Et mon dmesg : [code][ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-5-amd64 (Debian 2.6.32-25) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Fri Oct 15 00:56:30 UTC 2010
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=235dc21e-5a70-481b-ae36-69b704e472e1 ro quiet
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000aff90000 (usable)
[ 0.000000] BIOS-e820: 00000000aff90000 - 00000000aff9e000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000aff9e000 - 00000000affe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000affe0000 - 00000000b0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.4 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xaff90 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FE0000000 write-back
[ 0.000000] 2 base 0A0000000 mask FF0000000 write-back
[ 0.000000] 3 base 0B0000000 mask FF8000000 write-back
[ 0.000000] 4 base 0B8000000 mask FFC000000 write-back
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000aff90000
[ 0.000000] 0000000000 - 00afe00000 page 2M
[ 0.000000] 00afe00000 - 00aff90000 page 4k
[ 0.000000] kernel direct mapping tables up to aff90000 @ 10000-15000
[ 0.000000] RAMDISK: 3774d000 - 37fef0f4
[ 0.000000] ACPI: RSDP 00000000000fa950 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 00000000aff90000 00040 (v01 MSTEST TESTONLY 07000725 MSFT 00000097)
[ 0.000000] ACPI: FACP 00000000aff90200 00084 (v02 MSTEST OEMFACP 07000725 MSFT 00000097)
[ 0.000000] ACPI: DSDT 00000000aff905c0 07C09 (v01 A0518 A0518000 00000000 INTL 20060113)
[ 0.000000] ACPI: FACS 00000000aff9e000 00040
[ 0.000000] ACPI: APIC 00000000aff90390 0006C (v01 MSTEST OEMAPIC 07000725 MSFT 00000097)
[ 0.000000] ACPI: MCFG 00000000aff90400 0003C (v01 MSTEST OEMMCFG 07000725 MSFT 00000097)
[ 0.000000] ACPI: OEMB 00000000aff9e040 0007B (v01 MSTEST AMI_OEM 07000725 MSFT 00000097)
[ 0.000000] ACPI: HPET 00000000aff981d0 00038 (v01 MSTEST OEMHPET 07000725 MSFT 00000097)
[ 0.000000] ACPI: ASF! 00000000aff98208 00099 (v32 LEGEND I865PASF 00000001 INTL 20060113)
[ 0.000000] ACPI: GSCI 00000000aff9e0c0 02024 (v01 MSTEST GMCHSCI 07000725 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-00000000aff90000
[ 0.000000] Bootmem setup node 0 0000000000000000-00000000aff90000
[ 0.000000] NODE_DATA [0000000000013000 - 000000000001afff]
[ 0.000000] bootmap [000000000001b000 - 0000000000030ff7] pages 16
[ 0.000000] (7 early reservations) ==> bootmem [0000000000 - 00aff90000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
[ 0.000000] #2 [0001000000 - 0001688414] TEXT DATA BSS ==> [0001000000 - 0001688414]
[ 0.000000] #3 [003774d000 - 0037fef0f4] RAMDISK ==> [003774d000 - 0037fef0f4]
[ 0.000000] #4 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #5 [0001689000 - 000168928c] BRK ==> [0001689000 - 000168928c]
[ 0.000000] #6 [0000010000 - 0000013000] PGTABLE ==> [0000010000 - 0000013000]
[ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
[ 0.000000] [ffffea0000000000-ffffea00027fffff] PMD -> [ffff880001c00000-ffff8800043fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00100000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000aff90
[ 0.000000] On node 0 totalpages: 720671
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 102 pages reserved
[ 0.000000] DMA zone: 3825 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 9799 pages used for memmap
[ 0.000000] DMA32 zone: 706889 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a202 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at b0000000 (gap: b0000000:4ee00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff880001800000 s90328 r8192 d24360 u524288
[ 0.000000] pcpu-alloc: s90328 r8192 d24360 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 710714
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=235dc21e-5a70-481b-ae36-69b704e472e1 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Checking aperture…
[ 0.000000] No AGP bridge found
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 2825384k/2883136k available (3076k kernel code, 452k absent, 57300k reserved, 1894k data, 584k init)
[ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:4352 nr_irqs:440
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1866.764 MHz processor.
[ 0.004007] Calibrating delay loop (skipped), value calculated using timer frequency… 3733.52 BogoMIPS (lpj=7467056)
[ 0.004033] Security Framework initialized
[ 0.004039] SELinux: Disabled at boot.
[ 0.004466] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.009841] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.011718] Mount-cache hash table entries: 256
[ 0.011920] Initializing cgroup subsys ns
[ 0.011925] Initializing cgroup subsys cpuacct
[ 0.011930] Initializing cgroup subsys devices
[ 0.011932] Initializing cgroup subsys freezer
[ 0.011935] Initializing cgroup subsys net_cls
[ 0.011966] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.011968] CPU: L2 cache: 2048K
[ 0.011972] CPU 0/0x0 -> Node 0
[ 0.011975] CPU: Physical Processor ID: 0
[ 0.011976] CPU: Processor Core ID: 0
[ 0.012011] mce: CPU supports 6 MCE banks
[ 0.012021] CPU0: Thermal monitoring enabled (TM2)
[ 0.012025] using mwait in idle threads.
[ 0.012027] Performance Events: Core2 events, Intel PMU driver.
