Connexion imossible au réseau filaire
Oui ou mode root ou recorvery, au démarrage tu choisis la 2ème option
Je ne sais pas si cela va être lisible:
lspci
00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
00:01.0 PCI bridge: Intel Corporation 82945G/GZ/P/PL PCI Express Root Port (rev 02)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300]
01:00.1 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300 SE]
03:03.0 Modem: Intel Corporation FA82537EP 56K V.92 Data/Fax Modem PCI (rev 04)
03:08.0 Ethernet controller: Intel Corporation NM10/ICH7 Family LAN Controller (rev 01)
lspci -v
Subsystem: Dell Device 01d2
Flags: bus master, fast devsel, latency 0
Capabilities:
00:01.0 PCI bridge: Intel Corporation 82945G/GZ/P/PL PCI Express Root Port (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: efd00000-efefffff
Prefetchable memory behind bridge: 00000000ec000000-00000000edffffff
Capabilities:
Kernel driver in use: pcieport
Flags: bus master, fast devsel, latency 0, IRQ 42
Memory at efffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: efc00000-efcfffff
Prefetchable memory behind bridge: 0000000020000000-00000000201fffff
Capabilities:
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 21
I/O ports at ff80 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 22
I/O ports at ff60 [size=32]
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at ff40 [size=32]
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at ff20 [size=32]
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Memory at ffa80800 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ehci-pci
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: efb00000-efbfffff
Capabilities:
Capabilities:
Kernel driver in use: lpc_ich
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at ffa0 [size=16]
Kernel driver in use: ata_piix
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 20
I/O ports at fe00 [size=8]
I/O ports at fe10 [size=4]
I/O ports at fe20 [size=8]
I/O ports at fe30 [size=4]
I/O ports at fea0 [size=16]
Memory at 20200000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Flags: medium devsel, IRQ 9
I/O ports at ece0 [size=32]
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300] (prog-if 00 [VGA controller])
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0602
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at ec000000 (64-bit, prefetchable) [size=32M]
Memory at efde0000 (64-bit, non-prefetchable) [size=64K]
I/O ports at dc00 [size=256]
Expansion ROM at efe00000 [disabled] [size=128K]
Capabilities:
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0603
Memory at efdf0000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
03:03.0 Modem: Intel Corporation FA82537EP 56K V.92 Data/Fax Modem PCI (rev 04) (prog-if 00 [Generic])
Subsystem: Dell Device 1000
Flags: bus master, stepping, medium devsel, latency 64, IRQ 19
Memory at efbfe000 (32-bit, non-prefetchable) [size=4K]
I/O ports at cc00 [size=256]
Capabilities:
Kernel driver in use: serial
Subsystem: Dell Device 01ab
Flags: bus master, medium devsel, latency 64, IRQ 20
Memory at efbff000 (32-bit, non-prefetchable) [size=4K]
I/O ports at c8c0 [size=64]
Capabilities:
Kernel driver in use: e100
uname -a
Linux famille-Dell-DM051 3.13.0-24-generic #46-Ubuntu SMP Thu Apr 10 19:08:14 UTC 2014 i686 i686 i686 GNU/Linux
lsmod
Module Size Used by
nls_iso8859_1 12617 1
sr9700 13514 0
dm9601 13546 0
usbnet 37837 2 dm9601,sr9700
bnep 18895 2
rfcomm 53664 0
bluetooth 342263 10 bnep,rfcomm
parport_pc 31981 0
ppdev 17391 0
lp 13299 0
parport 40836 3 lp,ppdev,parport_pc
btrfs 822702 0
raid6_pq 97455 1 btrfs
xor 26221 1 btrfs
ufs 73656 0
qnx4 13101 0
hfsplus 93447 0
hfs 49390 0
minix 31317 0
ntfs 95723 0
msdos 17093 0
jfs 170009 0
xfs 802883 0
libcrc32c 12543 2 xfs,btrfs
hid_generic 12492 0
usbhid 47035 0
hid 87604 2 hid_generic,usbhid
snd_hda_codec_idt 48877 1
snd_hda_intel 42730 3
snd_hda_codec 164067 2 snd_hda_codec_idt,snd_hda_intel
snd_hwdep 13272 1 snd_hda_codec
radeon 1416373 0
snd_pcm 85501 2 snd_hda_codec,snd_hda_intel
snd_page_alloc 14230 2 snd_pcm,snd_hda_intel
snd_seq_midi 13132 0
gpio_ich 13229 0
snd_seq_midi_event 14475 1 snd_seq_midi
snd_rawmidi 25135 1 snd_seq_midi
snd_seq 55383 2 snd_seq_midi_event,snd_seq_midi
snd_seq_device 14137 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 28584 2 snd_pcm,snd_seq
snd 60871 16 snd_hwdep,snd_timer,snd_hda_codec_idt,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
ttm 72698 1 radeon
drm_kms_helper 46907 1 radeon
dcdbas 14448 0
drm 243792 3 ttm,drm_kms_helper,radeon
psmouse 91033 0
soundcore 12600 1 snd
serio_raw 13230 0
i2c_algo_bit 13197 1 radeon
lpc_ich 16864 0
mac_hid 13037 0
usb_storage 48417 1
e100 35945 0
mii 13654 4 e100,dm9601,sr9700,usbnet
[ 0.480166] system 00:06: [io 0x04d2-0x057f] has been reserved
[ 0.480212] system 00:06: [io 0x0580-0x0677] has been reserved
[ 0.480255] system 00:06: [io 0x0680-0x0777] has been reserved
[ 0.480298] system 00:06: [io 0x0780-0x07bb] has been reserved
[ 0.480342] system 00:06: [io 0x07c0-0x07ff] has been reserved
[ 0.480385] system 00:06: [io 0x08e0-0x08ff] has been reserved
[ 0.480428] system 00:06: [io 0x0900-0x09fe] has been reserved
[ 0.480471] system 00:06: [io 0x0a00-0x0afe] has been reserved
[ 0.480515] system 00:06: [io 0x0b00-0x0bfe] has been reserved
[ 0.480558] system 00:06: [io 0x0c80-0x0caf] has been reserved
[ 0.480601] system 00:06: [io 0x0cb0-0x0cbf] has been reserved
[ 0.480645] system 00:06: [io 0x0cc0-0x0cf7] has been reserved
[ 0.480688] system 00:06: [io 0x0d00-0x0dfe] has been reserved
[ 0.480731] system 00:06: [io 0x0e00-0x0efe] has been reserved
[ 0.480774] system 00:06: [io 0x0f00-0x0ffe] has been reserved
[ 0.480818] system 00:06: [io 0x2000-0x20fe] has been reserved
[ 0.480861] system 00:06: [io 0x2100-0x21fe] has been reserved
[ 0.480905] system 00:06: [io 0x2200-0x22fe] has been reserved
[ 0.480948] system 00:06: [io 0x2300-0x23fe] has been reserved
[ 0.480991] system 00:06: [io 0x2400-0x24fe] has been reserved
[ 0.481035] system 00:06: [io 0x2500-0x25fe] has been reserved
[ 0.481081] system 00:06: [io 0x2600-0x26fe] has been reserved
[ 0.481125] system 00:06: [io 0x2700-0x27fe] has been reserved
[ 0.481169] system 00:06: [io 0x2800-0x28fe] has been reserved
[ 0.481212] system 00:06: [io 0x2900-0x29fe] has been reserved
[ 0.481255] system 00:06: [io 0x2a00-0x2afe] has been reserved
[ 0.481299] system 00:06: [io 0x2b00-0x2bfe] has been reserved
[ 0.481342] system 00:06: [io 0x2c00-0x2cfe] has been reserved
[ 0.481385] system 00:06: [io 0x2d00-0x2dfe] has been reserved
[ 0.481429] system 00:06: [io 0x2e00-0x2efe] has been reserved
[ 0.481472] system 00:06: [io 0x2f00-0x2ffe] has been reserved
[ 0.481515] system 00:06: [io 0x5000-0x50fe] has been reserved
[ 0.481559] system 00:06: [io 0x5100-0x51fe] has been reserved
[ 0.481602] system 00:06: [io 0x5200-0x52fe] has been reserved
[ 0.481646] system 00:06: [io 0x5300-0x53fe] has been reserved
[ 0.481689] system 00:06: [io 0x5400-0x54fe] has been reserved
[ 0.481733] system 00:06: [io 0x5500-0x55fe] has been reserved
[ 0.481776] system 00:06: [io 0x5600-0x56fe] has been reserved
[ 0.481820] system 00:06: [io 0x5700-0x57fe] has been reserved
[ 0.481863] system 00:06: [io 0x5800-0x58fe] has been reserved
[ 0.481907] system 00:06: [io 0x5900-0x59fe] has been reserved
[ 0.481950] system 00:06: [io 0x5a00-0x5afe] has been reserved
[ 0.481994] system 00:06: [io 0x5b00-0x5bfe] has been reserved
[ 0.482037] system 00:06: [io 0x5c00-0x5cfe] has been reserved
[ 0.482081] system 00:06: [io 0x5d00-0x5dfe] has been reserved
[ 0.482124] system 00:06: [io 0x5e00-0x5efe] has been reserved
[ 0.482168] system 00:06: [io 0x5f00-0x5ffe] has been reserved
[ 0.482212] system 00:06: [io 0x6000-0x60fe] has been reserved
[ 0.482255] system 00:06: [io 0x6100-0x61fe] has been reserved
[ 0.482299] system 00:06: [io 0x6200-0x62fe] has been reserved
[ 0.482343] system 00:06: [io 0x6300-0x63fe] has been reserved
[ 0.482387] system 00:06: [io 0x6400-0x64fe] has been reserved
[ 0.482430] system 00:06: [io 0x6500-0x65fe] has been reserved
[ 0.482474] system 00:06: [io 0x6600-0x66fe] has been reserved
[ 0.482518] system 00:06: [io 0x6700-0x67fe] has been reserved
[ 0.482562] system 00:06: [io 0x6800-0x68fe] has been reserved
[ 0.482606] system 00:06: [io 0x6900-0x69fe] has been reserved
[ 0.482649] system 00:06: [io 0x6a00-0x6afe] has been reserved
[ 0.482693] system 00:06: [io 0x6b00-0x6bfe] has been reserved
[ 0.482737] system 00:06: [io 0x6c00-0x6cfe] has been reserved
[ 0.482781] system 00:06: [io 0x6d00-0x6dfe] has been reserved
[ 0.482825] system 00:06: [io 0x6e00-0x6efe] has been reserved
[ 0.482869] system 00:06: [io 0x6f00-0x6ffe] has been reserved
[ 0.482913] system 00:06: [io 0xa000-0xa0fe] has been reserved
[ 0.482958] system 00:06: [io 0xa100-0xa1fe] has been reserved
[ 0.483004] system 00:06: [io 0xa200-0xa2fe] has been reserved
[ 0.483049] system 00:06: [io 0xa300-0xa3fe] has been reserved
[ 0.483093] system 00:06: [io 0xa400-0xa4fe] has been reserved
[ 0.483137] system 00:06: [io 0xa500-0xa5fe] has been reserved
[ 0.483182] system 00:06: [io 0xa600-0xa6fe] has been reserved
[ 0.483226] system 00:06: [io 0xa700-0xa7fe] has been reserved
[ 0.483270] system 00:06: [io 0xa800-0xa8fe] has been reserved
[ 0.483315] system 00:06: [io 0xa900-0xa9fe] has been reserved
[ 0.483359] system 00:06: [io 0xaa00-0xaafe] has been reserved
[ 0.483404] system 00:06: [io 0xab00-0xabfe] has been reserved
[ 0.483448] system 00:06: [io 0xac00-0xacfe] has been reserved
[ 0.483493] system 00:06: [io 0xad00-0xadfe] has been reserved
[ 0.483537] system 00:06: [io 0xae00-0xaefe] has been reserved
[ 0.483582] system 00:06: [io 0xaf00-0xaffe] has been reserved
[ 0.483626] system 00:06: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 0.483670] system 00:06: [mem 0xfeda0000-0xfedacfff] has been reserved
[ 0.483716] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.483726] pnp: PnP ACPI: found 7 devices
[ 0.483767] ACPI: bus type PNP unregistered
[ 0.483810] PnPBIOS: Disabled by ACPI PNP
[ 0.522083] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.522091] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000
[ 0.522106] pci 0000:00:1f.0: BAR 13: [io 0x0800-0x087f] has bogus alignment
[ 0.522154] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.522159] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.522167] pci 0000:00:1c.0: BAR 15: assigned [mem 0x20000000-0x201fffff 64bit pref]
[ 0.522220] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.522265] pci 0000:00:1f.2: BAR 5: assigned [mem 0x20200000-0x202003ff]
[ 0.522973] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.523016] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.523062] pci 0000:00:01.0: bridge window [mem 0xefd00000-0xefefffff]
[ 0.523108] pci 0000:00:01.0: bridge window [mem 0xec000000-0xedffffff 64bit pref]
[ 0.523161] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.523205] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.523251] pci 0000:00:1c.0: bridge window [mem 0xefc00000-0xefcfffff]
[ 0.523297] pci 0000:00:1c.0: bridge window [mem 0x20000000-0x201fffff 64bit pref]
[ 0.523352] pci 0000:00:1e.0: PCI bridge to [bus 03]
[ 0.523396] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[ 0.523442] pci 0000:00:1e.0: bridge window [mem 0xefb00000-0xefbfffff]
[ 0.523494] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.523498] pci_bus 0000:00: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.523501] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.523505] pci_bus 0000:01: resource 1 [mem 0xefd00000-0xefefffff]
[ 0.523508] pci_bus 0000:01: resource 2 [mem 0xec000000-0xedffffff 64bit pref]
[ 0.523512] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 0.523515] pci_bus 0000:02: resource 1 [mem 0xefc00000-0xefcfffff]
[ 0.523518] pci_bus 0000:02: resource 2 [mem 0x20000000-0x201fffff 64bit pref]
[ 0.523522] pci_bus 0000:03: resource 0 [io 0xc000-0xcfff]
[ 0.523525] pci_bus 0000:03: resource 1 [mem 0xefb00000-0xefbfffff]
[ 0.523528] pci_bus 0000:03: resource 4 [io 0x0000-0xffff]
[ 0.523532] pci_bus 0000:03: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.523581] NET: Registered protocol family 2
[ 0.523835] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.523892] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.523952] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.524024] TCP: reno registered
[ 0.524066] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.524113] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.524231] NET: Registered protocol family 1
[ 0.527492] pci 0000:01:00.0: Boot video device
[ 0.527513] pci 0000:03:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.527567] PCI: CLS 64 bytes, default 64
[ 0.527648] Trying to unpack rootfs image as initramfs…
[ 1.000656] Freeing initrd memory: 18172K (dddf7000 - defb6000)
[ 1.000807] Simple Boot Flag at 0x7a set to 0x1
[ 1.001001] microcode: CPU0 sig=0xf43, pf=0x10, revision=0x5
[ 1.001052] microcode: CPU1 sig=0xf43, pf=0x10, revision=0x5
[ 1.001191] microcode: Microcode Update Driver: v2.00 tigran@aivazian.fsnet.co.uk, Peter Oruba
[ 1.001244] Scanning for low memory corruption every 60 seconds
[ 1.001671] Initialise system trusted keyring
[ 1.001772] audit: initializing netlink socket (disabled)
[ 1.001832] type=2000 audit(1409689271.000:1): initialized
[ 1.029915] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.031922] VFS: Disk quotas dquot_6.5.2
[ 1.032050] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.032816] fuse init (API version 7.22)
[ 1.032992] msgmni has been set to 985
[ 1.033121] Key type big_key registered
[ 1.033829] Key type asymmetric registered
[ 1.033874] Asymmetric key parser ‘x509’ registered
[ 1.033968] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.034070] io scheduler noop registered
[ 1.034115] io scheduler deadline registered (default)
[ 1.034197] io scheduler cfq registered
[ 1.034771] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 1.035170] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X
[ 1.035281] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.035350] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.035479] ipmi message handler version 39.2
[ 1.035605] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 1.035661] ACPI: Power Button [VBTN]
[ 1.035772] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.035824] ACPI: Power Button [PWRF]
[ 1.036050] GHES: HEST is not enabled!
