Mise à jour : système "cassé" après passage au noyau 3.16
syslog suite et fin
Apr 29 08:09:11 paris kernel: [ 0.193261] pci 0000:01:00.0: Video device with shadowed ROM Apr 29 08:09:11 paris kernel: [ 0.193289] PCI: CLS 32 bytes, default 64 Apr 29 08:09:11 paris kernel: [ 0.193360] Unpacking initramfs... Apr 29 08:09:11 paris kernel: [ 0.636860] Freeing initrd memory: 14248K (f641c000 - f7206000) Apr 29 08:09:11 paris kernel: [ 0.636980] Simple Boot Flag at 0x52 set to 0x1 Apr 29 08:09:11 paris kernel: [ 0.637238] microcode: CPU0 sig=0x6e8, pf=0x20, revision=0x39 Apr 29 08:09:11 paris kernel: [ 0.637252] microcode: CPU1 sig=0x6e8, pf=0x20, revision=0x39 Apr 29 08:09:11 paris kernel: [ 0.637382] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba Apr 29 08:09:11 paris kernel: [ 0.637879] futex hash table entries: 512 (order: 3, 32768 bytes) Apr 29 08:09:11 paris kernel: [ 0.637940] audit: initializing netlink subsys (disabled) Apr 29 08:09:11 paris kernel: [ 0.637971] audit: type=2000 audit(1430294882.636:1): initialized Apr 29 08:09:11 paris kernel: [ 0.638464] HugeTLB registered 2 MB page size, pre-allocated 0 pages Apr 29 08:09:11 paris kernel: [ 0.638491] zbud: loaded Apr 29 08:09:11 paris kernel: [ 0.638645] VFS: Disk quotas dquot_6.5.2 Apr 29 08:09:11 paris kernel: [ 0.638670] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Apr 29 08:09:11 paris kernel: [ 0.638761] msgmni has been set to 1738 Apr 29 08:09:11 paris kernel: [ 0.639321] alg: No test for stdrng (krng) Apr 29 08:09:11 paris kernel: [ 0.639362] bounce: pool size: 64 pages Apr 29 08:09:11 paris kernel: [ 0.639386] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) Apr 29 08:09:11 paris kernel: [ 0.639462] io scheduler noop registered Apr 29 08:09:11 paris kernel: [ 0.639466] io scheduler deadline registered Apr 29 08:09:11 paris kernel: [ 0.639528] io scheduler cfq registered (default) Apr 29 08:09:11 paris kernel: [ 0.639815] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 0.639993] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 0.640131] pcieport 0000:00:1c.3: enabling device (0106 -> 0107) Apr 29 08:09:11 paris kernel: [ 0.640230] pcieport 0000:00:1c.3: irq 42 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 0.640393] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 Apr 29 08:09:11 paris kernel: [ 0.640427] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 Apr 29 08:09:11 paris kernel: [ 0.640467] intel_idle: does not run on family 6 model 14 Apr 29 08:09:11 paris kernel: [ 0.640535] GHES: HEST is not enabled! Apr 29 08:09:11 paris kernel: [ 0.640567] isapnp: Scanning for PnP cards... Apr 29 08:09:11 paris kernel: [ 0.994075] isapnp: No Plug & Play device found Apr 29 08:09:11 paris kernel: [ 0.994208] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled Apr 29 08:09:11 paris kernel: [ 0.994958] Linux agpgart interface v0.103 Apr 29 08:09:11 paris kernel: [ 0.995400] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12 Apr 29 08:09:11 paris kernel: [ 0.997853] i8042: Detected active multiplexing controller, rev 1.1 Apr 29 08:09:11 paris kernel: [ 0.999014] serio: i8042 KBD port at 0x60,0x64 irq 1 Apr 29 08:09:11 paris kernel: [ 0.999022] serio: i8042 AUX0 port at 0x60,0x64 irq 12 Apr 29 08:09:11 paris kernel: [ 0.999080] serio: i8042 AUX1 port at 0x60,0x64 irq 12 Apr 29 08:09:11 paris kernel: [ 0.999130] serio: i8042 AUX2 port at 0x60,0x64 irq 12 Apr 29 08:09:11 paris kernel: [ 0.999180] serio: i8042 AUX3 port at 0x60,0x64 irq 12 Apr 29 08:09:11 paris kernel: [ 0.999422] mousedev: PS/2 mouse device common for all mice Apr 29 08:09:11 paris kernel: [ 0.999509] rtc_cmos 00:01: RTC can wake from S4 Apr 29 08:09:11 paris kernel: [ 0.999699] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0 Apr 29 08:09:11 paris kernel: [ 0.999732] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs Apr 29 08:09:11 paris kernel: [ 0.999757] ledtrig-cpu: registered to indicate activity on CPUs Apr 29 08:09:11 paris kernel: [ 1.000367] TCP: cubic registered Apr 29 08:09:11 paris kernel: [ 1.000418] NET: Registered protocol family 10 Apr 29 08:09:11 paris kernel: [ 1.000771] mip6: Mobile IPv6 Apr 29 08:09:11 paris kernel: [ 1.000776] NET: Registered protocol family 17 Apr 29 08:09:11 paris kernel: [ 1.000784] mpls_gso: MPLS GSO support Apr 29 08:09:11 paris kernel: [ 1.001065] Using IPI No-Shortcut mode Apr 29 08:09:11 paris kernel: [ 1.001294] registered taskstats version 1 Apr 29 08:09:11 paris kernel: [ 1.001925] rtc_cmos 00:01: setting system clock to 2015-04-29 08:08:03 UTC (1430294883) Apr 29 08:09:11 paris kernel: [ 1.002011] PM: Hibernation image not present or could not be loaded. Apr 29 08:09:11 paris kernel: [ 1.002429] Freeing unused kernel memory: 656K (c166d000 - c1711000) Apr 29 08:09:11 paris kernel: [ 1.002489] Write protecting the kernel text: 4600k Apr 29 08:09:11 paris kernel: [ 1.002554] Write protecting the kernel read-only data: 1452k Apr 29 08:09:11 paris kernel: [ 1.002556] NX-protecting the kernel data: 3592k Apr 29 08:09:11 paris kernel: [ 1.016612] random: systemd-udevd urandom read with 0 bits of entropy available Apr 29 08:09:11 paris kernel: [ 1.030536] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 Apr 29 08:09:11 paris kernel: [ 1.032471] ACPI: bus type USB registered Apr 29 08:09:11 paris kernel: [ 1.032525] usbcore: registered new interface driver usbfs Apr 29 08:09:11 paris kernel: [ 1.032546] usbcore: registered