Lenny vers squeeze
Surement vu que je ne sais pas ce que c’est…
ok je viens de voir ce que c’est…Ben non pourquoi ? lorsque je veux mettre en gras ou en code ça semble fonctionner…
[code]root@fit:/tmp/dpkg-avertissements# aptitude -s full-upgrade
libav-tools{a} libavcodec53{a} libavdevice53{ab} libavfilter2{a} libavformat53{a} libavutil51{a} libcdio-cdda1{a} libcdio-paranoia1{a} libcdio13{a} libopencv-core2.3{a} libopencv-imgproc2.3{a}
libpostproc52{a} libswscale2{a} libtbb2{a} libuuid-perl{ab} libvpx1{a} libx264-123{a} linux-base{a} linux-image-2.6.32-5-486{a} odbcinst{a} odbcinst1debian2{ab}
apache2-mpm-prefork apache2-utils apache2.2-bin apache2.2-common bash bind9-host bsd-mailx cpio dnsutils dovecot-common dovecot-core dovecot-imapd dpkg e2fslibs e2fsprogs ffmpeg file gnupg gpgv
krb5-locales libapache2-mod-php5 libavutil49 libbind9-80 libc-bin libc-dev-bin libc6 libc6-dev libc6-i686 libcomerr2 libcurl3-gnutls libdbi-perl libdns88 libdrm2 libfreetype6 libgcrypt11 libgd2-xpm
libgnutls26 libgssapi-krb5-2 libisc84 libisccc80 libisccfg82 libk5crypto3 libkrb5-3 libkrb5support0 libldap-2.4-2 liblua5.1-0 liblwres80 libmagic-dev libmagic1 libmp3lame0 libmysqlclient16
libmysqlclient18 libpq5 libsdl1.2debian libsdl1.2debian-alsa libss2 libssh2-1 libssl-dev libssl0.9.8 libssl1.0.0 libsvn1 libtasn1-3 libtasn1-3-bin libva-x11-1 libva1 libx11-6 libx11-data libxext6
libxfixes3 libxml2 libxvidcore4 linux-image-2.6-486 linux-libc-dev mime-support multiarch-support mysql-client mysql-client-5.5 mysql-server-5.5 ntpdate openssh-client openssh-server openssl perl
perl-base perl-modules php-pear php5-cli php5-common php5-dev php5-gd php5-ldap php5-mcrypt php5-mysql procmail python-reportbug python2.6 python2.6-minimal reportbug spamassassin squid
squid-common subversion tcpdump tzdata udev unixodbc unzip wget
Les paquets suivants sont RECOMMANDÉS mais ne seront pas installés :
dovecot-gssapi dovecot-ldap dovecot-mysql dovecot-pgsql dovecot-sieve dovecot-sqlite firmware-linux-free gnupg-curl manpages-dev
108 paquets mis à jour, 21 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 115 Mo d’archives. Après dépaquetage, 104 Mo seront utilisés.
Les paquets suivants ont des dépendances non satisfaites :
odbcinst1debian2: Est en conflit avec: odbcinst1debian1 mais 2.2.11-16 est installé.
libuuid-perl: Dépend: perlapi-5.10.1 qui est un paquet virtuel
libavdevice53: Dépend: libpulse0 (>= 0.99.1) mais il ne sera pas installé.
Dépend: libx11-6 (>= 2:1.4.99.1) mais 2:1.3.3-4+squeeze2 doit être installé.
  Supprimer les paquets suivants :
  1.  ffmpeg
  2.  linux-image-2.6-486
  3.  unixodbc
    Conserver les paquets suivants dans leur version actuelle :
  4.  libav-tools [Non installé]
  5.  libavdevice53 [Non installé]
  6.  libuuid-perl [Non installé]
  7.  linux-base [Non installé]
  8.  linux-image-2.6.32-5-486 [Non installé]
  9.  odbcinst [Non installé]
  10. odbcinst1debian2 [Non installé]
Accepter cette solution ? [Y/n/q/?] n
ouverts : 165 ; fermés : 127 ; reportés : 19 ; en conflit : 21 .Les acti:
  1. ffmpeg
  3. odbcinst1debian1
  1.  linux-image-2.6-486
  2.  unixodbc
  3.  ffmpeg [5:0.7.12-0.0 (now)]
  2. odbcinst1debian1
Accepter cette solution ? [Y/n/q/?] [/code]
Le retour du [mono]full-upgrade[/mono] est plaisant.
Aller, remontes tes bretelles, [mono]upgrade[/mono] et sans option, sur la foi de ton précédent retour.
Avant cela, as-tu [mono]Kdm, Gdm, autre[/mono] d’installer, si oui tu stopperas le service concerné.
Mets un terme à [mono]mysql et apache2[/mono], vois pour les autres applications de ce type.
[code]# service apache2 stop
service mysql stop
service …[/code]
Au moindre souci, évites d’interrompre le processus, tu posts de suite et archives ta console.
Voici les “erreurs”
/usr/bin/perl: symbol lookup error: /usr/lib/perl5/auto/Net/DNS/DNS.so: undefined symbol: Perl_Gthr_key_ptr dpkg: erreur de traitement de spamassassin (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 127 Paramétrage de libdbi-perl (1.622-1+deb7u1) ...
Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed! invoke-rc.d: initscript mysql, action "start" failed. dpkg: erreur de traitement de mysql-server-5.5 (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1
Des erreurs ont été rencontrées pendant l'exécution : spamassassin mysql-server-5.5 E: Sub-process /usr/bin/dpkg returned an error code (1) Échec de l'installation d'un paquet. Tentative de réparation :
Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed! invoke-rc.d: initscript mysql, action "start" failed. dpkg: erreur de traitement de mysql-server-5.5 (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 Des erreurs ont été rencontrées pendant l'exécution : spamassassin mysql-server-5.5
État actuel : 4 mises à jour restantes [-104].
j’ai plus de loopback
Ces retours, stp.
[code]# dpkg --configure -a
$ apt-get check
apt-show-versions -u
dpkg -C[/code]
$ apt-cache policy perl $ dpkg -l |grep perl $ dpkg -l |grep mysql $ dpkg -l |grep spamassassin
Et ces deux là, complets.