[ 1.036140] isapnp: Scanning for PnP cards…
[ 1.040081] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.043049] 0000:03:03.0: ttyS5 at I/O 0xcc08 (irq = 19, base_baud = 115200) is a 16450
[ 1.043268] 0000:03:03.0: ttyS6 at I/O 0xcc10 (irq = 19, base_baud = 115200) is a 8250
[ 1.043483] 0000:03:03.0: ttyS7 at I/O 0xcc18 (irq = 19, base_baud = 115200) is a 16450
[ 1.043696] 0000:03:03.0: ttyS8 at I/O 0xcc20 (irq = 19, base_baud = 115200) is a 8250
[ 1.043909] 0000:03:03.0: ttyS9 at I/O 0xcc28 (irq = 19, base_baud = 115200) is a 8250
[ 1.044991] 0000:03:03.0: ttyS16 at I/O 0xcc60 (irq = 19, base_baud = 115200) is a 8250
[ 1.047991] Linux agpgart interface v0.103
[ 1.050952] brd: module loaded
[ 1.052403] loop: module loaded
[ 1.052661] ata_piix 0000:00:1f.1: version 2.13
[ 1.056058] scsi0 : ata_piix
[ 1.056215] scsi1 : ata_piix
[ 1.056323] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.056370] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.056822] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.057120] ata2: port disabled–ignoring
[ 1.212515] scsi2 : ata_piix
[ 1.212653] scsi3 : ata_piix
[ 1.212772] ata3: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfea0 irq 20
[ 1.212820] ata4: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfea8 irq 20
[ 1.213521] libphy: Fixed MDIO Bus: probed
[ 1.213794] tun: Universal TUN/TAP device driver, 1.6
[ 1.213837] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.213951] PPP generic driver version 2.4.2
[ 1.214062] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.214112] ehci-pci: EHCI PCI platform driver
[ 1.214593] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.214646] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.214714] ehci-pci 0000:00:1d.7: debug port 1
[ 1.218672] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.218727] ehci-pci 0000:00:1d.7: irq 21, io mem 0xffa80800
[ 1.228025] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.228171] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.228218] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.228271] usb usb1: Product: EHCI Host Controller
[ 1.228315] usb usb1: Manufacturer: Linux 3.13.0-24-generic ehci_hcd
[ 1.228361] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.228588] hub 1-0:1.0: USB hub found
[ 1.228645] hub 1-0:1.0: 8 ports detected
[ 1.229045] ehci-platform: EHCI generic platform driver
[ 1.229105] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.229150] ohci-pci: OHCI PCI platform driver
[ 1.229214] ohci-platform: OHCI generic platform driver
[ 1.229270] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.229724] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.229775] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.229855] uhci_hcd 0000:00:1d.0: irq 21, io base 0x0000ff80
[ 1.229999] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.230047] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.230100] usb usb2: Product: UHCI Host Controller
[ 1.230144] usb usb2: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.230189] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.230397] hub 2-0:1.0: USB hub found
[ 1.230451] hub 2-0:1.0: 2 ports detected
[ 1.231030] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.231082] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.231175] uhci_hcd 0000:00:1d.1: irq 22, io base 0x0000ff60
[ 1.231302] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.231350] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.231402] usb usb3: Product: UHCI Host Controller
[ 1.231446] usb usb3: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.231492] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.231702] hub 3-0:1.0: USB hub found
[ 1.231755] hub 3-0:1.0: 2 ports detected
[ 1.232356] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.232408] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.232503] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.232640] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.232687] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.232740] usb usb4: Product: UHCI Host Controller
[ 1.232784] usb usb4: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.232829] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.233039] hub 4-0:1.0: USB hub found
[ 1.233092] hub 4-0:1.0: 2 ports detected
[ 1.233670] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.233721] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.233818] uhci_hcd 0000:00:1d.3: irq 23, io base 0x0000ff20
[ 1.233948] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.233995] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.234048] usb usb5: Product: UHCI Host Controller
[ 1.234093] usb usb5: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.234138] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.234347] hub 5-0:1.0: USB hub found
[ 1.234400] hub 5-0:1.0: 2 ports detected
[ 1.234711] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.237704] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.237755] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.237992] mousedev: PS/2 mouse device common for all mice
[ 1.238250] rtc_cmos 00:04: RTC can wake from S4
[ 1.238438] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.238511] rtc_cmos 00:04: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.238682] device-mapper: uevent: version 1.0.3
[ 1.238826] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[ 1.238918] platform eisa.0: Probing EISA bus 0
[ 1.238965] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 1.239013] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.239059] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.239117] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 1.239164] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 1.239222] platform eisa.0: EISA: Detected 0 cards
[ 1.239273] cpufreq-nforce2: No nForce2 chipset.
[ 1.239320] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.239600] TCP: cubic registered
[ 1.239833] NET: Registered protocol family 10
[ 1.240227] NET: Registered protocol family 17
[ 1.240290] Key type dns_resolver registered
[ 1.240590] Using IPI No-Shortcut mode
[ 1.241432] Loading compiled-in X.509 certificates
[ 1.247525] Loaded X.509 cert ‘Magrathea: Glacier signing key: 77d70e1df42996dc92b01d759d3e8562ea32a1c7’
[ 1.247599] registered taskstats version 1
[ 1.251252] Key type trusted registered
[ 1.254547] Key type encrypted registered
[ 1.257813] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.257861] IMA: No TPM chip found, activating TPM-bypass!
[ 1.258235] regulator-dummy: disabling
[ 1.258351] Magic number: 14:113:396
[ 1.258504] rtc_cmos 00:04: setting system clock to 2014-09-02 20:21:11 UTC (1409689271)
[ 1.258662] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.258708] EDD information not available.
[ 1.258818] PM: Hibernation image not present or could not be loaded.
[ 1.259678] ata1.00: ATAPI: HL-DT-ST DVD+/-RW GWA4164B, E113, max UDMA/33
[ 1.308292] ata1.00: configured for UDMA/33
[ 1.383153] ata3.00: ATA-7: WDC WD1600JS-75NCB1, 10.02E01, max UDMA/133
[ 1.383203] ata3.00: 312500000 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 1.388282] ata3.00: configured for UDMA/133
[ 1.390208] isapnp: No Plug & Play device found
[ 1.391891] scsi 0:0:0:0: CD-ROM HL-DT-ST DVD±RW GWA4164B E113 PQ: 0 ANSI: 5
[ 1.395180] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 1.395226] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.395438] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.395558] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.395830] scsi 2:0:0:0: Direct-Access ATA WDC WD1600JS-75N 10.0 PQ: 0 ANSI: 5
[ 1.396097] sd 2:0:0:0: [sda] 312500000 512-byte logical blocks: (160 GB/149 GiB)
[ 1.396159] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1.396323] sd 2:0:0:0: [sda] Write Protect is off
[ 1.396368] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.396429] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1.451000] sda: sda1 sda2 < sda5 sda6 >
[ 1.451649] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.452280] Freeing unused kernel memory: 872K (c19ae000 - c1a88000)
[ 1.452386] Write protecting the kernel text: 6512k
[ 1.452546] Write protecting the kernel read-only data: 2756k
[ 1.452589] NX-protecting the kernel data: 5776k
[ 1.471459] systemd-udevd[102]: starting version 204
[ 1.556065] usb 1-3: new high-speed USB device number 2 using ehci-pci
[ 1.560844] e100: Intel® PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.560899] e100: Copyright© 1999-2006 Intel Corporation
[ 1.595680] e100 0000:03:08.0 eth0: addr 0xefbff000, irq 20, MAC addr 00:12:3f:ae:e5:fd
[ 1.746448] usb 1-3: New USB device found, idVendor=0644, idProduct=0200
[ 1.746501] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.746619] usb 1-3: Product: CA-200
[ 1.746662] usb 1-3: Manufacturer: TEAC
[ 1.746704] usb 1-3: SerialNumber: 000003004770
[ 2.000023] tsc: Refined TSC clocksource calibration: 3191.999 MHz
[ 2.050313] EXT4-fs (sda5): INFO: recovery required on readonly filesystem
[ 2.050362] EXT4-fs (sda5): write access will be enabled during recovery
[ 2.124180] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 2.124349] scsi4 : usb-storage 1-3:1.0
[ 2.124546] usbcore: registered new interface driver usb-storage
[ 2.212515] EXT4-fs (sda5): recovery complete
[ 2.219456] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.224066] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[ 2.400055] usb 4-1: New USB device found, idVendor=046d, idProduct=c05a
[ 2.400106] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.400151] usb 4-1: Product: USB Optical Mouse
[ 2.400193] usb 4-1: Manufacturer: Logitech
[ 2.512049] usb 4-2: new low-speed USB device number 3 using uhci_hcd
[ 2.691050] usb 4-2: New USB device found, idVendor=046d, idProduct=c312
[ 2.691097] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.691143] usb 4-2: Product: USB Multimedia Keyboard
[ 2.691185] usb 4-2: Manufacturer: LITEON Technology
[ 2.774428] random: init urandom read with 95 bits of entropy available
[ 3.000108] Switched to clocksource tsc
[ 3.134478] scsi 4:0:0:0: Direct-Access TEAC USB HS-CF Card 4.08 PQ: 0 ANSI: 0
[ 3.138093] scsi 4:0:0:1: Direct-Access TEAC USB HS-xD/SM 4.08 PQ: 0 ANSI: 0
[ 3.141840] scsi 4:0:0:2: Direct-Access TEAC USB HS-MS Card 4.08 PQ: 0 ANSI: 0
[ 3.145094] scsi 4:0:0:3: Direct-Access TEAC USB HS-SD Card 4.08 PQ: 0 ANSI: 0
[ 3.145512] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 3.145799] sd 4:0:0:1: Attached scsi generic sg3 type 0
[ 3.146067] sd 4:0:0:2: Attached scsi generic sg4 type 0
[ 3.146337] sd 4:0:0:3: Attached scsi generic sg5 type 0
[ 3.185334] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 3.189960] sd 4:0:0:1: [sdc] Attached SCSI removable disk
[ 3.194456] sd 4:0:0:2: [sdd] Attached SCSI removable disk
[ 3.198357] sd 4:0:0:3: [sde] Attached SCSI removable disk
[ 3.273315] random: nonblocking pool is initialized
[ 3.738120] systemd-udevd[213]: starting version 204
[ 4.315787] intel_rng: Firmware space is locked read-only. If you can’t or
[ 4.315787] intel_rng: don’t want to disable this in firmware setup, and if
[ 4.315787] intel_rng: you are certain that your system has a functional
[ 4.315787] intel_rng: RNG, try using the ‘no_fwh_detect’ option.
[ 4.436659] ACPI Warning: 0x00000828-0x0000082f SystemIO conflicts with Region \GLBC 1 (20131115/utaddress-251)
[ 4.436789] ACPI Warning: 0x00000828-0x0000082f SystemIO conflicts with Region \SACT 2 (20131115/utaddress-251)
[ 4.436938] ACPI Warning: 0x00000828-0x0000082f SystemIO conflicts with Region \SSTS 3 (20131115/utaddress-251)
[ 4.437068] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 4.437356] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 4.586606] leds_ss4200: no LED devices found
[ 4.591898] [drm] Initialized drm 1.1.0 20060810
[ 4.656922] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 5.226094] gpio_ich: GPIO from 206 to 255 on gpio_ich
[ 5.405244] [drm] VGACON disable radeon kernel modesetting.
[ 5.405294] [drm] radeon userspace modesetting enabled.
[ 5.406111] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.406162] [drm] No driver support for vblank timestamp query.
[ 5.406206] [drm] Initialized radeon 1.34.0 20080528 for 0000:01:00.0 on minor 0
[ 5.616774] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 5.696191] autoconfig: line_outs=3 (0xd/0xc/0xf/0x0/0x0) type:speaker
[ 5.696249] speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.696298] hp_outs=1 (0xa/0x0/0x0/0x0/0x0)
[ 5.696348] mono: mono_out=0x0
[ 5.696394] inputs:
[ 5.696442] Front Mic=0xe
[ 5.696489] Rear Mic=0xb
[ 5.696537] Line=0x15
[ 5.712427] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 5.713098] input: HDA Intel Speaker CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 5.715247] input: HDA Intel Speaker Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 5.716143] input: HDA Intel Speaker Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 5.716676] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 5.717813] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 5.968376] hidraw: raw HID events driver © Jiri Kosina
[ 6.099614] usbcore: registered new interface driver usbhid
[ 6.099668] usbhid: USB HID core driver
[ 6.156631] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input11
[ 6.156943] hid-generic 0003:046D:C05A.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.2-1/input0
[ 6.158068] input: LITEON Technology USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input12
[ 6.158527] hid-generic 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-0000:00:1d.2-2/input0
[ 7.313913] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.004550] Adding 1951740k swap on /dev/sda1. Priority:-1 extents:1 across:1951740k FS
[ 14.525747] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 14.775420] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 29.500004] mtrr: no MTRR for ec000000,1000000 found
[ 45.342148] mtrr: no MTRR for ec000000,1000000 found
[ 72.746544] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[ 72.785551] JFS: nTxBlock = 3950, nTxLock = 31602
[ 72.838898] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 72.910043] QNX4 filesystem 0.2.3 registered.
[ 72.957156] xor: measuring software checksum speed
[ 72.996013] pIII_sse : 4475.000 MB/sec
[ 73.036011] prefetch64-sse: 4521.000 MB/sec
[ 73.036017] xor: using function: prefetch64-sse (4521.000 MB/sec)
[ 73.116033] raid6: mmxx1 1963 MB/s
[ 73.184039] raid6: mmxx2 2285 MB/s
[ 73.252051] raid6: sse1x1 1170 MB/s
[ 73.320029] raid6: sse1x2 2254 MB/s
[ 73.388022] raid6: sse2x1 2362 MB/s
[ 73.456024] raid6: sse2x2 3333 MB/s
[ 73.456027] raid6: using algorithm sse2x2 (3333 MB/s)
[ 73.456030] raid6: using intx1 recovery algorithm
[ 73.547541] bio: create slab at 1
[ 73.551149] Btrfs loaded
[ 85.668852] mtrr: no MTRR for ec000000,1000000 found
[ 153.598151] mtrr: no MTRR for ec000000,1000000 found
[ 156.767294] init: plymouth-upstart-bridge main process (2654) terminated with status 1
[ 156.767332] init: plymouth-upstart-bridge main process ended, respawning
[ 156.852472] init: plymouth-upstart-bridge main process (2687) terminated with status 1
[ 156.852504] init: plymouth-upstart-bridge main process ended, respawning
[ 156.906391] init: plymouth-upstart-bridge main process (2692) terminated with status 1
[ 156.906428] init: plymouth-upstart-bridge main process ended, respawning
[ 156.947715] init: plymouth-upstart-bridge main process (2696) terminated with status 1
[ 156.947746] init: plymouth-upstart-bridge main process ended, respawning
[ 157.054944] lp: driver loaded but no devices found
[ 157.135579] ppdev: user-space parallel port driver
[ 158.961148] init: udev-fallback-graphics main process (2781) terminated with status 1
[ 161.186170] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 162.658738] Bluetooth: Core ver 2.17
[ 162.658780] NET: Registered protocol family 31
[ 162.658785] Bluetooth: HCI device and connection manager initialized
[ 162.658802] Bluetooth: HCI socket layer initialized
[ 162.658810] Bluetooth: L2CAP socket layer initialized
[ 162.658823] Bluetooth: SCO socket layer initialized
[ 162.725121] Bluetooth: RFCOMM TTY layer initialized
[ 162.725139] Bluetooth: RFCOMM socket layer initialized
[ 162.725152] Bluetooth: RFCOMM ver 1.11
[ 162.746120] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 162.746127] Bluetooth: BNEP filters: protocol multicast
[ 162.746143] Bluetooth: BNEP socket layer initialized
[ 162.908207] init: avahi-cups-reload main process (3090) terminated with status 1
[ 163.126577] type=1400 audit(1409689433.363:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/lib/cups/backend/cups-pdf" pid=3061 comm=“apparmor_parser”
[ 163.126590] type=1400 audit(1409689433.363:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/sbin/cupsd" pid=3061 comm=“apparmor_parser”
[ 163.127262] type=1400 audit(1409689433.363:4): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name="/usr/sbin/cupsd" pid=3061 comm=“apparmor_parser”
[ 163.732263] type=1400 audit(1409689433.971:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/sbin/cups-browsed" pid=3113 comm=“apparmor_parser”
[ 282.202001] type=1400 audit(1409689552.439:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/sbin/dhclient" pid=3179 comm=“apparmor_parser”
[ 282.202023] type=1400 audit(1409689552.439:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=3179 comm=“apparmor_parser”
[ 282.202038] type=1400 audit(1409689552.439:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/lib/connman/scripts/dhclient-script" pid=3179 comm=“apparmor_parser”
[ 282.203111] type=1400 audit(1409689552.439:9): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=3179 comm=“apparmor_parser”
[ 282.203123] type=1400 audit(1409689552.439:10): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name="/usr/lib/connman/scripts/dhclient-script" pid=3179 comm=“apparmor_parser”
[ 282.203465] type=1400 audit(1409689552.439:11): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name="/usr/lib/connman/scripts/dhclient-script" pid=3179 comm=“apparmor_parser”
[ 282.208852] type=1400 audit(1409689552.447:12): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/lib/lightdm/lightdm-guest-session" pid=3178 comm=“apparmor_parser”
[ 282.208869] type=1400 audit(1409689552.447:13): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“chromium” pid=3178 comm=“apparmor_parser”
[ 282.209540] type=1400 audit(1409689552.447:14): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“chromium” pid=3178 comm=“apparmor_parser”
[ 282.231305] type=1400 audit(1409689552.467:15): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/lib/telepathy/mission-control-5" pid=3182 comm=“apparmor_parser”
[ 287.249007] init: plymouth-upstart-bridge main process ended, respawning
[ 288.497750] init: friendly-recovery post-stop process (2648) terminated with status 1
[ 327.740042] usb 2-2: new full-speed USB device number 2 using uhci_hcd
[ 327.898042] usb 2-2: New USB device found, idVendor=0fe6, idProduct=9700
[ 327.898047] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 327.898051] usb 2-2: Product: USB 2.0 10/100M Ethernet Adaptor
[ 328.105403] dm9601 2-2:1.0 eth1: register ‘dm9601’ at usb-0000:00:1d.0-2, Davicom DM96xx USB 10/100 Ethernet, 00:e0:4c:53:44:58
[ 328.105621] usbcore: registered new interface driver dm9601
[ 328.121032] usbcore: registered new interface driver sr9700
[ 328.241077] dm9601 2-2:1.0 eth1: link up, 100Mbps, full-duplex, lpa 0xFFFF
[ 329.271038] dm9601 2-2:1.0 eth1: kevent 4 may have been dropped
[ 329.273033] dm9601 2-2:1.0 eth1: kevent 4 may have been dropped
[ 329.283033] dm9601 2-2:1.0 eth1: kevent 4 may have been dropped
[ 329.285033] dm9601 2-2:1.0 eth1: kevent 4 may have been dropped
[ 329.287032] dm9601 2-2:1.0 eth1: kevent 4 may have been dropped
[ 329.289032] dm9601 2-2:1.0 eth1: kevent 4 may have been dropped
[ 329.327049] dm9601 2-2:1.0 eth1: link up, 100Mbps, full-duplex, lpa 0xFFFF
[ 329.512050] dm9601 2-2:1.0 eth1: link up, 100Mbps, full-duplex, lpa 0xFFFF
[ 464.864068] usb 1-8: new high-speed USB device number 6 using ehci-pci
[ 465.000948] usb 1-8: New USB device found, idVendor=0951, idProduct=1665
[ 465.000954] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 465.000958] usb 1-8: Product: DataTraveler 2.0
[ 465.000961] usb 1-8: Manufacturer: Kingston
[ 465.000964] usb 1-8: SerialNumber: 00241D8CE3F7BD30A93101CE
[ 465.001269] usb-storage 1-8:1.0: USB Mass Storage device detected
[ 465.001374] scsi5 : usb-storage 1-8:1.0
[ 466.082279] scsi 5:0:0:0: Direct-Access Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 4
[ 466.082793] sd 5:0:0:0: Attached scsi generic sg6 type 0
[ 467.819136] sd 5:0:0:0: [sdf] 30712320 512-byte logical blocks: (15.7 GB/14.6 GiB)
[ 467.819748] sd 5:0:0:0: [sdf] Write Protect is off
[ 467.819754] sd 5:0:0:0: [sdf] Mode Sense: 23 00 00 00
[ 467.820379] sd 5:0:0:0: [sdf] No Caching mode page found
[ 467.820386] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[ 467.825753] sd 5:0:0:0: [sdf] No Caching mode page found
[ 467.825761] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[ 467.845672] sdf: sdf1
[ 467.849888] sd 5:0:0:0: [sdf] No Caching mode page found
[ 467.849896] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[ 467.849902] sd 5:0:0:0: [sdf] Attached SCSI removable disk
[ 470.169002] FAT-fs (sdf1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 474.614171] systemd-hostnamed[4667]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
284.561]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 284.561] X Protocol Version 11, Revision 0
[ 284.561] Build Operating System: Linux 3.2.0-37-generic i686 Ubuntu
[ 284.561] Current Operating System: Linux famille-Dell-DM051 3.13.0-24-generic #46-Ubuntu SMP Thu Apr 10 19:08:14 UTC 2014 i686
[ 284.561] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-24-generic root=UUID=a53ca049-5dd2-418a-bd05-01739f68fe70 ro recovery nomodeset
[ 284.561] Build Date: 16 April 2014 01:40:08PM
[ 284.561] xorg-server 2:1.15.1-0ubuntu2 (For technical support please see ubuntu.com/support)
[ 284.561] Current version of pixman: 0.30.2
[ 284.561] Before reporting problems, check wiki.x.org
[ 284.561] Markers: (–) probed, () from config file, (==) default setting,
[ 284.561] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Sep 2 22:25:54 2014
[ 284.583] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 284.584] (==) No Layout section. Using the first Screen section.