new interface driver hub Apr 29 08:09:11 paris kernel: [ 1.038028] usbcore: registered new device driver usb Apr 29 08:09:11 paris kernel: [ 1.038960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Apr 29 08:09:11 paris kernel: [ 1.039479] uhci_hcd: USB Universal Host Controller Interface driver Apr 29 08:09:11 paris kernel: [ 1.039691] uhci_hcd 0000:00:1d.0: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.039705] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1 Apr 29 08:09:11 paris kernel: [ 1.039718] uhci_hcd 0000:00:1d.0: detected 2 ports Apr 29 08:09:11 paris kernel: [ 1.039769] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ec00 Apr 29 08:09:11 paris kernel: [ 1.040296] ehci-pci: EHCI PCI platform driver Apr 29 08:09:11 paris kernel: [ 1.040480] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 Apr 29 08:09:11 paris kernel: [ 1.040485] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Apr 29 08:09:11 paris kernel: [ 1.040488] usb usb1: Product: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.040491] usb usb1: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd Apr 29 08:09:11 paris kernel: [ 1.040494] usb usb1: SerialNumber: 0000:00:1d.0 Apr 29 08:09:11 paris kernel: [ 1.040933] hub 1-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.040945] hub 1-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.042044] ACPI: Fan [FN00] (off) Apr 29 08:09:11 paris kernel: [ 1.042632] uhci_hcd 0000:00:1d.1: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.042643] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2 Apr 29 08:09:11 paris kernel: [ 1.042652] uhci_hcd 0000:00:1d.1: detected 2 ports Apr 29 08:09:11 paris kernel: [ 1.042698] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e880 Apr 29 08:09:11 paris kernel: [ 1.042772] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 Apr 29 08:09:11 paris kernel: [ 1.042776] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Apr 29 08:09:11 paris kernel: [ 1.042779] usb usb2: Product: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.042782] usb usb2: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd Apr 29 08:09:11 paris kernel: [ 1.042785] usb usb2: SerialNumber: 0000:00:1d.1 Apr 29 08:09:11 paris kernel: [ 1.043003] hub 2-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.043015] hub 2-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.043287] uhci_hcd 0000:00:1d.2: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.043296] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3 Apr 29 08:09:11 paris kernel: [ 1.043305] uhci_hcd 0000:00:1d.2: detected 2 ports Apr 29 08:09:11 paris kernel: [ 1.043341] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e800 Apr 29 08:09:11 paris kernel: [ 1.043405] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 Apr 29 08:09:11 paris kernel: [ 1.043409] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Apr 29 08:09:11 paris kernel: [ 1.043412] usb usb3: Product: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.043415] usb usb3: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd Apr 29 08:09:11 paris kernel: [ 1.043418] usb usb3: SerialNumber: 0000:00:1d.2 Apr 29 08:09:11 paris kernel: [ 1.043727] hub 3-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.043844] hub 3-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.044133] uhci_hcd 0000:00:1d.3: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.044143] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4 Apr 29 08:09:11 paris kernel: [ 1.044151] uhci_hcd 0000:00:1d.3: detected 2 ports Apr 29 08:09:11 paris kernel: [ 1.044188] uhci_hcd 0000:00:1d.3: irq 22, io base 0x0000e480 Apr 29 08:09:11 paris kernel: [ 1.044254] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 Apr 29 08:09:11 paris kernel: [ 1.044258] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Apr 29 08:09:11 paris kernel: [ 1.044261] usb usb4: Product: UHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.044264] usb usb4: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd Apr 29 08:09:11 paris kernel: [ 1.044267] usb usb4: SerialNumber: 0000:00:1d.3 Apr 29 08:09:11 paris kernel: [ 1.044463] hub 4-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.044474] hub 4-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.045429] ehci-pci 0000:00:1d.7: EHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.045439] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 5 Apr 29 08:09:11 paris kernel: [ 1.045458] ehci-pci 0000:00:1d.7: debug port 1 Apr 29 08:09:11 paris kernel: [ 1.049383] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported Apr 29 08:09:11 paris kernel: [ 1.049868] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfebfbc00 Apr 29 08:09:11 paris kernel: [ 1.055623] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded Apr 29 08:09:11 paris kernel: [ 1.055634] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control Apr 29 08:09:11 paris kernel: [ 1.059142] sdhci: Secure Digital Host Controller Interface driver Apr 29 08:09:11 paris kernel: [ 1.059146] sdhci: Copyright(c) Pierre Ossman Apr 29 08:09:11 paris kernel: [ 1.059516] sdhci-pci 0000:04:01.2: SDHCI controller found [1180:0822] (rev 17) Apr 29 08:09:11 paris kernel: [ 1.059590] r8169 0000:02:00.0: irq 43 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 1.059909] r8169 0000:02:00.0 eth0: RTL8168b/8111b at 0xf7e2e000, 00:17:31:cf:01:90, XID 18000000 IRQ 43 Apr 29 08:09:11 paris