[ 0.012034] … version: 2
[ 0.012035] … bit width: 40
[ 0.012037] … generic registers: 2
[ 0.012039] … value mask: 000000ffffffffff
[ 0.012041] … max period: 000000007fffffff
[ 0.012043] … fixed-purpose events: 3
[ 0.012045] … event mask: 0000000700000003
[ 0.013177] ACPI: Core revision 20090903
[ 0.024069] Setting APIC routing to flat
[ 0.024374] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.065301] CPU0: Intel® Core™2 CPU 6300 @ 1.86GHz stepping 06
[ 0.068001] APIC calibration not consistent with PM-Timer: 135ms instead of 100ms
[ 0.068001] APIC delta adjusted to PM-Timer: 1666663 (2266637)
[ 0.068001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.008000] Initializing CPU#1
[ 0.008000] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.008000] CPU: L2 cache: 2048K
[ 0.008000] CPU 1/0x1 -> Node 0
[ 0.008000] CPU: Physical Processor ID: 0
[ 0.008000] CPU: Processor Core ID: 1
[ 0.008000] CPU1: Thermal monitoring enabled (TM2)
[ 0.152113] CPU1: Intel® Core™2 CPU 6300 @ 1.86GHz stepping 06
[ 0.152121] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.156022] Brought up 2 CPUs
[ 0.156025] Total of 2 processors activated (7466.89 BogoMIPS).
[ 0.156491] CPU0 attaching sched-domain:
[ 0.156495] domain 0: span 0-1 level MC
[ 0.156497] groups: 0 1
[ 0.156504] CPU1 attaching sched-domain:
[ 0.156506] domain 0: span 0-1 level MC
[ 0.156509] groups: 1 0
[ 0.156576] devtmpfs: initialized
[ 0.160056] regulator: core version 0.5
[ 0.160080] NET: Registered protocol family 16
[ 0.160193] ACPI: bus type pci registered
[ 0.160263] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.160266] PCI: Not using MMCONFIG.
[ 0.160268] PCI: Using configuration type 1 for base access
[ 0.160650] bio: create slab at 0
[ 0.160708] ACPI: EC: Look up EC in DSDT
[ 0.164991] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.171780] ACPI: Interpreter enabled
[ 0.171784] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.171811] ACPI: Using IOAPIC for interrupt routing
[ 0.171869] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.175481] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 0.183095] PCI: Using MMCONFIG at e0000000 - efffffff
[ 0.193356] ACPI Warning: Incorrect checksum in table [OEMB] - B9, should be AC (20090903/tbutils-314)
[ 0.194179] ACPI: No dock devices found.
[ 0.194306] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.194421] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.194425] pci 0000:00:01.0: PME# disabled
[ 0.194485] pci 0000:00:1a.0: reg 20 io port: [0xdc00-0xdc1f]
[ 0.194532] pci 0000:00:1a.1: reg 20 io port: [0xe000-0xe01f]
[ 0.194587] pci 0000:00:1a.7: reg 10 32bit mmio: [0xfebff800-0xfebffbff]
[ 0.194635] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.194639] pci 0000:00:1a.7: PME# disabled
[ 0.194677] pci 0000:00:1b.0: reg 10 64bit mmio: [0xfebf8000-0xfebfbfff]
[ 0.194716] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.194720] pci 0000:00:1b.0: PME# disabled
[ 0.194780] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.194784] pci 0000:00:1c.0: PME# disabled
[ 0.194848] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.194852] pci 0000:00:1c.4: PME# disabled
[ 0.194913] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.194916] pci 0000:00:1c.5: PME# disabled
[ 0.194961] pci 0000:00:1d.0: reg 20 io port: [0xd480-0xd49f]
[ 0.195008] pci 0000:00:1d.1: reg 20 io port: [0xd800-0xd81f]
[ 0.195054] pci 0000:00:1d.2: reg 20 io port: [0xd880-0xd89f]
[ 0.195109] pci 0000:00:1d.7: reg 10 32bit mmio: [0xfebff400-0xfebff7ff]
[ 0.195156] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.195161] pci 0000:00:1d.7: PME# disabled
[ 0.195277] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
[ 0.195282] pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
[ 0.195286] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.195335] pci 0000:00:1f.2: reg 10 io port: [0xec00-0xec07]
[ 0.195341] pci 0000:00:1f.2: reg 14 io port: [0xe880-0xe883]
[ 0.195347] pci 0000:00:1f.2: reg 18 io port: [0xe800-0xe807]
[ 0.195352] pci 0000:00:1f.2: reg 1c io port: [0xe480-0xe483]
[ 0.195358] pci 0000:00:1f.2: reg 20 io port: [0xe400-0xe40f]
[ 0.195364] pci 0000:00:1f.2: reg 24 io port: [0xe080-0xe08f]
[ 0.195383] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.195387] pci 0000:00:1f.2: PME# disabled
[ 0.195408] pci 0000:00:1f.3: reg 10 32bit mmio: [0x000000-0x0000ff]
[ 0.195424] pci 0000:00:1f.3: reg 20 io port: [0x400-0x41f]
[ 0.195462] pci 0000:00:1f.5: reg 10 io port: [0xd400-0xd407]
[ 0.195468] pci 0000:00:1f.5: reg 14 io port: [0xd080-0xd083]
[ 0.195474] pci 0000:00:1f.5: reg 18 io port: [0xd000-0xd007]
[ 0.195480] pci 0000:00:1f.5: reg 1c io port: [0xcc00-0xcc03]
[ 0.195485] pci 0000:00:1f.5: reg 20 io port: [0xc880-0xc88f]
[ 0.195491] pci 0000:00:1f.5: reg 24 io port: [0xc800-0xc80f]
[ 0.195510] pci 0000:00:1f.5: PME# supported from D3hot
[ 0.195514] pci 0000:00:1f.5: PME# disabled
[ 0.195550] pci 0000:01:00.0: reg 10 32bit mmio: [0xfd000000-0xfdffffff]
[ 0.195559] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xc0000000-0xcfffffff]
[ 0.195568] pci 0000:01:00.0: reg 1c 64bit mmio: [0xfa000000-0xfbffffff]
[ 0.195574] pci 0000:01:00.0: reg 24 io port: [0x8c00-0x8c7f]
[ 0.195580] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfe7e0000-0xfe7fffff]
[ 0.195691] pci 0000:00:01.0: bridge io port: [0x8000-0x8fff]