[ 284.584] (==) No screen section available. Using defaults.
[ 284.584] (
) |–>Screen “Default Screen Section” (0)
[ 284.584] (**) | |–>Monitor “”
[ 284.584] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 284.584] (==) Automatically adding devices
[ 284.584] (==) Automatically enabling devices
[ 284.584] (==) Automatically adding GPU devices
[ 284.584] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 284.584] Entry deleted from font path.
[ 284.584] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 284.584] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 284.584] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 284.584] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 284.584] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 284.584] (==) ModulePath set to “/usr/lib/i386-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 284.584] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 284.584] (II) Loader magic: 0xb77326c0
[ 284.584] (II) Module ABI versions:
[ 284.584] X.Org ANSI C Emulation: 0.4
[ 284.584] X.Org Video Driver: 15.0
[ 284.585] X.Org XInput driver : 20.0
[ 284.585] X.Org Server Extension : 8.0
[ 284.585] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 284.587] (–) PCI:*(0:1:0:0) 1002:5b60:1002:0602 rev 0, Mem @ 0xec000000/33554432, 0xefde0000/65536, I/O @ 0x0000dc00/256, BIOS @ 0x???/131072
[ 284.587] (–) PCI: (0:1:0:1) 1002:5b70:1002:0603 rev 0, Mem @ 0xefdf0000/65536
[ 284.587] Initializing built-in extension Generic Event Extension
[ 284.587] Initializing built-in extension SHAPE
[ 284.587] Initializing built-in extension MIT-SHM
[ 284.587] Initializing built-in extension XInputExtension
[ 284.587] Initializing built-in extension XTEST
[ 284.587] Initializing built-in extension BIG-REQUESTS
[ 284.587] Initializing built-in extension SYNC
[ 284.587] Initializing built-in extension XKEYBOARD
[ 284.587] Initializing built-in extension XC-MISC
[ 284.587] Initializing built-in extension SECURITY
[ 284.587] Initializing built-in extension XINERAMA
[ 284.587] Initializing built-in extension XFIXES
[ 284.587] Initializing built-in extension RENDER
[ 284.587] Initializing built-in extension RANDR
[ 284.587] Initializing built-in extension COMPOSITE
[ 284.587] Initializing built-in extension DAMAGE
[ 284.587] Initializing built-in extension MIT-SCREEN-SAVER
[ 284.587] Initializing built-in extension DOUBLE-BUFFER
[ 284.587] Initializing built-in extension RECORD
[ 284.587] Initializing built-in extension DPMS
[ 284.587] Initializing built-in extension Present
[ 284.587] Initializing built-in extension DRI3
[ 284.588] Initializing built-in extension X-Resource
[ 284.588] Initializing built-in extension XVideo
[ 284.588] Initializing built-in extension XVideo-MotionCompensation
[ 284.588] Initializing built-in extension SELinux
[ 284.588] Initializing built-in extension XFree86-VidModeExtension
[ 284.588] Initializing built-in extension XFree86-DGA
[ 284.588] Initializing built-in extension XFree86-DRI
[ 284.588] Initializing built-in extension DRI2
[ 284.588] (II) LoadModule: “glx”
[ 284.588] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 284.590] (II) Module glx: vendor=“X.Org Foundation”
[ 284.590] compiled for 1.15.1, module version = 1.0.0
[ 284.590] ABI class: X.Org Server Extension, version 8.0
[ 284.590] (==) AIGLX enabled
[ 284.590] Loading extension GLX
[ 284.590] (==) Matched fglrx as autoconfigured driver 0
[ 284.590] (==) Matched ati as autoconfigured driver 1
[ 284.590] (==) Matched fglrx as autoconfigured driver 2
[ 284.590] (==) Matched ati as autoconfigured driver 3
[ 284.590] (==) Matched modesetting as autoconfigured driver 4
[ 284.590] (==) Matched fbdev as autoconfigured driver 5
[ 284.590] (==) Matched vesa as autoconfigured driver 6
[ 284.590] (==) Assigned the driver to the xf86ConfigLayout
[ 284.590] (II) LoadModule: “fglrx”
[ 284.603] (WW) Warning, couldn’t open module fglrx
[ 284.603] (II) UnloadModule: “fglrx”
[ 284.603] (II) Unloading fglrx
[ 284.603] (EE) Failed to load module “fglrx” (module does not exist, 0)
[ 284.603] (II) LoadModule: “ati”
[ 284.603] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 284.608] (II) Module ati: vendor=“X.Org Foundation”
[ 284.608] compiled for 1.15.0, module version = 7.3.0
[ 284.608] Module class: X.Org Video Driver
[ 284.608] ABI class: X.Org Video Driver, version 15.0
[ 284.608] (II) LoadModule: “radeon”
[ 284.608] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 284.650] (II) Module radeon: vendor=“X.Org Foundation”
[ 284.650] compiled for 1.15.0, module version = 7.3.0
[ 284.650] Module class: X.Org Video Driver
[ 284.650] ABI class: X.Org Video Driver, version 15.0
[ 284.650] (II) LoadModule: “modesetting”
[ 284.650] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 284.660] (II) Module modesetting: vendor=“X.Org Foundation”
[ 284.660] compiled for 1.15.0, module version = 0.8.1
[ 284.660] Module class: X.Org Video Driver
[ 284.660] ABI class: X.Org Video Driver, version 15.0
[ 284.660] (II) LoadModule: “fbdev”
[ 284.660] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 284.664] (II) Module fbdev: vendor=“X.Org Foundation”
[ 284.664] compiled for 1.15.0, module version = 0.4.4
[ 284.664] Module class: X.Org Video Driver
[ 284.664] ABI class: X.Org Video Driver, version 15.0
[ 284.664] (II) LoadModule: “vesa”
[ 284.664] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 284.664] (II) Module vesa: vendor=“X.Org Foundation”
[ 284.664] compiled for 1.15.0, module version = 2.3.3
[ 284.664] (==) Matched fglrx as autoconfigured driver 0
[ 284.664] (==) Matched ati as autoconfigured driver 1
[ 284.664] (==) Matched fglrx as autoconfigured driver 2
[ 284.664] (==) Matched ati as autoconfigured driver 3
[ 284.664] (==) Matched modesetting as autoconfigured driver 4
[ 284.664] (==) Matched fbdev as autoconfigured driver 5
[ 284.664] (==) Matched vesa as autoconfigured driver 6
[ 284.664] (==) Assigned the driver to the xf86ConfigLayout
[ 284.665] (II) LoadModule: “fglrx”
[ 284.665] (WW) Warning, couldn’t open module fglrx
[ 284.665] (II) UnloadModule: “fglrx”
[ 284.665] (II) Unloading fglrx
[ 284.665] (EE) Failed to load module “fglrx” (module does not exist, 0)
[ 284.665] (II) LoadModule: “ati”
[ 284.666] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 284.666] (II) Module ati: vendor=“X.Org Foundation”
[ 284.666] compiled for 1.15.0, module version = 7.3.0
[ 284.666] Module class: X.Org Video Driver
[ 284.666] ABI class: X.Org Video Driver, version 15.0
[ 284.666] (II) LoadModule: “modesetting”
[ 284.666] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 284.666] (II) Module modesetting: vendor=“X.Org Foundation”
[ 284.666] compiled for 1.15.0, module version = 0.8.1
[ 284.666] (II) UnloadModule: “modesetting”
[ 284.666] (II) Unloading modesetting
[ 284.666] (II) Failed to load module “modesetting” (already loaded, 0)
[ 284.666] (II) LoadModule: “fbdev”
[ 284.667] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 284.667] (II) Module fbdev: vendor=“X.Org Foundation”
[ 284.667] compiled for 1.15.0, module version = 0.4.4
[ 284.667] Module class: X.Org Video Driver
[ 284.667] ABI class: X.Org Video Driver, version 15.0
[ 284.667] (II) UnloadModule: “fbdev”
[ 284.667] (II) Unloading fbdev
[ 284.667] (II) Failed to load module “fbdev” (already loaded, 0)
[ 284.667] (II) LoadModule: “vesa”
[ 284.667] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 284.667] (II) Module vesa: vendor=“X.Org Foundation”
[ 284.667] compiled for 1.15.0, module version = 2.3.3
[ 284.667] (II) UnloadModule: “vesa”
[ 284.667] (II) Unloading vesa
[ 284.667] (II) Failed to load module “vesa” (already loaded, 0)
[ 284.667] (II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI FireMV 2400 3155 (PCI),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
ATI Radeon 8500 AIW BB (AGP), ATI Radeon IGP320M (U1) 4336,
ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
ATI Radeon X800 VE (R420) JT (AGP), ATI Radeon X850 (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI FireMV 2400 PCI,
ATI Radeon 9700 Pro ND (AGP), ATI Radeon 9700/9500Pro NE (AGP),
ATI Radeon 9600TX NF (AGP), ATI FireGL X1 NG (AGP),
ATI Radeon 9800PRO NH (AGP), ATI Radeon 9800 NI (AGP),
ATI FireGL X2 NK (AGP), ATI Radeon 9800XT NJ (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835,
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE),
ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE),
ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
ATI Mobility Radeon X1700, ATI Radeon X2300HD,
ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI FireGL V7400,
ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600,
ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon 4800 Series, ATI Radeon HD 4850 x2,
ATI FirePro V8750 (FireGL), ATI FirePro V7760 (FireGL),
ATI Mobility RADEON HD 4850, ATI Mobility RADEON HD 4850 X2,
ATI Radeon 4800 Series, ATI FirePro RV770, AMD FireStream 9270,
AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI Mobility RADEON HD 4870, ATI Radeon 4800 Series,
ATI Radeon 4800 Series, ATI FirePro M7750, ATI M98, ATI M98, ATI M98,
ATI Mobility Radeon HD 4650, ATI Radeon RV730 (AGP),
ATI Mobility Radeon HD 4670, ATI FirePro M5750,
ATI Mobility Radeon HD 4670, ATI Radeon RV730 (AGP),
ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI Radeon HD 4770,
ATI FirePro M5750, ATI RV610, ATI Radeon HD 2400 XT,
ATI Radeon HD 2400 Pro, ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000,
ATI RV610, ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610,
ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI RV670,
ATI Mobility Radeon HD 3870, ATI Mobility Radeon HD 3870 X2,
ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850,
ATI Radeon HD3690, AMD Firestream 9170, ATI Radeon HD 4550,
ATI Radeon RV710, ATI Radeon RV710, ATI Radeon RV710,
ATI Radeon HD 4350, ATI Mobility Radeon 4300 Series,
ATI Mobility Radeon 4500 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3450, ATI Radeon HD 3430,
ATI Radeon HD 3450, ATI FirePro V3700, ATI FireMV 2450,
ATI FireMV 2260, ATI FireMV 2260, ATI Radeon HD 3600 Series,
ATI Radeon HD 3650 AGP, ATI Radeon HD 3600 PRO,
ATI Radeon HD 3600 XT, ATI Radeon HD 3600 PRO,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon HD 3200 Graphics,
ATI Radeon 3000 Graphics, SUMO, SUMO, SUMO2, SUMO2, SUMO2, SUMO2,
SUMO, SUMO, SUMO2, SUMO, SUMO, SUMO, SUMO, SUMO, ATI Radeon HD 4200,
ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6310 Graphics,
AMD Radeon HD 6250 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, PALM, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5900 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Mobility Radeon HD 5800 Series, ATI Radeon HD 5700 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5670,
ATI Radeon HD 5570, ATI Radeon HD 5500 Series, REDWOOD,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon Graphics,
ATI Mobility Radeon Graphics, CEDAR,
ATI FirePro (FireGL) Graphics Adapter, ATI FirePro 2270, CEDAR,
ATI Radeon HD 5450, CEDAR, CEDAR, CAYMAN, CAYMAN, CAYMAN, CAYMAN,
CAYMAN, CAYMAN, CAYMAN, CAYMAN, CAYMAN, CAYMAN,
AMD Radeon HD 6900 Series, AMD Radeon HD 6900 Series, CAYMAN, CAYMAN,
CAYMAN, AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series,
BARTS, BARTS, Mobility Radeon HD 6000 Series,
Mobility Radeon HD 6000 Series, BARTS, BARTS, BARTS, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6800 Series,
AMD Radeon HD 6700 Series, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS,
TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS,
CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS,
CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, ARUBA, ARUBA,
ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA,
ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, TAHITI, TAHITI, TAHITI, TAHITI,
TAHITI, TAHITI, TAHITI, TAHITI, TAHITI, TAHITI, TAHITI, TAHITI,
TAHITI, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN,
PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN,
VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE,
VERDE, VERDE, VERDE, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND,
OLAND, OLAND, OLAND, OLAND, OLAND, OLAND, HAINAN, HAINAN, HAINAN,
HAINAN, HAINAN, HAINAN, BONAIRE, BONAIRE, BONAIRE, BONAIRE, BONAIRE,
BONAIRE, BONAIRE, BONAIRE, KABINI, KABINI, KABINI, KABINI, KABINI,
KABINI, KABINI, KABINI, KABINI, KABINI, KABINI, KABINI, KABINI,
KABINI, KABINI, KABINI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI,
KAVERI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI,
HAWAII, HAWAII, HAWAII, HAWAII, HAWAII, HAWAII, HAWAII, HAWAII,
[ 284.685] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 284.685] (II) FBDEV: driver for framebuffer: fbdev
[ 284.685] (II) VESA: driver for VESA chipsets: vesa
[ 284.686] (++) using VT number 7
[ 284.686] (II) [KMS] drm report modesetting isn’t supported.
[ 284.687] (II) [KMS] drm report modesetting isn’t supported.
[ 284.687] (WW) Falling back to old probe method for modesetting
[ 284.687] (II) Loading sub module “fbdevhw”
[ 284.687] (II) LoadModule: “fbdevhw”
[ 284.688] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 284.696] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 284.696] compiled for 1.15.1, module version = 0.0.2
[ 284.696] ABI class: X.Org Video Driver, version 15.0
[ 284.696] (EE) open /dev/fb0: No such file or directory
[ 284.696] (II) Loading sub module “fbdevhw”
[ 284.696] (II) LoadModule: “fbdevhw”
[ 284.696] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 284.697] (WW) Falling back to old probe method for fbdev
[ 284.697] (II) Loading sub module “fbdevhw”
[ 284.697] (II) LoadModule: “fbdevhw”
[ 284.697] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 284.697] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 284.697] compiled for 1.15.1, module version = 0.0.2
[ 284.697] ABI class: X.Org Video Driver, version 15.0
[ 284.697] (EE) open /dev/fb0: No such file or directory
[ 284.697] (EE) Screen 0 deleted because of no matching config section.
[ 284.697] (II) UnloadModule: “radeon”
[ 284.697] (II) UnloadModule: “modesetting”
[ 284.698] (EE) Screen 0 deleted because of no matching config section.
[ 284.698] (II) UnloadModule: “fbdev”
[ 284.698] (II) UnloadSubModule: “fbdevhw”
[ 284.698] (II) Loading sub module “vbe”
[ 284.698] (II) LoadModule: “vbe”
[ 284.698] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 284.698] (II) Module vbe: vendor=“X.Org Foundation”
[ 284.698] compiled for 1.15.1, module version = 1.1.0
[ 284.698] ABI class: X.Org Video Driver, version 15.0
[ 284.698] (II) Loading sub module “int10”
[ 284.698] (II) LoadModule: “int10”
[ 284.699] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 284.699] (II) Module int10: vendor=“X.Org Foundation”
[ 284.699] compiled for 1.15.1, module version = 1.0.0
[ 284.699] ABI class: X.Org Video Driver, version 15.0
[ 284.699] (II) VESA(0): initializing int10
[ 284.700] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 284.700] (II) VESA(0): VESA BIOS detected
[ 284.700] (II) VESA(0): VESA VBE Version 2.0
[ 284.700] (II) VESA(0): VESA VBE Total Mem: 16384 kB
[ 284.700] (II) VESA(0): VESA VBE OEM: ATI RV370
[ 284.700] (II) VESA(0): VESA VBE OEM Software Rev: 1.0
[ 284.700] (II) VESA(0): VESA VBE OEM Vendor: ATI Technologies Inc.