$ aptitude -s upgrade $ aptitude -s full-upgrade
:wink:
Les problèmes mysql sont dus, comme pour mes int reseaux, du fait qu’il ne sont pas configurés au demarrage. Donc pas de loopback
je l’ai rajouté à la main le service démarre…
pour le reste
dpkg --configure -a Paramétrage de spamassassin (3.3.2-5+deb7u3) ... /usr/bin/perl: symbol lookup error: /usr/lib/perl5/auto/Net/DNS/DNS.so: undefined symbol: Perl_Gthr_key_ptr dpkg: erreur de traitement de spamassassin (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 127 Paramétrage de mysql-server-5.5 (5.5.43-0+deb7u1) ... Stopping MySQL database server: mysqld. Starting MySQL database server: mysqld .. Checking for corrupt, not cleanly closed and upgrade needing tables.. Des erreurs ont été rencontrées pendant l'exécution : spamassassin
root@fit:/etc/network# apt-get check Lecture des listes de paquets... Fait Construction de l'arbre des dépendances Lecture des informations d'état... Fait
root@fit:/etc/network# apt-show-versions -u Can't load '/usr/lib/perl5/auto/AptPkg/AptPkg.so' for module AptPkg: libapt-pkg-libc6.7-6.so.4.6: cannot open shared object file: No such file or directory at /usr/lib/perl/5.14/DynaLoader.pm line 184. at /usr/lib/perl5/AptPkg/Cache.pm line 8 Compilation failed in require at /usr/lib/perl5/AptPkg/Cache.pm line 8. BEGIN failed--compilation aborted at /usr/lib/perl5/AptPkg/Cache.pm line 8. Compilation failed in require at /usr/bin/apt-show-versions line 43. BEGIN failed--compilation aborted at /usr/bin/apt-show-versions line 43.
[code]root@fit:/etc/network# dpkg -C
Les paquets suivants sont à demi configurés, probablement à cause de
problèmes survenus lors de la première configuration. Il faudrait réessayer
de les configurer en utilisant dpkg --configure ou l’option
configure du menu de dselect :
spamassassin Perl-based spam filter using text analysis
Les paquets qui suivent ne possèdent pas de fichier de somme de contrôle MD5 dans
la base de données et doivent être réinstallés :
squirrelmail Webmail for nuts
netbase Basic TCP/IP networking system
doc-debian Debian Project documentation and other documents
mawk a pattern scanning and text processing language
libdb4.2 Berkeley v4.2 Database Libraries [runtime]
libdb4.3 Berkeley v4.3 Database Libraries [runtime]
libdb4.4 Berkeley v4.4 Database Libraries [runtime]
libssh2-php PHP Bindings for libssh2
git fast, scalable, distributed revision control system
mpack tools for encoding/decoding MIME messages
root@fit:/etc/network# apt-cache policy perl perl: Installé : 5.14.2-21+deb7u2 Candidat : 5.14.2-21+deb7u2 Table de version : *** 5.14.2-21+deb7u2 0 500 http://ftp2.fr.debian.org/debian/ wheezy/main i386 Packages 100 /var/lib/dpkg/status 5.10.1-17squeeze6 0 990 http://security.debian.org/ squeeze/updates/main i386 Packages 990 http://ftp2.fr.debian.org/debian/ squeeze/main i386 Packages 5.10.0-19lenny5 0 800 http://archive.debian.org/debian-archive/debian/ lenny/main i386 Packages
root@fit:/etc/network# dpkg -l |grep perl ii libauthen-sasl-cyrus-perl 0.13-server-8+b2 i386 Perl extension for Cyrus SASL library ii libauthen-sasl-perl 2.1500-1 all Authen::SASL - SASL Authentication framework ii libclass-isa-perl 0.36-3 all report the search path for a class's ISA tree ii libconfig-inifiles-perl 2.75-1 all Read .ini-style configuration files ii libdate-manip-perl 6.11-1 all module for manipulating dates ii libdbd-mysql-perl 4.021-1+b1 i386 Perl5 database interface to the MySQL database ii libdbi-perl 1.622-1+deb7u1 i386 Perl Database Interface (DBI) ii libdigest-hmac-perl 1.03+dfsg-1 all module for creating standard message integrity checks ii liberror-perl 0.17-1 all Perl module for error/exception handling in an OO-ish way ii libfile-copy-recursive-perl 0.38-1 all Perl extension for recursively copying files and directories ii libfont-afm-perl 1.20-1 all Font::AFM - Interface to Adobe Font Metrics files ii libgeo-ipfree-perl 1.101650-1 all module to look up the country of an IPv4 address ii libhtml-format-perl 2.04-2 all format HTML syntax trees into text, PostScript or RTF ii libhtml-parser-perl 3.69-2 i386 collection of modules that parse HTML text documents ii libhtml-tagset-perl 3.20-2 all Data tables pertaining to HTML ii libhtml-template-perl 2.9-2 all module for using HTML Templates with Perl ii libhtml-tree-perl 3.23-2 all Perl module to represent and create HTML syntax trees ii libio-socket-inet6-perl 2.65-1.1 all Object interface for AF_INET6 domain sockets ii liblist-moreutils-perl 0.33-1+b1 i386 Perl module with additional list functions not found in List::Util ii liblocale-gettext-perl 1.05-7+b1 i386 module using libc functions for internationalization in Perl ii libmail-spf-perl 2.007-1 all Perl implementation of Sender Policy Framework and Sender ID ii libmailtools-perl 2.06-1 all Manipulate email in perl programs ii libnet-daemon-perl 0.48-1 all Perl module for building portable Perl daemons easily ii libnet-dns-perl 0.66-2+b2 i386 Perform DNS queries from a Perl script ii libnet-ip-perl 1.25-2 all Perl extension for manipulating IPv4/IPv6 addresses ii libnet-xwhois-perl 0.90-3 all Whois Client Interface for Perl5 ii libnetaddr-ip-perl 4.062+dfsg-1 i386 IP address manipulation module ii libplrpc-perl 0.2017-1.1 all Perl extensions for writing PlRPC servers and clients ii libsocket6-perl 0.23-1+b2 i386 Perl extensions for IPv6 ii libswitch-perl 2.16-2 all switch statement for Perl ii libsys-hostname-long-perl 1.4-2 all Figure out the long (fully-qualified) hostname ii libterm-readkey-perl 2.30-4+b2 i386 A perl module for simple terminal control ii libtext-charwidth-perl 0.04-7+b1 i386 get display widths of characters on the terminal ii libtext-iconv-perl 1.7-5 i386 converts between character sets in Perl ii libtext-wrapi18n-perl 0.06-7 all internationalized substitute of Text::Wrap ii libtimedate-perl 1.2000-1 all collection of modules to manipulate date/time information ii liburi-perl 1.54-2 all module to manipulate and access URI strings ii libwww-perl 5.836-1 all Perl HTTP/WWW client/server library ii libyaml-syck-perl 1.20-1 i386 Perl module providing a fast, lightweight YAML loader and dumper ii perl 5.14.2-21+deb7u2 i386 Larry Wall's Practical Extraction and Report Language ii perl-base 5.14.2-21+deb7u2 i386 minimal Perl system ii perl-modules 5.14.2-21+deb7u2 all Core Perl modules
root@fit:/etc/network# dpkg -l |grep spamassassin iF spamassassin 3.3.2-5+deb7u3 all Perl-based spam filter using text analysis
[code]root@fit:/etc/network# aptitude -s upgrade
Résolution des dépendances…
Les paquets partiellement installés suivants seront configurés :
spamassassin
Aucun paquet ne va être installé, mis à jour ou enlevé.
