Installation phpmyadmin
$ aptitude search ~c
$ dpkg -l | grep dbconfig-common
$ dpkg -l | grep phpmyadmin
Pas de retours (rappel : dbconfig-common et phpmyadmin sont désinstallés)
$ dpkg -l | grep mysql
ii libdbd-mysql-perl 4.021-1+b1 amd64 Perl5 database interface to the MySQL database
ii libmysqlclient18:amd64 5.5.37-0+wheezy1 amd64 MySQL database client library
ii libqt4-sql-mysql:amd64 4:4.8.2+dfsg-11 amd64 Qt 4 MySQL database driver
ii mysql-client-5.5 5.5.37-0+wheezy1 amd64 MySQL database client binaries
ii mysql-common 5.5.37-0+wheezy1 all MySQL database common files, e.g. /etc/mysql/my.cnf
ii mysql-server 5.5.37-0+wheezy1 all MySQL database server (metapackage depending on the latest version)
ii mysql-server-5.5 5.5.37-0+wheezy1 amd64 MySQL database server binaries and system database setup
ii mysql-server-core-5.5 5.5.37-0+wheezy1 amd64 MySQL database server binaries
ii php5-mysql 5.4.4-14+deb7u11 amd64 MySQL module for php5
# find / -path ‘/usr/share’ -prune -o -path ‘/var/cache’ -prune -o -path ‘/var/lib/dpkg’ -prune -o -path ‘/var/log’ -prune -o -iname “phpmyadmin” -print
/var/tmp/phpmyadmin.phpmyadmin.2014-06-23-10.44.mysql.iYgryp
/var/tmp/phpmyadmin.phpmyadmin.2014-06-23-10.56.mysql.nNUWbK
/var/tmp/phpmyadmin.phpmyadmin.2014-06-23-10.47.mysql.eclUJh
/var/tmp/phpmyadmin.phpmyadmin.2014-06-23-18.31.mysql.gGRzeu
/var/tmp/phpmyadmin.phpmyadmin.2014-06-25-17.46.mysql.gT33hh
/var/tmp/phpmyadmin.phpmyadmin.2014-06-23-11.47.mysql.mU9DGa
[quote=“François”]$ aptitude search ~c
Pas de retours
C’est bien clean chez toi. :023
Ce retour s’il te plaît, en mode simulation (option -s)
# aptitude -s remove --purge mysql-client-5.5 mysql-common mysql-server mysql-server-5.5 mysql-server-core-5.5 php5-mysql
cdparanoia{pu} flac{pu} guile-1.8{pu} guile-1.8-libs{pu} libaio1{pu} libaudiofile1{pu} libdbd-mysql-perl{pu} libdbi-perl{pu}
libhtml-template-perl{pu} liblo7{pu} liblrdf0{pu} libnet-daemon-perl{pu} libplrpc-perl{pu} libraptor1{pu} librtaudio4{pu} librtmidi1{pu}
libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} mysql-client-5.5 mysql-common mysql-server
mysql-server-5.5 mysql-server-core-5.5 php5-mysql sndfile-programs{pu} sndfile-tools{pu} sox{pu} stk{pu} vorbis-tools{pu} wavpack{pu}
0 paquets mis à jour, 0 nouvellement installés, 34 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 809 Mo seront libérés.
Les paquets suivants ont des dépendances non satisfaites :
libmysqlclient18 : Dépend: mysql-common (>= 5.5.37-0+wheezy1) mais il ne sera pas installé.
 Supprimer les paquets suivants :
  1. libmysqlclient18
  2. libqt4-sql-mysql
Accepter cette solution ? [Y/n/q/?]
Ok.
À présent, ce retour, stp.
Accepter cette solution ? [Y/n/q/?] q
Abandon de tous les efforts pour rechercher une solution à ces dépendances.
Abandon.
# aptitude -s remove --purge mysql-client-5.5 mysql-server mysql-server-5.5 mysql-server-core-5.5 php5-mysql
Pas de retour
(PS : l’option -s rend les réponses “Y” et “n” équivalentes à “q” je suppose)
Y, j’accepte
N, non
Q, je quitte.
Extrait : [mono]$ man aptitude[/mono]
[quote] -s, --simulate
En mode ligne de commande, afficher la liste des actions qui seraient réalisées, mais ne pas les lancer réellement. Il n’est pas nécessaire d’avoir les privilèges
d’administration. Dans l’interface visuelle, ouvre toujours le cache en mode lecture seule que vous soyez administrateur ou non.
[quote=“François”]# aptitude -s remove --purge mysql-client-5.5 mysql-server mysql-server-5.5 mysql-server-core-5.5 php5-mysql
[strike]Pas de retour[/strike]
Désolé j’avais recopié aussi le # dans la console … ce qui renvoie à la ligne sans retour.
libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} mysql-client-5.5 mysql-server
0 paquets mis à jour, 0 nouvellement installés, 33 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 808 Mo seront libérés.