kernel: [ 1.059914] r8169 0000:02:00.0 eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko] Apr 29 08:09:11 paris kernel: [ 1.062970] SCSI subsystem initialized Apr 29 08:09:11 paris kernel: [ 1.064533] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00 Apr 29 08:09:11 paris kernel: [ 1.064622] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 Apr 29 08:09:11 paris kernel: [ 1.064626] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Apr 29 08:09:11 paris kernel: [ 1.064629] usb usb5: Product: EHCI Host Controller Apr 29 08:09:11 paris kernel: [ 1.064632] usb usb5: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd Apr 29 08:09:11 paris kernel: [ 1.064635] usb usb5: SerialNumber: 0000:00:1d.7 Apr 29 08:09:11 paris kernel: [ 1.065970] hub 5-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.066167] hub 5-0:1.0: 8 ports detected Apr 29 08:09:11 paris kernel: [ 1.066744] libata version 3.00 loaded. Apr 29 08:09:11 paris kernel: [ 1.067766] sdhci-pci 0000:04:01.2: Will use DMA mode even though HW doesn't fully claim to support it. Apr 29 08:09:11 paris kernel: [ 1.067775] mmc0: no vqmmc regulator found Apr 29 08:09:11 paris kernel: [ 1.067778] mmc0: no vmmc regulator found Apr 29 08:09:11 paris kernel: [ 1.068778] sdhci-pci 0000:04:01.2: Will use DMA mode even though HW doesn't fully claim to support it. Apr 29 08:09:11 paris kernel: [ 1.075239] thermal LNXTHERM:00: registered as thermal_zone0 Apr 29 08:09:11 paris kernel: [ 1.075243] ACPI: Thermal Zone [THRM] (74 C) Apr 29 08:09:11 paris kernel: [ 1.075514] mmc0: SDHCI controller on PCI [0000:04:01.2] using DMA Apr 29 08:09:11 paris kernel: [ 1.088137] hub 1-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.088153] hub 1-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.112132] hub 2-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.112219] hub 2-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.136101] hub 3-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.136115] hub 3-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.140090] firewire_ohci 0000:04:01.1: added OHCI v1.0 device as card 0, 4 IR + 4 IT contexts, quirks 0x11 Apr 29 08:09:11 paris kernel: [ 1.160106] hub 4-0:1.0: USB hub found Apr 29 08:09:11 paris kernel: [ 1.160119] hub 4-0:1.0: 2 ports detected Apr 29 08:09:11 paris kernel: [ 1.160436] ata_piix 0000:00:1f.1: version 2.13 Apr 29 08:09:11 paris kernel: [ 1.162220] scsi0 : ata_piix Apr 29 08:09:11 paris kernel: [ 1.162390] scsi1 : ata_piix Apr 29 08:09:11 paris kernel: [ 1.162485] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14 Apr 29 08:09:11 paris kernel: [ 1.162488] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15 Apr 29 08:09:11 paris kernel: [ 1.162767] ata2: port disabled--ignoring Apr 29 08:09:11 paris kernel: [ 1.334179] ata1.00: ATA-8: SAMSUNG HM160HC, LQ100-10, max UDMA/100 Apr 29 08:09:11 paris kernel: [ 1.334184] ata1.00: 312581808 sectors, multi 16: LBA48 Apr 29 08:09:11 paris kernel: [ 1.334192] ata1.01: ATAPI: HL-DT-ST DVDRAM GMA-4082N, HJ02, max UDMA/33 Apr 29 08:09:11 paris kernel: [ 1.350058] ata1.00: configured for UDMA/100 Apr 29 08:09:11 paris kernel: [ 1.364241] ata1.01: configured for UDMA/33 Apr 29 08:09:11 paris kernel: [ 1.366718] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HM160HC 0-10 PQ: 0 ANSI: 5 Apr 29 08:09:11 paris kernel: [ 1.370621] scsi 0:0:1:0: CD-ROM HL-DT-ST DVDRAM GMA-4082N HJ02 PQ: 0 ANSI: 5 Apr 29 08:09:11 paris kernel: [ 1.391384] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray Apr 29 08:09:11 paris kernel: [ 1.391391] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) Apr 29 08:09:11 paris kernel: [ 1.391393] cdrom: Uniform CD-ROM driver Revision: 3.20 Apr 29 08:09:11 paris kernel: [ 1.391617] sr 0:0:1:0: Attached scsi CD-ROM sr0 Apr 29 08:09:11 paris kernel: [ 1.391769] sd 0:0:0:0: [sda] Write Protect is off Apr 29 08:09:11 paris kernel: [ 1.391773] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 Apr 29 08:09:11 paris kernel: [ 1.391890] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Apr 29 08:09:11 paris kernel: [ 1.392441] sd 0:0:0:0: Attached scsi generic sg0 type 0 Apr 29 08:09:11 paris kernel: [ 1.392499] sr 0:0:1:0: Attached scsi generic sg1 type 5 Apr 29 08:09:11 paris kernel: [ 1.432047] usb 5-7: new high-speed USB device number 3 using ehci-pci Apr 29 08:09:11 paris kernel: [ 1.493174] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 > Apr 29 08:09:11 paris kernel: [ 1.511404] sd 0:0:0:0: [sda] Attached SCSI disk Apr 29 08:09:11 paris kernel: [ 1.571800] usb 5-7: New USB device found, idVendor=0402, idProduct=5602 Apr 29 08:09:11 paris kernel: [ 1.571809] usb 5-7: New USB device strings: Mfr=0, Product=1, SerialNumber=0 Apr 29 08:09:11 paris kernel: [ 1.571815] usb 5-7: Product: USB2.0 Camera Apr 29 08:09:11 paris kernel: [ 1.636056] tsc: Refined TSC clocksource calibration: 1728.999 MHz Apr 29 08:09:11 paris kernel: [ 1.640133] firewire_core 0000:04:01.1: created device fw0: GUID 00e01800035ca992, S400 Apr 29 08:09:11 paris kernel: [ 1.940051] usb 2-1: new low-speed USB device number 2 using uhci_hcd Apr 29 08:09:11 paris kernel: [ 2.115051] usb 2-1: New USB device found, idVendor=046d, idProduct=c016 Apr 29 08:09:11 paris kernel: [ 2.115058] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 Apr 29 08:09:11 paris kernel: [ 2.115062] usb 2-1: Product: Optical USB Mouse Apr 29 08:09:11 paris kernel: [ 2.115064] usb 2-1: Manufacturer: Logitech Apr 29 08:09:11 paris kernel: [ 2.119626] hidraw: raw HID events driver (C) Jiri Kosina Apr 29 08:09:11 paris kernel: [ 2.133951] usbcore: registered new interface driver usbhid Apr 29 08:09:11 paris kernel: [ 2.133955] usbhid: USB HID core driver Apr 29 08:09:11 paris kernel: [ 2.135577] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:1d.1/usb2/2-1/2-1:1.0/0003:046D:C016.0001/input/input5 Apr 29 08:09:11 paris kernel: [ 2.135722] hid-generic 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.1-1/input0 Apr 29 08:09:11 paris kernel: [ 2.192837] PM: Starting manual resume from disk Apr 29 08:09:11 paris kernel: [ 2.192845] PM: Hibernation image partition 8:7 present Apr 29 08:09:11 paris kernel: [ 2.192848] PM: Looking for hibernation image. Apr 29 08:09:11 paris kernel: [ 2.193159] PM: Image not found (code -22) Apr 29 08:09:11 paris kernel: [ 2.193162] PM: Hibernation image not present or could not be loaded. Apr 29 08:09:11 paris kernel: [ 2.404565] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) Apr 29 08:09:11 paris kernel: [ 2.636100] Switched to clocksource tsc Apr 29 08:09:11 paris kernel: [ 3.054382] random: nonblocking pool is initialized Apr 29 08:09:11 paris kernel: [ 6.261884] tsc: Marking TSC unstable due to TSC halts in idle Apr 29 08:09:11 paris kernel: [ 6.261894] ACPI: acpi_idle registered with cpuidle Apr 29 08:09:11 paris kernel: [ 6.262087] Switched to clocksource hpet Apr 29 08:09:11 paris kernel: [ 6.550424] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input6 Apr 29 08:09:11 paris kernel: [ 6.552191] ACPI: Lid Switch [LID] Apr 29 08:09:11 paris kernel: [ 6.552396] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7 Apr 29 08:09:11 paris kernel: [ 6.552408] ACPI: Power Button [PWRB] Apr 29 08:09:11 paris kernel: [ 6.552590] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input8 Apr 29 08:09:11 paris kernel: [ 6.552600] ACPI: Sleep Button [SLPB] Apr 29 08:09:11 paris kernel: [ 6.552785] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input9 Apr 29 08:09:11 paris kernel: [ 6.552794] ACPI: Power Button [PWRF] Apr 29 08:09:11 paris kernel: [ 6.827452] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 Apr 29 08:09:11 paris kernel: [ 6.872097] ACPI: AC Adapter [AC0] (on-line) Apr 29 08:09:11 paris kernel: [ 6.905804] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no) Apr 29 08:09:11 paris kernel: [ 6.906123] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input10 Apr 29 08:09:11 paris kernel: [ 7.052502] ACPI: Battery Slot [BAT0] (battery present) Apr 29 08:09:11 paris kernel: [ 7.088060] asus_laptop: Asus Laptop Support version 0.42 Apr 29 08:09:11 paris kernel: [ 7.088245] asus_laptop: A6JC model detected Apr 29 08:09:11 paris kernel: [ 7.092147] input: Asus Laptop extra buttons as /devices/platform/asus_laptop/input/input11 Apr 29 08:09:11 paris kernel: [ 7.199073] cfg80211: Calling CRDA to update world regulatory domain Apr 29 08:09:11 paris kernel: [ 7.228092] snd_hda_intel 0000:00:1b.0: irq 44 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 7.500305] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, in-tree:s Apr 29 08:09:11 paris kernel: [ 7.500315] iwl3945: Copyright(c) 2003-2011 Intel Corporation Apr 29 08:09:11 paris kernel: [ 7.500414] iwl3945 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control Apr 29 08:09:11 paris kernel: [ 7.553943] iwl3945 0000:03:00.0: Tunable channels: 13 802.11bg, 23 802.11a channels Apr 29 08:09:11 paris kernel: [ 7.553954] iwl3945 0000:03:00.0: Detected Intel Wireless WiFi Link 3945ABG Apr 29 08:09:11 paris kernel: [ 7.554036] iwl3945 0000:03:00.0: irq 45 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 7.610560] intel_rng: FWH not detected Apr 29 08:09:11 paris kernel: [ 7.776835] sound hdaudioC0D0: autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:hp Apr 29 08:09:11 paris kernel: [ 7.776849] sound hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0) Apr 29 08:09:11 paris kernel: [ 7.776857] sound hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0) Apr 29 08:09:11 paris kernel: [ 7.776864] sound hdaudioC0D0: mono: mono_out=0x0 Apr 29 08:09:11 paris kernel: [ 7.776871] sound hdaudioC0D0: dig-out=0x1e/0x0 Apr 29 08:09:11 paris kernel: [ 7.776876] sound hdaudioC0D0: inputs: Apr 29 08:09:11 paris kernel: [ 7.776884] sound hdaudioC0D0: Mic=0x18 Apr 29 08:09:11 paris kernel: [ 7.776890] sound hdaudioC0D0: Line=0x1a Apr 29 08:09:11 paris kernel: [ 7.776897] sound hdaudioC0D0: CD=0x1c Apr 29 08:09:11 paris kernel: [ 7.823183] ieee80211 phy0: Selected rate control algorithm 'iwl-3945-rs' Apr 29 08:09:11 paris kernel: [ 7.932793] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/hdaudioC0D0/input12 Apr 29 08:09:11 paris kernel: [ 8.174230] yenta_cardbus 0000:04:01.0: CardBus bridge found [1043:1237] Apr 29 08:09:11 paris kernel: [ 8.300885] yenta_cardbus 0000:04:01.0: ISA IRQ mask 0x0cb8, PCI irq 17 Apr 29 08:09:11 paris kernel: [ 8.300897] yenta_cardbus 0000:04:01.0: Socket status: 30000006 Apr 29 08:09:11 paris kernel: [ 8.300908] pci_bus 0000:04: Raising subordinate bus# of parent bus (#04) from #05 to #08 Apr 29 08:09:11 paris kernel: [ 8.300925] yenta_cardbus 0000:04:01.0: pcmcia: parent PCI bridge window: [io 0xd000-0xdfff] Apr 29 08:09:11 paris kernel: [ 8.300934] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xd000-0xdfff: Apr 29 08:09:11 paris kernel: [ 8.302362] excluding 0xd000-0xd0ff 