0 paquets mis à jour, 0 nouvellement installés, 0 à enlever et 4 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 0 o seront utilisés.
Charger/installer/enlever des paquets.
root@fit:/etc/network# aptitude -s full-upgrade
ffmpeg linux-image-2.6-486 udev unixodbc
spamassassin
firmware-linux-free
4 paquets mis à jour, 21 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 36,3 Mo d’archives. Après dépaquetage, 106 Mo seront utilisés.
Dépend: libx11-6 (>= 2:1.4.99.1) mais 2:1.3.3-4+squeeze2 est installé.
  1.  ffmpeg
  3.  unixodbc
  1. ffmpeg
  3. odbcinst1debian1
  2.  unixodbc
  2. odbcinst1debian1
odbcinst{a} odbcinst1debian2{a}
linux-image-2.6-486{a} odbcinst1debian1{a}
udev unixodbc
spamassassin
2 paquets mis à jour, 2 nouvellement installés, 2 à enlever et 1 non mis à jour.
Il est nécessaire de télécharger 868 ko d’archives. Après dépaquetage, 934 ko seront utilisés.
Voulez-vous continuer ? [Y/n/?]
== Resolu
Bon alors, pour ce que j’en perçois, [mono]perl ou/et spamassassin[/mono] sont implicitement concernés.
Vraisemblablement, un fichier [mono].postrm[/mono] est dans le lot.
As-tu un fichier [mono]/etc/Net[/mono] ou repertoire en ces lieux ?
[quote][15:08:59][mono]:~$ aptitude show spamassassin=3.3.2-5+deb7u3[/mono]
Paquet : spamassassin
État: non installé
Version : 3.3.2-5+deb7u3
[mono]Dépend: perl (>= 5.8.0), libhtml-parser-perl (>= 3.43), libsocket6-perl, libsys-hostname-long-perl, libarchive-tar-perl, libwww-perl, libnet-dns-perl (>= 0.34), libnetaddr-ip-perl, perl-modules (>= 5.10) | libio-zlib-perl (>= 1.04), adduser[/mono]
Recommande: spamc (>= 2.30), libmail-spf-perl, re2c, libsys-syslog-perl, gnupg, gcc, libc6-dev, make, libio-socket-inet6-perl
Suggère: razor (>= 2.361-2), libnet-ident-perl, libio-socket-ssl-perl, libdbi-perl, pyzor, libcompress-zlib-perl, libmail-dkim-perl
[quote][mono][14:36:22] ~ # apt-file search /usr/lib/perl5/auto/Net/DNS/DNS.so
libnet-dns-perl: /usr/lib/perl5/auto/Net/DNS/DNS.so
[14:36:53] ~ #[/mono][/quote]
[quote][15:24:25][mono]:~$ ash libnet-dns-perl=0.66-2+b2[/mono]
[mono]Dépend: perl (>= 5.14.2-3), perlapi-5.14.2, libc6 (>= 2.4), libdigest-hmac-perl (>= 1), libmime-base64-perl, libnet-ip-perl (>= 1.2)[/mono]
Suggère: libio-socket-inet6-perl
Description : [mono]Effectue des requêtes DNS à partir d’un script perl Net::DNS est un module Perl de résolution de noms. Il permet aux scripts Perl d’effectuer à peu près tous les types possibles de requêtes DNS.
En combinaison avec libio-socket-inet6-perl, il gère également IPv6.[/mono]
Site : net-dns.org/
$ apt-cache policy libio-socket-inet6-perl $ dpkg -l | grep libio-socket-inet6-perl
Dans un premier temps.
Allons au plus simple, [mono]remove spamassassin[/mono], remove maintient tes fichiers de conf.
* edit *
root@fit:/etc# find / -name Net /usr/share/php/Net /usr/share/perl5/Net /usr/share/perl/5.14.2/Net /usr/lib/perl5/Net /usr/lib/perl5/auto/Net /etc/perl/Net /var/www/webmail/plugins/managesieve/lib/Net /var/www/webmail/program/lib/Net
root@fit:/usr/lib/perl5/Net# ls -l total 32 drwxr-xr-x 4 root root 4096 3 mai 18:43 DNS -rw-r--r-- 1 root root 26217 15 mars 2010 DNS.pm
root@fit:/usr/lib/perl5/Net/DNS# ls -l total 144 -rw-r--r-- 1 root root 9172 15 mars 2010 Domain.pm -rw-r--r-- 1 root root 1114 18 mars 2010 FAQ.pod -rw-r--r-- 1 root root 7802 15 févr. 2008 Header.pm -rw-r--r-- 1 root root 23841 18 mars 2010 Nameserver.pm -rw-r--r-- 1 root root 20470 15 mars 2010 Packet.pm -rw-r--r-- 1 root root 6451 15 mars 2010 Question.pm drwxr-xr-x 2 root root 4096 3 mai 18:43 Resolver -rw-r--r-- 1 root root 20529 18 mars 2010 Resolver.pm drwxr-xr-x 3 root root 4096 3 mai 18:43 RR -rw-r--r-- 1 root root 25950 15 mars 2010 RR.pm -rw-r--r-- 1 root root 5498 31 mars 2006 Update.pm
root@fit:/etc# apt-cache policy libio-socket-inet6-perl libio-socket-inet6-perl: Installé : 2.65-1.1 Candidat : 2.65-1.1 Table de version : 2.69-2 0 500 http://ftp2.fr.debian.org/debian/ wheezy/main i386 Packages *** 2.65-1.1 0 990 http://ftp2.fr.debian.org/debian/ squeeze/main i386 Packages 100 /var/lib/dpkg/status 2.54-1 0 800 http://archive.debian.org/debian-archive/debian/ lenny/main i386 Packages
root@fit:/etc# dpkg -l | grep libio-socket-inet6-perl ii libio-socket-inet6-perl 2.65-1.1 all Object interface for AF_INET6 domain sockets
root@fit:/etc# aptitude -s remove spamassassin Les paquets suivants seront ENLEVÉS : spamassassin 0 paquets mis à jour, 0 nouvellement installés, 1 à enlever et 4 non mis à jour. Il est nécessaire de télécharger 0 o d'archives. Après dépaquetage, 3 469 ko seront libérés. Charger/installer/enlever des paquets.