[ 284.700] (II) VESA(0): VESA VBE OEM Product: V380
[ 284.700] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[ 285.346] (II) VESA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 285.346] (==) VESA(0): Depth 24, (–) framebuffer bpp 32
[ 285.346] (==) VESA(0): RGB weight 888
[ 285.346] (==) VESA(0): Default visual is TrueColor
[ 285.346] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 285.346] (II) Loading sub module “ddc”
[ 285.346] (II) LoadModule: “ddc”
[ 285.346] (II) Module “ddc” already built-in
[ 285.355] (II) VESA(0): VESA VBE DDC supported
[ 285.355] (II) VESA(0): VESA VBE DDC Level 2
[ 285.355] (II) VESA(0): VESA VBE DDC transfer in appr. 2 sec.
[ 286.074] (II) VESA(0): VESA VBE DDC read successfully
[ 286.074] (II) VESA(0): Manufacturer: MAX Model: 962 Serial#: 16843009
[ 286.074] (II) VESA(0): Year: 2007 Week: 43
[ 286.074] (II) VESA(0): EDID Version: 1.3
[ 286.074] (II) VESA(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 286.074] (II) VESA(0): Sync: Separate Composite
[ 286.074] (II) VESA(0): Max Image Size [cm]: horiz.: 52 vert.: 33
[ 286.074] (II) VESA(0): Gamma: 2.20
[ 286.074] (II) VESA(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 286.074] (II) VESA(0): First detailed timing is preferred mode
[ 286.074] (II) VESA(0): redX: 0.653 redY: 0.337 greenX: 0.295 greenY: 0.607
[ 286.074] (II) VESA(0): blueX: 0.144 blueY: 0.075 whiteX: 0.313 whiteY: 0.329
[ 286.074] (II) VESA(0): Supported established timings:
[ 286.074] (II) VESA(0): 720x400@70Hz
[ 286.074] (II) VESA(0): 640x480@60Hz
[ 286.075] (II) VESA(0): 640x480@67Hz
[ 286.075] (II) VESA(0): 640x480@72Hz
[ 286.075] (II) VESA(0): 640x480@75Hz
[ 286.075] (II) VESA(0): 800x600@60Hz
[ 286.075] (II) VESA(0): 800x600@72Hz
[ 286.075] (II) VESA(0): 800x600@75Hz
[ 286.075] (II) VESA(0): 832x624@75Hz
[ 286.075] (II) VESA(0): 1024x768@60Hz
[ 286.075] (II) VESA(0): 1024x768@70Hz
[ 286.075] (II) VESA(0): 1024x768@75Hz
[ 286.075] (II) VESA(0): 1280x1024@75Hz
[ 286.075] (II) VESA(0): 1152x864@75Hz
[ 286.075] (II) VESA(0): Manufacturer’s mask: 0
[ 286.075] (II) VESA(0): Supported standard timings:
[ 286.075] (II) VESA(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 286.075] (II) VESA(0): #1: hsize: 1280 vsize 1024 refresh: 76 vid: 36993
[ 286.075] (II) VESA(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 286.075] (II) VESA(0): #3: hsize: 1280 vsize 1024 refresh: 72 vid: 35969
[ 286.075] (II) VESA(0): #4: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 286.075] (II) VESA(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 286.075] (II) VESA(0): #6: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 286.075] (II) VESA(0): #7: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 286.075] (II) VESA(0): Supported detailed timing:
[ 286.075] (II) VESA(0): clock: 154.0 MHz Image Size: 519 x 324 mm
[ 286.075] (II) VESA(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 286.075] (II) VESA(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
[ 286.075] (II) VESA(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 286.075] (II) VESA(0): Monitor name: o.disp4.1_24w
[ 286.075] (II) VESA(0): Serial No: 074311400757
[ 286.075] (II) VESA(0): EDID (in hex):
[ 286.075] (II) VESA(0): 00ffffffffffff003438620901010101
[ 286.075] (II) VESA(0): 2b1101036c342178ea5ad5a7564b9b24
[ 286.075] (II) VESA(0): 135054bdef80714f81908180818ca940
[ 286.075] (II) VESA(0): b300950f9500283c80a070b023403020
[ 286.075] (II) VESA(0): 360007442100001a000000fd00384c1e
[ 286.075] (II) VESA(0): 5311000a202020202020000000fc006f
[ 286.075] (II) VESA(0): 2e64697370342e315f323477000000ff
[ 286.075] (II) VESA(0): 003037343331313430303735370a0093
[ 286.076] (II) VESA(0): EDID vendor “MAX”, prod id 2402
[ 286.076] (II) VESA(0): Using EDID range info for horizontal sync
[ 286.076] (II) VESA(0): Using EDID range info for vertical refresh
[ 286.076] (II) VESA(0): Printing DDC gathered Modelines:
[ 286.076] (II) VESA(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[ 286.076] (II) VESA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 286.076] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 286.076] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 286.076] (II) VESA(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 286.076] (II) VESA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 286.076] (II) VESA(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 286.076] (II) VESA(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 286.076] (II) VESA(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 286.076] (II) VESA(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 286.076] (II) VESA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 286.076] (II) VESA(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 286.076] (II) VESA(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 286.076] (II) VESA(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 286.076] (II) VESA(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 286.076] (II) VESA(0): Modeline "1280x1024"x76.0 141.82 1280 1376 1512 1744 1024 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[ 286.076] (II) VESA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 286.076] (II) VESA(0): Modeline "1280x1024"x72.0 132.75 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[ 286.076] (II) VESA(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 286.076] (II) VESA(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 286.076] (II) VESA(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 286.076] (II) VESA(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 286.076] (II) VESA(0): Searching for matching VESA mode(s):
[ 286.093] Mode: 6a (800x600)
[ 286.093] ModeAttributes: 0x1b
[ 286.093] WinAAttributes: 0x7
[ 286.093] WinBAttributes: 0x0
[ 286.093] WinGranularity: 64
[ 286.093] WinSize: 64
[ 286.093] WinASegment: 0xa000
[ 286.093] WinBSegment: 0xa000
[ 286.093] WinFuncPtr: 0xc00055c9
[ 286.093] BytesPerScanline: 100
[ 286.093] XResolution: 800
[ 286.093] YResolution: 600
[ 286.093] XCharSize: 8
[ 286.093] YCharSize: 14
[ 286.093] NumberOfPlanes: 4
[ 286.093] BitsPerPixel: 4
[ 286.093] NumberOfBanks: 1
[ 286.093] MemoryModel: 3
[ 286.093] BankSize: 0
[ 286.093] NumberOfImages: 3
[ 286.093] RedMaskSize: 0
[ 286.093] RedFieldPosition: 0
[ 286.093] GreenMaskSize: 0
[ 286.093] GreenFieldPosition: 0
[ 286.093] BlueMaskSize: 0
[ 286.093] BlueFieldPosition: 0
[ 286.093] RsvdMaskSize: 0
[ 286.093] RsvdFieldPosition: 0
[ 286.093] DirectColorModeInfo: 0
[ 286.093] PhysBasePtr: 0x0
[ 286.110] Mode: 102 (800x600)
[ 286.110] ModeAttributes: 0x1b
[ 286.110] WinAAttributes: 0x7
[ 286.110] WinBAttributes: 0x0
[ 286.110] WinGranularity: 64
[ 286.110] WinSize: 64
[ 286.110] WinASegment: 0xa000
[ 286.110] WinBSegment: 0xa000
[ 286.110] WinFuncPtr: 0xc00055c9
[ 286.110] BytesPerScanline: 100
[ 286.110] XResolution: 800
[ 286.110] YResolution: 600
[ 286.110] XCharSize: 8
[ 286.110] YCharSize: 14
[ 286.110] NumberOfPlanes: 4
[ 286.110] BitsPerPixel: 4
[ 286.110] NumberOfBanks: 1
[ 286.110] MemoryModel: 3
[ 286.110] BankSize: 0
[ 286.110] NumberOfImages: 3
[ 286.110] RedMaskSize: 0
[ 286.110] RedFieldPosition: 0
[ 286.110] GreenMaskSize: 0
[ 286.110] GreenFieldPosition: 0
[ 286.110] BlueMaskSize: 0
[ 286.110] BlueFieldPosition: 0
[ 286.110] RsvdMaskSize: 0
[ 286.110] RsvdFieldPosition: 0
[ 286.110] DirectColorModeInfo: 0
[ 286.110] PhysBasePtr: 0x0
[ 286.127] Mode: 104 (1024x768)
[ 286.127] ModeAttributes: 0x1b
[ 286.127] WinAAttributes: 0x7
[ 286.127] WinBAttributes: 0x0
[ 286.127] WinGranularity: 64
[ 286.127] WinSize: 64
[ 286.127] WinASegment: 0xa000
[ 286.127] WinBSegment: 0xa000
[ 286.127] WinFuncPtr: 0xc00055c9
[ 286.127] BytesPerScanline: 128
[ 286.127] XResolution: 1024
[ 286.128] YResolution: 768
[ 286.128] XCharSize: 8
[ 286.128] YCharSize: 16
[ 286.128] NumberOfPlanes: 4
[ 286.128] BitsPerPixel: 4
[ 286.128] NumberOfBanks: 1
[ 286.128] MemoryModel: 3
[ 286.128] BankSize: 0
[ 286.128] NumberOfImages: 1
[ 286.128] RedMaskSize: 0
[ 286.128] RedFieldPosition: 0
[ 286.128] GreenMaskSize: 0
[ 286.128] GreenFieldPosition: 0
[ 286.128] BlueMaskSize: 0
[ 286.128] BlueFieldPosition: 0
[ 286.128] RsvdMaskSize: 0
[ 286.128] RsvdFieldPosition: 0
[ 286.128] DirectColorModeInfo: 0
[ 286.128] PhysBasePtr: 0x0
[ 286.135] Mode: 182 (320x200)
[ 286.135] ModeAttributes: 0xbb
[ 286.135] WinAAttributes: 0x7
[ 286.135] WinBAttributes: 0x0
[ 286.135] WinGranularity: 64
[ 286.135] WinSize: 64
[ 286.135] WinASegment: 0xa000
[ 286.135] WinBSegment: 0xa000
[ 286.135] WinFuncPtr: 0xc00055c9
[ 286.135] BytesPerScanline: 320
[ 286.135] XResolution: 320
[ 286.135] YResolution: 200
[ 286.135] XCharSize: 8
[ 286.135] YCharSize: 8
[ 286.135] NumberOfPlanes: 1
[ 286.135] BitsPerPixel: 8
[ 286.135] NumberOfBanks: 1
[ 286.135] MemoryModel: 4
[ 286.135] BankSize: 0
[ 286.135] NumberOfImages: 254
[ 286.135] RedMaskSize: 0
[ 286.135] RedFieldPosition: 0
[ 286.135] GreenMaskSize: 0
[ 286.135] GreenFieldPosition: 0
[ 286.135] BlueMaskSize: 0
[ 286.135] BlueFieldPosition: 0
[ 286.135] RsvdMaskSize: 0
[ 286.135] RsvdFieldPosition: 0
[ 286.135] DirectColorModeInfo: 0
[ 286.135] PhysBasePtr: 0xec000000
[ 286.142] Mode: 10d (320x200)
[ 286.142] ModeAttributes: 0xbb
[ 286.142] WinAAttributes: 0x7
[ 286.142] WinBAttributes: 0x0
[ 286.142] WinGranularity: 64
[ 286.142] WinSize: 64
[ 286.142] WinASegment: 0xa000
[ 286.142] WinBSegment: 0xa000
[ 286.142] WinFuncPtr: 0xc00055c9
[ 286.142] BytesPerScanline: 640
[ 286.142] XResolution: 320
[ 286.142] YResolution: 200
[ 286.142] XCharSize: 8
[ 286.142] YCharSize: 8
[ 286.142] NumberOfPlanes: 1
[ 286.142] BitsPerPixel: 15
[ 286.142] NumberOfBanks: 1
[ 286.142] MemoryModel: 6
[ 286.142] BankSize: 0
[ 286.142] NumberOfImages: 127
[ 286.142] RedMaskSize: 5
[ 286.143] RedFieldPosition: 10
[ 286.143] GreenMaskSize: 5
[ 286.143] GreenFieldPosition: 5
[ 286.143] BlueMaskSize: 5
[ 286.143] BlueFieldPosition: 0
[ 286.143] RsvdMaskSize: 0
[ 286.143] RsvdFieldPosition: 0
[ 286.143] DirectColorModeInfo: 0
[ 286.143] PhysBasePtr: 0xec000000
[ 286.149] Mode: 10e (320x200)
[ 286.149] ModeAttributes: 0xbb
[ 286.149] WinAAttributes: 0x7
[ 286.149] WinBAttributes: 0x0
[ 286.150] WinGranularity: 64
[ 286.150] WinSize: 64
[ 286.150] WinASegment: 0xa000
[ 286.150] WinBSegment: 0xa000
[ 286.150] WinFuncPtr: 0xc00055c9
[ 286.150] BytesPerScanline: 640
[ 286.150] XResolution: 320
[ 286.150] YResolution: 200
[ 286.150] XCharSize: 8
[ 286.150] YCharSize: 8
[ 286.150] NumberOfPlanes: 1
[ 286.150] BitsPerPixel: 16
[ 286.150] NumberOfBanks: 1
[ 286.150] MemoryModel: 6
[ 286.150] BankSize: 0
[ 286.150] NumberOfImages: 127
[ 286.150] RedMaskSize: 5
[ 286.150] RedFieldPosition: 11
[ 286.150] GreenMaskSize: 6
[ 286.150] GreenFieldPosition: 5
[ 286.150] BlueMaskSize: 5
[ 286.150] BlueFieldPosition: 0
[ 286.150] RsvdMaskSize: 0
[ 286.150] RsvdFieldPosition: 0
[ 286.150] DirectColorModeInfo: 0
[ 286.150] PhysBasePtr: 0xec000000
[ 286.157] Mode: 10f (320x200)
[ 286.157] ModeAttributes: 0xbb
[ 286.157] WinAAttributes: 0x7
[ 286.157] WinBAttributes: 0x0
[ 286.157] WinGranularity: 64
[ 286.157] WinSize: 64
[ 286.157] WinASegment: 0xa000
[ 286.157] WinBSegment: 0xa000
[ 286.157] WinFuncPtr: 0xc00055c9
[ 286.157] BytesPerScanline: 960
[ 286.157] XResolution: 320
[ 286.157] YResolution: 200
[ 286.157] XCharSize: 8
[ 286.157] YCharSize: 8
[ 286.157] NumberOfPlanes: 1
[ 286.157] BitsPerPixel: 24
[ 286.157] NumberOfBanks: 1
[ 286.157] MemoryModel: 6
[ 286.157] BankSize: 0
[ 286.157] NumberOfImages: 84
[ 286.157] RedMaskSize: 8
[ 286.157] RedFieldPosition: 16
[ 286.157] GreenMaskSize: 8
[ 286.157] GreenFieldPosition: 8
[ 286.157] BlueMaskSize: 8
[ 286.157] BlueFieldPosition: 0
[ 286.157] RsvdMaskSize: 0
[ 286.157] RsvdFieldPosition: 0
[ 286.157] DirectColorModeInfo: 0
[ 286.157] PhysBasePtr: 0xec000000
[ 286.164] *Mode: 120 (320x200)
[ 286.164] ModeAttributes: 0xbb
[ 286.164] WinAAttributes: 0x7
[ 286.164] WinBAttributes: 0x0
[ 286.164] WinGranularity: 64
[ 286.164] WinSize: 64
[ 286.164] WinASegment: 0xa000
[ 286.164] WinBSegment: 0xa000
[ 286.164] WinFuncPtr: 0xc00055c9
[ 286.164] BytesPerScanline: 1280
[ 286.164] XResolution: 320
[ 286.164] YResolution: 200
[ 286.164] XCharSize: 8
[ 286.164] YCharSize: 8
[ 286.165] NumberOfPlanes: 1
[ 286.165] BitsPerPixel: 32
[ 286.165] NumberOfBanks: 1
[ 286.165] MemoryModel: 6
[ 286.165] BankSize: 0
[ 286.165] NumberOfImages: 63
[ 286.165] RedMaskSize: 8
[ 286.165] RedFieldPosition: 16
[ 286.165] GreenMaskSize: 8
[ 286.165] GreenFieldPosition: 8
[ 286.165] BlueMaskSize: 8
[ 286.165] BlueFieldPosition: 0
[ 286.165] RsvdMaskSize: 0
[ 286.165] RsvdFieldPosition: 0
[ 286.165] DirectColorModeInfo: 0
[ 286.165] PhysBasePtr: 0xec000000
[ 286.172] Mode: 192 (320x240)
[ 286.172] ModeAttributes: 0xbb
[ 286.172] WinAAttributes: 0x7
[ 286.172] WinBAttributes: 0x0
