WPA and WPA2 (IEEE 802.11i)
ii x-ttcidfont-conf 31 TrueType and CID fonts configuration for X
ii x11-common 1:7.3+20 X Window System (X.Org) infrastructure
ii xauth 1:1.0.3-2 X authentication utility
ii xfonts-encodings 1:1.0.2-3 Encodings for X.Org fonts
ii xfonts-utils 1:7.4+1 X Window System font utility programs
ii xml-core 0.12 XML infrastructure and XML catalog file support
ii zlib1g 1:1.2.3.3.dfsg-12 compression library - runtime
ii zlib1g-dev 1:1.2.3.3.dfsg-12 compression library - development
Merci.