Ok, voyons encore ceci.
PS: il est possible que cette dernière fasse doublon.
root@fit:/usr/lib/perl5/Net/DNS# dpkg -l | grep perl ii libauthen-sasl-cyrus-perl 0.13-server-8+b2 i386 Perl extension for Cyrus SASL library ii libauthen-sasl-perl 2.1500-1 all Authen::SASL - SASL Authentication framework ii libclass-isa-perl 0.36-3 all report the search path for a class's ISA tree ii libconfig-inifiles-perl 2.75-1 all Read .ini-style configuration files ii libdate-manip-perl 6.11-1 all module for manipulating dates ii libdbd-mysql-perl 4.021-1+b1 i386 Perl5 database interface to the MySQL database ii libdbi-perl 1.622-1+deb7u1 i386 Perl Database Interface (DBI) ii libdigest-hmac-perl 1.03+dfsg-1 all module for creating standard message integrity checks ii liberror-perl 0.17-1 all Perl module for error/exception handling in an OO-ish way ii libfile-copy-recursive-perl 0.38-1 all Perl extension for recursively copying files and directories ii libfont-afm-perl 1.20-1 all Font::AFM - Interface to Adobe Font Metrics files ii libgeo-ipfree-perl 1.101650-1 all module to look up the country of an IPv4 address ii libhtml-format-perl 2.04-2 all format HTML syntax trees into text, PostScript or RTF ii libhtml-parser-perl 3.69-2 i386 collection of modules that parse HTML text documents ii libhtml-tagset-perl 3.20-2 all Data tables pertaining to HTML ii libhtml-template-perl 2.9-2 all module for using HTML Templates with Perl ii libhtml-tree-perl 3.23-2 all Perl module to represent and create HTML syntax trees ii libio-socket-inet6-perl 2.65-1.1 all Object interface for AF_INET6 domain sockets ii liblist-moreutils-perl 0.33-1+b1 i386 Perl module with additional list functions not found in List::Util ii liblocale-gettext-perl 1.05-7+b1 i386 module using libc functions for internationalization in Perl ii libmail-spf-perl 2.007-1 all Perl implementation of Sender Policy Framework and Sender ID ii libmailtools-perl 2.06-1 all Manipulate email in perl programs ii libnet-daemon-perl 0.48-1 all Perl module for building portable Perl daemons easily ii libnet-dns-perl 0.66-2+b2 i386 Perform DNS queries from a Perl script ii libnet-ip-perl 1.25-2 all Perl extension for manipulating IPv4/IPv6 addresses ii libnet-xwhois-perl 0.90-3 all Whois Client Interface for Perl5 ii libnetaddr-ip-perl 4.062+dfsg-1 i386 IP address manipulation module ii libplrpc-perl 0.2017-1.1 all Perl extensions for writing PlRPC servers and clients ii libsocket6-perl 0.23-1+b2 i386 Perl extensions for IPv6 ii libswitch-perl 2.16-2 all switch statement for Perl ii libsys-hostname-long-perl 1.4-2 all Figure out the long (fully-qualified) hostname ii libterm-readkey-perl 2.30-4+b2 i386 A perl module for simple terminal control ii libtext-charwidth-perl 0.04-7+b1 i386 get display widths of characters on the terminal ii libtext-iconv-perl 1.7-5 i386 converts between character sets in Perl ii libtext-wrapi18n-perl 0.06-7 all internationalized substitute of Text::Wrap ii libtimedate-perl 1.2000-1 all collection of modules to manipulate date/time information ii liburi-perl 1.54-2 all module to manipulate and access URI strings ii libwww-perl 5.836-1 all Perl HTTP/WWW client/server library ii libyaml-syck-perl 1.20-1 i386 Perl module providing a fast, lightweight YAML loader and dumper ii perl 5.14.2-21+deb7u2 i386 Larry Wall's Practical Extraction and Report Language ii perl-base 5.14.2-21+deb7u2 i386 minimal Perl system ii perl-modules 5.14.2-21+deb7u2 all Core Perl modules
Ok.
Tu veux dire comme ça ?
Voici dans l’ordre
root@fit:/etc/apt#apt-cache policy libtext-charwidth-perl libtext-iconv-perl libtext-wrapi18n-perl libtimedate-perl liburi-perl libwww-perl libyaml-syck-perl perl perl-base perl-modules libswitch-perl libsys-hostname-long-perl libterm-readkey-perl libdigest-hmac-perl liberror-perl libfile-copy-recursive-perl
perl:
 Table de version :
     5.10.1-17squeeze6 0
     5.10.0-19lenny5 0
perl-modules:
 Table de version :
     5.10.1-17squeeze6 0
     5.10.0-19lenny5 0
liburi-perl:
  Installé : 1.54-2
  Candidat : 1.54-2
 Table de version :
     1.60-1 0
 *** 1.54-2 0
     1.35.dfsg.1-1 0
libwww-perl:
  Installé : 5.836-1
  Candidat : 5.836-1
 Table de version :
     6.04-1 0
 *** 5.836-1 0
     5.813-1+lenny2 0
libterm-readkey-perl:
  Installé : 2.30-4+b2
  Candidat : 2.30-4+b2
 Table de version :
 *** 2.30-4+b2 0
     2.30-4 0
libtimedate-perl:
  Installé : 1.2000-1
  Candidat : 1.2000-1
 Table de version :
 *** 1.2000-1 0
     1.1600-9 0
libfile-copy-recursive-perl:
  Installé : 0.38-1
  Candidat : 0.38-1
 Table de version :
 *** 0.38-1 0
     0.36-1 0
libyaml-syck-perl:
  Installé : 1.20-1
  Candidat : 1.20-1
 Table de version :
 *** 1.20-1 0
     1.12-1 0
     1.05-1 0
perl-base:
 Table de version :
     5.10.1-17squeeze6 0
     5.10.0-19lenny5 0