[ 0.195694] pci 0000:00:01.0: bridge 32bit mmio: [0xf8700000-0xfe7fffff]
[ 0.195699] pci 0000:00:01.0: bridge 64bit mmio pref: [0xbfe00000-0xdfdfffff]
[ 0.195742] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xdfe00000-0xdfefffff]
[ 0.195831] pci 0000:03:00.0: reg 24 32bit mmio: [0xfe9fe000-0xfe9fffff]
[ 0.195840] pci 0000:03:00.0: reg 30 32bit mmio pref: [0xfe9e0000-0xfe9effff]
[ 0.195871] pci 0000:03:00.0: PME# supported from D3hot
[ 0.195877] pci 0000:03:00.0: PME# disabled
[ 0.195934] pci 0000:03:00.1: reg 10 io port: [0xac00-0xac07]
[ 0.195943] pci 0000:03:00.1: reg 14 io port: [0xa880-0xa883]
[ 0.195952] pci 0000:03:00.1: reg 18 io port: [0xa800-0xa807]
[ 0.195961] pci 0000:03:00.1: reg 1c io port: [0xa480-0xa483]
[ 0.195970] pci 0000:03:00.1: reg 20 io port: [0xa400-0xa40f]
[ 0.196045] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with ‘pcie_aspm=force’
[ 0.196113] pci 0000:00:1c.4: bridge io port: [0xa000-0xafff]
[ 0.196117] pci 0000:00:1c.4: bridge 32bit mmio: [0xfe900000-0xfe9fffff]
[ 0.196178] pci 0000:02:00.0: reg 10 io port: [0x9800-0x98ff]
[ 0.196200] pci 0000:02:00.0: reg 18 64bit mmio: [0xfe8ff000-0xfe8fffff]
[ 0.196221] pci 0000:02:00.0: reg 30 32bit mmio pref: [0xfe8c0000-0xfe8dffff]
[ 0.196267] pci 0000:02:00.0: supports D1 D2
[ 0.196269] pci 0000:02:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.196275] pci 0000:02:00.0: PME# disabled
[ 0.196315] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with ‘pcie_aspm=force’
[ 0.196386] pci 0000:00:1c.5: bridge io port: [0x9000-0x9fff]
[ 0.196390] pci 0000:00:1c.5: bridge 32bit mmio: [0xfe800000-0xfe8fffff]
[ 0.196431] pci 0000:05:01.0: reg 10 32bit mmio: [0xfeaff800-0xfeafffff]
[ 0.196439] pci 0000:05:01.0: reg 14 32bit mmio: [0xfeaf8000-0xfeafbfff]
[ 0.196480] pci 0000:05:01.0: supports D1 D2
[ 0.196482] pci 0000:05:01.0: PME# supported from D0 D1 D2 D3hot
[ 0.196487] pci 0000:05:01.0: PME# disabled
[ 0.196528] pci 0000:05:04.0: reg 10 io port: [0xb800-0xb8ff]
[ 0.196535] pci 0000:05:04.0: reg 14 32bit mmio: [0xfeaff400-0xfeaff7ff]
[ 0.196575] pci 0000:05:04.0: supports D1 D2
[ 0.196578] pci 0000:05:04.0: PME# supported from D1 D2 D3hot D3cold
[ 0.196582] pci 0000:05:04.0: PME# disabled
[ 0.196625] pci 0000:00:1e.0: transparent bridge
[ 0.196629] pci 0000:00:1e.0: bridge io port: [0xb000-0xbfff]
[ 0.196633] pci 0000:00:1e.0: bridge 32bit mmio: [0xfea00000-0xfeafffff]
[ 0.196659] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
[ 0.196839] ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P2.PRT]
[ 0.196905] ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P1.PRT]
[ 0.197029] ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P8.PRT]
[ 0.197109] ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P9.PRT]
[ 0.197197] ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P4._PRT]
[ 0.215283] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.215416] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.215550] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.215680] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.215810] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.215939] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.216082] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.216211] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.216344] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.216350] vgaarb: loaded
[ 0.216373] PCI: Using ACPI for IRQ routing
[ 0.216373] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.216373] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.220025] Switching to clocksource tsc
[ 0.221447] pnp: PnP ACPI init
[ 0.221457] ACPI: bus type pnp registered
[ 0.226121] pnp: PnP ACPI: found 15 devices
[ 0.226124] ACPI: ACPI bus type pnp unregistered
[ 0.226135] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
[ 0.226144] system 00:08: ioport range 0x290-0x297 has been reserved
[ 0.226151] system 00:09: ioport range 0x4d0-0x4d1 has been reserved
[ 0.226154] system 00:09: ioport range 0x800-0x87f has been reserved
[ 0.226157] system 00:09: ioport range 0x480-0x4bf has been reserved
[ 0.226161] system 00:09: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.226165] system 00:09: iomem range 0xfed20000-0xfed8ffff has been reserved
[ 0.226168] system 00:09: iomem range 0xff9fa000-0xff9fafff has been reserved
[ 0.226175] system 00:09: iomem range 0xfff00000-0xfffffffe has been reserved
[ 0.226179] system 00:09: iomem range 0xffafe000-0xffafefff has been reserved
[ 0.226182] system 00:09: iomem range 0xfebfe000-0xfebfefff has been reserved
[ 0.226190] system 00:0c: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.226193] system 00:0c: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.226199] system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.226206] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
[ 0.226209] system 00:0e: iomem range 0xc0000-0xcffff has been reserved
[ 0.226213] system 00:0e: iomem range 0xe0000-0xfffff could not be reserved
[ 0.226216] system 00:0e: iomem range 0x100000-0xafffffff could not be reserved
[ 0.230998] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.231002] pci 0000:00:01.0: IO window: 0x8000-0x8fff
[ 0.231006] pci 0000:00:01.0: MEM window: 0xf8700000-0xfe7fffff
[ 0.231010] pci 0000:00:01.0: PREFETCH window: 0x000000bfe00000-0x000000dfdfffff
