Impossible de démarrer une session graphique depuis mon installation de buster [résolu]
Tags: #<Tag:0x00007f63f4ac6cf0> #<Tag:0x00007f63f4ac6c00> #<Tag:0x00007f63f4ac6a20>
J’ai installer Buster en UEFI. L’affichage graphique ne se lance pas.
J’exécute startx en root ou en utilisateur normal, j’ai cette erreur qui s’affiche:
(==) Log file: "/var/log/Xorg.1.log", Time: Mon Jan 27 20:09:49 2020
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(II) [KMS] drm report modesetting isn't supported.
(EE)
Fatal server error:
(EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
xinit: unable to connect to X server: Connection refused
Le fichier de log /var/log/Xorg.1.log :
[  9828.240] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  9828.240] (II) FBDEV: driver for framebuffer: fbdev
[  9828.240] (II) VESA: driver for VESA chipsets: vesa
[  9828.240] (II) [KMS] drm report modesetting isn't supported.
[  9828.240] (WW) Falling back to old probe method for modesetting
[  9828.240] (II) modeset(2): using default device
[  9828.240] (II) Loading sub module "fbdevhw"
[  9828.240] (II) LoadModule: "fbdevhw"
[  9828.240] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  9828.240] (II) Module fbdevhw: vendor="Xorg Foundation"
[  9828.240] 	compiled for 1.20.4, module version = 0.0.2
[  9828.240] 	ABI class: X.Org Video Driver, version 24.0
[  9828.241] (EE) Unable to find a valid framebuffer device
[  9828.241] (WW) Falling back to old probe method for fbdev
[  9828.241] (II) Loading sub module "fbdevhw"
[  9828.241] (II) LoadModule: "fbdevhw"
[  9828.241] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  9828.241] (II) Module fbdevhw: vendor="X.Org Foundation"
[  9828.241] 	compiled for 1.20.4, module version = 0.0.2
[  9828.241] 	ABI class:  X.Org  Video Driver, version 24.0
[  9828.241] (II) FBDEV(4): using default device
[  9828.241] (II) modeset(G0): using drv /dev/dri/card0
[  9828.241] (EE) Screen 0 deleted because of no matching config section.
[  9828.241] (II) UnloadModule: "radeon"
[  9828.241] (II) UnloadModule: "modesetting"
[  9828.241] (EE) Screen 1 deleted because of no matching config section.
[  9828.241] (II) UnloadModule: "fbdev"
[  9828.241] (II) UnloadSubModule: "fbdevhw"
[  9828.241] (EE)
Fatal server error:
[  9828.241] (EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
[  9828.241] (EE)
merci pour votre aide.
Déjà, si tu sais faire, tu dois pouvoir récupèrer une interface graphique de dépannage en passant un argument nomodeset au boot linux dans grub (je pense que ça doit marcher, au vu des messages d’erreur).
Mais bon, ça, c’est pour un peu de confort temporaire, il faut surtout qu’on sache avec quelle carte graphique ça plante.
Ca serait bien d’avoir le résultat de lspci -k | grep -A2 -Ei "vga|display"
Je ne sais pas utiliser nomodeset. Par contre j’ai réglé, je suppose, le problème en installant le paquet de firmware-linux-nonfree et en réinstallant Xorg hier. Je ne l’avais pas redémarré depuis mais aujourd’hui lors de du démarrage du PC la session graphique s’est lancé correctement.
OK, ben ça doit être ça qui a marché.
Ca par contre, ça ne servait à rien.