libswitch-perl:
  Installé : 2.16-2
  Candidat : 2.16-2
 Table de version :
 *** 2.16-2 0
libdigest-hmac-perl:
  Installé : 1.03+dfsg-1
  Candidat : 1.03+dfsg-1
 Table de version :
 *** 1.03+dfsg-1 0
     1.02+dfsg-1 0
     1.01-7 0
libtext-iconv-perl:
  Installé : 1.7-5
  Candidat : 1.7-5
 Table de version :
 *** 1.7-5 0
     1.7-2 0
     1.7-1+b1 0
liberror-perl:
  Installé : 0.17-1
  Candidat : 0.17-1
 Table de version :
 *** 0.17-1 0
libtext-wrapi18n-perl:
  Installé : 0.06-7
  Candidat : 0.06-7
 Table de version :
 *** 0.06-7 0
     0.06-6 0
libtext-charwidth-perl:
  Installé : 0.04-7+b1
  Candidat : 0.04-7+b1
 Table de version :
 *** 0.04-7+b1 0
     0.04-6 0
     0.04-5+b1 0
libsys-hostname-long-perl:
  Installé : 1.4-2
  Candidat : 1.4-2
 Table de version :
 *** 1.4-2 0
root@fit:/etc/apt#
root@fit:/etc/apt#apt-cache policy libauthen-sasl-cyrus-perl libauthen-sasl-perl libclass-isa-perl libconfig-inifiles-perl libdate-manip-perl libdbd-mysql-perl libdbi-perl  libfont-afm-perl libgeo-ipfree-perl libhtml-format-perl libhtml-parser-perl
libdate-manip-perl:
  Installé : 6.11-1
  Candidat : 6.11-1
 Table de version :
     6.32-1 0
 *** 6.11-1 0
     5.54-1 0
libdbd-mysql-perl:
  Installé : 4.021-1+b1
  Candidat : 4.021-1+b1
 Table de version :
 *** 4.021-1+b1 0
     4.016-1 0
     4.007-1+lenny1 0
libdbi-perl:
  Installé : 1.622-1+deb7u1
  Candidat : 1.622-1+deb7u1
 Table de version :
 *** 1.622-1+deb7u1 0
     1.612-1+deb6u1 0
     1.605-1 0
libhtml-parser-perl:
  Installé : 3.69-2
  Candidat : 3.69-2
 Table de version :
 *** 3.69-2 0
     3.66-1 0
     3.56-1+lenny1 0
libhtml-format-perl:
  Installé : 2.04-2
  Candidat : 2.04-2
 Table de version :
     2.10-1 0
 *** 2.04-2 0
libconfig-inifiles-perl:
  Installé : 2.75-1
  Candidat : 2.75-1
 Table de version :
 *** 2.75-1 0
     2.52-1+squeeze1 0
     2.39-5 0
libauthen-sasl-perl:
  Installé : 2.1500-1
  Candidat : 2.1500-1
 Table de version :
 *** 2.1500-1 0
     2.12-1 0
libclass-isa-perl:
  Installé : 0.36-3
  Candidat : 0.36-3
 Table de version :
 *** 0.36-3 0
libgeo-ipfree-perl:
  Installé : 1.101650-1
  Candidat : 1.101650-1
 Table de version :
     1.121660-1 0
 *** 1.101650-1 0
     0.2-7 0
libauthen-sasl-cyrus-perl:
  Installé : 0.13-server-8+b2
  Candidat : 0.13-server-8+b2
 Table de version :
 *** 0.13-server-8+b2 0
     0.13-server-5 0
     0.13-server-3+b1 0
libfont-afm-perl:
  Installé : 1.20-1
  Candidat : 1.20-1
 Table de version :
 *** 1.20-1 0
root@fit:/etc/apt#
libnet-dns-perl:
  Installé : 0.66-2+b2
  Candidat : 0.66-2+b2
 Table de version :
 *** 0.66-2+b2 0
     0.66-2 0
     0.63-2 0
libhtml-template-perl:
  Installé : 2.9-2
  Candidat : 2.9-2
 Table de version :
     2.91-1 0
 *** 2.9-2 0
     2.9-1 0
libmailtools-perl:
  Installé : 2.06-1
  Candidat : 2.06-1
 Table de version :
     2.09-1 0
 *** 2.06-1 0
     2.03-1 0
libhtml-tree-perl:
  Installé : 3.23-2
  Candidat : 3.23-2
 Table de version :
     5.02-1 0
 *** 3.23-2 0
     3.23-1 0
liblocale-gettext-perl:
  Installé : 1.05-7+b1
  Candidat : 1.05-7+b1
 Table de version :
 *** 1.05-7+b1 0
     1.05-6 0
     1.05-4 0
libsocket6-perl:
  Installé : 0.23-1+b2
  Candidat : 0.23-1+b2
 Table de version :
 *** 0.23-1+b2 0
     0.23-1 0
     0.20-1 0
  Installé : 2.65-1.1
  Candidat : 2.65-1.1
 Table de version :
     2.69-2 0
 *** 2.65-1.1 0
     2.54-1 0
liblist-moreutils-perl:
  Installé : 0.33-1+b1
  Candidat : 0.33-1+b1
 Table de version :
 *** 0.33-1+b1 0
     0.25~02-1 0
     0.22-1+b1 0
libnet-ip-perl:
  Installé : 1.25-2
  Candidat : 1.25-2
 Table de version :
     1.25-3 0
 *** 1.25-2 0
libnet-xwhois-perl:
  Installé : 0.90-3
  Candidat : 0.90-3
 Table de version :
 *** 0.90-3 0
libnetaddr-ip-perl:
  Installé : 4.062+dfsg-1
  Candidat : 4.062+dfsg-1
 Table de version :
 *** 4.062+dfsg-1 0
     4.028+dfsg-1 0
     4.007+dfsg-2+b1 0
libmail-spf-perl:
  Installé : 2.007-1
  Candidat : 2.007-1
 Table de version :
     2.8.0-1 0
 *** 2.007-1 0
     2.005-1 0
libhtml-tagset-perl:
  Installé : 3.20-2
  Candidat : 3.20-2
 Table de version :
 *** 3.20-2 0
libnet-daemon-perl:
  Installé : 0.48-1
  Candidat : 0.48-1
 Table de version :
 *** 0.48-1 0
     0.43-1 0
     0.38-1.1 0
libplrpc-perl:
  Installé : 0.2017-1.1
  Candidat : 0.2017-1.1
 Table de version :
 *** 0.2017-1.1 0
root@fit:/etc/apt#
Non, édites ton dernier message et s’il te plaît, sur tes retours à venir, inclus le prompt ([mono]~$[/mono] ou [mono]~ #[/mono]) de départ et fin comprenant [mono]la ligne de commande[/mono].
Cela me facilitera (énormément) la tâche, merci.
PS: dans le cadre d’un [mono]update[/mono] et/ou d’un [mono]upgrade/full-upgrade[/mono], tu tronques les lignes de téléchargements.
Là, c’est nickel ! :023
Cela me permet, à moi aussi, de faire des copier/coller, tranquille. Merci.
