Le plus étrange c’est qu’avec l’installer que j’ai cité plus haut, ma carte wifi était détecté ?!?
Un petit
sudo dmesg |grep firmware
et / ou
sudo dmesg |grep iwlwifi
Peut peut-être donner des idées
et réinstaller firmware-iwlwifi
Retour premières commandes :
saloon@saloon:~$ sudo dmesg |grep firmware
[sudo] Mot de passe de saloon :
[ 5.756651] i915 0000:00:02.0: firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[ 5.756889] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
[ 9.429996] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[ 9.438830] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[ 9.536210] iwlwifi 0000:00:0c.0: firmware: failed to load iwl-dbg-cfg.ini (-2)
[ 9.536268] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 9.559869] iwlwifi 0000:00:0c.0: firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[ 9.560691] iwlwifi 0000:00:0c.0: loaded firmware version 46.6f9f215c.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 17.749252] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 17.754980] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[ 17.754992] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[ 19.163592] Bluetooth: hci0: Waiting for firmware download to complete
[ 19.178688] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[17016.540984] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[17016.541173] (NULL device *): firmware: direct-loading firmware regulatory.db
[17016.541222] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[17016.541233] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[17016.541689] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[17016.541891] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[20872.235334] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[20872.235591] (NULL device *): firmware: direct-loading firmware regulatory.db
[20872.235660] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[20872.235722] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[20872.236436] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[20872.236942] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[26619.719145] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[26619.719408] (NULL device *): firmware: direct-loading firmware regulatory.db
[26619.719472] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[26619.719537] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[26619.720394] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[26619.721028] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[59023.373553] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[59023.374698] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[59023.374725] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[59023.375505] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[59023.375507] (NULL device *): firmware: direct-loading firmware regulatory.db
[59023.375554] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[117272.459473] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[117272.459478] (NULL device *): firmware: direct-loading firmware regulatory.db
[117272.459725] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[117272.459804] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[117272.460405] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[117272.461710] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[122392.232968] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[122392.233190] (NULL device *): firmware: direct-loading firmware regulatory.db
[122392.233246] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[122392.233262] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[122392.233773] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[122392.234133] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[128238.874405] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[128238.874669] (NULL device *): firmware: direct-loading firmware regulatory.db
[128238.874712] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[128238.875196] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[128238.875424] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[128238.876010] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[143462.384943] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[143462.385135] (NULL device *): firmware: direct-loading firmware regulatory.db
[143462.385194] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[143462.385201] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[143462.385614] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[143462.385899] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[156391.237297] (NULL device *): firmware: direct-loading firmware i915/glk_dmc_ver1_04.bin
[156391.237796] (NULL device *): firmware: direct-loading firmware regulatory.db
[156391.237893] (NULL device *): firmware: direct-loading firmware regulatory.db.p7s
[156391.238267] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[156391.252364] (NULL device *): firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[156391.252715] (NULL device *): firmware: direct-loading firmware intel/ibt-17-16-1.sfi
saloon@saloon:~$ sudo dmesg |grep iwlwifi
[ 9.206159] Loading modules backported from iwlwifi
[ 9.206162] iwlwifi-stack-public:master:9470:66b8bd0c
[ 9.534844] iwlwifi 0000:00:0c.0: enabling device (0000 -> 0002)
[ 9.559918] iwlwifi 0000:00:0c.0: WRT: Overriding region id 0
[ 9.559920] iwlwifi 0000:00:0c.0: WRT: Overriding region id 1
[ 9.559922] iwlwifi 0000:00:0c.0: WRT: Overriding region id 2
[ 9.559924] iwlwifi 0000:00:0c.0: WRT: Overriding region id 3
[ 9.559925] iwlwifi 0000:00:0c.0: WRT: Overriding region id 4
[ 9.559927] iwlwifi 0000:00:0c.0: WRT: Overriding region id 6
[ 9.559928] iwlwifi 0000:00:0c.0: WRT: Overriding region id 8
[ 9.559930] iwlwifi 0000:00:0c.0: WRT: Overriding region id 9
[ 9.559931] iwlwifi 0000:00:0c.0: WRT: Overriding region id 10
[ 9.559933] iwlwifi 0000:00:0c.0: WRT: Overriding region id 11
[ 9.559934] iwlwifi 0000:00:0c.0: WRT: Overriding region id 15
[ 9.559936] iwlwifi 0000:00:0c.0: WRT: Overriding region id 16
[ 9.559937] iwlwifi 0000:00:0c.0: WRT: Overriding region id 18
[ 9.559938] iwlwifi 0000:00:0c.0: WRT: Overriding region id 19
[ 9.559940] iwlwifi 0000:00:0c.0: WRT: Overriding region id 20
[ 9.559941] iwlwifi 0000:00:0c.0: WRT: Overriding region id 21
[ 9.559943] iwlwifi 0000:00:0c.0: WRT: Overriding region id 28
[ 9.954101] iwlwifi 0000:00:0c.0: Detected Intel(R) Wireless-AC 9461, REV=0x312
[ 10.008887] iwlwifi 0000:00:0c.0: base HW address: a4:b1:c1:f8:db:e4
[ 10.147258] iwlwifi 0000:00:0c.0 wlo2: renamed from wlan0
saloon@saloon:~$
Pour le firmware j’ai déjà la dernière version et j’ai effectué plusieurs réinstallations. Toujours pas de réseau.
Vous avez remarqué cela ?
Bizarre qu’il soit détecté ainsi…
Pour répondre et clôturer ce post je vous apporte la solution à mon problème.
Il « suffit » de faire ce qui est expliqué ici : How to Update Linux Firmware on Debian Bullseye Guide • Updating Firmware • tutorialforlinux.com.
Et voila tout est OK pour moi, si ça peut aider quelqu’un.
