Merci l’info aptitude update et aptitude upgrade fonctionne mieux.
J’attends qu’il ternmine pour voir le résultat
Azigui
Azigui
Par contre il fait beaucoup de suppression, va-til ensuite effectuer une mise à niveau
J’ai trouvé une sacré liste de linux-image mais laquelle je dois choisir:
v linux-image -
v linux-image-2.6 -
p linux-image-2.6-486 - Linux 2.6 image on old PCs
i linux-image-2.6-686 - Linux 2.6 image on modern PCs
p linux-image-2.6-686-bigmem - Linux 2.6 image on PCs with 4GB+ RAM
p linux-image-2.6-amd64 - Linux 2.6 image on 64-bit PCs
p linux-image-2.6-k7 - Image du noyau Linux version 2.6 pour AMD
p linux-image-2.6-openvz-686 - Linux 2.6 image on PPro/Celeron/PII/PIII/P
p linux-image-2.6-vserver-686 - Linux 2.6 image on PPro/Celeron/PII/PIII/P
p linux-image-2.6-vserver-686-big - Linux 2.6 image on PPro/Celeron/PII/PIII/P
p linux-image-2.6-xen-686 - Linux 2.6 image on i686, oldstyle Xen supp
p linux-image-2.6.26-1-486 - Linux 2.6.26 image on x86
i A linux-image-2.6.26-1-686 - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-1-686-bigmem - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-1-amd64 - Linux 2.6.26 image on AMD64
p linux-image-2.6.26-1-openvz-686 - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-1-vserver-68 - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-1-xen-686 - Linux 2.6.26 image on i686, oldstyle Xen s
p linux-image-2.6.26-2-486 - Linux 2.6.26 image on x86
i linux-image-2.6.26-2-686 - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-2-686-bigmem - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-2-amd64 - Linux 2.6.26 image on AMD64
p linux-image-2.6.26-2-openvz-686 - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-2-vserver-68 - Linux 2.6.26 image on PPro/Celeron/PII/PII
p linux-image-2.6.26-2-xen-686 - Linux 2.6.26 image on i686, oldstyle Xen s
p linux-image-2.6.30-2-486 - Linux 2.6.30 image on x86
p linux-image-2.6.30-2-686 - Linux 2.6.30 image on PPro/Celeron/PII/PII
p linux-image-2.6.30-2-686-bigmem - Linux 2.6.30 image on PPro/Celeron/PII/PII
p linux-image-2.6.30-2-amd64 - Linux 2.6.30 image on AMD64
p linux-image-2.6.31-1-486 - Linux 2.6.31 for old PCs
p linux-image-2.6.31-1-686 - Linux 2.6.31 for modern PCs
p linux-image-2.6.31-1-686-bigmem - Linux 2.6.31 for PCs with 4GB+ RAM
p linux-image-2.6.31-1-amd64 - Linux 2.6.31 for 64-bit PCs
p linux-image-2.6.32-rc8-486 - Linux 2.6.32-rc8 for old PCs
p linux-image-2.6.32-rc8-686 - Linux 2.6.32-rc8 for modern PCs
p linux-image-2.6.32-rc8-686-bigm - Linux 2.6.32-rc8 for PCs with 4GB+ RAM
p linux-image-2.6.32-rc8-amd64 - Linux 2.6.32-rc8 for 64-bit PCs
p linux-image-2.6.32-trunk-486 - Linux 2.6.32 for old PCs
p linux-image-2.6.32-trunk-686 - Linux 2.6.32 for modern PCs
p linux-image-2.6.32-trunk-686-bi - Linux 2.6.32 for PCs with 4GB+ RAM
p linux-image-2.6.32-trunk-amd64 - Linux 2.6.32 for 64-bit PCs
p linux-image-486 - Linux image on old PCs
p linux-image-686 - Linux image on modern PCs
p linux-image-686-bigmem - Linux image on PCs with 4GB+ RAM
p linux-image-amd64 - Linux image on 64-bit PCs
p linux-image-k7 - Linux image on AMD K7 - transition package
p linux-image-openvz-686 - Linux image on PPro/Celeron/PII/PIII/P4, O
p linux-image-vserver-686 - Linux image on PPro/Celeron/PII/PIII/P4, L
p linux-image-vserver-686-bigmem - Linux image on PPro/Celeron/PII/PIII/P4, L
p linux-image-xen-686 - Linux image on i686, oldstyle Xen support
Ma config est :
Packard Bell de 2005
Processeur : Athlon 64 2Ghz
1,2 Go de RAM
ATI Radeon
Actuellement, j’ai Linux-2.6.26-2-686
[quote=“linux78”][quote=“azigui”]J’ai pu faire apt-get upgrade.
il n’a rien récupéré ni mis à jour.