[ 286.172] WinGranularity: 64
[ 286.172] WinSize: 64
[ 286.172] WinASegment: 0xa000
[ 286.172] WinBSegment: 0xa000
[ 286.172] WinFuncPtr: 0xc00055c9
[ 286.172] BytesPerScanline: 320
[ 286.172] XResolution: 320
[ 286.172] YResolution: 240
[ 286.172] XCharSize: 8
[ 286.172] YCharSize: 8
[ 286.172] NumberOfPlanes: 1
[ 286.172] BitsPerPixel: 8
[ 286.172] NumberOfBanks: 1
[ 286.172] MemoryModel: 4
[ 286.172] BankSize: 0
[ 286.172] NumberOfImages: 127
[ 286.172] RedMaskSize: 0
[ 286.172] RedFieldPosition: 0
[ 286.172] GreenMaskSize: 0
[ 286.172] GreenFieldPosition: 0
[ 286.172] BlueMaskSize: 0
[ 286.172] BlueFieldPosition: 0
[ 286.172] RsvdMaskSize: 0
[ 286.172] RsvdFieldPosition: 0
[ 286.172] DirectColorModeInfo: 0
[ 286.172] PhysBasePtr: 0xec000000
[ 286.179] Mode: 193 (320x240)
[ 286.179] ModeAttributes: 0xbb
[ 286.179] WinAAttributes: 0x7
[ 286.179] WinBAttributes: 0x0
[ 286.179] WinGranularity: 64
[ 286.179] WinSize: 64
[ 286.179] WinASegment: 0xa000
[ 286.179] WinBSegment: 0xa000
[ 286.179] WinFuncPtr: 0xc00055c9
[ 286.179] BytesPerScanline: 640
[ 286.179] XResolution: 320
[ 286.180] YResolution: 240
[ 286.180] XCharSize: 8
[ 286.180] YCharSize: 8
[ 286.180] NumberOfPlanes: 1
[ 286.180] BitsPerPixel: 15
[ 286.180] NumberOfBanks: 1
[ 286.180] MemoryModel: 6
[ 286.180] BankSize: 0
[ 286.180] NumberOfImages: 84
[ 286.180] RedMaskSize: 5
[ 286.180] RedFieldPosition: 10
[ 286.180] GreenMaskSize: 5
[ 286.180] GreenFieldPosition: 5
[ 286.180] BlueMaskSize: 5
[ 286.180] BlueFieldPosition: 0
[ 286.180] RsvdMaskSize: 0
[ 286.180] RsvdFieldPosition: 0
[ 286.180] DirectColorModeInfo: 0
[ 286.180] PhysBasePtr: 0xec000000
[ 286.187] Mode: 194 (320x240)
[ 286.187] ModeAttributes: 0xbb
[ 286.187] WinAAttributes: 0x7
[ 286.187] WinBAttributes: 0x0
[ 286.187] WinGranularity: 64
[ 286.187] WinSize: 64
[ 286.187] WinASegment: 0xa000
[ 286.187] WinBSegment: 0xa000
[ 286.187] WinFuncPtr: 0xc00055c9
[ 286.187] BytesPerScanline: 640
[ 286.187] XResolution: 320
[ 286.187] YResolution: 240
[ 286.187] XCharSize: 8
[ 286.187] YCharSize: 8
[ 286.187] NumberOfPlanes: 1
[ 286.187] BitsPerPixel: 16
[ 286.187] NumberOfBanks: 1
[ 286.187] MemoryModel: 6
[ 286.187] BankSize: 0
[ 286.187] NumberOfImages: 84
[ 286.187] RedMaskSize: 5
[ 286.187] RedFieldPosition: 11
[ 286.187] GreenMaskSize: 6
[ 286.187] GreenFieldPosition: 5
[ 286.187] BlueMaskSize: 5
[ 286.187] BlueFieldPosition: 0
[ 286.187] RsvdMaskSize: 0
[ 286.187] RsvdFieldPosition: 0
[ 286.187] DirectColorModeInfo: 0
[ 286.187] PhysBasePtr: 0xec000000
[ 286.194] Mode: 195 (320x240)
[ 286.194] ModeAttributes: 0xbb
[ 286.194] WinAAttributes: 0x7
[ 286.194] WinBAttributes: 0x0
[ 286.194] WinGranularity: 64
[ 286.194] WinSize: 64
[ 286.194] WinASegment: 0xa000
[ 286.195] WinBSegment: 0xa000
[ 286.195] WinFuncPtr: 0xc00055c9
[ 286.195] BytesPerScanline: 960
[ 286.195] XResolution: 320
[ 286.195] YResolution: 240
[ 286.195] XCharSize: 8
[ 286.195] YCharSize: 8
[ 286.195] NumberOfPlanes: 1
[ 286.195] BitsPerPixel: 24
[ 286.195] NumberOfBanks: 1
[ 286.195] MemoryModel: 6
[ 286.195] BankSize: 0
[ 286.195] NumberOfImages: 63
[ 286.195] RedMaskSize: 8
[ 286.195] RedFieldPosition: 16
[ 286.195] GreenMaskSize: 8
[ 286.195] GreenFieldPosition: 8
[ 286.195] BlueMaskSize: 8
[ 286.195] BlueFieldPosition: 0
[ 286.195] RsvdMaskSize: 0
[ 286.195] RsvdFieldPosition: 0
[ 286.195] DirectColorModeInfo: 0
[ 286.195] PhysBasePtr: 0xec000000
[ 286.202] *Mode: 196 (320x240)
[ 286.202] ModeAttributes: 0xbb
[ 286.202] WinAAttributes: 0x7
[ 286.202] WinBAttributes: 0x0
[ 286.202] WinGranularity: 64
[ 286.202] WinSize: 64
[ 286.202] WinASegment: 0xa000
[ 286.202] WinBSegment: 0xa000
[ 286.202] WinFuncPtr: 0xc00055c9
[ 286.202] BytesPerScanline: 1280
[ 286.202] XResolution: 320
[ 286.202] YResolution: 240
[ 286.202] XCharSize: 8
[ 286.202] YCharSize: 8
[ 286.202] NumberOfPlanes: 1
[ 286.202] BitsPerPixel: 32
[ 286.202] NumberOfBanks: 1
[ 286.202] MemoryModel: 6
[ 286.202] BankSize: 0
[ 286.202] NumberOfImages: 50
[ 286.202] RedMaskSize: 8
[ 286.202] RedFieldPosition: 16
[ 286.202] GreenMaskSize: 8
[ 286.202] GreenFieldPosition: 8
[ 286.202] BlueMaskSize: 8
[ 286.202] BlueFieldPosition: 0
[ 286.202] RsvdMaskSize: 0
[ 286.202] RsvdFieldPosition: 0
[ 286.203] DirectColorModeInfo: 0
[ 286.203] PhysBasePtr: 0xec000000
[ 286.219] Mode: 1a2 (400x300)
[ 286.219] ModeAttributes: 0xbb
[ 286.219] WinAAttributes: 0x7
[ 286.219] WinBAttributes: 0x0
[ 286.219] WinGranularity: 64
[ 286.219] WinSize: 64
[ 286.219] WinASegment: 0xa000
[ 286.219] WinBSegment: 0xa000
[ 286.219] WinFuncPtr: 0xc00055c9
[ 286.219] BytesPerScanline: 400
[ 286.219] XResolution: 400
[ 286.219] YResolution: 300
[ 286.219] XCharSize: 8
[ 286.219] YCharSize: 16
[ 286.219] NumberOfPlanes: 1
[ 286.219] BitsPerPixel: 8
[ 286.219] NumberOfBanks: 1
[ 286.219] MemoryModel: 4
[ 286.219] BankSize: 0
[ 286.219] NumberOfImages: 127
[ 286.219] RedMaskSize: 0
[ 286.219] RedFieldPosition: 0
[ 286.219] GreenMaskSize: 0
[ 286.219] GreenFieldPosition: 0
[ 286.219] BlueMaskSize: 0
[ 286.219] BlueFieldPosition: 0
[ 286.219] RsvdMaskSize: 0
[ 286.220] RsvdFieldPosition: 0
[ 286.220] DirectColorModeInfo: 0
[ 286.220] PhysBasePtr: 0xec000000
286.236] Mode: 1a3 (400x300)
[ 286.236] ModeAttributes: 0xbb
[ 286.236] WinAAttributes: 0x7
[ 286.236] WinBAttributes: 0x0
[ 286.236] WinGranularity: 64
[ 286.236] WinSize: 64
[ 286.236] WinASegment: 0xa000
[ 286.236] WinBSegment: 0xa000
[ 286.236] WinFuncPtr: 0xc00055c9
[ 286.236] BytesPerScanline: 800
[ 286.236] XResolution: 400
[ 286.236] YResolution: 300
[ 286.236] XCharSize: 8
[ 286.236] YCharSize: 16
[ 286.236] NumberOfPlanes: 1
[ 286.236] BitsPerPixel: 15
[ 286.236] NumberOfBanks: 1
[ 286.236] MemoryModel: 6
[ 286.236] BankSize: 0
[ 286.236] NumberOfImages: 63
[ 286.236] RedMaskSize: 5
[ 286.236] RedFieldPosition: 10
[ 286.236] GreenMaskSize: 5
[ 286.236] GreenFieldPosition: 5
[ 286.236] BlueMaskSize: 5
[ 286.236] BlueFieldPosition: 0
[ 286.236] RsvdMaskSize: 0
[ 286.236] RsvdFieldPosition: 0
[ 286.237] DirectColorModeInfo: 0
[ 286.237] PhysBasePtr: 0xec000000
[ 286.253] Mode: 1a4 (400x300)
[ 286.253] ModeAttributes: 0xbb
[ 286.253] WinAAttributes: 0x7
[ 286.253] WinBAttributes: 0x0
[ 286.253] WinGranularity: 64
[ 286.253] WinSize: 64
[ 286.253] WinASegment: 0xa000
[ 286.253] WinBSegment: 0xa000
[ 286.253] WinFuncPtr: 0xc00055c9
[ 286.253] BytesPerScanline: 800
[ 286.253] XResolution: 400
[ 286.253] YResolution: 300
[ 286.253] XCharSize: 8
[ 286.253] YCharSize: 16
[ 286.253] NumberOfPlanes: 1
[ 286.253] BitsPerPixel: 16
[ 286.253] NumberOfBanks: 1
[ 286.253] MemoryModel: 6
[ 286.253] BankSize: 0
[ 286.253] NumberOfImages: 63
[ 286.253] RedMaskSize: 5
[ 286.253] RedFieldPosition: 11
[ 286.253] GreenMaskSize: 6
[ 286.253] GreenFieldPosition: 5
[ 286.253] BlueMaskSize: 5
[ 286.253] BlueFieldPosition: 0
[ 286.253] RsvdMaskSize: 0
[ 286.253] RsvdFieldPosition: 0
[ 286.254] DirectColorModeInfo: 0
[ 286.254] PhysBasePtr: 0xec000000
[ 286.270] Mode: 1a5 (400x300)
[ 286.270] ModeAttributes: 0xbb
[ 286.270] WinAAttributes: 0x7
[ 286.270] WinBAttributes: 0x0
[ 286.270] WinGranularity: 64
[ 286.270] WinSize: 64
[ 286.270] WinASegment: 0xa000
[ 286.270] WinBSegment: 0xa000
[ 286.270] WinFuncPtr: 0xc00055c9
[ 286.270] BytesPerScanline: 1200
[ 286.270] XResolution: 400
[ 286.270] YResolution: 300
[ 286.270] XCharSize: 8
[ 286.270] YCharSize: 16
[ 286.270] NumberOfPlanes: 1
[ 286.270] BitsPerPixel: 24
[ 286.270] NumberOfBanks: 1
[ 286.270] MemoryModel: 6
[ 286.270] BankSize: 0
[ 286.270] NumberOfImages: 41
[ 286.270] RedMaskSize: 8
[ 286.270] RedFieldPosition: 16
[ 286.270] GreenMaskSize: 8
[ 286.270] GreenFieldPosition: 8
[ 286.270] BlueMaskSize: 8
[ 286.270] BlueFieldPosition: 0
[ 286.270] RsvdMaskSize: 0
[ 286.270] RsvdFieldPosition: 0
[ 286.270] DirectColorModeInfo: 0
[ 286.270] PhysBasePtr: 0xec000000
[ 286.287] *Mode: 1a6 (400x300)
[ 286.287] ModeAttributes: 0xbb
[ 286.287] WinAAttributes: 0x7
[ 286.287] WinBAttributes: 0x0
[ 286.287] WinGranularity: 64
[ 286.287] WinSize: 64
[ 286.287] WinASegment: 0xa000
[ 286.287] WinBSegment: 0xa000
[ 286.287] WinFuncPtr: 0xc00055c9
[ 286.287] BytesPerScanline: 1600
[ 286.287] XResolution: 400
[ 286.287] YResolution: 300
[ 286.287] XCharSize: 8
[ 286.287] YCharSize: 16
[ 286.287] NumberOfPlanes: 1
[ 286.287] BitsPerPixel: 32
[ 286.287] NumberOfBanks: 1
[ 286.287] MemoryModel: 6
[ 286.287] BankSize: 0
[ 286.287] NumberOfImages: 31
[ 286.287] RedMaskSize: 8
[ 286.287] RedFieldPosition: 16
[ 286.287] GreenMaskSize: 8
[ 286.287] GreenFieldPosition: 8
[ 286.287] BlueMaskSize: 8
[ 286.287] BlueFieldPosition: 0
[ 286.287] RsvdMaskSize: 0
[ 286.287] RsvdFieldPosition: 0
[ 286.287] DirectColorModeInfo: 0
[ 286.287] PhysBasePtr: 0xec000000
[ 286.295] Mode: 1b2 (512x384)
[ 286.295] ModeAttributes: 0xbb
[ 286.295] WinAAttributes: 0x7
[ 286.295] WinBAttributes: 0x0
[ 286.295] WinGranularity: 64
[ 286.295] WinSize: 64
[ 286.295] WinASegment: 0xa000
[ 286.295] WinBSegment: 0xa000
[ 286.295] WinFuncPtr: 0xc00055c9
[ 286.295] BytesPerScanline: 512
[ 286.295] XResolution: 512
[ 286.295] YResolution: 384
[ 286.295] XCharSize: 8
[ 286.295] YCharSize: 16
[ 286.295] NumberOfPlanes: 1
[ 286.295] BitsPerPixel: 8
[ 286.295] NumberOfBanks: 1
[ 286.295] MemoryModel: 4
[ 286.295] BankSize: 0
[ 286.295] NumberOfImages: 84
[ 286.295] RedMaskSize: 0
[ 286.295] RedFieldPosition: 0
[ 286.295] GreenMaskSize: 0
[ 286.295] GreenFieldPosition: 0
[ 286.295] BlueMaskSize: 0
[ 286.295] BlueFieldPosition: 0
[ 286.295] RsvdMaskSize: 0
[ 286.295] RsvdFieldPosition: 0
[ 286.295] DirectColorModeInfo: 0
[ 286.295] PhysBasePtr: 0xec000000
[ 286.302] Mode: 1b3 (512x384)
[ 286.303] ModeAttributes: 0xbb
[ 286.303] WinAAttributes: 0x7
[ 286.303] WinBAttributes: 0x0
[ 286.303] WinGranularity: 64
[ 286.303] WinSize: 64
[ 286.303] WinASegment: 0xa000
[ 286.303] WinBSegment: 0xa000
[ 286.303] WinFuncPtr: 0xc00055c9
[ 286.303] BytesPerScanline: 1024
[ 286.303] XResolution: 512
[ 286.303] YResolution: 384
[ 286.303] XCharSize: 8
[ 286.303] YCharSize: 16
[ 286.303] NumberOfPlanes: 1
[ 286.303] BitsPerPixel: 15
[ 286.303] NumberOfBanks: 1
[ 286.303] MemoryModel: 6
[ 286.303] BankSize: 0
[ 286.303] NumberOfImages: 41
[ 286.303] RedMaskSize: 5
[ 286.303] RedFieldPosition: 10
[ 286.303] GreenMaskSize: 5
[ 286.303] GreenFieldPosition: 5
[ 286.303] BlueMaskSize: 5
[ 286.303] BlueFieldPosition: 0
[ 286.303] RsvdMaskSize: 0
[ 286.303] RsvdFieldPosition: 0
[ 286.303] DirectColorModeInfo: 0
[ 286.303] PhysBasePtr: 0xec000000
[ 286.310] Mode: 1b4 (512x384)
[ 286.310] ModeAttributes: 0xbb
[ 286.310] WinAAttributes: 0x7
[ 286.310] WinBAttributes: 0x0
[ 286.310] WinGranularity: 64
[ 286.311] WinSize: 64
[ 286.311] WinASegment: 0xa000
[ 286.311] WinBSegment: 0xa000
[ 286.311] WinFuncPtr: 0xc00055c9
[ 286.311] BytesPerScanline: 1024
[ 286.311] XResolution: 512
[ 286.311] YResolution: 384
[ 286.311] XCharSize: 8
[ 286.311] YCharSize: 16
[ 286.311] NumberOfPlanes: 1
[ 286.311] BitsPerPixel: 16
[ 286.311] NumberOfBanks: 1
[ 286.311] MemoryModel: 6
[ 286.311] BankSize: 0
[ 286.311] NumberOfImages: 41
[ 286.311] RedMaskSize: 5
[ 286.311] RedFieldPosition: 11
[ 286.311] GreenMaskSize: 6
[ 286.311] GreenFieldPosition: 5
[ 286.311] BlueMaskSize: 5
[ 286.311] BlueFieldPosition: 0
[ 286.311] RsvdMaskSize: 0
[ 286.311] RsvdFieldPosition: 0
[ 286.311] DirectColorModeInfo: 0
[ 286.311] PhysBasePtr: 0xec000000
[ 286.318] Mode: 1b5 (512x384)
[ 286.318] ModeAttributes: 0xbb
[ 286.318] WinAAttributes: 0x7
[ 286.318] WinBAttributes: 0x0
[ 286.318] WinGranularity: 64
[ 286.318] WinSize: 64
[ 286.318] WinASegment: 0xa000
[ 286.318] WinBSegment: 0xa000
[ 286.318] WinFuncPtr: 0xc00055c9
[ 286.318] BytesPerScanline: 1536
[ 286.318] XResolution: 512
[ 286.318] YResolution: 384
[ 286.319] XCharSize: 8
[ 286.319] YCharSize: 16
[ 286.319] NumberOfPlanes: 1
[ 286.319] BitsPerPixel: 24
[ 286.319] NumberOfBanks: 1
[ 286.319] MemoryModel: 6
[ 286.319] BankSize: 0
[ 286.319] NumberOfImages: 27
[ 286.319] RedMaskSize: 8
[ 286.319] RedFieldPosition: 16
[ 286.319] GreenMaskSize: 8
[ 286.319] GreenFieldPosition: 8
[ 286.319] BlueMaskSize: 8
[ 286.319] BlueFieldPosition: 0
[ 286.319] RsvdMaskSize: 0
[ 286.319] RsvdFieldPosition: 0
[ 286.319] DirectColorModeInfo: 0
[ 286.319] PhysBasePtr: 0xec000000
[ 286.326] *Mode: 1b6 (512x384)
[ 286.326] ModeAttributes: 0xbb
[ 286.326] WinAAttributes: 0x7
[ 286.326] WinBAttributes: 0x0
[ 286.326] WinGranularity: 64
[ 286.326] WinSize: 64
[ 286.326] WinASegment: 0xa000
[ 286.326] WinBSegment: 0xa000
[ 286.326] WinFuncPtr: 0xc00055c9
[ 286.326] BytesPerScanline: 2048
[ 286.326] XResolution: 512
[ 286.326] YResolution: 384
[ 286.326] XCharSize: 8
[ 286.326] YCharSize: 16
[ 286.326] NumberOfPlanes: 1
[ 286.326] BitsPerPixel: 32
[ 286.326] NumberOfBanks: 1
[ 286.326] MemoryModel: 6
[ 286.326] BankSize: 0
[ 286.326] NumberOfImages: 20
[ 286.326] RedMaskSize: 8