0xd3b0-0xd3df 0xd400-0xd4ff 0xd7b0-0xd7df 0xdbb0-0xdbdf 0xdfb0-0xdfdf Apr 29 08:09:11 paris kernel: [ 8.307126] yenta_cardbus 0000:04:01.0: pcmcia: parent PCI bridge window: [mem 0xfe200000-0xfeafffff] Apr 29 08:09:11 paris kernel: [ 8.307136] pcmcia_socket pcmcia_socket0: cs: memory probe 0xfe200000-0xfeafffff: Apr 29 08:09:11 paris kernel: [ 8.307163] excluding 0xfea70000-0xfeafffff Apr 29 08:09:11 paris kernel: [ 8.307174] yenta_cardbus 0000:04:01.0: pcmcia: parent PCI bridge window: [mem 0xddf00000-0xdfefffff 64bit pref] Apr 29 08:09:11 paris kernel: [ 8.307183] pcmcia_socket pcmcia_socket0: cs: memory probe 0xddf00000-0xdfefffff: Apr 29 08:09:11 paris kernel: [ 8.307203] excluding 0xddf00000-0xdfefffff Apr 29 08:09:11 paris kernel: [ 8.389672] input: PC Speaker as /devices/platform/pcspkr/input/input13 Apr 29 08:09:11 paris kernel: [ 8.430472] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x00000800-0x0000084f (\GPIS) (20140424/utaddress-258) Apr 29 08:09:11 paris kernel: [ 8.430486] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x00000800-0x0000084f (\PMIO) (20140424/utaddress-258) Apr 29 08:09:11 paris kernel: [ 8.430496] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver Apr 29 08:09:11 paris kernel: [ 8.430503] ACPI Warning: SystemIO range 0x000004b0-0x000004bf conflicts with OpRegion 0x00000480-0x000004bf (\GPIO) (20140424/utaddress-258) Apr 29 08:09:11 paris kernel: [ 8.430512] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver Apr 29 08:09:11 paris kernel: [ 8.430516] ACPI Warning: SystemIO range 0x00000480-0x000004af conflicts with OpRegion 0x00000480-0x000004bf (\GPIO) (20140424/utaddress-258) Apr 29 08:09:11 paris kernel: [ 8.430524] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver Apr 29 08:09:11 paris kernel: [ 8.430528] lpc_ich: Resource conflict(s) found affecting gpio_ich Apr 29 08:09:11 paris kernel: [ 8.489072] r592: driver successfully loaded Apr 29 08:09:11 paris kernel: [ 8.502756] leds_ss4200: no LED devices found Apr 29 08:09:11 paris kernel: [ 8.551861] [drm] Initialized drm 1.1.0 20060810 Apr 29 08:09:11 paris kernel: [ 8.856383] wmi: Mapper loaded Apr 29 08:09:11 paris kernel: [ 9.422318] iTCO_vendor_support: vendor-support=0 Apr 29 08:09:11 paris kernel: [ 9.423333] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11 Apr 29 08:09:11 paris kernel: [ 9.423424] iTCO_wdt: Found a ICH7-M or ICH7-U TCO device (Version=2, TCOBASE=0x0860) Apr 29 08:09:11 paris kernel: [ 9.423730] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) Apr 29 08:09:11 paris kernel: [ 9.480728] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: Apr 29 08:09:11 paris kernel: [ 9.481850] excluding 0x170-0x177 0x1f0-0x1f7 0x370-0x377 Apr 29 08:09:11 paris kernel: [ 9.482717] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: Apr 29 08:09:11 paris kernel: [ 9.483011] excluding 0x3f0-0x3f7 0x400-0x41f 0x480-0x4bf 0x4d0-0x4d7 Apr 29 08:09:11 paris kernel: [ 9.483304] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: Apr 29 08:09:11 paris kernel: [ 9.483545] excluding 0x820-0x87f Apr 29 08:09:11 paris kernel: [ 9.483797] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: Apr 29 08:09:11 paris kernel: [ 9.484567] clean. Apr 29 08:09:11 paris kernel: [ 9.484625] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: Apr 29 08:09:11 paris kernel: [ 9.484640] excluding 0xc0000-0xcffff 0xe0000-0xfffff Apr 29 08:09:11 paris kernel: [ 9.484708] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: Apr 29 08:09:11 paris kernel: [ 9.484749] clean. Apr 29 08:09:11 paris kernel: [ 9.484791] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: Apr 29 08:09:11 paris kernel: [ 9.484831] clean. Apr 29 08:09:11 paris kernel: [ 9.484873] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: Apr 29 08:09:11 paris kernel: [ 9.485644] clean. Apr 29 08:09:11 paris kernel: [ 9.526349] psmouse serio4: synaptics: Touchpad model: 1, fw: 6.1, id: 0xa3a0b3, caps: 0xa04713/0x10008/0x0, board id: 3655, fw id: 30712 Apr 29 08:09:11 paris kernel: [ 9.563867] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input17 Apr 29 08:09:11 paris kernel: [ 9.714046] nouveau [ DEVICE][0000:01:00.0] BOOT0 : 0x046700a3 Apr 29 08:09:11 paris kernel: [ 9.714058] nouveau [ DEVICE][0000:01:00.0] Chipset: G72 (NV46) Apr 29 08:09:11 paris kernel: [ 9.714065] nouveau [ DEVICE][0000:01:00.0] Family : NV40 Apr 29 08:09:11 paris kernel: [ 9.714224] nouveau [ VBIOS][0000:01:00.0] checking PRAMIN for image... Apr 29 08:09:11 paris kernel: [ 9.800053] nouveau [ VBIOS][0000:01:00.0] ... appears to be valid Apr 29 08:09:11 paris kernel: [ 9.800060] nouveau [ VBIOS][0000:01:00.0] using image from PRAMIN Apr 29 08:09:11 paris kernel: [ 9.800303] nouveau [ VBIOS][0000:01:00.0] BIT signature found Apr 29 08:09:11 paris kernel: [ 9.800310] nouveau [ VBIOS][0000:01:00.0] version 05.72.22.41.92 Apr 29 08:09:11 paris kernel: [ 9.800827] nouveau 0000:01:00.0: irq 46 for MSI/MSI-X Apr 29 08:09:11 paris kernel: [ 9.800841] nouveau [ PMC][0000:01:00.0] MSI interrupts enabled Apr 29 08:09:11 paris kernel: [ 9.800881] nouveau [ PFB][0000:01:00.0] RAM type: DDR2 Apr 29 08:09:11 paris kernel: [ 9.800885] nouveau [ PFB][0000:01:00.0] RAM size: 128 MiB Apr 29 08:09:11 paris kernel: [ 9.800888] nouveau [ PFB][0000:01:00.0] ZCOMP: 0 tags Apr 29 08:09:11 paris kernel: [ 9.845649] nouveau [ PTHERM][0000:01:00.0] FAN control: none / external Apr 29 08:09:11 paris kernel: [ 9.845664] nouveau [ PTHERM][0000:01:00.0] fan management: automatic Apr 29 08:09:11 paris kernel: [ 9.845668] nouveau [ PTHERM][0000:01:00.0] internal sensor: yes Apr 29 08:09:11 paris kernel: [ 9.865538] nouveau [ CLK][0000:01:00.0] 20: core 100 MHz shader 100 MHz memory 270 MHz Apr 29 08:09:11 paris kernel: [ 9.865544] nouveau [ CLK][0000:01:00.0] 21: core 200 MHz shader 200 MHz memory 400 MHz Apr 29 08:09:11 paris kernel: [ 9.865549] nouveau [ CLK][0000:01:00.0] 22: core 350 MHz shader 350 MHz memory 600 MHz Apr 29 08:09:11 paris kernel: [ 9.865560] nouveau [ CLK][0000:01:00.0] --: core 199 MHz memory 391 MHz Apr 29 08:09:11 paris kernel: [ 9.865712] [TTM] Zone kernel: Available graphics memory: 445276 kiB Apr 29 08:09:11 paris kernel: [ 9.865715] [TTM] Zone highmem: Available graphics memory: 515840 kiB Apr 29 08:09:11 paris kernel: [ 9.865717] [TTM] Initializing pool allocator Apr 29 08:09:11 paris kernel: [ 9.865728] [TTM] Initializing DMA pool allocator Apr 29 08:09:11 paris kernel: [ 9.866885] nouveau [ DRM] VRAM: 124 MiB Apr 29 08:09:11 paris kernel: [ 9.866891] nouveau [ DRM] GART: 512 MiB Apr 29 08:09:11 paris kernel: [ 9.866898] nouveau [ DRM] TMDS table version 1.1 Apr 29 08:09:11 paris kernel: [ 9.866901] nouveau W[ DRM] TMDS table script pointers not stubbed Apr 29 08:09:11 paris kernel: [ 9.866904] nouveau [ DRM] DCB version 3.0 Apr 29 08:09:11 paris kernel: [ 9.866908] nouveau [ DRM] DCB outp 00: 03005323 00000004 Apr 29 08:09:11 paris kernel: [ 9.866912] nouveau [ DRM] DCB outp 01: 01010300 00000028 Apr 29 08:09:11 paris kernel: [ 9.866915] nouveau [ DRM] DCB outp 02: 04026312 00000000 Apr 29 08:09:11 paris kernel: [ 9.866918] nouveau [ DRM] DCB outp 03: 020333f1 0080c070 Apr 29 08:09:11 paris kernel: [ 9.866922] nouveau [ DRM] DCB conn 00: 0000 Apr 29 08:09:11 paris kernel: [ 9.866926] nouveau [ DRM] DCB conn 01: 0130 Apr 29 08:09:11 paris kernel: [ 9.866929] nouveau [ DRM] DCB conn 02: 0210 Apr 29 08:09:11 paris kernel: [ 9.866932] nouveau [ DRM] DCB conn 03: 0211 Apr 29 08:09:11 paris kernel: [ 9.866934] nouveau [ DRM] DCB conn 04: 0213 Apr 29 08:09:11 paris kernel: [ 9.866937] nouveau [ DRM] DCB conn 05: 0340 Apr 29 08:09:11 paris kernel: [ 9.866940] nouveau [ DRM] DCB conn 06: 1431 Apr 29 08:09:11 paris kernel: [ 9.867145] nouveau [ DRM] Saving VGA fonts Apr 29 08:09:11 paris kernel: [ 9.929028] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). Apr 29 08:09:11 paris kernel: [ 9.929033] [drm] Driver supports precise vblank timestamp query. Apr 29 08:09:11 paris kernel: [ 9.929041] nouveau [ DRM] 0xD518: Parsing digital output script table Apr 29 08:09:11 paris kernel: [ 9.983119] nouveau [ DRM] MM: using M2MF for buffer copies Apr 29 08:09:11 paris kernel: [ 9.983139] nouveau [ DRM] Calling LVDS script 6: Apr 29 08:09:11 paris kernel: [ 9.983147] nouveau [ DRM] 0xD259: Parsing digital output script table Apr 29 08:09:11 paris kernel: [ 10.261031] nouveau [ DRM] Setting dpms mode 3 on TV encoder (output 3) Apr 29 08:09:11 paris kernel: [ 10.348350] nouveau [ DRM] allocated 1280x800 fb: 0x9000, bo f6fa1c00 Apr 29 08:09:11 paris kernel: [ 10.348601] fbcon: nouveaufb (fb0) is primary device Apr 29 08:09:11 paris kernel: [ 10.370198] nouveau [ DRM] Calling LVDS script 2: Apr 29 08:09:11 paris kernel: [ 10.370201] nouveau [ DRM] 0xD2BA: Parsing digital output script table Apr 29 08:09:11 paris kernel: [ 10.501185] nouveau [ DRM] Calling LVDS script 5: Apr 29 08:09:11 paris kernel: [ 10.501188] nouveau [ DRM] 0xD24A: Parsing digital output script table Apr 29 08:09:11 paris kernel: [ 10.502915] Console: switching to colour frame buffer device 160x50 Apr 29 08:09:11 paris kernel: [ 10.504722] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device Apr 29 08:09:11 paris kernel: [ 10.504725] nouveau 0000:01:00.0: registered panic notifier Apr 29 08:09:11 paris kernel: [ 10.516099] [drm] Initialized nouveau 1.1.2 20120801 for 0000:01:00.0 on minor 0 Apr 29 08:09:11 paris kernel: [ 11.513450] media: Linux media interface: v0.10 Apr 29 08:09:11 paris kernel: [ 11.548168] Linux video capture interface: v2.00 Apr 29 08:09:11 paris kernel: [ 11.661593] gspca_main: v2.14.0 registered Apr 29 08:09:11 paris kernel: [ 11.729193] gspca_main: ALi m5602-2.14.0 probing 0402:5602 Apr 29 08:09:11 paris kernel: [ 11.809562] gspca_m5602: Detected an ov9650 sensor Apr 29 08:09:11 paris kernel: [ 11.875270] usbcore: registered new interface driver ALi m5602 Apr 29 08:09:11 paris kernel: [ 12.229272] EXT4-fs (sda2): re-mounted. Opts: (null) Apr 29 08:09:11 paris kernel: [ 42.852122] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen Apr 29 08:09:11 paris kernel: [ 42.852164] ata1.00: failed command: READ DMA Apr 29 08:09:11 paris kernel: [ 42.852194] ata1.00: cmd c8/00:90:20:c7:3a/00:00:00:00:00/e1 tag 0 dma 73728 in Apr 29 08:09:11 paris kernel: [ 42.852194] res 40/00:fe:00:00:00/00:00:00:00:00/40 Emask 0x4 (timeout) Apr 29 08:09:11 paris kernel: [ 42.852235] ata1.00: status: { DRDY } Apr 29 08:09:11 paris kernel: [ 47.892051] ata1: link is slow to respond, please be patient (ready=0) Apr 29 08:09:11 paris kernel: [ 52.876052] ata1: device not ready (errno=-16), forcing hardreset Apr 29 08:09:11 paris kernel: [ 52.876069] ata1: soft resetting link Apr 29 08:09:11 paris kernel: [ 53.066139] ata1.00: configured for UDMA/100 Apr 29 08:09:11 paris kernel: [ 53.080300] ata1.01: configured for UDMA/33 Apr 29 08:09:11 paris kernel: [ 53.082604] ata1.00: device reported invalid CHS sector 0 Apr 29 08:09:11 paris kernel: [ 53.082621] ata1: EH complete Apr 29 08:09:11 paris kernel: [ 64.361483] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro Apr 29 08:09:11 paris kernel: [ 65.373795] lp: driver loaded but no devices found Apr 29 08:09:11 paris kernel: [ 65.390459] ppdev: user-space parallel port driver Apr 29 08:09:11 paris kernel: [ 65.416407] EXT4-fs (sda6): mounting ext3 file system using the ext4 subsystem Apr 29 08:09:11 paris kernel: [ 65.435660] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: user_xattr Apr 29 08:09:11 paris kernel: [ 65.473896] FAT-fs (sda5): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! Apr 29 08:09:11 paris kernel: [ 65.489079] loop: module loaded Apr 29 08:09:11 paris kernel: [ 65.522909] fuse init (API version 7.23) Apr 29 08:09:11 paris kernel: [ 65.574865] FAT-fs (sda5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. Apr 29 08:09:11 paris kernel: [ 65.612564] REISERFS (device sda3): found reiserfs format "3.6" with standard journal Apr 29 08:09:11 paris kernel: [ 65.612583] REISERFS (device sda3): using ordered data mode Apr 29 08:09:11 paris kernel: [ 65.612587] reiserfs: using flush barriers Apr 29 08:09:11 paris kernel: [ 65.623460] REISERFS (device sda3): journal params: device sda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Apr 29 08:09:11 paris kernel: [ 65.624143] REISERFS (device sda3): checking transaction log (sda3) Apr 29 08:09:11 paris kernel: [ 65.687830] REISERFS (device sda3): Using r5 hash to sort names Apr 29 08:09:11 paris kernel: [ 66.449368] r8169 0000:02:00.0 eth0: link down Apr 29 08:09:11 paris kernel: [ 66.449389] r8169 0000:02:00.0 eth0: link down Apr 29 08:09:11 paris kernel: [ 66.449412] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Apr 29 08:09:11 paris kernel: [ 67.451417] RPC: Registered named UNIX socket transport module. Apr 29 08:09:11 paris kernel: [ 67.451423] RPC: Registered udp transport module. Apr 29 08:09:11 paris kernel: [ 67.451426] RPC: Registered tcp transport module. Apr 29 08:09:11 paris kernel: [ 67.451428] RPC: Registered tcp NFSv4.1 backchannel transport module. Apr 29 08:09:11 paris kernel: [ 67.464631] FS-Cache: Loaded Apr 29 08:09:11 paris kernel: [ 67.500816] FS-Cache: Netfs 'nfs' registered for caching Apr 29 08:09:11 paris kernel: [ 67.556702] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Apr 29 08:09:11 paris kernel: [ 68.172487] r8169 0000:02:00.0 eth0: link up Apr 29 08:09:11 paris kernel: [ 68.172503] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Apr 29 08:09:11 paris kernel: [ 68.599709] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input18 Apr 29 08:09:11 paris rsyslogd-2007: action 'action 17' suspended, next retry is Wed Apr 29 08:09:41 2015 [try http://www.rsyslog.com/e/2007 ] Apr 29 08:09:11 paris anacron[2028]: Anacron 2.3 started on 2015-04-29 Apr 29 08:09:11 paris anacron[2028]: Normal exit (0 jobs run) Apr 29 08:09:11 paris acpid: starting up with netlink and the input layer Apr 29 08:09:11 paris kernel: [ 69.259366] apm: BIOS not found. Apr 29 08:09:12 paris acpid: 27 rules loaded Apr 29 08:09:12 paris acpid: waiting for events: event logging is off Apr 29 08:09:12 paris cron[2163]: (CRON) INFO (pidfile fd = 3) Apr 29 08:09:12 paris cron[2164]: (CRON) STARTUP (fork ok) Apr 29 08:09:12 paris cron[2164]: (CRON) INFO (Running @reboot jobs) Apr 29 08:09:12 paris dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3 Apr 29 08:09:12 paris dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67 Apr 29 08:09:12 paris dhclient: DHCPOFFER from 192.168.1.1 Apr 29 08:09:12 paris dhclient: DHCPACK from 192.168.1.1 Apr 29 08:09:13 paris dhclient: bound to 192.168.1.11 -- renewal in 38552 seconds. Apr 29 08:09:13 paris ntpd[2380]: ntpd 4.2.6p5@1.2349-o Fri Apr 10 19:27:19 UTC 2015 (1) Apr 29 08:09:13 paris ntpd[2603]: proto: precision = 1.466 usec Apr 29 08:09:13 paris ntpd[2603]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123 Apr 29 08:09:13 paris ntpd[2603]: Listen and drop on 1 v6wildcard :: UDP 123 Apr 29 08:09:13 paris ntpd[2603]: Listen normally on 2 lo 127.0.0.1 UDP 123 Apr 29 08:09:13 paris ntpd[2603]: Listen normally on 3 eth0 192.168.1.11 UDP 123 Apr 29 08:09:13 paris ntpd[2603]: Listen normally on 4 lo ::1 UDP 123 Apr 29 08:09:13 paris ntpd[2603]: Listen normally on 5 eth0 fe80::217:31ff:fecf:190 UDP 123 Apr 29 08:09:13 paris ntpd[2603]: peers refreshed Apr 29 08:09:13 paris ntpd[2603]: Listening on routing socket on fd #22 for interface updates Apr 29 08:09:14 paris bluetoothd[2710]: Bluetooth daemon 5.23 Apr 29 08:09:14 paris avahi-daemon[2779]: Found user 'avahi' (UID 109) and group 'avahi' (GID 119). Apr 29 08:09:14 paris avahi-daemon[2779]: Successfully dropped root privileges. Apr 29 08:09:14 paris avahi-daemon[2779]: avahi-daemon 0.6.31 starting up. Apr 29 08:09:14 paris avahi-daemon[2779]: Successfully called chroot(). Apr 29 08:09:14 paris avahi-daemon[2779]: Successfully dropped remaining capabilities. Apr 29 08:09:14 paris avahi-daemon[2779]: Loading service file /services/udisks.service. Apr 29 08:09:15 paris avahi-daemon[2779]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::217:31ff:fecf:190. Apr 29 08:09:15 paris avahi-daemon[2779]: New relevant interface eth0.IPv6 for mDNS. Apr 29 08:09:15 paris avahi-daemon[2779]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.11. Apr 29 08:09:15 paris avahi-daemon[2779]: New relevant interface eth0.IPv4 for mDNS. Apr 29 08:09:15 paris avahi-daemon[2779]: Network interface enumeration completed. Apr 29 08:09:15 paris avahi-daemon[2779]: Registering new address record for fe80::217:31ff:fecf:190 on eth0.