Notes: je n’obtiens pas le même ordre, il me faut donc rechercher chaque paquet (pour lui imposer une version) dans cet ordre diffèrent, alors que …
Cela fait déjà quelques heures que l’idée de modifier le [mono]pinning[/mono] en place me trotte, suite à ce (dernier, peut-être) retour, il est possible que cela se fasse.
J’y verrai peux être plus clair sur une simulation.
Rappel : tu as le cul entre trois chaises, cela dit, nous touchons au but. [mono]Lenny > Squeeze[/mono].
[mono]Squeeze/Wheezy[/mono] devrait être une formalité, à mon avis.
Voyons ça.
$ aptitude -s install liburi-perl=1.60-1 libwww-perl=6.04-1 libdate-manip-perl=6.32-1 libhtml-format-perl=2.10-1 libgeo-ipfree-perl=1.121660-1 libhtml-template-perl=2.91-1 libmailtools-perl=2.09-1 libhtml-tree-perl=5.02-1 libio-socket-inet6-perl=2.69-2 libnet-ip-perl=1.25-3 libmail-spf-perl=2.8.0-1
[code]root@fit:/etc/apt#aptitude -s install liburi-perl=1.60-1 libwww-perl=6.04-1 libdate-manip-perl=6.32-1 libhtml-format-perl=2.10-1 libgeo-ipfree-perl=1.121660-1 libhtml-template-perl=2.91-1 libmailtools-perl=2.09-1 libhtml-tree-perl=5.02-1 libio-socket-inet6-perl=2.69-2 libnet-ip-perl=1.25-3 libmail-spf-perl=2.8.0-1
[ 0%] Construction de l’arbre des dépendances
libencode-locale-perl{a} libfile-listing-perl{a} libhttp-cookies-perl{a} libhttp-date-perl{a} libhttp-message-perl{a} libhttp-negotiate-perl{a} liblwp-mediatypes-perl{a}
liblwp-protocol-https-perl{ab} libnet-http-perl{a} libwww-robotrules-perl{a}
libdate-manip-perl libgeo-ipfree-perl libhtml-format-perl libhtml-template-perl libhtml-tree-perl libio-socket-inet6-perl libmail-spf-perl libmailtools-perl libnet-ip-perl liburi-perl libwww-perl
spamassassin
libhtml-form-perl libhttp-daemon-perl
11 paquets mis à jour, 10 nouvellement installés, 0 à enlever et 4 non mis à jour.
Il est nécessaire de télécharger 4 508 ko d’archives. Après dépaquetage, 3 065 ko seront libérés.
liblwp-protocol-https-perl: Dépend: libio-socket-ssl-perl (>= 1.54) mais il ne sera pas installé.
ouverts : 60 ; fermés : 64 ; reportés : 28 ; en conflit : 39 oLes acti:
  1. libwww-perl
  2. spamassassin
  3. squidguard
  4. liblwp-protocol-https-perl [Non installé]
Accepter cette solution ? [Y/n/q/?] Les paquets suivants seront ENLEVÉS :
libwww-perl{a} spamassassin{a} squidguard{a}
10 paquets mis à jour, 0 nouvellement installés, 3 à enlever et 4 non mis à jour.
Il est nécessaire de télécharger 4 086 ko d’archives. Après dépaquetage, 8 190 ko seront libérés.
Voulez-vous continuer ? [Y/n/?] n
Abandon.
root@fit:/etc/apt#
Ok.
Valides et donnes moi le retour, stp.
[code]root@fit:/etc/apt# aptitude remove spamassassin
spamassassin
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 3 469 ko seront libérés.
/usr/bin/perl: symbol lookup error: /usr/lib/perl5/auto/Text/Iconv/Iconv.so: undefined symbol: Perl_Gthr_key_ptr
(Lecture de la base de données… 40143 fichiers et répertoires déjà installés.)
Suppression de spamassassin …
Stopping SpamAssassin Mail Filter Daemon: No /usr/bin/perl found running; none killed.
spamd.
Traitement des actions différées (« triggers ») pour « man-db »…
root@fit:/etc/apt# [/code]
root@fit:/etc/apt# apt-cache policy spamassassin spamassassin: Installé : (aucun) Candidat : 3.3.1-1.1 Table de version : 3.3.2-5+deb7u3 0 500 http://ftp2.fr.debian.org/debian/ wheezy-updates/main i386 Packages 100 /var/lib/dpkg/status 3.3.2-5+deb7u2 0 500 http://ftp2.fr.debian.org/debian/ wheezy/main i386 Packages 3.3.1-1.1 0 990 http://ftp2.fr.debian.org/debian/ squeeze/main i386 Packages 3.2.5-2+lenny3 0 800 http://archive.debian.org/debian-archive/debian/ lenny/main i386 Packages root@fit:/etc/apt#
Au travers de cette dernière, [mono]# ps -aux[/mono] tu devrais retrouver le [mono]Pid[/mono] de [mono]perl[/mono].
Un copier de cette ligne (ces, lignes[mono]perl[/mono]), stp.
As-tu une trace de [mono]spamassassin[/mono] en ce lieu ?
* edit *
En vue de modifier le [mono]pinning[/mono], ces retours, stp.
