[quote]root@odile-MS-7204:/home/odile# blkid
/dev/sda1: UUID=“801C41581C414A7C” TYPE=“ntfs”
/dev/sda2: UUID=“6088303D5F6FB897” TYPE=“ntfs”
/dev/sda5: UUID=“e850a908-5fc6-4678-b44a-d09806d1b26f” TYPE=“swap”
/dev/sda6: UUID=“fa1579ee-021a-4018-afda-6afef897a61e” TYPE=“ext4”
/dev/sda7: UUID=“9430374d-7cbe-4ebc-8e44-427fe05d1d5a” TYPE=“ext4”[/quote]
[quote]root@odile-MS-7204:/home/odile# cat /etc/fstab
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda7 during installation
UUID=9430374d-7cbe-4ebc-8e44-427fe05d1d5a / ext4 errors=remount-ro 0 1
UUID=fa1579ee-021a-4018-afda-6afef897a61e /home ext4 defaults 0 0
swap was on /dev/sda5 during installation
UUID=e850a908-5fc6-4678-b44a-d09806d1b26f none swap sw 0 0
#/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0[/quote]
[quote]root@odile-MS-7204:/media/odile# df -h /dev/sda6
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
/dev/sda6 126G 15G 105G 13% /home
root@odile-MS-7204:/media/odile# df -h /dev/sda7
udev 488M 8,0K 488M 1% /dev[/quote]
Sur /dev/sda7 j’ai normalement mon système d’installé. Pourquoi j’ai ce résultat avec “df” ??
[quote]# fdisk -l
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 têtes, 63 secteurs/piste, 30401 cylindres, total 488397168 secteurs
Unités = secteurs de 1 * 512 = 512 octets
taille d’E/S (minimale / optimale) : 512 octets / 512 octets
Identifiant de disque : 0xbf7fbf7f
Périphérique Amorçage Début Fin Blocs Id. Système
/dev/sda1 * 63 103541759 51770848+ 7 HPFS/NTFS/exFAT
/dev/sda2 103554990 183422975 39933993 7 HPFS/NTFS/exFAT
/dev/sda4 183425022 488392064 152483521+ 5 Étendue
/dev/sda5 215704818 221568479 2931831 82 partition d’échange Linux / Solaris
/dev/sda6 221568543 488392064 133411761 83 Linux
/dev/sda7 183425024 215703551 16139264 83 Linux
Les entrées de la table de partitions ne sont pas dans l’ordre du disque[/quote]