Voulez-vous continuer ? [Y/n/?]
Il y-a un truc qui cloche.
[quote=“François”]Les paquets suivants seront ENLEVÉS :
libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu}[/quote]
Quelques paquets pris au hasard …
[19:59:03] ~ # apt-cache depends cdparanoia cdparanoia Dépend: libc6 Dépend: libcdparanoia0 [19:59:22] ~ # [19:59:34] ~ # apt-cache depends flac flac Dépend: libc6 Dépend: libflac8 Dépend: libogg0 [19:59:38] ~ # [19:59:54] ~ # apt-cache depends liblo7 liblo7 Dépend: libc6 Suggère: liblo-dev [19:59:57] ~ # [20:00:07] ~ # apt-cache depends guile-1.8-libs guile-1.8-libs Dépend: libc6 Dépend: libgmp10 Dépend: libltdl7 Dépend: libncurses5 Dépend: libreadline6 Dépend: libtinfo5 Est en conflit avec: <guile-1.8-slib> Remplace: guile-1.8-dev Remplace: <guile-1.8-slib> guile-1.8-libs [20:00:10] ~ # [20:02:04] ~ # apt-cache depends libraptor1 libraptor1 Dépend: libc6 Dépend: libcurl3-gnutls Dépend: libxml2 Dépend: libxslt1.1 Suggère: raptor-utils [20:02:07] ~ #
[mono]$ apt-cache policy libc6[/mono] ??
libc6:
Installé : 2.13-38+deb7u1
Candidat : 2.13-38+deb7u1
Table de version :
*** 2.13-38+deb7u1 0
500 ftp.belnet.be/debian/ wheezy/main amd64 Packages
100 /var/lib/dpkg/status
Bon et bien essayons de déterminer le pourquoi du comment … :033
Ces retours séparés, stp.
# aptitude -s remove --purge mysql-server
# aptitude -s remove --purge mysql-server-5.5
# aptitude -s remove --purge mysql-server-core-5.5
# aptitude -s remove --purge php5-mysql
* edit *
$ apt-cache policy  mysql-client-5.5 mysql-server mysql-server-5.5 mysql-server-core-5.5 php5-mysql
cdparanoia{pu} flac{pu} guile-1.8{pu} guile-1.8-libs{pu} libaudiofile1{pu} liblo7{pu} liblrdf0{pu} libraptor1{pu} librtaudio4{pu}
librtmidi1{pu} libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} mysql-client-5.5
0 paquets mis à jour, 0 nouvellement installés, 23 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 752 Mo seront libérés.
mysql-server-5.5 : Dépend: mysql-client-5.5 (>= 5.5.37-0+wheezy1) mais il ne sera pas installé.
  1. mysql-server
  2. mysql-server-5.5
Abandon.
libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} mysql-client-5.5{pu} mysql-server
mysql-server-5.5{pu} mysql-server-core-5.5{pu} sndfile-programs{pu} sndfile-tools{pu} sox{pu} stk{pu} vorbis-tools{pu} wavpack{pu}
0 paquets mis à jour, 0 nouvellement installés, 32 à enlever et 0 non mis à jour.
Voulez-vous continuer ? [Y/n/?] n
Abandon.
librtmidi1{pu} libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} mysql-server-5.5
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 747 Mo seront libérés.
mysql-server : Dépend: mysql-server-5.5 mais il ne sera pas installé.
  1. mysql-server
Abandon.
librtmidi1{pu} libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} mysql-server-core-5.5
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 735 Mo seront libérés.
mysql-server-5.5 : Dépend: mysql-server-core-5.5 (>= 5.5.37-0+wheezy1) mais il ne sera pas installé.
  1. mysql-server
  2. mysql-server-5.5
Accepter cette solution ? [Y/n/q/?] n
 Conserver les paquets suivants dans leur version actuelle :
  1. mysql-server-core-5.5 [5.5.37-0+wheezy1 (now, stable)]
 Réinstaller à une version antérieure les paquets suivants :
  1. mysql-server-5.5 [5.5.37-0+wheezy1 (now, stable) -> 5.5.35+dfsg-0+wheezy1 (stable)]
  2. mysql-server-core-5.5 [5.5.37-0+wheezy1 (now, stable) -> 5.5.35+dfsg-0+wheezy1 (stable)]
*** Aucune autre solution disponible ***
Abandon.
librtmidi1{pu} libsdl-ttf2.0-0{pu} libstk0c2a{pu} lilypond{pu} lilypond-data{pu} lilypond-doc{pu} lmms-common{pu} php5-mysql
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 715 Mo seront libérés.