[code]# find /etc/apt -name ‘pref’ -exec bash -c ‘echo -e “\n$1\n”; nl -ba “$1”’ _ ‘{}’ ;
find /etc/apt -name ‘.list’ -exec bash -c ‘echo -e “\n$1\n”; nl -ba “$1”’ _ ‘{}’ ;
$ apt-cache policy[/code]
Aucune trace de perl ou spamassasin dans les process
root@fit:/etc/apt# ps -aux | grep perl Warning: bad ps syntax, perhaps a bogus '-'? See http://procps.sf.net/faq.html root 21859 0.0 0.3 3604 788 pts/0 S+ 17:48 0:00 grep perl root@fit:/etc/apt#
root@fit:/etc/apt# aptitude search ~c c courier-pop - Courier mail server - POP3 server c dbus - simple interprocess messaging system (daemon and utilities) c defoma - Gestionnaire de polices Debian -- prise en charge de la configuration automatique des polices c dhcp3-client - ISC DHCP server (transitional package) c exim4 - metapackage to ease Exim MTA (v4) installation c exim4-base - support files for all Exim MTA (v4) packages c exim4-config - configuration for the Exim MTA (v4) c exim4-daemon-light - lightweight Exim MTA (v4) daemon c flashplugin-nonfree - Adobe Flash Player - browser plugin c fontconfig - generic font configuration library - support binaries c ifupdown - Outils de haut niveau pour configurer les interfaces réseau c klogd - Service de journalisation du noyau c language-env - Outil de configuration simple pour l'environnement de langage natif c libatk1.0-0 - ATK accessibility toolkit c libavahi-client3 - Avahi client library c libavahi-common3 - Avahi common library c libavifile-0.7c2 - shared libraries for AVI read/writing c libbind9-50 - BIND9 Shared Library used by BIND c libcairo2 - The Cairo 2D vector graphics library c libcups2 - Common UNIX Printing System(tm) - Core library c libdatrie1 - Double-array trie library c libdbus-1-3 - simple interprocess messaging system (library) c libdevmapper1.02 - The Linux Kernel Device Mapper userspace library c libdns58 - DNS Shared Library used by BIND c libept0 - Bibliothèque de haut niveau pour gérer les informations des paquets Debian c libfam0 - Bibliothèque cliente pour contrôler le démon FAM c libfontenc1 - X11 font encoding library c libglib2.0-0 - GLib library of C routines c libgssapi2 - A mechanism-switch gssapi library c libgtk2.0-0 - GTK+ graphical user interface library c libice6 - X11 Inter-Client Exchange library c libisc50 - ISC Shared Library used by BIND c libisccc50 - Command Channel Library used by BIND c libisccfg50 - Config File Handling Library used by BIND c libjasper1 - JasPer JPEG-2000 runtime library c liblwres50 - Lightweight Resolver Library used by BIND c libmpfr1ldbl - multiple precision floating-point computation c libnspr4-0d - NetScape Portable Runtime Library - transitional package c libnss3-1d - Network Security Service libraries - transitional package c libpango1.0-0 - Mise en place et rendu de texte internationalisé c libpango1.0-common - Fichiers de modules et de configuration pour Pango c libpci2 - Obsolete shared library for accessing pci devices c libpixman-1-0 - Bibliothèque de manipulation de pixel pour X et cairo c libpq4 - PostgreSQL C client library c libsm6 - X11 Session Management library c libsqlite0 - SQLite shared library c libt1-5 - Type 1 font rasterizer library - runtime c libthai0 - Bibliothèque de gestion de la langue Thaï c libtiff4 - Tag Image File Format (TIFF) library (old version) c libxcb-render-util0 - Bibliothèque d'utilitaires pour les liens C avec X -- render-util c libxcb-render0 - Liens C avec X, extension de rendu c libxcb-xlib0 - Liens C avec X, bibliothèque d'interface Xlib/XCB c libxcomposite1 - X11 Composite extension library c libxcursor1 - Bibliothèque de gestion du curseur X c libxdamage1 - X11 damaged region extension library c libxfont1 - X11 font rasterisation library c libxft2 - Bibliothèque de tracé de polices basées sur FreeType pour X c libxi6 - X11 Input extension library c libxinerama1 - X11 Xinerama extension library c libxrandr2 - X11 RandR extension library c libxrender1 - X Rendering Extension client library c libxt6 - X11 toolkit intrinsics library c libxxf86dga1 - X11 Direct Graphics Access extension library c libxxf86vm1 - X11 XFree86 video mode extension library c locales - GNU C Library: National Language (locale) data [support] c mutt - Outil de lecture de courriel en mode texte, gérant MIME, GPG, PGP et les fils de discussion c mysql-server-5.0 - binaires du serveur de bases de données MySQL c nfs-common - NFS support files common to client and server c python2.4 - Langage interactif de haut niveau orienté objet (version 2.4) c python2.4-minimal - Sous-ensemble minimal du langage python (version 2.4) c python2.5 - Langage interactif de haut niveau orienté objet (version 2.5) c python2.5-minimal - Sous-ensemble minimal du langage Python (version 2.5) c sasl2-bin - Cyrus SASL - administration programs for SASL users database c shared-mime-info - FreeDesktop.org shared MIME database and spec c smcroute - static multicast router daemon c spamassassin - Filtre anti-pourriel basé sur perl et l'analyse de texte c ssmtp - extremely simple MTA to get mail off the system to a mail hub c sysklogd - Service de journalisation système c tcl8.4 - Tcl (the Tool Command Language) v8.4 - fichiers exécutables c ttf-dejavu-extra - Vera font family derivate with additional characters c ulogd - The Netfilter Userspace Logging Daemon c x-ttcidfont-conf - Configuration des polices TrueType et CID pour X c x11-common - Infrastructure du système X Window (X.Org) c xfonts-utils - X Window System font utility programs c xmail - advanced, fast and reliable ESMTP/POP3 mail server root@fit:/etc/apt#
[code]root@fit:/etc/apt# find /etc/apt -name ‘pref’ -exec bash -c ‘echo -e “\n$1\n”; nl -ba “$1”’ _ ‘{}’ ;
/etc/apt/preferences
 1  Package: *
 2  Pin: release v=6.0-lts,o=Debian,a=squeeze-lts,n=squeeze-lts,l=Debian
 3  Pin-Priority: 990
 4
 5  Package: *
 6  Pin: release v=6.0,o=Debian,a=oldoldstable,n=squeeze,l=Debian-Security
 7  Pin-Priority: 990
 8
 9  Package: *
10  Pin: release o=Debian,a=oldoldstable-updates,n=squeeze-updates,l=Debian
11  Pin-Priority: 990
12
13  Package: *
14  Pin: release v=6.0.10,o=Debian,a=oldoldstable,n=squeeze,l=Debian
15  Pin-Priority: 990
16
17  Package: *
18  Pin: release o=Debian Backports,a=squeeze-backports,n=squeeze-backports,l=Debian Backports
19  Pin-Priority: 980
20
21  Package: *
22  Pin: release v=5.0.10,o=Debian,a=oldstable,n=lenny,l=Debian