[ 0.231015] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:04
[ 0.231018] pci 0000:00:1c.0: IO window: 0x1000-0x1fff
[ 0.231023] pci 0000:00:1c.0: MEM window: 0xb0000000-0xb03fffff
[ 0.231027] pci 0000:00:1c.0: PREFETCH window: 0x000000dfe00000-0x000000dfefffff
[ 0.231034] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:03
[ 0.231037] pci 0000:00:1c.4: IO window: 0xa000-0xafff
[ 0.231042] pci 0000:00:1c.4: MEM window: 0xfe900000-0xfe9fffff
[ 0.231046] pci 0000:00:1c.4: PREFETCH window: 0x000000b0400000-0x000000b05fffff
[ 0.231052] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:02
[ 0.231056] pci 0000:00:1c.5: IO window: 0x9000-0x9fff
[ 0.231061] pci 0000:00:1c.5: MEM window: 0xfe800000-0xfe8fffff
[ 0.231065] pci 0000:00:1c.5: PREFETCH window: 0x000000b0600000-0x000000b07fffff
[ 0.231071] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:05
[ 0.231075] pci 0000:00:1e.0: IO window: 0xb000-0xbfff
[ 0.231079] pci 0000:00:1e.0: MEM window: 0xfea00000-0xfeafffff
[ 0.231083] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.231095] alloc irq_desc for 16 on node -1
[ 0.231098] alloc kstat_irqs on node -1
[ 0.231104] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.231108] pci 0000:00:01.0: setting latency timer to 64
[ 0.231115] pci 0000:00:1c.0: enabling device (0106 -> 0107)
[ 0.231119] alloc irq_desc for 17 on node -1
[ 0.231121] alloc kstat_irqs on node -1
[ 0.231125] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.231129] pci 0000:00:1c.0: setting latency timer to 64
[ 0.231137] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.231141] pci 0000:00:1c.4: setting latency timer to 64
[ 0.231149] pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 0.231153] pci 0000:00:1c.5: setting latency timer to 64
[ 0.231159] pci 0000:00:1e.0: setting latency timer to 64
[ 0.231163] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.231166] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.231169] pci_bus 0000:01: resource 0 io: [0x8000-0x8fff]
[ 0.231172] pci_bus 0000:01: resource 1 mem: [0xf8700000-0xfe7fffff]
[ 0.231175] pci_bus 0000:01: resource 2 pref mem [0xbfe00000-0xdfdfffff]
[ 0.231178] pci_bus 0000:04: resource 0 io: [0x1000-0x1fff]
[ 0.231181] pci_bus 0000:04: resource 1 mem: [0xb0000000-0xb03fffff]
[ 0.231183] pci_bus 0000:04: resource 2 pref mem [0xdfe00000-0xdfefffff]
[ 0.231186] pci_bus 0000:03: resource 0 io: [0xa000-0xafff]
[ 0.231189] pci_bus 0000:03: resource 1 mem: [0xfe900000-0xfe9fffff]
[ 0.231192] pci_bus 0000:03: resource 2 pref mem [0xb0400000-0xb05fffff]
[ 0.231195] pci_bus 0000:02: resource 0 io: [0x9000-0x9fff]
[ 0.231197] pci_bus 0000:02: resource 1 mem: [0xfe800000-0xfe8fffff]
[ 0.231200] pci_bus 0000:02: resource 2 pref mem [0xb0600000-0xb07fffff]
[ 0.231203] pci_bus 0000:05: resource 0 io: [0xb000-0xbfff]
[ 0.231206] pci_bus 0000:05: resource 1 mem: [0xfea00000-0xfeafffff]
[ 0.231208] pci_bus 0000:05: resource 3 io: [0x00-0xffff]
[ 0.231211] pci_bus 0000:05: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.231244] NET: Registered protocol family 2
[ 0.231437] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.233070] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.240422] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.241386] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.241389] TCP reno registered
[ 0.241524] NET: Registered protocol family 1
[ 1.473042] pci 0000:01:00.0: Boot video device
[ 1.473121] Unpacking initramfs…
[ 1.709917] Freeing initrd memory: 8840k freed
[ 1.714363] audit: initializing netlink socket (disabled)
[ 1.714378] type=2000 audit(1287679444.712:1): initialized
[ 1.717956] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.719634] VFS: Disk quotas dquot_6.5.2
[ 1.719696] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.719784] msgmni has been set to 5535
[ 1.720008] alg: No test for stdrng (krng)
[ 1.720065] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.720069] io scheduler noop registered
[ 1.720071] io scheduler anticipatory registered
[ 1.720073] io scheduler deadline registered
[ 1.720114] io scheduler cfq registered (default)
[ 1.720244] alloc irq_desc for 24 on node -1
[ 1.720247] alloc kstat_irqs on node -1
[ 1.720258] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[ 1.720264] pcieport 0000:00:01.0: setting latency timer to 64
[ 1.720360] alloc irq_desc for 25 on node -1
[ 1.720362] alloc kstat_irqs on node -1
[ 1.720372] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
[ 1.720379] pcieport 0000:00:1c.0: setting latency timer to 64
[ 1.720497] alloc irq_desc for 26 on node -1
[ 1.720499] alloc kstat_irqs on node -1
[ 1.720507] pcieport 0000:00:1c.4: irq 26 for MSI/MSI-X
[ 1.720514] pcieport 0000:00:1c.4: setting latency timer to 64
[ 1.720629] alloc irq_desc for 27 on node -1
[ 1.720631] alloc kstat_irqs on node -1
[ 1.720638] pcieport 0000:00:1c.5: irq 27 for MSI/MSI-X
[ 1.720645] pcieport 0000:00:1c.5: setting latency timer to 64
[ 1.722516] Linux agpgart interface v0.103
[ 1.722585] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.722682] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.723014] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.723247] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 1.723327] PNP: No PS/2 controller found. Probing ports directly.