Du coup je n’ai plus accès à ma fenêtre de session mais directement à ma console, et je n’ai pas corrigé les erreurs sur le kernel.
Merci de ton aide
Azigui[/quote]
Regarde si il n’y a pas de problèmes du côté des bureaux graphiques (essaye de les lancer depuis la console et tiens-moi au courant de l’évolution du problème).[/quote]
comment peut-on le lancer depuis la console ?
Azigui
[quote=“azigui”]Bonjour à tous,
Nouveau sur ce forum et dans le monde de Linux, je fais appel à votre aide.
Voilà que depuis 2 jours, en redémarrant ma machine, j’ai ce message :
“udevd: missing sysfs features; please update the kernel or disable kernel’s CONFIG_SYSFS_DEPRECATED”.
Résultat j’ai ma fenetre de session qui clignote continuellement, et donc impossible de saisir mon login et password. Le pb vient du fait que j’ai tenté de mettre à jour ma version Debian Lenny, qui a planté et au lieu de rester sur la session et de corriger le bug, j’ai redémarrer ma bécane.
J’ai pu passer en mode console modifier le fichier de conf du noyau en désactivant les modules “CONFIG_SYSFS_DEPRECATED=y” et “CONFIG_SYSFS_DEPRECATED_V2=y” en les passant à “is not set”,
mais je ne sais pas compiler.
Cordialement,
Azigui[/quote]
Quelles sont les commandes pour recompiler mon kernel actuel ?
Doit-on être dans un répertoire spécifique ?
Azigui
[quote=“azigui”][quote=“linux78”][quote=“azigui”]J’ai pu faire apt-get upgrade.
Merci de ton aide
Azigui[/quote]
Azigui[/quote]
J’ai trouvé la commande c’est startx, et là j’ai un écran noir
[quote=“azigui”][quote=“azigui”][quote=“linux78”][quote=“azigui”]J’ai pu faire apt-get upgrade.
Merci de ton aide
Azigui[/quote]
Azigui[/quote]
J’ai trouvé la commande c’est startx, et là j’ai un écran noir[/quote]
Tente un apt-get -f install ou un dpkg-configure -a.
avec la commande apt-get -f install, j’ai:
0 maj, 0 nouvellement installé, 0 à enlever et 0 non mis à jour
avec la cde dpkg-configure-a, j’ai:
command not found
Azigui
[quote=“azigui”]avec la commande apt-get -f install, j’ai:
command not found
Azigui[/quote]
Je me suis trompé, excuse-moi, c’est:
dpkg-configure -a
T’as essayé de mettre un nvx kernel comme conseillé dans ton premier post(ce qui ne changera rien par rapport à ton pb de lancement de X à mon avis):
Ensuite, quelle environnement utilises-tu ? (gnome, kde ?)
Lors de la MAJ problématique, qu’est-ce qui a été mis à jour ?
Quelle est ta carte graphique, et que contient ton xorg.conf ?
J’utilise le bureau Gnome.
Concernant les maj, je ne sais pas exactement ce qui l’a été, tout ce que je peux dire c’est que j’ai utilisé les sources de Lenny et Testing.
ma carte grapique est une ATI Radeon, je crois.
Sur mon fichier xorg.conf est indiqué
Section "Device"
Indentifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Merci de ton aide
Azigui
[quote=“yanlolot”]T’as essayé de mettre un nvx kernel comme conseillé dans ton premier post(ce qui ne changera rien par rapport à ton pb de lancement de X à mon avis):
Quelle est ta carte graphique, et que contient ton xorg.conf ?[/quote]
Merci yanlolot,
Super, je n’ai plus mon message d’erreur en updatant le kernel.
Par contre je n’arrive toujours pas à affcher mon bureau graphique
Azigui
[quote=“azigui”][quote=“yanlolot”]T’as essayé de mettre un nvx kernel comme conseillé dans ton premier post(ce qui ne changera rien par rapport à ton pb de lancement de X à mon avis):
Merci yanlolot,
Azigui[/quote]
Essaye de lancer ton gestionnaire graphique (en tant que root) et tiens nous au courant du problème.