Abandon.
mysql-client-5.5:
Installé : 5.5.37-0+wheezy1
Candidat : 5.5.37-0+wheezy1
Table de version :
*** 5.5.37-0+wheezy1 0
500 security.debian.org/ wheezy/updates/main amd64 Packages
5.5.35+dfsg-0+wheezy1 0
mysql-server:
Table de version :
mysql-server-5.5:
Table de version :
mysql-server-core-5.5:
Table de version :
php5-mysql:
Installé : 5.4.4-14+deb7u11
Candidat : 5.4.4-14+deb7u11
Table de version :
*** 5.4.4-14+deb7u11 0
5.4.4-14+deb7u9 0
Aurais tu eus recours (quand ?) aux options [mono]markauto, unmarkauto[/mono] ? Cela te chante t-il ?
Jamais de ma propre initiative. Il m’arrive cependant de suivre des instructions prodiguées sur des forums (généralement celui-ci) …
Aucun souvenir de ces options.
Ok.
Allons-y … :wink:
À la suite de quoi, envoi le retour suivant. (option : -s)
# aptitude unmarkauto cdparanoia flac guile-1.8 guile-1.8-libs libaio1 libaudiofile1 libdbd-mysql-perl libdbi-perl libhtml-template-perl liblo7 liblrdf0 libnet-daemon-perl libplrpc-perl libraptor1 librtaudio4 librtmidi1 libsdl-ttf2.0-0 libstk0c2a lilypond lilypond-data lilypond-doc lmms-common sndfile-programs sndfile-tools sox stk vorbis-tools wavpack
cdparanoia{u} flac{u} guile-1.8{u} guile-1.8-libs{u} libaudiofile1{u} liblo7{u} liblrdf0{u} libraptor1{u} librtaudio4{u} librtmidi1{u}
libsdl-ttf2.0-0{u} libstk0c2a{u} lilypond{u} lilypond-data{u} lilypond-doc{u} lmms-common{u} sndfile-programs{u} sndfile-tools{u} sox{u}
stk{u} vorbis-tools{u} wavpack{u}
0 paquets mis à jour, 0 nouvellement installés, 22 à enlever et 0 non mis à jour.
Voulez-vous continuer ? [Y/n/?] Y
(Lecture de la base de données… 192333 fichiers et répertoires déjà installés.)
Suppression de cdparanoia …
Suppression de flac …
Suppression de lilypond …
Suppression de guile-1.8 …
Suppression de guile-1.8-libs …
Suppression de libaudiofile1:amd64 …
Suppression de liblo7 …
Suppression de liblrdf0 …
Suppression de libraptor1 …
Suppression de stk …
Suppression de libstk0c2a:amd64 …
Suppression de librtaudio4:amd64 …
Suppression de librtmidi1:amd64 …
Suppression de libsdl-ttf2.0-0:amd64 …
Suppression de lilypond-data …
Suppression de lilypond-doc …
Suppression de lmms-common …
Suppression de sndfile-programs …
Suppression de sndfile-tools …
Suppression de sox …
Suppression de vorbis-tools …
Suppression de wavpack …
Traitement des actions différées (« triggers ») pour « man-db »…
Traitement des actions différées (« triggers ») pour « menu »…
Traitement des actions différées (« triggers ») pour « fontconfig »…
Traitement des actions différées (« triggers ») pour « install-info »…
Traitement des actions différées (« triggers ») pour « mime-support »…
0 paquets mis à jour, 0 nouvellement installés, 6 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 90,9 Mo seront libérés.
  1. libdbd-mysql-perl
  2. libmysqlclient18
  3. libqt4-sql-mysql
Accepter cette solution ? [Y/n/q/?] Y
libdbd-mysql-perl{a} libmysqlclient18{a} libqt4-sql-mysql{a} mysql-client-5.5 mysql-common mysql-server mysql-server-5.5 mysql-server-core-5.5
php5-mysql
0 paquets mis à jour, 0 nouvellement installés, 9 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 95,1 Mo seront libérés.
Charger/installer/enlever des paquets.
[quote=“François”][mono]# aptitude unmarkauto cdparanoia flac guile-1.8 guile-1.8-libs libaio1 libaudiofile1 libdbd-mysql-perl libdbi-perl libhtml-template-perl liblo7 liblrdf0 libnet-daemon-perl libplrpc-perl libraptor1 librtaudio4 librtmidi1 libsdl-ttf2.0-0 libstk0c2a lilypond lilypond-data lilypond-doc lmms-common sndfile-programs sndfile-tools sox stk vorbis-tools wavpack
Les paquets suivants seront ENLEVÉS :[/mono]
[mono]cdparanoia{u} flac{u} guile-1.8{u} guile-1.8-libs{u} libaudiofile1{u} liblo7{u} liblrdf0{u} libraptor1{u} librtaudio4{u} librtmidi1{u}
[/mono]
[mono]Voulez-vous continuer ? [Y/n/?] Y[/mono]
C’est quoi ce … fouillis/torchon/tronqué/erroné/falsifié … ??
Pourrais-tu expliquer stp.
Sauf erreur, c’est à toi la main …
Je ne comprends pas ce que tu me dis. Je fais quoi maintenant ?
Re.
C’est toi qui vois … :whistle:
Cartes sur table, si je puis dire … :033