[ 1.726093] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.726100] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.726195] mice: PS/2 mouse device common for all mice
[ 1.726236] rtc_cmos 00:03: RTC can wake from S4
[ 1.726277] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.726301] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.726318] cpuidle: using governor ladder
[ 1.726320] cpuidle: using governor menu
[ 1.726325] No iBFT detected.
[ 1.726674] TCP cubic registered
[ 1.726803] NET: Registered protocol family 10
[ 1.727335] lo: Disabled Privacy Extensions
[ 1.727636] Mobile IPv6
[ 1.727640] NET: Registered protocol family 17
[ 1.727728] PM: Resume from disk failed.
[ 1.727739] registered taskstats version 1
[ 1.728160] rtc_cmos 00:03: setting system clock to 2010-10-21 16:44:05 UTC (1287679445)
[ 1.728192] Initalizing network drop monitor service
[ 1.728222] Freeing unused kernel memory: 584k freed
[ 1.728446] Write protecting the kernel read-only data: 4232k
[ 1.744152] udev[56]: starting version 163
[ 1.865538] usbcore: registered new interface driver usbfs
[ 1.865575] usbcore: registered new interface driver hub
[ 1.865719] usbcore: registered new device driver usb
[ 1.867287] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.867327] alloc irq_desc for 18 on node -1
[ 1.867330] alloc kstat_irqs on node -1
[ 1.867341] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.867363] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1.867366] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 1.867392] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.867427] ehci_hcd 0000:00:1a.7: debug port 1
[ 1.871303] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[ 1.871498] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfebff800
[ 1.880540] SCSI subsystem initialized
[ 1.884831] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.884866] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.884869] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.884872] usb usb1: Product: EHCI Host Controller
[ 1.884874] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 1.884877] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.884973] usb usb1: configuration #1 chosen from 1 choice
[ 1.885011] hub 1-0:1.0: USB hub found
[ 1.885019] hub 1-0:1.0: 4 ports detected
[ 1.885089] alloc irq_desc for 23 on node -1
[ 1.885091] alloc kstat_irqs on node -1
[ 1.885102] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.885122] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.885125] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.885135] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 1.885167] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.889066] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 1.889154] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfebff400
[ 1.895565] libata version 3.00 loaded.
[ 1.897923] pata_jmicron 0000:03:00.1: enabling device (0000 -> 0001)
[ 1.897932] pata_jmicron 0000:03:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.897972] pata_jmicron 0000:03:00.1: setting latency timer to 64
[ 1.900675] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.900697] r8169 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.900742] r8169 0000:02:00.0: setting latency timer to 64
[ 1.900799] alloc irq_desc for 28 on node -1
[ 1.900802] alloc kstat_irqs on node -1
[ 1.900837] r8169 0000:02:00.0: irq 28 for MSI/MSI-X
[ 1.901570] eth0: RTL8168b/8111b at 0xffffc9001139c000, 00:18:f3:06:1e:0e, XID 18000000 IRQ 28
[ 1.904099] scsi0 : pata_jmicron
[ 1.904269] scsi1 : pata_jmicron
[ 1.905230] ata1: PATA max UDMA/100 cmd 0xac00 ctl 0xa880 bmdma 0xa400 irq 17
[ 1.905234] ata2: PATA max UDMA/100 cmd 0xa800 ctl 0xa480 bmdma 0xa408 irq 17
[ 1.905270] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.905305] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.905308] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.905311] usb usb2: Product: EHCI Host Controller
[ 1.905313] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 1.905316] usb usb2: SerialNumber: 0000:00:1d.7
[ 1.905401] usb usb2: configuration #1 chosen from 1 choice
[ 1.905438] hub 2-0:1.0: USB hub found
[ 1.905447] hub 2-0:1.0: 6 ports detected
[ 1.905756] Floppy drive(s): fd0 is 1.44M
[ 1.907835] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.907889] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.907900] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.907904] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.907919] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.907958] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000dc00
[ 1.907999] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.908002] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.908005] usb usb3: Product: UHCI Host Controller
[ 1.908007] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 1.908009] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.908094] usb usb3: configuration #1 chosen from 1 choice
[ 1.908131] hub 3-0:1.0: USB hub found
[ 1.908138] hub 3-0:1.0: 2 ports detected
[ 1.908193] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.908200] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1.908203] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.908212] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.908236] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000e000
[ 1.908270] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.908272] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.908275] usb usb4: Product: UHCI Host Controller