[ 286.326] RedFieldPosition: 16
[ 286.327] GreenMaskSize: 8
[ 286.327] GreenFieldPosition: 8
[ 286.327] BlueMaskSize: 8
[ 286.327] BlueFieldPosition: 0
[ 286.327] RsvdMaskSize: 0
[ 286.327] RsvdFieldPosition: 0
[ 286.327] DirectColorModeInfo: 0
[ 286.327] PhysBasePtr: 0xec000000
[ 286.334] Mode: 1c2 (640x350)
[ 286.334] ModeAttributes: 0xbb
[ 286.334] WinAAttributes: 0x7
[ 286.334] WinBAttributes: 0x0
[ 286.334] WinGranularity: 64
[ 286.334] WinSize: 64
[ 286.334] WinASegment: 0xa000
[ 286.334] WinBSegment: 0xa000
[ 286.334] WinFuncPtr: 0xc00055c9
[ 286.334] BytesPerScanline: 640
[ 286.334] XResolution: 640
[ 286.334] YResolution: 350
[ 286.334] XCharSize: 8
[ 286.334] YCharSize: 14
[ 286.334] NumberOfPlanes: 1
[ 286.334] BitsPerPixel: 8
[ 286.334] NumberOfBanks: 1
[ 286.334] MemoryModel: 4
[ 286.334] BankSize: 0
[ 286.334] NumberOfImages: 63
[ 286.334] RedMaskSize: 0
[ 286.335] RedFieldPosition: 0
[ 286.335] GreenMaskSize: 0
[ 286.335] GreenFieldPosition: 0
[ 286.335] BlueMaskSize: 0
[ 286.335] BlueFieldPosition: 0
[ 286.335] RsvdMaskSize: 0
[ 286.335] RsvdFieldPosition: 0
[ 286.335] DirectColorModeInfo: 0
[ 286.335] PhysBasePtr: 0xec000000
[ 286.342] Mode: 1c3 (640x350)
[ 286.342] ModeAttributes: 0xbb
[ 286.342] WinAAttributes: 0x7
[ 286.342] WinBAttributes: 0x0
[ 286.342] WinGranularity: 64
[ 286.342] WinSize: 64
[ 286.342] WinASegment: 0xa000
[ 286.342] WinBSegment: 0xa000
[ 286.342] WinFuncPtr: 0xc00055c9
[ 286.342] BytesPerScanline: 1280
[ 286.342] XResolution: 640
[ 286.342] YResolution: 350
[ 286.342] XCharSize: 8
[ 286.342] YCharSize: 14
[ 286.342] NumberOfPlanes: 1
[ 286.342] BitsPerPixel: 15
[ 286.342] NumberOfBanks: 1
[ 286.342] MemoryModel: 6
[ 286.342] BankSize: 0
[ 286.342] NumberOfImages: 35
[ 286.343] RedMaskSize: 5
[ 286.343] RedFieldPosition: 10
[ 286.343] GreenMaskSize: 5
[ 286.343] GreenFieldPosition: 5
[ 286.343] BlueMaskSize: 5
[ 286.343] BlueFieldPosition: 0
[ 286.343] RsvdMaskSize: 0
[ 286.343] RsvdFieldPosition: 0
[ 286.343] DirectColorModeInfo: 0
[ 286.343] PhysBasePtr: 0xec000000
[ 286.350] Mode: 1c4 (640x350)
[ 286.350] ModeAttributes: 0xbb
[ 286.350] WinAAttributes: 0x7
[ 286.350] WinBAttributes: 0x0
[ 286.350] WinGranularity: 64
[ 286.350] WinSize: 64
[ 286.350] WinASegment: 0xa000
[ 286.350] WinBSegment: 0xa000
[ 286.350] WinFuncPtr: 0xc00055c9
[ 286.350] BytesPerScanline: 1280
[ 286.350] XResolution: 640
[ 286.350] YResolution: 350
[ 286.350] XCharSize: 8
[ 286.350] YCharSize: 14
[ 286.350] NumberOfPlanes: 1
[ 286.350] BitsPerPixel: 16
[ 286.350] NumberOfBanks: 1
[ 286.350] MemoryModel: 6
[ 286.350] BankSize: 0
[ 286.350] NumberOfImages: 35
[ 286.351] RedMaskSize: 5
[ 286.351] RedFieldPosition: 11
[ 286.351] GreenMaskSize: 6
[ 286.351] GreenFieldPosition: 5
[ 286.351] BlueMaskSize: 5
[ 286.351] BlueFieldPosition: 0
[ 286.351] RsvdMaskSize: 0
[ 286.351] RsvdFieldPosition: 0
[ 286.351] DirectColorModeInfo: 0
[ 286.351] PhysBasePtr: 0xec000000
[ 286.358] Mode: 1c5 (640x350)
[ 286.358] ModeAttributes: 0xbb
[ 286.358] WinAAttributes: 0x7
[ 286.358] WinBAttributes: 0x0
[ 286.358] WinGranularity: 64
[ 286.358] WinSize: 64
[ 286.358] WinASegment: 0xa000
[ 286.358] WinBSegment: 0xa000
[ 286.358] WinFuncPtr: 0xc00055c9
[ 286.358] BytesPerScanline: 1920
[ 286.358] XResolution: 640
[ 286.358] YResolution: 350
[ 286.358] XCharSize: 8
[ 286.358] YCharSize: 14
[ 286.358] NumberOfPlanes: 1
[ 286.358] BitsPerPixel: 24
[ 286.358] NumberOfBanks: 1
[ 286.358] MemoryModel: 6
[ 286.358] BankSize: 0
[ 286.358] NumberOfImages: 22
[ 286.358] RedMaskSize: 8
[ 286.359] RedFieldPosition: 16
[ 286.359] GreenMaskSize: 8
[ 286.359] GreenFieldPosition: 8
[ 286.359] BlueMaskSize: 8
[ 286.359] BlueFieldPosition: 0
[ 286.359] RsvdMaskSize: 0
[ 286.359] RsvdFieldPosition: 0
[ 286.359] DirectColorModeInfo: 0
[ 286.359] PhysBasePtr: 0xec000000
[ 286.366] *Mode: 1c6 (640x350)
[ 286.366] ModeAttributes: 0xbb
[ 286.366] WinAAttributes: 0x7
[ 286.366] WinBAttributes: 0x0
[ 286.366] WinGranularity: 64
[ 286.366] WinSize: 64
[ 286.366] WinASegment: 0xa000
[ 286.366] WinBSegment: 0xa000
[ 286.366] WinFuncPtr: 0xc00055c9
[ 286.366] BytesPerScanline: 2560
[ 286.366] XResolution: 640
[ 286.366] YResolution: 350
[ 286.366] XCharSize: 8
[ 286.366] YCharSize: 14
[ 286.366] NumberOfPlanes: 1
[ 286.366] BitsPerPixel: 32
[ 286.366] NumberOfBanks: 1
[ 286.366] MemoryModel: 6
[ 286.366] BankSize: 0
[ 286.366] NumberOfImages: 17
[ 286.367] RedMaskSize: 8
[ 286.367] RedFieldPosition: 16
[ 286.367] GreenMaskSize: 8
[ 286.367] GreenFieldPosition: 8
[ 286.367] BlueMaskSize: 8
[ 286.367] BlueFieldPosition: 0
[ 286.367] RsvdMaskSize: 0
[ 286.367] RsvdFieldPosition: 0
[ 286.367] DirectColorModeInfo: 0
[ 286.367] PhysBasePtr: 0xec000000
[ 286.374] Mode: 100 (640x400)
[ 286.374] ModeAttributes: 0xbb
[ 286.374] WinAAttributes: 0x7
[ 286.374] WinBAttributes: 0x0
[ 286.374] WinGranularity: 64
[ 286.374] WinSize: 64
[ 286.374] WinASegment: 0xa000
[ 286.374] WinBSegment: 0xa000
[ 286.374] WinFuncPtr: 0xc00055c9
[ 286.374] BytesPerScanline: 640
[ 286.374] XResolution: 640
[ 286.374] YResolution: 400
[ 286.374] XCharSize: 8
[ 286.374] YCharSize: 16
[ 286.374] NumberOfPlanes: 1
[ 286.375] BitsPerPixel: 8
[ 286.375] NumberOfBanks: 1
[ 286.375] MemoryModel: 4
[ 286.375] BankSize: 0
[ 286.375] NumberOfImages: 63
[ 286.375] RedMaskSize: 0
[ 286.375] RedFieldPosition: 0
[ 286.375] GreenMaskSize: 0
[ 286.375] GreenFieldPosition: 0
[ 286.375] BlueMaskSize: 0
[ 286.375] BlueFieldPosition: 0
[ 286.375] RsvdMaskSize: 0
[ 286.375] RsvdFieldPosition: 0
[ 286.375] DirectColorModeInfo: 0
[ 286.375] PhysBasePtr: 0xec000000
[ 286.382] Mode: 183 (640x400)
[ 286.382] ModeAttributes: 0xbb
[ 286.382] WinAAttributes: 0x7
[ 286.382] WinBAttributes: 0x0
[ 286.382] WinGranularity: 64
[ 286.383] WinSize: 64
[ 286.383] WinASegment: 0xa000
[ 286.383] WinBSegment: 0xa000
[ 286.383] WinFuncPtr: 0xc00055c9
[ 286.383] BytesPerScanline: 1280
[ 286.383] XResolution: 640
[ 286.383] YResolution: 400
[ 286.383] XCharSize: 8
[ 286.383] YCharSize: 16
[ 286.383] NumberOfPlanes: 1
[ 286.383] BitsPerPixel: 15
[ 286.383] NumberOfBanks: 1
[ 286.383] MemoryModel: 6
[ 286.383] BankSize: 0
[ 286.383] NumberOfImages: 31
[ 286.383] RedMaskSize: 5
[ 286.383] RedFieldPosition: 10
[ 286.383] GreenMaskSize: 5
[ 286.383] GreenFieldPosition: 5
[ 286.383] BlueMaskSize: 5
[ 286.383] BlueFieldPosition: 0
[ 286.383] RsvdMaskSize: 0
[ 286.383] RsvdFieldPosition: 0
[ 286.383] DirectColorModeInfo: 0
[ 286.383] PhysBasePtr: 0xec000000
[ 286.391] Mode: 184 (640x400)
[ 286.391] ModeAttributes: 0xbb
[ 286.391] WinAAttributes: 0x7
[ 286.391] WinBAttributes: 0x0
[ 286.391] WinGranularity: 64
[ 286.391] WinSize: 64
[ 286.391] WinASegment: 0xa000
[ 286.391] WinBSegment: 0xa000
[ 286.391] WinFuncPtr: 0xc00055c9
[ 286.391] BytesPerScanline: 1280
[ 286.391] XResolution: 640
[ 286.391] YResolution: 400
[ 286.391] XCharSize: 8
[ 286.391] YCharSize: 16
[ 286.391] NumberOfPlanes: 1
[ 286.391] BitsPerPixel: 16
[ 286.391] NumberOfBanks: 1
[ 286.391] MemoryModel: 6
[ 286.391] BankSize: 0
[ 286.391] NumberOfImages: 31
[ 286.391] RedMaskSize: 5
[ 286.391] RedFieldPosition: 11
[ 286.391] GreenMaskSize: 6
[ 286.391] GreenFieldPosition: 5
[ 286.391] BlueMaskSize: 5
[ 286.391] BlueFieldPosition: 0
[ 286.391] RsvdMaskSize: 0
[ 286.391] RsvdFieldPosition: 0
[ 286.391] DirectColorModeInfo: 0
[ 286.391] PhysBasePtr: 0xec000000
[ 286.399] Mode: 185 (640x400)
[ 286.399] ModeAttributes: 0xbb
[ 286.399] WinAAttributes: 0x7
[ 286.399] WinBAttributes: 0x0
[ 286.399] WinGranularity: 64
[ 286.399] WinSize: 64
[ 286.399] WinASegment: 0xa000
[ 286.399] WinBSegment: 0xa000
[ 286.399] WinFuncPtr: 0xc00055c9
[ 286.399] BytesPerScanline: 1920
[ 286.399] XResolution: 640
[ 286.399] YResolution: 400
[ 286.399] XCharSize: 8
[ 286.399] YCharSize: 16
[ 286.399] NumberOfPlanes: 1
[ 286.399] BitsPerPixel: 24
[ 286.399] NumberOfBanks: 1
[ 286.399] MemoryModel: 6
[ 286.399] BankSize: 0
[ 286.399] NumberOfImages: 20
[ 286.399] RedMaskSize: 8
[ 286.399] RedFieldPosition: 16
[ 286.399] GreenMaskSize: 8
[ 286.399] GreenFieldPosition: 8
[ 286.399] BlueMaskSize: 8
[ 286.399] BlueFieldPosition: 0
[ 286.399] RsvdMaskSize: 0
[ 286.399] RsvdFieldPosition: 0
[ 286.399] DirectColorModeInfo: 0
[ 286.399] PhysBasePtr: 0xec000000
[ 286.407] *Mode: 186 (640x400)
[ 286.407] ModeAttributes: 0xbb
[ 286.407] WinAAttributes: 0x7
[ 286.407] WinBAttributes: 0x0
[ 286.407] WinGranularity: 64
[ 286.407] WinSize: 64
[ 286.407] WinASegment: 0xa000
[ 286.407] WinBSegment: 0xa000
[ 286.407] WinFuncPtr: 0xc00055c9
[ 286.407] BytesPerScanline: 2560
[ 286.407] XResolution: 640
[ 286.407] YResolution: 400
[ 286.407] XCharSize: 8
[ 286.407] YCharSize: 16
[ 286.407] NumberOfPlanes: 1
[ 286.407] BitsPerPixel: 32
[ 286.407] NumberOfBanks: 1
[ 286.407] MemoryModel: 6
[ 286.407] BankSize: 0
[ 286.407] NumberOfImages: 15
[ 286.407] RedMaskSize: 8
[ 286.407] RedFieldPosition: 16
[ 286.407] GreenMaskSize: 8
[ 286.407] GreenFieldPosition: 8
[ 286.407] BlueMaskSize: 8
[ 286.407] BlueFieldPosition: 0
[ 286.407] RsvdMaskSize: 0
[ 286.407] RsvdFieldPosition: 0
[ 286.407] DirectColorModeInfo: 0
[ 286.407] PhysBasePtr: 0xec000000
[ 286.423] Mode: 101 (640x480)
[ 286.423] ModeAttributes: 0xbb
[ 286.423] WinAAttributes: 0x7
[ 286.423] WinBAttributes: 0x0
[ 286.423] WinGranularity: 64
[ 286.423] WinSize: 64
[ 286.423] WinASegment: 0xa000
[ 286.423] WinBSegment: 0xa000
[ 286.423] WinFuncPtr: 0xc00055c9
[ 286.423] BytesPerScanline: 640
[ 286.423] XResolution: 640
[ 286.424] YResolution: 480
[ 286.424] XCharSize: 8
[ 286.424] YCharSize: 16
[ 286.424] NumberOfPlanes: 1
[ 286.424] BitsPerPixel: 8
[ 286.424] NumberOfBanks: 1
[ 286.424] MemoryModel: 4
[ 286.424] BankSize: 0
[ 286.424] NumberOfImages: 50
[ 286.424] RedMaskSize: 0
[ 286.424] RedFieldPosition: 0
[ 286.424] GreenMaskSize: 0
[ 286.424] GreenFieldPosition: 0
[ 286.424] BlueMaskSize: 0
[ 286.424] BlueFieldPosition: 0
[ 286.424] RsvdMaskSize: 0
[ 286.424] RsvdFieldPosition: 0
[ 286.424] DirectColorModeInfo: 0
[ 286.424] PhysBasePtr: 0xec000000
[ 286.440] Mode: 110 (640x480)
[ 286.440] ModeAttributes: 0xbb
[ 286.440] WinAAttributes: 0x7
[ 286.440] WinBAttributes: 0x0
[ 286.440] WinGranularity: 64
[ 286.440] WinSize: 64
[ 286.440] WinASegment: 0xa000
[ 286.440] WinBSegment: 0xa000
[ 286.440] WinFuncPtr: 0xc00055c9
[ 286.440] BytesPerScanline: 1280
[ 286.440] XResolution: 640
[ 286.440] YResolution: 480
[ 286.440] XCharSize: 8
[ 286.440] YCharSize: 16
[ 286.440] NumberOfPlanes: 1
[ 286.440] BitsPerPixel: 15
[ 286.440] NumberOfBanks: 1
[ 286.440] MemoryModel: 6
[ 286.440] BankSize: 0
[ 286.440] NumberOfImages: 24
[ 286.440] RedMaskSize: 5
[ 286.440] RedFieldPosition: 10
[ 286.440] GreenMaskSize: 5
[ 286.440] GreenFieldPosition: 5
[ 286.440] BlueMaskSize: 5
[ 286.440] BlueFieldPosition: 0
[ 286.440] RsvdMaskSize: 0
[ 286.440] RsvdFieldPosition: 0
[ 286.440] DirectColorModeInfo: 0
[ 286.440] PhysBasePtr: 0xec000000
[ 286.456] Mode: 111 (640x480)
[ 286.456] ModeAttributes: 0xbb
[ 286.456] WinAAttributes: 0x7
[ 286.456] WinBAttributes: 0x0
[ 286.456] WinGranularity: 64
[ 286.456] WinSize: 64
[ 286.456] WinASegment: 0xa000
[ 286.456] WinBSegment: 0xa000
[ 286.456] WinFuncPtr: 0xc00055c9
[ 286.456] BytesPerScanline: 1280
[ 286.456] XResolution: 640
[ 286.456] YResolution: 480
[ 286.456] XCharSize: 8
[ 286.456] YCharSize: 16
[ 286.456] NumberOfPlanes: 1
[ 286.457] BitsPerPixel: 16
[ 286.457] NumberOfBanks: 1
[ 286.457] MemoryModel: 6
[ 286.457] BankSize: 0
[ 286.457] NumberOfImages: 24
[ 286.457] RedMaskSize: 5
[ 286.457] RedFieldPosition: 11
[ 286.457] GreenMaskSize: 6
[ 286.457] GreenFieldPosition: 5
[ 286.457] BlueMaskSize: 5
[ 286.457] BlueFieldPosition: 0
[ 286.457] RsvdMaskSize: 0
[ 286.457] RsvdFieldPosition: 0
[ 286.457] DirectColorModeInfo: 0
[ 286.457] PhysBasePtr: 0xec000000
[ 286.473] Mode: 112 (640x480)
[ 286.473] ModeAttributes: 0xbb
[ 286.473] WinAAttributes: 0x7
[ 286.473] WinBAttributes: 0x0
[ 286.473] WinGranularity: 64
[ 286.473] WinSize: 64
[ 286.473] WinASegment: 0xa000
[ 286.473] WinBSegment: 0xa000
[ 286.473] WinFuncPtr: 0xc00055c9
[ 286.473] BytesPerScanline: 1920
[ 286.473] XResolution: 640
[ 286.473] YResolution: 480
[ 286.473] XCharSize: 8
[ 286.473] YCharSize: 16
[ 286.473] NumberOfPlanes: 1
[ 286.473] BitsPerPixel: 24
[ 286.473] NumberOfBanks: 1
[ 286.473] MemoryModel: 6
[ 286.473] BankSize: 0
[ 286.473] NumberOfImages: 16
[ 286.473] RedMaskSize: 8
[ 286.473] RedFieldPosition: 16
[ 286.473] GreenMaskSize: 8
[ 286.473] GreenFieldPosition: 8
[ 286.473] BlueMaskSize: 8
[ 286.473] BlueFieldPosition: 0
[ 286.473] RsvdMaskSize: 0
[ 286.473] RsvdFieldPosition: 0
[ 286.473] DirectColorModeInfo: 0
[ 286.473] PhysBasePtr: 0xec000000
[ 286.489] *Mode: 121 (640x480)
[ 286.489] ModeAttributes: 0xbb
[ 286.489] WinAAttributes: 0x7
[ 286.489] WinBAttributes: 0x0
[ 286.489] WinGranularity: 64
[ 286.489] WinSize: 64