[quote=“linux78”][quote=“azigui”][quote=“yanlolot”]T’as essayé de mettre un nvx kernel comme conseillé dans ton premier post(ce qui ne changera rien par rapport à ton pb de lancement de X à mon avis):
Merci yanlolot,
Azigui[/quote]
Essaye de lancer ton gestionnaire graphique (en tant que root) et tiens nous au courant du problème.[/quote]
en utilisant la cde startx ?
Ecran noir à nouveau.
Dois-je redémarrer la machine en mode console pour sortir de cet écran noir ?
En lançant apt-get install gnome, j’ai comme message :
Lecture des listes de paquets…
Construction de l’arbre des dépendances…
Lecture des informations d’état…
que vous avez demandé l’impossible, ou bien, si vous utilisez
la distribution unstable, que certains paquets n’ont pas encore
été créés ou ne sont pas sortis d’Incoming.
L’information suivante devrait vous aider à résoudre la situation :
gnome: Dépend: gnome-desktop-environment (= 1:2.22.2~5) mais ne sera pas installé
Dépend: gdm-themes mais ne sera pas installé
Dépend: gnome-games (>= 1:2.22.2) mais ne sera pas installé
Dépend: rhythmbox (>= 0.11.5) mais ne sera pas installé
Dépend: system-config-printer (>= 1.0.0) mais ne sera pas installé
Dépend: totem-mozilla mais ne sera pas installé
Dépend: epiphany-extensions mais ne sera pas installé
Dépend: evolution-plugins (>= 2.22.2) mais ne sera pas installé
Dépend: evolution-exchange (>= 2.22.2) mais ne sera pas installé
Dépend: evolution-webcal (>= 2.21.92) mais ne sera pas installé
Dépend: gnome-spell (>= 1.0.4) mais ne sera pas installé
Dépend: serpentine mais ne sera pas installé
Dépend: gnome-app-install mais ne sera pas installé
Dépend: bluez-gnome mais ne sera pas installé
Dépend: gnome-vfs-obexftp mais ne sera pas installé
Recommande: gnome-office (= 1:2.22.2~5) mais ne sera pas installé
Recommande: tomboy (>= 0.10.2)
Recommande: update-notifier mais ne sera pas installé
Recommande: empathy mais ne sera pas installé ou
pidgin mais ne sera pas installé
Recommande: tsclient mais ne sera pas installé
Recommande: network-manager-gnome mais ne sera pas installé
Recommande: gthumb mais ne sera pas installé
Recommande: liferea mais ne sera pas installé ou
blam mais ne sera pas installé
Recommande: gdebi mais ne sera pas installé
Paquets défectueux
[quote=“azigui”]Ecran noir à nouveau.
Paquets défectueux
Merci[/quote]
Fais un apt-get -f install gnome.
J’ai eu le même problème que celui décrit dans le 1er message (je suis en SID), un ctrl+c au démarrage permet de passer outre le message d’erreur, ensuite la commade suivante à réglé le problème :
pl.
Enfin,
J’ai fait un aptitude install gnome, l’install s’est faite mais j’ai des erreurs sur desktop-base, comme quoi il n’a pas pu configuré.
J’ai rebooté, je suis maintenant sur mon bureau graphique GNOME. J’ai juste une fenêtre avec un message d’erreur suivant :
“Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network was broken”
GNOME esssaiera de redémarrer le démon des préférences la prochaine fois que vous vous connecterez.
Si vous avez une idée, je suis preneur, en tout cas je tenais à vous remercier tous pour votre aide.
Cdlt,
Azigui
[quote=“azigui”]Enfin,
Cdlt,
Azigui[/quote]
un dpkg-configure -a devrait faire l’affaire.
En fait c’est dpkg --configure -a, mais j’ai comme message :
Paramétrage de desktop-base (5.0.3) …
update-alternatives: error: le chemin alternatif /usr/share/images/desktop-base/debblue-1600x1200.png n’existe pas.
dpkg : erreur de traitement de desktop-base (–configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d’état 2
dpkg : des problèmes de dépendances empêchent la configuration de gnome-desktop-environment :
gnome-desktop-environment dépend de desktop-base ; cependant :
Le paquet desktop-base n’est pas encore configuré.
dpkg : erreur de traitement de gnome-desktop-environment (–configure) :
problèmes de dépendances - laissé non configuré
desktop-base
Azigui