[ 1.908277] usb usb4: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 1.908280] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.908343] usb usb4: configuration #1 chosen from 1 choice
[ 1.908375] hub 4-0:1.0: USB hub found
[ 1.908382] hub 4-0:1.0: 2 ports detected
[ 1.908431] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.908437] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.908440] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.908448] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 1.908472] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000d480
[ 1.908506] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.908509] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.908512] usb usb5: Product: UHCI Host Controller
[ 1.908514] usb usb5: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 1.908516] usb usb5: SerialNumber: 0000:00:1d.0
[ 1.908582] usb usb5: configuration #1 chosen from 1 choice
[ 1.908612] hub 5-0:1.0: USB hub found
[ 1.908618] hub 5-0:1.0: 2 ports detected
[ 1.908667] alloc irq_desc for 19 on node -1
[ 1.908670] alloc kstat_irqs on node -1
[ 1.908677] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.908684] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.908687] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.908695] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 1.908727] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d800
[ 1.908764] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.908767] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.908769] usb usb6: Product: UHCI Host Controller
[ 1.908772] usb usb6: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 1.908774] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.908839] usb usb6: configuration #1 chosen from 1 choice
[ 1.908869] hub 6-0:1.0: USB hub found
[ 1.908875] hub 6-0:1.0: 2 ports detected
[ 1.908921] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.908928] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.908931] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.908942] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 1.911484] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d880
[ 1.911522] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.911525] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.911528] usb usb7: Product: UHCI Host Controller
[ 1.911530] usb usb7: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 1.911533] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.911609] usb usb7: configuration #1 chosen from 1 choice
[ 1.911643] hub 7-0:1.0: USB hub found
[ 1.911650] hub 7-0:1.0: 2 ports detected
[ 1.911727] ata_piix 0000:00:1f.2: version 2.13
[ 1.911741] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.911746] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.914987] ahci 0000:03:00.0: version 3.0
[ 1.915007] ahci 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.924623] FDC 0 is a post-1991 82077
[ 1.928924] ahci 0000:03:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 1.928930] ahci 0000:03:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 1.928937] ahci 0000:03:00.0: setting latency timer to 64
[ 1.929153] scsi2 : ahci
[ 1.929247] scsi3 : ahci
[ 1.929361] ata3: SATA max UDMA/133 abar m8192@0xfe9fe000 port 0xfe9fe100 irq 16
[ 1.929366] ata4: SATA max UDMA/133 abar m8192@0xfe9fe000 port 0xfe9fe180 irq 16
[ 2.017527] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 2.017814] scsi4 : ata_piix
[ 2.017901] scsi5 : ata_piix
[ 2.020420] ata5: SATA max UDMA/133 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 19
[ 2.020425] ata6: SATA max UDMA/133 cmd 0xe800 ctl 0xe480 bmdma 0xe408 irq 19
[ 2.020483] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 2.020488] ata_piix 0000:00:1f.5: MAP [ P0 – P1 – ]
[ 2.020531] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 2.020575] scsi6 : ata_piix
[ 2.020667] scsi7 : ata_piix
[ 2.022261] ata7: SATA max UDMA/133 cmd 0xd400 ctl 0xd080 bmdma 0xc880 irq 19
[ 2.022265] ata8: SATA max UDMA/133 cmd 0xd000 ctl 0xcc00 bmdma 0xc888 irq 19
[ 2.033060] ata1.00: ATAPI: TSSTcorp CDDVDW SH-S222A, SB02, max UDMA/66
[ 2.033108] ata1.01: ATAPI: PHILIPS DVDR1660P1, P1.3, max UDMA/33
[ 2.049047] ata1.00: configured for UDMA/66
[ 2.065320] ata1.01: configured for UDMA/33
[ 2.069891] scsi 0:0:0:0: CD-ROM TSSTcorp CDDVDW SH-S222A SB02 PQ: 0 ANSI: 5
[ 2.072268] scsi 0:0:1:0: CD-ROM PHILIPS DVDR1660P1 P1.3 PQ: 0 ANSI: 5
[ 2.128046] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.128076] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.132053] usb 1-3: new high speed USB device using ehci_hcd and address 2
[ 2.268409] usb 1-3: New USB device found, idVendor=0bf8, idProduct=100f
[ 2.268413] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.268492] usb 1-3: configuration #1 chosen from 1 choice
[ 2.350709] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.380131] usb 1-4: new high speed USB device using ehci_hcd and address 3
[ 2.504585] ata7: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.525519] usb 1-4: New USB device found, idVendor=05e3, idProduct=0710
[ 2.525522] usb 1-4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[ 2.525525] usb 1-4: Product: USB 2.0 Card
[ 2.525528] usb 1-4: Manufacturer: Genesys
[ 2.525530] usb 1-4: SerialNumber: 000000000000
[ 2.525624] usb 1-4: configuration #1 chosen from 1 choice
[ 2.532194] Initializing USB Mass Storage driver…
[ 2.532310] scsi8 : SCSI emulation for USB Mass Storage devices
[ 2.532401] usbcore: registered new interface driver usb-storage
[ 2.532404] USB Mass Storage support registered.