23  Pin-Priority: 800
24
/etc/apt/preferences.d
nl: /etc/apt/preferences.d: Is a directory
root@fit:/etc/apt# apt-cache policy Fichiers du paquet : 100 /var/lib/dpkg/status release a=now 1 http://ftp.cyconet.org/debian/ wheezy-updates/non-free i386 Packages release v=7.0,o=Wheezy Updates,a=wheezy-updates,n=wheezy-updates,l=Wheezy Updates,c=non-free origin ftp.cyconet.org 1 http://ftp.cyconet.org/debian/ wheezy-updates/contrib i386 Packages release v=7.0,o=Wheezy Updates,a=wheezy-updates,n=wheezy-updates,l=Wheezy Updates,c=contrib origin ftp.cyconet.org 1 http://ftp.cyconet.org/debian/ wheezy-updates/main i386 Packages release v=7.0,o=Wheezy Updates,a=wheezy-updates,n=wheezy-updates,l=Wheezy Updates,c=main origin ftp.cyconet.org 500 http://archive.debian.org/debian-archive/debian/ lenny/main Translation-fr 800 http://archive.debian.org/debian-archive/debian/ lenny/non-free i386 Packages release v=5.0.10,o=Debian,a=oldstable,n=lenny,l=Debian,c=non-free origin archive.debian.org 800 http://archive.debian.org/debian-archive/debian/ lenny/contrib i386 Packages release v=5.0.10,o=Debian,a=oldstable,n=lenny,l=Debian,c=contrib origin archive.debian.org 800 http://archive.debian.org/debian-archive/debian/ lenny/main i386 Packages release v=5.0.10,o=Debian,a=oldstable,n=lenny,l=Debian,c=main origin archive.debian.org 500 http://ftp2.fr.debian.org/debian/ wheezy/non-free i386 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=non-free origin ftp2.fr.debian.org 500 http://ftp2.fr.debian.org/debian/ wheezy/contrib i386 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=contrib origin ftp2.fr.debian.org 500 http://ftp2.fr.debian.org/debian/ wheezy/main i386 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=main origin ftp2.fr.debian.org 500 http://ftp2.fr.debian.org/debian/ wheezy-updates/non-free i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=non-free origin ftp2.fr.debian.org 500 http://ftp2.fr.debian.org/debian/ wheezy-updates/contrib i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=contrib origin ftp2.fr.debian.org 500 http://ftp2.fr.debian.org/debian/ wheezy-updates/main i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=main origin ftp2.fr.debian.org 500 http://security.debian.org/ wheezy/updates/non-free i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ wheezy/updates/contrib i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ wheezy/updates/main i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=main origin security.debian.org 990 http://ftp2.fr.debian.org/debian/ squeeze/non-free i386 Packages release v=6.0.10,o=Debian,a=oldoldstable,n=squeeze,l=Debian,c=non-free origin ftp2.fr.debian.org 990 http://ftp2.fr.debian.org/debian/ squeeze/contrib i386 Packages release v=6.0.10,o=Debian,a=oldoldstable,n=squeeze,l=Debian,c=contrib origin ftp2.fr.debian.org 990 http://ftp2.fr.debian.org/debian/ squeeze/main i386 Packages release v=6.0.10,o=Debian,a=oldoldstable,n=squeeze,l=Debian,c=main origin ftp2.fr.debian.org 990 http://ftp2.fr.debian.org/debian/ squeeze-updates/non-free i386 Packages release o=Debian,a=oldoldstable-updates,n=squeeze-updates,l=Debian,c=non-free origin ftp2.fr.debian.org 990 http://ftp2.fr.debian.org/debian/ squeeze-updates/contrib i386 Packages release o=Debian,a=oldoldstable-updates,n=squeeze-updates,l=Debian,c=contrib origin ftp2.fr.debian.org 990 http://ftp2.fr.debian.org/debian/ squeeze-updates/main i386 Packages release o=Debian,a=oldoldstable-updates,n=squeeze-updates,l=Debian,c=main origin ftp2.fr.debian.org 990 http://security.debian.org/ squeeze/updates/non-free i386 Packages release v=6.0,o=Debian,a=oldoldstable,n=squeeze,l=Debian-Security,c=non-free origin security.debian.org 990 http://security.debian.org/ squeeze/updates/contrib i386 Packages release v=6.0,o=Debian,a=oldoldstable,n=squeeze,l=Debian-Security,c=contrib origin security.debian.org 990 http://security.debian.org/ squeeze/updates/main i386 Packages release v=6.0,o=Debian,a=oldoldstable,n=squeeze,l=Debian-Security,c=main origin security.debian.org 990 http://ftp.us.debian.org/debian/ squeeze-lts/non-free i386 Packages release v=6.0-lts,o=Debian,a=squeeze-lts,n=squeeze-lts,l=Debian,c=non-free origin ftp.us.debian.org 990 http://ftp.us.debian.org/debian/ squeeze-lts/contrib i386 Packages release v=6.0-lts,o=Debian,a=squeeze-lts,n=squeeze-lts,l=Debian,c=contrib origin ftp.us.debian.org 990 http://ftp.us.debian.org/debian/ squeeze-lts/main i386 Packages release v=6.0-lts,o=Debian,a=squeeze-lts,n=squeeze-lts,l=Debian,c=main origin ftp.us.debian.org Paquets étiquetés : root@fit:/etc/apt#
Ok.
J’ai édité ci-dessus (Cf. find sources.list)
PS: sur la foi de [mono]aptitude search ~c[/mono], n’étais tu pas censé avoir purger ces derniers au travers de [mono][strike]# aptitude purge ~c[/strike][/mono], comme demander ces derniers jours ?
Bref, pour l’heure, tu n’en fais rien.
Essayons encore, cela.
J’en ai pas souvenir - j’ai peu être zappé
ouverts : 56 ; fermés : 61 ; reportés : 25 ; en conflit : 36 oLes acti:
  1. libwww-perl
  2. squidguard
  3. liblwp-protocol-https-perl [Non installé]
ouverts : 114 ; fermés : 150 ; reportés : 34 ; en conflit : 47 .Les acti:
  1.  libfile-listing-perl [Non installé]
  2.  libhttp-cookies-perl [Non installé]
  3.  libhttp-date-perl [Non installé]
  4.  libhttp-message-perl [Non installé]
  5.  libhttp-negotiate-perl [Non installé]
  6.  liblwp-mediatypes-perl [Non installé]
  7.  liblwp-protocol-https-perl [Non installé]
  8.  libnet-http-perl [Non installé]
  9.  libwww-perl [5.836-1 (now, oldoldstable)]
  10. libwww-robotrules-perl [Non installé]
 Installer les paquets suivants :
  1. libio-socket-ssl-perl [1.76-2 (oldstable)]
  2. libnet-ssleay-perl [1.48-1+b1 (oldstable)]
ouverts : 3016 ; fermés : 3811 ; reportés : 48 ; en conflit : 63 OLes acti:
  9.  libwww-robotrules-perl [Non installé]
    Réinstaller à une version antérieure les paquets suivants :
  10. libwww-perl [5.836-1 (now, oldoldstable) -> 5.813-1+lenny2 (oldstable)]
Les paquets suivants vont être RÉINSTALLÉS à une VERSION ANTÉRIEURE :
libwww-perl
10 paquets mis à jour, 0 nouvellement installés, 1 remis à une version antérieure, 0 à enlever et 4 non mis à jour.
Il est nécessaire de télécharger 4 460 ko d’archives. Après dépaquetage, 3 357 ko seront libérés.
Je vais devoir me deconnecter - Merci encore de cette energie mise en oeuvre !!