[ 286.489] WinASegment: 0xa000
[ 286.489] WinBSegment: 0xa000
[ 286.489] WinFuncPtr: 0xc00055c9
[ 286.489] BytesPerScanline: 2560
[ 286.489] XResolution: 640
[ 286.489] YResolution: 480
[ 286.489] XCharSize: 8
[ 286.489] YCharSize: 16
[ 286.489] NumberOfPlanes: 1
[ 286.489] BitsPerPixel: 32
[ 286.489] NumberOfBanks: 1
[ 286.489] MemoryModel: 6
[ 286.489] BankSize: 0
[ 286.489] NumberOfImages: 12
[ 286.490] RedMaskSize: 8
[ 286.490] RedFieldPosition: 16
[ 286.490] GreenMaskSize: 8
[ 286.490] GreenFieldPosition: 8
[ 286.490] BlueMaskSize: 8
[ 286.490] BlueFieldPosition: 0
[ 286.490] RsvdMaskSize: 0
[ 286.490] RsvdFieldPosition: 0
[ 286.490] DirectColorModeInfo: 0
[ 286.490] PhysBasePtr: 0xec000000
[ 286.506] Mode: 103 (800x600)
[ 286.506] ModeAttributes: 0xbb
[ 286.506] WinAAttributes: 0x7
[ 286.506] WinBAttributes: 0x0
[ 286.506] WinGranularity: 64
[ 286.506] WinSize: 64
[ 286.506] WinASegment: 0xa000
[ 286.506] WinBSegment: 0xa000
[ 286.506] WinFuncPtr: 0xc00055c9
[ 286.506] BytesPerScanline: 800
[ 286.506] XResolution: 800
[ 286.506] YResolution: 600
[ 286.506] XCharSize: 8
[ 286.506] YCharSize: 14
[ 286.506] NumberOfPlanes: 1
[ 286.506] BitsPerPixel: 8
[ 286.506] NumberOfBanks: 1
[ 286.506] MemoryModel: 4
[ 286.506] BankSize: 0
[ 286.507] NumberOfImages: 31
[ 286.507] RedMaskSize: 0
[ 286.507] RedFieldPosition: 0
[ 286.507] GreenMaskSize: 0
[ 286.507] GreenFieldPosition: 0
[ 286.507] BlueMaskSize: 0
[ 286.507] BlueFieldPosition: 0
[ 286.507] RsvdMaskSize: 0
[ 286.507] RsvdFieldPosition: 0
[ 286.507] DirectColorModeInfo: 0
[ 286.507] PhysBasePtr: 0xec000000
[ 286.523] Mode: 113 (800x600)
[ 286.523] ModeAttributes: 0xbb
[ 286.523] WinAAttributes: 0x7
[ 286.523] WinBAttributes: 0x0
[ 286.523] WinGranularity: 64
[ 286.523] WinSize: 64
[ 286.523] WinASegment: 0xa000
[ 286.523] WinBSegment: 0xa000
[ 286.523] WinFuncPtr: 0xc00055c9
[ 286.523] BytesPerScanline: 1600
[ 286.523] XResolution: 800
[ 286.523] YResolution: 600
[ 286.523] XCharSize: 8
[ 286.523] YCharSize: 14
[ 286.524] NumberOfPlanes: 1
[ 286.524] BitsPerPixel: 15
[ 286.524] NumberOfBanks: 1
[ 286.524] MemoryModel: 6
[ 286.524] BankSize: 0
[ 286.524] NumberOfImages: 16
[ 286.524] RedMaskSize: 5
[ 286.524] RedFieldPosition: 10
[ 286.524] GreenMaskSize: 5
[ 286.524] GreenFieldPosition: 5
[ 286.524] BlueMaskSize: 5
[ 286.524] BlueFieldPosition: 0
[ 286.524] RsvdMaskSize: 0
[ 286.524] RsvdFieldPosition: 0
[ 286.524] DirectColorModeInfo: 0
[ 286.524] PhysBasePtr: 0xec000000
[ 286.540] Mode: 114 (800x600)
[ 286.540] ModeAttributes: 0xbb
[ 286.540] WinAAttributes: 0x7
[ 286.540] WinBAttributes: 0x0
[ 286.540] WinGranularity: 64
[ 286.540] WinSize: 64
[ 286.540] WinASegment: 0xa000
[ 286.540] WinBSegment: 0xa000
[ 286.541] WinFuncPtr: 0xc00055c9
[ 286.541] BytesPerScanline: 1600
[ 286.541] XResolution: 800
[ 286.541] YResolution: 600
[ 286.541] XCharSize: 8
[ 286.541] YCharSize: 14
[ 286.541] NumberOfPlanes: 1
[ 286.541] BitsPerPixel: 16
[ 286.541] NumberOfBanks: 1
[ 286.541] MemoryModel: 6
[ 286.541] BankSize: 0
[ 286.541] NumberOfImages: 16
[ 286.541] RedMaskSize: 5
[ 286.541] RedFieldPosition: 11
[ 286.541] GreenMaskSize: 6
[ 286.541] GreenFieldPosition: 5
[ 286.541] BlueMaskSize: 5
[ 286.541] BlueFieldPosition: 0
[ 286.541] RsvdMaskSize: 0
[ 286.541] RsvdFieldPosition: 0
[ 286.541] DirectColorModeInfo: 0
[ 286.541] PhysBasePtr: 0xec000000
[ 286.557] Mode: 115 (800x600)
[ 286.557] ModeAttributes: 0xbb
[ 286.558] WinAAttributes: 0x7
[ 286.558] WinBAttributes: 0x0
[ 286.558] WinGranularity: 64
[ 286.558] WinSize: 64
[ 286.558] WinASegment: 0xa000
[ 286.558] WinBSegment: 0xa000
[ 286.558] WinFuncPtr: 0xc00055c9
[ 286.558] BytesPerScanline: 2400
[ 286.558] XResolution: 800
[ 286.558] YResolution: 600
[ 286.558] XCharSize: 8
[ 286.558] YCharSize: 14
[ 286.558] NumberOfPlanes: 1
[ 286.558] BitsPerPixel: 24
[ 286.558] NumberOfBanks: 1
[ 286.558] MemoryModel: 6
[ 286.558] BankSize: 0
[ 286.558] NumberOfImages: 10
[ 286.558] RedMaskSize: 8
[ 286.558] RedFieldPosition: 16
[ 286.558] GreenMaskSize: 8
[ 286.558] GreenFieldPosition: 8
[ 286.558] BlueMaskSize: 8
[ 286.558] BlueFieldPosition: 0
[ 286.558] RsvdMaskSize: 0
[ 286.558] RsvdFieldPosition: 0
[ 286.558] DirectColorModeInfo: 0
[ 286.558] PhysBasePtr: 0xec000000
[ 286.574] *Mode: 122 (800x600)
[ 286.575] ModeAttributes: 0xbb
[ 286.575] WinAAttributes: 0x7
[ 286.575] WinBAttributes: 0x0
[ 286.575] WinGranularity: 64
[ 286.575] WinSize: 64
[ 286.575] WinASegment: 0xa000
[ 286.575] WinBSegment: 0xa000
[ 286.575] WinFuncPtr: 0xc00055c9
[ 286.575] BytesPerScanline: 3200
[ 286.575] XResolution: 800
[ 286.575] YResolution: 600
[ 286.575] XCharSize: 8
[ 286.575] YCharSize: 14
[ 286.575] NumberOfPlanes: 1
[ 286.575] BitsPerPixel: 32
[ 286.575] NumberOfBanks: 1
[ 286.575] MemoryModel: 6
[ 286.575] BankSize: 0
[ 286.575] NumberOfImages: 7
[ 286.575] RedMaskSize: 8
[ 286.575] RedFieldPosition: 16
[ 286.575] GreenMaskSize: 8
[ 286.575] GreenFieldPosition: 8
[ 286.575] BlueMaskSize: 8
[ 286.575] BlueFieldPosition: 0
[ 286.575] RsvdMaskSize: 0
[ 286.575] RsvdFieldPosition: 0
[ 286.575] DirectColorModeInfo: 0
[ 286.575] PhysBasePtr: 0xec000000
[ 286.592] Mode: 105 (1024x768)
[ 286.592] ModeAttributes: 0xbb
[ 286.592] WinAAttributes: 0x7
[ 286.593] WinBAttributes: 0x0
[ 286.593] WinGranularity: 64
[ 286.593] WinSize: 64
[ 286.593] WinASegment: 0xa000
[ 286.593] WinBSegment: 0xa000
[ 286.593] WinFuncPtr: 0xc00055c9
[ 286.593] BytesPerScanline: 1024
[ 286.593] XResolution: 1024
[ 286.593] YResolution: 768
[ 286.593] XCharSize: 8
[ 286.593] YCharSize: 16
[ 286.593] NumberOfPlanes: 1
[ 286.593] BitsPerPixel: 8
[ 286.593] NumberOfBanks: 1
[ 286.593] MemoryModel: 4
[ 286.593] BankSize: 0
[ 286.593] NumberOfImages: 20
[ 286.593] RedMaskSize: 0
[ 286.593] RedFieldPosition: 0
[ 286.593] GreenMaskSize: 0
[ 286.593] GreenFieldPosition: 0
[ 286.593] BlueMaskSize: 0
[ 286.593] BlueFieldPosition: 0
[ 286.593] RsvdMaskSize: 0
[ 286.593] RsvdFieldPosition: 0
[ 286.593] DirectColorModeInfo: 0
[ 286.593] PhysBasePtr: 0xec000000
[ 286.610] Mode: 116 (1024x768)
[ 286.610] ModeAttributes: 0xbb
[ 286.610] WinAAttributes: 0x7
[ 286.610] WinBAttributes: 0x0
[ 286.610] WinGranularity: 64
[ 286.610] WinSize: 64
[ 286.610] WinASegment: 0xa000
[ 286.610] WinBSegment: 0xa000
[ 286.611] WinFuncPtr: 0xc00055c9
[ 286.611] BytesPerScanline: 2048
[ 286.611] XResolution: 1024
[ 286.611] YResolution: 768
[ 286.611] XCharSize: 8
[ 286.611] YCharSize: 16
[ 286.611] NumberOfPlanes: 1
[ 286.611] BitsPerPixel: 15
[ 286.611] NumberOfBanks: 1
[ 286.611] MemoryModel: 6
[ 286.611] BankSize: 0
[ 286.611] NumberOfImages: 9
[ 286.611] RedMaskSize: 5
[ 286.611] RedFieldPosition: 10
[ 286.611] GreenMaskSize: 5
[ 286.611] GreenFieldPosition: 5
[ 286.611] BlueMaskSize: 5
[ 286.611] BlueFieldPosition: 0
[ 286.611] RsvdMaskSize: 0
[ 286.611] RsvdFieldPosition: 0
[ 286.611] DirectColorModeInfo: 0
[ 286.611] PhysBasePtr: 0xec000000
[ 286.628] Mode: 117 (1024x768)
[ 286.628] ModeAttributes: 0xbb
[ 286.628] WinAAttributes: 0x7
[ 286.628] WinBAttributes: 0x0
[ 286.628] WinGranularity: 64
[ 286.628] WinSize: 64
[ 286.628] WinASegment: 0xa000
[ 286.628] WinBSegment: 0xa000
[ 286.628] WinFuncPtr: 0xc00055c9
[ 286.628] BytesPerScanline: 2048
[ 286.629] XResolution: 1024
[ 286.629] YResolution: 768
[ 286.629] XCharSize: 8
[ 286.629] YCharSize: 16
[ 286.629] NumberOfPlanes: 1
[ 286.629] BitsPerPixel: 16
[ 286.629] NumberOfBanks: 1
[ 286.629] MemoryModel: 6
[ 286.629] BankSize: 0
[ 286.629] NumberOfImages: 9
[ 286.629] RedMaskSize: 5
[ 286.629] RedFieldPosition: 11
[ 286.629] GreenMaskSize: 6
[ 286.629] GreenFieldPosition: 5
[ 286.629] BlueMaskSize: 5
[ 286.629] BlueFieldPosition: 0
[ 286.629] RsvdMaskSize: 0
[ 286.629] RsvdFieldPosition: 0
[ 286.629] DirectColorModeInfo: 0
[ 286.629] PhysBasePtr: 0xec000000
[ 286.646] Mode: 118 (1024x768)
[ 286.646] ModeAttributes: 0xbb
[ 286.646] WinAAttributes: 0x7
[ 286.646] WinBAttributes: 0x0
[ 286.646] WinGranularity: 64
[ 286.646] WinSize: 64
[ 286.646] WinASegment: 0xa000
[ 286.646] WinBSegment: 0xa000
[ 286.646] WinFuncPtr: 0xc00055c9
[ 286.646] BytesPerScanline: 3072
[ 286.646] XResolution: 1024
[ 286.646] YResolution: 768
[ 286.646] XCharSize: 8
[ 286.646] YCharSize: 16
[ 286.647] NumberOfPlanes: 1
[ 286.647] BitsPerPixel: 24
[ 286.647] NumberOfBanks: 1
[ 286.647] MemoryModel: 6
[ 286.647] BankSize: 0
[ 286.647] NumberOfImages: 6
[ 286.647] RedMaskSize: 8
[ 286.647] RedFieldPosition: 16
[ 286.647] GreenMaskSize: 8
[ 286.647] GreenFieldPosition: 8
[ 286.647] BlueMaskSize: 8
[ 286.647] BlueFieldPosition: 0
[ 286.647] RsvdMaskSize: 0
[ 286.647] RsvdFieldPosition: 0
[ 286.647] DirectColorModeInfo: 0
[ 286.647] PhysBasePtr: 0xec000000
[ 286.664] *Mode: 123 (1024x768)
[ 286.664] ModeAttributes: 0xbb
[ 286.664] WinAAttributes: 0x7
[ 286.664] WinBAttributes: 0x0
[ 286.664] WinGranularity: 64
[ 286.664] WinSize: 64
[ 286.664] WinASegment: 0xa000
[ 286.664] WinBSegment: 0xa000
[ 286.664] WinFuncPtr: 0xc00055c9
[ 286.664] BytesPerScanline: 4096
[ 286.664] XResolution: 1024
[ 286.664] YResolution: 768
[ 286.664] XCharSize: 8
[ 286.664] YCharSize: 16
[ 286.664] NumberOfPlanes: 1
[ 286.664] BitsPerPixel: 32
[ 286.664] NumberOfBanks: 1
[ 286.664] MemoryModel: 6
[ 286.664] BankSize: 0
[ 286.664] NumberOfImages: 4
[ 286.665] RedMaskSize: 8
[ 286.665] RedFieldPosition: 16
[ 286.665] GreenMaskSize: 8
[ 286.665] GreenFieldPosition: 8
[ 286.665] BlueMaskSize: 8
[ 286.665] BlueFieldPosition: 0
[ 286.665] RsvdMaskSize: 0
[ 286.665] RsvdFieldPosition: 0
[ 286.665] DirectColorModeInfo: 0
[ 286.665] PhysBasePtr: 0xec000000
[ 286.683] Mode: 107 (1280x1024)
[ 286.683] ModeAttributes: 0xbb
[ 286.683] WinAAttributes: 0x7
[ 286.683] WinBAttributes: 0x0
[ 286.683] WinGranularity: 64
[ 286.683] WinSize: 64
[ 286.683] WinASegment: 0xa000
[ 286.683] WinBSegment: 0xa000
[ 286.683] WinFuncPtr: 0xc00055c9
[ 286.683] BytesPerScanline: 1280
[ 286.683] XResolution: 1280
[ 286.683] YResolution: 1024
[ 286.683] XCharSize: 8
[ 286.683] YCharSize: 16
[ 286.683] NumberOfPlanes: 1
[ 286.683] BitsPerPixel: 8
[ 286.683] NumberOfBanks: 1
[ 286.683] MemoryModel: 4
[ 286.683] BankSize: 0
[ 286.683] NumberOfImages: 11
[ 286.683] RedMaskSize: 0
[ 286.683] RedFieldPosition: 0
[ 286.683] GreenMaskSize: 0
[ 286.683] GreenFieldPosition: 0
[ 286.683] BlueMaskSize: 0
[ 286.683] BlueFieldPosition: 0
[ 286.683] RsvdMaskSize: 0
[ 286.683] RsvdFieldPosition: 0
[ 286.683] DirectColorModeInfo: 0
[ 286.683] PhysBasePtr: 0xec000000
[ 286.702] Mode: 119 (1280x1024)
[ 286.702] ModeAttributes: 0xbb
[ 286.702] WinAAttributes: 0x7
[ 286.702] WinBAttributes: 0x0
[ 286.702] WinGranularity: 64
[ 286.702] WinSize: 64
[ 286.702] WinASegment: 0xa000
[ 286.702] WinBSegment: 0xa000
[ 286.702] WinFuncPtr: 0xc00055c9
[ 286.702] BytesPerScanline: 2560
[ 286.702] XResolution: 1280
[ 286.702] YResolution: 1024
[ 286.702] XCharSize: 8
[ 286.702] YCharSize: 16
[ 286.702] NumberOfPlanes: 1
[ 286.702] BitsPerPixel: 15
[ 286.702] NumberOfBanks: 1
[ 286.702] MemoryModel: 6
[ 286.702] BankSize: 0
[ 286.702] NumberOfImages: 5
[ 286.702] RedMaskSize: 5
[ 286.702] RedFieldPosition: 10
[ 286.702] GreenMaskSize: 5
[ 286.702] GreenFieldPosition: 5
[ 286.702] BlueMaskSize: 5
[ 286.702] BlueFieldPosition: 0
[ 286.702] RsvdMaskSize: 0
[ 286.702] RsvdFieldPosition: 0
[ 286.702] DirectColorModeInfo: 0
[ 286.703] PhysBasePtr: 0xec000000
[ 286.721] Mode: 11a (1280x1024)
[ 286.721] ModeAttributes: 0xbb
[ 286.721] WinAAttributes: 0x7
[ 286.721] WinBAttributes: 0x0
[ 286.721] WinGranularity: 64
[ 286.721] WinSize: 64
[ 286.721] WinASegment: 0xa000
[ 286.721] WinBSegment: 0xa000
[ 286.721] WinFuncPtr: 0xc00055c9
[ 286.721] BytesPerScanline: 2560
[ 286.721] XResolution: 1280
[ 286.721] YResolution: 1024
[ 286.721] XCharSize: 8
[ 286.721] YCharSize: 16
[ 286.721] NumberOfPlanes: 1
[ 286.721] BitsPerPixel: 16
[ 286.721] NumberOfBanks: 1
[ 286.721] MemoryModel: 6
[ 286.721] BankSize: 0
[ 286.721] NumberOfImages: 5
[ 286.721] RedMaskSize: 5
[ 286.721] RedFieldPosition: 11
[ 286.721] GreenMaskSize: 6
[ 286.721] GreenFieldPosition: 5
[ 286.721] BlueMaskSize: 5
[ 286.721] BlueFieldPosition: 0
[ 286.721] RsvdMaskSize: 0
[ 286.721] RsvdFieldPosition: 0
[ 286.721] DirectColorModeInfo: 0
[ 286.721] PhysBasePtr: 0xec000000
[ 286.739] Mode: 11b (1280x1024)
[ 286.739] ModeAttributes: 0xbb
[ 286.739] WinAAttributes: 0x7
[ 286.739] WinBAttributes: 0x0
[ 286.740] WinGranularity: 64
[ 286.740] WinSize: 64
[ 286.740] WinASegment: 0xa000
[ 286.740] WinBSegment: 0xa000
[ 286.740] WinFuncPtr: 0xc00055c9
[ 286.740] BytesPerScanline: 3840
[ 286.740] XResolution: 1280
[ 286.740] YResolution: 1024
[ 286.740] XCharSize: 8
[ 286.740] YCharSize: 16
[ 286.740] NumberOfPlanes: 1
[ 286.740] BitsPerPixel: 24
[ 286.740] NumberOfBanks: 1
[ 286.740] MemoryModel: 6
[ 286.740] BankSize: 0
[ 286.740] NumberOfImages: 3
[ 286.740] RedMaskSize: 8
[ 286.740] RedFieldPosition: 16