[ 2.532409] usb-storage: device found at 3
[ 2.532411] usb-storage: waiting for device to settle before scanning
[ 2.560282] ata7.00: ATA-7: MAXTOR STM3160815AS, 4.AAB, max UDMA/133
[ 2.560286] ata7.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.635249] ata7.00: configured for UDMA/133
[ 2.636553] usb 2-2: new high speed USB device using ehci_hcd and address 2
[ 2.768900] usb 2-2: New USB device found, idVendor=2040, idProduct=7070
[ 2.768903] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.768906] usb 2-2: Product: Nova-T Stick
[ 2.768908] usb 2-2: Manufacturer: Hauppauge
[ 2.768910] usb 2-2: SerialNumber: 4032285071
[ 2.768996] usb 2-2: configuration #1 chosen from 1 choice
[ 2.816143] ata6.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.816155] ata6.01: SATA link down (SStatus 4 SControl 300)
[ 2.816270] ata5.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.816282] ata5.01: SATA link down (SStatus 4 SControl 300)
[ 2.851813] ata5.00: ATA-8: MAXTOR STM3160813AS, MC1J, max UDMA/133
[ 2.851817] ata5.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.856299] ata6.00: ATA-7: MAXTOR STM3160215AS, 3.AAD, max UDMA/133
[ 2.856302] ata6.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.907676] ata5.00: configured for UDMA/133
[ 2.907800] scsi 4:0:0:0: Direct-Access ATA MAXTOR STM316081 MC1J PQ: 0 ANSI: 5
[ 2.922958] ata6.00: configured for UDMA/133
[ 2.923059] scsi 5:0:0:0: Direct-Access ATA MAXTOR STM316021 3.AA PQ: 0 ANSI: 5
[ 2.923276] scsi 6:0:0:0: Direct-Access ATA MAXTOR STM316081 4.AA PQ: 0 ANSI: 5
[ 2.924612] alloc irq_desc for 20 on node -1
[ 2.924615] alloc kstat_irqs on node -1
[ 2.924624] firewire_ohci 0000:05:01.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.936545] usb 2-4: new high speed USB device using ehci_hcd and address 4
[ 2.936864] sd 4:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 2.936924] sd 4:0:0:0: [sda] Write Protect is off
[ 2.936927] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.936953] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.937110] sda:
[ 2.937307] sd 5:0:0:0: [sdb] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 2.937366] sd 5:0:0:0: [sdb] Write Protect is off
[ 2.937369] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.937395] sd 5:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.937530] sdb:
[ 2.937714] sd 6:0:0:0: [sdc] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 2.937771] sd 6:0:0:0: [sdc] Write Protect is off
[ 2.937774] sd 6:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.937800] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.937934] sdc:sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.942316] Uniform CD-ROM driver Revision: 3.20
[ 2.942442] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 2.950590] sr1: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 2.950703] sr 0:0:1:0: Attached scsi CD-ROM sr1
[ 2.952034] sda1 < sdc1 sdc2
[ 2.958375] sd 6:0:0:0: [sdc] Attached SCSI disk
[ 2.959435] sda5 sdb1 < sdb5 sda6 sdb6 sda7 >
[ 2.981275] sd 4:0:0:0: [sda] Attached SCSI disk
[ 2.990262] sdb7 >
[ 2.990665] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 2.996189] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 2.996532] firewire_ohci: Added fw-ohci device 0000:05:01.0, OHCI version 1.10
[ 2.996950] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 2.997343] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 2.997718] sd 5:0:0:0: Attached scsi generic sg3 type 0
[ 2.997764] sd 6:0:0:0: Attached scsi generic sg4 type 0
[ 3.068888] usb 2-4: New USB device found, idVendor=058f, idProduct=6254
[ 3.068892] usb 2-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.068992] usb 2-4: configuration #1 chosen from 1 choice
[ 3.069170] hub 2-4:1.0: USB hub found
[ 3.069254] hub 2-4:1.0: 4 ports detected
[ 3.308053] usb 6-1: new low speed USB device using uhci_hcd and address 2
[ 3.386804] PM: Starting manual resume from disk
[ 3.386808] PM: Resume from partition 8:6
[ 3.386809] PM: Checking hibernation image.
[ 3.401240] PM: Error -22 checking image file
[ 3.401242] PM: Resume from disk failed.
