Fichiers du paquet :
100 /var/lib/dpkg/status
release a=now
99 http://http.debian.net/debian unstable/main amd64 Packages
release o=Debian,a=unstable,n=sid,l=Debian,c=main,b=amd64
origin http.debian.net
498 http://www.deb-multimedia.org unstable/main amd64 Packages
release v=0.0,o=Unofficial Multimedia Packages,a=unstable,n=sid,l=Unofficial Multimedia Packages,c=main,b=amd64
origin www.deb-multimedia.org
499 http://www.deb-multimedia.org testing/main amd64 Packages
release v=0.0,o=Unofficial Multimedia Packages,a=testing,n=buster,l=Unofficial Multimedia Packages,c=main,b=amd64
500 http://ftp.fr.debian.org/debian testing/non-free amd64 Packages
release o=Debian,a=testing,n=buster,l=Debian,c=non-free,b=amd64
origin ftp.fr.debian.org
500 http://ftp.fr.debian.org/debian testing/contrib amd64 Packages
release o=Debian,a=testing,n=buster,l=Debian,c=contrib,b=amd64
500 http://ftp.fr.debian.org/debian testing/main amd64 Packages
release o=Debian,a=testing,n=buster,l=Debian,c=main,b=amd64
Paquets épinglés :
Probleme de traduction, j’ai trouvé.
/etc/preferences
Package: *
Pin: release o=Debian,a=testing
Pin-Priority: 990
Package: *
Pin: release o=Debian,a=unstable
Pin-Priority: 99
Package: *
Pin: release o=Unofficial Multimedia Packages,a=testing
Pin-Priority: 989
Package: *
Pin: release o=Unofficial Multimedia Packages,a=unstable
Pin-Priority: 498
source :
## Debian testing - dépôts officiels
deb http://ftp.fr.debian.org/debian/ testing main contrib non-free
deb http://ftp.fr.debian.org/debian/ testing-updates main contrib non-free
deb http://security.debian.org/ testing/updates main
## Third Parties Repos
# Debian Multimedia
deb http://www.deb-multimedia.org testing main
deb http://www.deb-multimedia.org unstable main
# Dépôt nécessaire uniquement pour installer Firefox release
deb http://http.debian.net/debian unstable main
J’ai réécrit les deux fichiers
~$ sudo apt update && sudo apt upgrade && sudo apt install avidemux-qt
82 mis à jour, 27 nouvellement installés, 0 à enlever et 0 non mis à jour.
c’est normal ?
sinon j’ai pas bien vu la différence ?
si c’es bon , tu peux y aller
Pourquoi il propose de mettre à jour mes paquets multimédias ? J’ai l’impression e faire le contraire de précédemment : mise à jour ascendante après la mise à jour descendante
Non la tu met à jour à partir de testing et non unstable.
c’est pour ça que tu as beaucoup moins de package.
et du coup qu’est ce qui a débloqué avidemux ?
La priorité du depot testing de multimedia
la traduction du pipenning m’a induit en erreur.
Il pioche d’abord dans le depot officiel testing de debian.
Si pas meilleurs version ou pas dispo dans testing ou , il va dans le testing de multimedia.
voila t’as une debian bien paramétré.
Tout est bon de mon côté, et consigné pour la prochaine fois
Merci beaucoup cleloup pour le décrassage de printemps
Np.
ça m’a valu de voir une erreur dans mon wiki.
L’essentiel c’est la réussite.
c’est quoi l’adresse de ton wiki par curiosité ?
c’est turtl privé.
c’est que par invit.
il est chez framanote.
J’ai des petites docs intéressantes.
on peut en parler en mp c’est plus simple
coucou
Juste une info pour toi
cette page t’aide à comprendre le pinning
https://debian-facile.org/doc:systeme:apt:pinning
elle est tres bien foutu.
Je reviens sur cette question :
Actuellement Firefox 60 est dispo dans sid pour mon archi (amd64) I Challenge Thee
Pourtant la mise à jour ne m’est pas proposée par un classique sudo apt update && sudo apt upgrade..!
apt-get install -t sid firefox
ça te pinnera ton paquet sur sid.
les autres mises à, jours seront automatique.
c’est ce que je pensais merci
Du coup j’ai ajouté sudo apt install -t sid firefox-l10n-fr à mes commandes de mises à jour habituelles
Merci !
Pour info
Lors d'une installation en précisant la branche d'un paquet avec « /votrebranche », le paquet concerné prend une priorité 990.
Le paquet sera installé sauf si une version plus récente est déjà installée.
500 < P ≤ 990
source : https://debian-facile.org/doc:systeme:apt:pinning
Donc il sera mis toujours à jours.
tu veux dire : avec la commande sudo apt install -t sid firefox-l10n-fr ?
non avec sudo apt upgrade
si tu fais apt-cache policy firefox
ton paquet sera pinner sur sid.
