mysql> USE mysql;
Database changed
mysql> DESCRIBE user;
| Field | Type | Null | Key | Default | Extra |
| Host | char(60) | NO | PRI | | |
| User | char(32) | NO | PRI | | |
| Select_priv | enum('N','Y') | NO | | N | |
| Insert_priv | enum('N','Y') | NO | | N | |
| Update_priv | enum('N','Y') | NO | | N | |
| Delete_priv | enum('N','Y') | NO | | N | |
| Create_priv | enum('N','Y') | NO | | N | |
| Drop_priv | enum('N','Y') | NO | | N | |
| Reload_priv | enum('N','Y') | NO | | N | |
| Shutdown_priv | enum('N','Y') | NO | | N | |
| Process_priv | enum('N','Y') | NO | | N | |
| File_priv | enum('N','Y') | NO | | N | |
| Grant_priv | enum('N','Y') | NO | | N | |
| References_priv | enum('N','Y') | NO | | N | |
| Index_priv | enum('N','Y') | NO | | N | |
| Alter_priv | enum('N','Y') | NO | | N | |
| Show_db_priv | enum('N','Y') | NO | | N | |
| Super_priv | enum('N','Y') | NO | | N | |
| Create_tmp_table_priv | enum('N','Y') | NO | | N | |
| Lock_tables_priv | enum('N','Y') | NO | | N | |
| Execute_priv | enum('N','Y') | NO | | N | |
| Repl_slave_priv | enum('N','Y') | NO | | N | |
| Repl_client_priv | enum('N','Y') | NO | | N | |
| Create_view_priv | enum('N','Y') | NO | | N | |
| Show_view_priv | enum('N','Y') | NO | | N | |
| Create_routine_priv | enum('N','Y') | NO | | N | |
| Alter_routine_priv | enum('N','Y') | NO | | N | |
| Create_user_priv | enum('N','Y') | NO | | N | |
| Event_priv | enum('N','Y') | NO | | N | |
| Trigger_priv | enum('N','Y') | NO | | N | |
| Create_tablespace_priv | enum('N','Y') | NO | | N | |
| ssl_type | enum('','ANY','X509','SPECIFIED') | NO | | | |
| ssl_cipher | blob | NO | | NULL | |
| x509_issuer | blob | NO | | NULL | |
| x509_subject | blob | NO | | NULL | |
| max_questions | int(11) unsigned | NO | | 0 | |
| max_updates | int(11) unsigned | NO | | 0 | |
| max_connections | int(11) unsigned | NO | | 0 | |
| max_user_connections | int(11) unsigned | NO | | 0 | |
| plugin | char(64) | NO | | mysql_native_password | |
| authentication_string | text | YES | | NULL | |
| password_expired | enum('N','Y') | NO | | N | |
| password_last_changed | timestamp | YES | | NULL | |
| password_lifetime | smallint(5) unsigned | YES | | NULL | |
| account_locked | enum('N','Y') | NO | | N | |
45 rows in set (0,00 sec)
mysql>
Apparemment le champ a changé dans les dernières versions… Je ne savais pas.
UPDATE user SET authentication_string=password('glop') WHERE User="root" AND Host="localhost";
Après que tu es continué la manip’ du dessus tu devrai pouvoir te reconnecter sans problème avec les identifiants.
Edit : Juste une question que j’aurai du te poser au début, tu as installé lamp-server ou tu es passé par les paquets manuellement ?
sorry
j’ai pas pu répondre => trop de posts premier jour
j’ai créé un autre compte
Tout a fonctionné Mille merci
Tout est ok merci
J’ai pas pu te remercier, les nouveaux sont bloqués à 22 messages le premier jour. (je suis devenu fou !)
Phpmyadmin fonctionne aussi.
Je vais installer un Wordpress pour vérifier tout çà mais il n’y a pas de raison.
Tes compétences et ta gentillesse m’ont impressionné !
Je vais revenir ces jours ci et j’espère t’y retrouver
Faudrait que je configure mon réseau (avec Windows 7)
So long…
Du coup ton problème initial avec phpmyadmin est aussi réglé ?