[ 3.443267] EXT4-fs (sda5): INFO: recovery required on readonly filesystem
[ 3.443272] EXT4-fs (sda5): write access will be enabled during recovery
[ 3.465700] usb 6-1: New USB device found, idVendor=1267, idProduct=0103
[ 3.465703] usb 6-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.465825] usb 6-1: configuration #1 chosen from 1 choice
[ 3.477951] usbcore: registered new interface driver hiddev
[ 3.491016] input: HID 1267:0103 as /devices/pci0000:00/0000:00:1d.1/usb6/6-1/6-1:1.0/input/input1
[ 3.491092] generic-usb 0003:1267:0103.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 1267:0103] on usb-0000:00:1d.1-1/input0
[ 3.496251] firewire_core: created device fw0: GUID 0011d80000e03c05, S400
[ 3.513812] input: HID 1267:0103 as /devices/pci0000:00/0000:00:1d.1/usb6/6-1/6-1:1.1/input/input2
[ 3.513942] generic-usb 0003:1267:0103.0002: input,hidraw1: USB HID v1.10 Device [HID 1267:0103] on usb-0000:00:1d.1-1/input1
[ 3.513969] usbcore: registered new interface driver usbhid
[ 3.513972] usbhid: v2.6:USB HID core driver
[ 3.550792] EXT4-fs (sda5): recovery complete
[ 3.553098] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 3.556111] usb 2-4.1: new low speed USB device using ehci_hcd and address 5
[ 3.667850] usb 2-4.1: New USB device found, idVendor=046d, idProduct=c019
[ 3.667854] usb 2-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.667857] usb 2-4.1: Product: USB Optical Mouse
[ 3.667859] usb 2-4.1: Manufacturer: Logitech
[ 3.667964] usb 2-4.1: configuration #1 chosen from 1 choice
[ 3.669974] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4.1/2-4.1:1.0/input/input3
[ 3.670044] generic-usb 0003:046D:C019.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.7-4.1/input0
[ 5.239099] udev[471]: starting version 163
[ 6.210341] ACPI: SSDT 00000000affa00f0 001C6 (v01 AMI CPU1PM 00000001 INTL 20060113)
[ 6.210882] processor LNXCPU:00: registered as cooling_device0
[ 6.211500] ACPI: SSDT 00000000affa02c0 0013A (v01 AMI CPU2PM 00000001 INTL 20060113)
[ 6.211788] processor LNXCPU:01: registered as cooling_device1
[ 6.250614] cfg80211: Using static regulatory domain info
[ 6.250617] cfg80211: Regulatory domain: US
[ 6.250622] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.250623] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 6.250627] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.250630] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.250633] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.250636] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.250639] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 6.250832] cfg80211: Calling CRDA for country: US
[ 6.507841] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[ 6.507899] ACPI: Power Button [PWRB]
[ 6.507968] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 6.508004] ACPI: Power Button [PWRF]
[ 6.516540] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 6.626421] rtl8180 0000:05:04.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.641773] dib0700: loaded with support for 13 different device-types
[ 6.642071] dvb-usb: found a ‘Hauppauge Nova-T Stick’ in cold state, will try to load a firmware
[ 6.642076] usb 2-2: firmware: requesting dvb-usb-dib0700-1.20.fw
[ 6.964831] nvidia: module license ‘NVIDIA’ taints kernel.
[ 6.964835] Disabling lock debugging due to kernel taint
[ 7.319720] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[ 7.319729] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 7.319734] ACPI: I/O resource 0000:00:1f.3 [0x400-0x41f] conflicts with ACPI region SMRG [0x400-0x40f]
[ 7.319781] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 7.336176] dvb-usb: did not find the firmware file. (dvb-usb-dib0700-1.20.fw) Please see linux/Documentation/dvb/ for more details on firmware-problems. (-2)
[ 7.336268] usbcore: registered new interface driver dvb_usb_dib0700
[ 7.366781] phy0: Selected rate control algorithm ‘minstrel’
[ 7.367469] phy0: hwaddr 00:14:d1:e3:19:00, RTL8185vD + rtl8225z2
[ 7.493178] parport_pc 00:0b: reported by Plug and Play ACPI
[ 7.493282] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 7.533033] usb-storage: device scan complete
[ 7.534403] scsi 8:0:0:0: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 7.536045] scsi 8:0:0:1: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 7.537662] scsi 8:0:0:2: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 7.538905] scsi 8:0:0:3: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 7.541399] scsi 8:0:0:4: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 7.542379] sd 8:0:0:0: Attached scsi generic sg5 type 0
[ 7.542888] sd 8:0:0:1: Attached scsi generic sg6 type 0
[ 7.543423] sd 8:0:0:2: Attached scsi generic sg7 type 0
[ 7.544109] sd 8:0:0:3: Attached scsi generic sg8 type 0
[ 7.544749] sd 8:0:0:4: Attached scsi generic sg9 type 0
[ 7.567027] sd 8:0:0:0: [sdd] Attached SCSI removable disk
[ 7.568044] sd 8:0:0:1: [sde] Attached SCSI removable disk
[ 7.569157] sd 8:0:0:2: [sdf] Attached SCSI removable disk
[ 7.570401] sd 8:0:0:3: [sdg] Attached SCSI removable disk
[ 7.571647] sd 8:0:0:4: [sdh] Attached SCSI removable disk
[ 7.573800] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 7.573810] nvidia 0000:01:00.0: setting latency timer to 64
[ 7.573815] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 7.574309] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 195.36.24 Thu Apr 22 19:10:14 PDT 2010
[ 7.913585] alloc irq_desc for 22 on node -1
[ 7.913588] alloc kstat_irqs on node -1
[ 7.913597] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 7.913642] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 8.346356] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7
[ 8.926953] Adding 3905528k swap on /dev/sda6. Priority:-1 extents:1 across:3905528k
[ 8.972910] Adding 2931820k swap on /dev/sdb6. Priority:-2 extents:1 across:2931820k
[ 9.399572] loop: module loaded
[ 10.021095] EXT4-fs (sda7): mounted filesystem with ordered data mode
[ 10.731870] fuse init (API version 7.13)
[ 11.125407] r8169: eth0: link up
[ 11.125416] r8169: eth0: link up
[ 16.711698] lp0: using parport0 (interrupt-driven).
[ 16.841342] ppdev: user-space parallel port driver
[ 17.761770] [drm] Initialized drm 1.1.0 20060810
[ 19.204497] mtrr: base(0xfb000000) is not aligned on a size(0xe00000) boundary
[ 21.632008] eth0: no IPv6 routers present
[ 226.096532] lo: Disabled Privacy Extensions
[/code
La référence de ma carte : TRENDnet TEW-423PI H/W:C1.2R