[ 286.740] GreenMaskSize: 8
[ 286.740] GreenFieldPosition: 8
[ 286.740] BlueMaskSize: 8
[ 286.740] BlueFieldPosition: 0
[ 286.740] RsvdMaskSize: 0
[ 286.740] RsvdFieldPosition: 0
[ 286.740] DirectColorModeInfo: 0
[ 286.740] PhysBasePtr: 0xec000000
[ 286.758] *Mode: 124 (1280x1024)
[ 286.758] ModeAttributes: 0xbb
[ 286.758] WinAAttributes: 0x7
[ 286.758] WinBAttributes: 0x0
[ 286.758] WinGranularity: 64
[ 286.758] WinSize: 64
[ 286.758] WinASegment: 0xa000
[ 286.758] WinBSegment: 0xa000
[ 286.758] WinFuncPtr: 0xc00055c9
[ 286.758] BytesPerScanline: 5120
[ 286.758] XResolution: 1280
[ 286.758] YResolution: 1024
[ 286.758] XCharSize: 8
[ 286.758] YCharSize: 16
[ 286.758] NumberOfPlanes: 1
[ 286.758] BitsPerPixel: 32
[ 286.759] NumberOfBanks: 1
[ 286.759] MemoryModel: 6
[ 286.759] BankSize: 0
[ 286.759] NumberOfImages: 2
[ 286.759] RedMaskSize: 8
[ 286.759] RedFieldPosition: 16
[ 286.759] GreenMaskSize: 8
[ 286.759] GreenFieldPosition: 8
[ 286.759] BlueMaskSize: 8
[ 286.759] BlueFieldPosition: 0
[ 286.759] RsvdMaskSize: 0
[ 286.759] RsvdFieldPosition: 0
[ 286.759] DirectColorModeInfo: 0
[ 286.759] PhysBasePtr: 0xec000000
[ 286.760]
[ 286.760] (II) VESA(0): Total Memory: 256 64KB banks (16384kB)
[ 286.760] (II) VESA(0): : Using hsync range of 30.00-83.00 kHz
[ 286.760] (II) VESA(0): : Using vrefresh range of 56.00-76.00 Hz
[ 286.760] (II) VESA(0): : Using maximum pixel clock of 175.00 MHz
[ 286.760] (WW) VESA(0): Unable to estimate virtual size
[ 286.761] (II) VESA(0): Not using built-in mode “640x400” (no mode of this name)
[ 286.761] (II) VESA(0): Not using built-in mode “640x350” (no mode of this name)
[ 286.761] (II) VESA(0): Not using built-in mode “512x384” (no mode of this name)
[ 286.761] (II) VESA(0): Not using built-in mode “400x300” (no mode of this name)
[ 286.761] (II) VESA(0): Not using built-in mode “320x240” (no mode of this name)
[ 286.761] (II) VESA(0): Not using built-in mode “320x200” (no mode of this name)
[ 286.761] (–) VESA(0): Virtual size is 1280x1024 (pitch 1280)
[ 286.761] () VESA(0): *Built-in mode “1280x1024”
[ 286.761] (
) VESA(0): *Built-in mode “1024x768”
[ 286.761] () VESA(0): *Built-in mode “800x600”
[ 286.761] (
) VESA(0): *Built-in mode “640x480”
[ 286.761] () VESA(0): Display dimensions: (520, 330) mm
[ 286.761] (
) VESA(0): DPI set to (62, 78)
[ 286.761] () VESA(0): Using “Shadow Framebuffer”
[ 286.761] (II) Loading sub module “shadow”
[ 286.761] (II) LoadModule: “shadow”
[ 286.761] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 286.762] (II) Module shadow: vendor=“X.Org Foundation”
[ 286.762] compiled for 1.15.1, module version = 1.1.0
[ 286.762] ABI class: X.Org ANSI C Emulation, version 0.4
[ 286.762] (II) Loading sub module “fb”
[ 286.762] (II) LoadModule: “fb”
[ 286.762] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 286.762] (II) Module fb: vendor=“X.Org Foundation”
[ 286.762] compiled for 1.15.1, module version = 1.0.0
[ 286.762] (II) UnloadModule: “radeon”
[ 286.762] (==) Depth 24 pixmap format is 32 bpp
[ 286.762] (II) Loading sub module “int10”
[ 286.762] (II) LoadModule: “int10”
[ 286.763] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 286.763] (II) Module int10: vendor=“X.Org Foundation”
[ 286.763] compiled for 1.15.1, module version = 1.0.0
[ 286.763] ABI class: X.Org Video Driver, version 15.0
[ 286.763] (II) VESA(0): initializing int10
[ 286.763] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 286.763] (II) VESA(0): VESA BIOS detected
[ 286.763] (II) VESA(0): VESA VBE Version 2.0
[ 286.764] (II) VESA(0): VESA VBE Total Mem: 16384 kB
[ 286.764] (II) VESA(0): VESA VBE OEM: ATI RV370
[ 286.764] (II) VESA(0): VESA VBE OEM Software Rev: 1.0
[ 286.764] (II) VESA(0): VESA VBE OEM Vendor: ATI Technologies Inc.
[ 286.764] (II) VESA(0): VESA VBE OEM Product: V380
[ 286.764] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[ 286.764] (II) VESA(0): virtual address = 0xb59bf000,
physical address = 0xec000000, size = 16777216
[ 286.774] (II) VESA(0): Setting up VESA Mode 0x124 (1280x1024)
[ 286.774] (II) VESA(0): VBESetVBEMode failed, mode set without customized refresh.
[ 287.129] (==) VESA(0): Default visual is TrueColor
[ 287.130] (==) VESA(0): Backing store enabled
[ 287.130] (==) VESA(0): DPMS enabled
[ 287.130] (==) RandR enabled
[ 287.141] (II) SELinux: Disabled on system
[ 287.143] (II) AIGLX: Screen 0 is not DRI2 capable
[ 287.143] (EE) AIGLX: reverting to software rendering
[ 287.166] (II) AIGLX: Loaded and initialized swrast
[ 287.166] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 287.187] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 287.192] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 287.192] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 287.192] (II) LoadModule: “evdev”
[ 287.193] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 287.193] (II) Module evdev: vendor=“X.Org Foundation”
[ 287.193] compiled for 1.15.0, module version = 2.8.2
[ 287.193] Module class: X.Org XInput Driver
[ 287.193] ABI class: X.Org XInput driver, version 20.0
[ 287.193] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 287.193] () Power Button: always reports core events
[ 287.193] (
) evdev: Power Button: Device: “/dev/input/event1”
[ 287.193] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 287.193] (–) evdev: Power Button: Found keys
[ 287.193] (II) evdev: Power Button: Configuring as keyboard
[ 287.193] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 287.194] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 287.194] (
) Option “xkb_rules” “evdev”
[ 287.194] () Option “xkb_model” “pc105”
[ 287.194] (
) Option “xkb_layout” “fr”
[ 287.194] () Option “xkb_variant” “latin9”
[ 287.200] (II) XKB: reuse xkmfile /var/lib/xkb/server-816A055A5FF7D63897839A4BDEDC3908551E49DA.xkm
[ 287.201] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 287.201] (
[ 287.201] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 287.201] () Power Button: always reports core events
[ 287.201] (
) evdev: Power Button: Device: “/dev/input/event0”
[ 287.201] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 287.201] (–) evdev: Power Button: Found keys
[ 287.201] (II) evdev: Power Button: Configuring as keyboard
[ 287.201] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0”
[ 287.201] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 287.201] (
[ 287.202] () Option “xkb_model” “pc105”
[ 287.202] (
[ 287.202] () Option “xkb_variant” “latin9”
[ 287.202] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 287.202] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 287.203] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event2)
[ 287.203] (II) No input driver specified, ignoring this device.
[ 287.203] (II) This device may have been added with another device file.
[ 287.203] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event7)
[ 287.203] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event6)
[ 287.204] (II) No input driver specified, ignoring this device.
[ 287.204] (II) This device may have been added with another device file.
[ 287.204] (II) config/udev: Adding input device HDA Intel Speaker Front (/dev/input/event5)
[ 287.204] (II) config/udev: Adding input device HDA Intel Speaker Surround (/dev/input/event4)
[ 287.205] (II) No input driver specified, ignoring this device.
[ 287.205] (II) This device may have been added with another device file.
[ 287.205] (II) config/udev: Adding input device HDA Intel Speaker CLFE (/dev/input/event3)
[ 287.206] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event8)
[ 287.206] (
) Logitech USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 287.206] (II) Using input driver ‘evdev’ for ‘Logitech USB Optical Mouse’
[ 287.206] () Logitech USB Optical Mouse: always reports core events
[ 287.206] (
) evdev: Logitech USB Optical Mouse: Device: “/dev/input/event8”
[ 287.206] (–) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc05a
[ 287.206] (–) evdev: Logitech USB Optical Mouse: Found 12 mouse buttons
[ 287.206] (–) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[ 287.206] (–) evdev: Logitech USB Optical Mouse: Found relative axes
[ 287.206] (–) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[ 287.206] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[ 287.206] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[ 287.206] () evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 287.206] (
) evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 287.206] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input11/event8”
[ 287.206] (II) XINPUT: Adding extended input device “Logitech USB Optical Mouse” (type: MOUSE, id 8)
[ 287.206] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[ 287.206] (
) Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 287.206] () Logitech USB Optical Mouse: (accel) acceleration profile 0
[ 287.206] (
) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 287.206] () Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 287.207] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[ 287.207] (II) No input driver specified, ignoring this device.
[ 287.207] (II) This device may have been added with another device file.
[ 287.208] (II) config/udev: Adding input device LITEON Technology USB Multimedia Keyboard (/dev/input/event9)
[ 287.208] (
) LITEON Technology USB Multimedia Keyboard: Applying InputClass “evdev keyboard catchall”
[ 287.208] (II) Using input driver ‘evdev’ for ‘LITEON Technology USB Multimedia Keyboard’
[ 287.208] () LITEON Technology USB Multimedia Keyboard: always reports core events
[ 287.208] (
) evdev: LITEON Technology USB Multimedia Keyboard: Device: “/dev/input/event9”
[ 287.208] (–) evdev: LITEON Technology USB Multimedia Keyboard: Vendor 0x46d Product 0xc312
[ 287.208] (–) evdev: LITEON Technology USB Multimedia Keyboard: Found keys
[ 287.208] (II) evdev: LITEON Technology USB Multimedia Keyboard: Configuring as keyboard
[ 287.208] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input12/event9”
[ 287.208] (II) XINPUT: Adding extended input device “LITEON Technology USB Multimedia Keyboard” (type: KEYBOARD, id 9)
[ 287.208] (
[ 287.208] () Option “xkb_model” “pc105”
[ 287.208] (
[ 287.208] (**) Option “xkb_variant” “latin9”
[ 290.811] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 296.819] (II) XKB: reuse xkmfile /var/lib/xkb/server-FCE784E457E827DE63A60012DC8F25390069A73C.xkm
[ 296.908] (II) XKB: reuse xkmfile /var/lib/xkb/server-FCE784E457E827DE63A60012DC8F25390069A73C.xkm
[ 305.939] (II) XKB: reuse xkmfile /var/lib/xkb/server-1BB3DE285E70FB9185F4D20DA8259C6A5B347C21.xkm
Pfff
Bon courage
Le pc est lent.
Est ce que je dois remettre MINT maintenant que je peux avoir internet par le biais de la clé?
Mais est ce que je pourrais faire la même manip de remettre internet sur la carte réseau comme sur UBUNTU? (En espérant que c possible…)
Est ce que DEBIAN peut être mieux que UBUNTU et MINT?
Question naive sur un forum debian.
Que veux tu qu’on te réponde ? Que BSD c’est mieux que linux ? Ou que solaris c’est encore mieux, mais c’est plus cher ?
Tout dépend de ton besoin, et de ton niveau de connaissance des autres distribution. La meilleure distribution, c’est celle qu’on maitrise et qui répond à son besoin.
Ta réponse fait avancer les choses.
Bonne journée
piratebab n’a pas faux… je ne pourrai pas répondre mieux… Après, forcément, nous on préfère debian, parce qu’on s’y est habitué et qu’elle répond à nos attentes…
Quand tu mets autant de copier/coller, essaye de mettre des balises CODE, ça facilite la lecture :blush:
Bon… Tu as fait quelque chose de plus depuis ou pas ?
Hello.
L ordinateur ne démarre pas graphiquement même après un long moment.
Avec tout ce que j’ai envoyé, qu en déduis tu?
Que dois je faire au niveau graphique? Au niveau carte réseau? Et est ce que une DEBIAN est adaptée à wdesutilisateurs avec peu de connaissance informatique, principalement de l internet et un peu de traitement de texte basique. Et quelques photos. C’est tout. Est ce qu’il y a une grosse différence d interface graphique?
si vous le souhaitez je supprime le post ?
[quote]Avec tout ce que j’ai envoyé, qu en déduis tu?
Que dois je faire au niveau graphique? Au niveau carte réseau? Et est ce que une DEBIAN est adaptée à wdesutilisateurs avec peu de connaissance informatique, principalement de l internet et un peu de traitement de texte basique. Et quelques photos. C’est tout. Est ce qu’il y a une grosse différence d interface graphique? [/quote]
heu, qu’il y a beaucoup à lire, que ton pilote radeon à un problème avec ta carte, qu’il n’arrive pas à charger le mode vesa (c’est le mode basique graphique)
Pour debian, c’est pas grand chose différent, sauf que c’est moins “friendly”
HandyLinux : Debian sans se prendre la tête
tiens je connaissais pas celle-là :astonished:
