pour répondre à la version du noyau j’étais sur 2.6
la commande uname -a me donne ceci :
Linux Debian 2.6.18-3-686 #1 SMP Mon Dec 4 16:41:14 UTC 2006 i686 GNU/Linux
J’ai tester la méthode mat mais rien …
Ensuite j’ai lancé 2 lecteurs de video :
le premier : totem
voilà le message d’erreur :
[code]Debian:/home/thibaut# totem
(totem:17338): GnomeUI-WARNING **: While connecting to session manager:
Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed.
** (totem:17338): WARNING **: Failed to connect to the session bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Creating link /root/.kde/socket-Debian.
can’t create mcop director[/code]y
et se referme tout seul.
Ensuite VLC :
[code]Debian:/home/thibaut# vlc
VLC media player 0.8.6a Janus
starting VLC root wrapper… using UID 0 (root)
- Running VLC as root is discouraged. *
It is potentially dangerous, and might not even work properly.
libdvdnav: Using dvdnav version 0.1.10 from http://dvd.sf.net
libdvdread: Using libdvdcss version 1.2.9 for DVD access
libdvdread: Can’t stat /home/thibaut/Films/13-Fantomes[FDT]Divx-fr-test\351-www. divxovore.com.avi
Aucun fichier ou répertoire de ce type
libdvdnav: vm: faild to open/read the DVD
[00000281] main input error: no suitable access module for `/home/thibaut/Films/ 13-Fantomes[FDT]Divx-fr-test\351-www.divxovore.com.avi’
[00000276] main playlist: nothing to play
ALSA lib confmisc.c:670:(snd_func_card_driver) cannot find card '0’
ALSA lib conf.c:3500:(_snd_config_evaluate) function snd_func_card_driver returned error: Aucun périphérique de ce type
ALSA lib confmisc.c:391:(snd_func_concat) error evaluating strings
ALSA lib conf.c:3500:(_snd_config_evaluate) function snd_func_concat returned error: Aucun périphérique de ce type
ALSA lib confmisc.c:1070:(snd_func_refer) error evaluating name
ALSA lib conf.c:3500:(_snd_config_evaluate) function snd_func_refer returned error: Aucun périphérique de ce type
ALSA lib conf.c:3968:(snd_config_expand) Evaluate error: Aucun périphérique de ce type
ALSA lib pcm.c:2143:(snd_pcm_open_noupdate) Unknown PCM default
[00000294] oss audio output error: cannot open audio device (/dev/dsp)
[00000294] main audio output error: couldn’t find a filter for the conversion
[00000294] main audio output error: couldn’t create audio output pipeline
[/code]>
le film se lance mais sans son et à priori cela viendrai du driver de la carte son …