*. Apr 29 08:09:15 paris avahi-daemon[2779]: Registering new address record for 192.168.1.11 on eth0.IPv4. Apr 29 08:09:15 paris avahi-daemon[2779]: Registering HINFO record with values 'I686'/'LINUX'. Apr 29 08:09:15 paris bluetoothd[2710]: Starting SDP server Apr 29 08:09:15 paris kernel: [ 72.733527] Bluetooth: Core ver 2.19 Apr 29 08:09:15 paris kernel: [ 72.733572] NET: Registered protocol family 31 Apr 29 08:09:15 paris kernel: [ 72.733578] Bluetooth: HCI device and connection manager initialized Apr 29 08:09:15 paris kernel: [ 72.733597] Bluetooth: HCI socket layer initialized Apr 29 08:09:15 paris kernel: [ 72.733606] Bluetooth: L2CAP socket layer initialized Apr 29 08:09:15 paris kernel: [ 72.733631] Bluetooth: SCO socket layer initialized Apr 29 08:09:15 paris kernel: [ 73.376795] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Apr 29 08:09:15 paris kernel: [ 73.376805] Bluetooth: BNEP filters: protocol multicast Apr 29 08:09:15 paris kernel: [ 73.376825] Bluetooth: BNEP socket layer initialized Apr 29 08:09:15 paris bluetoothd[2710]: Bluetooth management interface 1.6 initialized Apr 29 08:09:15 paris dbus[2647]: [system] Activating service name='org.freedesktop.hostname1' (using servicehelper) Apr 29 08:09:15 paris dbus[2647]: [system] Successfully activated service 'org.freedesktop.hostname1' Apr 29 08:09:15 paris avahi-daemon[2779]: Server startup complete. Host name is paris.local. Local service cookie is 2746328492. Apr 29 08:09:16 paris avahi-daemon[2779]: Service "paris" (/services/udisks.service) successfully established. Apr 29 08:09:18 paris kernel: [ 75.757305] iwl3945 0000:03:00.0: firmware: direct-loading firmware iwlwifi-3945-2.ucode Apr 29 08:09:18 paris kernel: [ 75.757320] iwl3945 0000:03:00.0: loaded firmware version 15.32.2.9 Apr 29 08:09:18 paris kernel: [ 75.826277] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready Apr 29 08:09:18 paris kernel: [ 76.647390] cfg80211: Calling CRDA to update world regulatory domain Apr 29 08:09:29 paris dbus[2647]: [system] Activating service name='org.freedesktop.ConsoleKit' (using servicehelper) Apr 29 08:09:29 paris dbus[2647]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper) Apr 29 08:09:29 paris polkitd[3026]: started daemon version 0.105 using authority implementation `local' version `0.105' Apr 29 08:09:29 paris dbus[2647]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Apr 29 08:09:29 paris dbus[2647]: [system] Successfully activated service 'org.freedesktop.ConsoleKit' Apr 29 08:10:07 paris console-kit-daemon[2959]: GLib-CRITICAL: Source ID 23 was not found when attempting to remove it Apr 29 08:17:01 paris CRON[3159]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 08:40:12 paris kernel: [ 1930.204081] nouveau [ DRM] Calling LVDS script 6: Apr 29 08:40:12 paris kernel: [ 1930.204087] nouveau [ DRM] 0xD259: Parsing digital output script table Apr 29 09:04:50 paris kernel: [ 3407.648409] nouveau [ DRM] Calling LVDS script 2: Apr 29 09:04:50 paris kernel: [ 3407.648416] nouveau [ DRM] 0xD2BA: Parsing digital output script table Apr 29 09:04:50 paris kernel: [ 3407.779423] nouveau [ DRM] Calling LVDS script 5: Apr 29 09:04:50 paris kernel: [ 3407.779427] nouveau [ DRM] 0xD24A: Parsing digital output script table Apr 29 09:17:01 paris CRON[3899]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 09:34:53 paris kernel: [ 5211.100083] nouveau [ DRM] Calling LVDS script 6: Apr 29 09:34:53 paris kernel: [ 5211.100089] nouveau [ DRM] 0xD259: Parsing digital output script table Apr 29 09:54:00 paris kernel: [ 6358.154249] nouveau [ DRM] Calling LVDS script 2: Apr 29 09:54:00 paris kernel: [ 6358.154255] nouveau [ DRM] 0xD2BA: Parsing digital output script table Apr 29 09:54:00 paris kernel: [ 6358.285263] nouveau [ DRM] Calling LVDS script 5: Apr 29 09:54:00 paris kernel: [ 6358.285268] nouveau [ DRM] 0xD24A: Parsing digital output script table Apr 29 09:54:27 paris kernel: [ 6385.236106] usb 5-1: new high-speed USB device number 4 using ehci-pci Apr 29 09:54:27 paris kernel: [ 6385.676070] usb 5-1: new high-speed USB device number 5 using ehci-pci Apr 29 09:54:28 paris kernel: [ 6385.809157] usb 5-1: New USB device found, idVendor=1058, idProduct=07a8 Apr 29 09:54:28 paris kernel: [ 6385.809166] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Apr 29 09:54:28 paris kernel: [ 6385.809174] usb 5-1: Product: My Passport 07A8 Apr 29 09:54:28 paris kernel: [ 6385.809181] usb 5-1: Manufacturer: Western Digital Apr 29 09:54:28 paris kernel: [ 6385.809187] usb 5-1: SerialNumber: 575838314141324431333932 Apr 29 09:54:28 paris mtp-probe: checking bus 5, device 5: "/sys/devices/pci0000:00/0000:00:1d.7/usb5/5-1" Apr 29 09:54:28 paris mtp-probe: bus: 5, device: 5 was not an MTP device Apr 29 09:54:28 paris kernel: [ 6385.949458] usb-storage 5-1:1.0: USB Mass Storage device detected Apr 29 09:54:28 paris kernel: [ 6385.950033] scsi2 : usb-storage 5-1:1.0 Apr 29 09:54:28 paris kernel: [ 6385.950319] usbcore: registered new interface driver usb-storage Apr 29 09:54:29 paris kernel: [ 6387.312164] scsi 2:0:0:0: Direct-Access WD My Passport 07A8 1033 PQ: 0 ANSI: 6 Apr 29 09:54:29 paris kernel: [ 6387.312547] scsi 2:0:0:1: Enclosure WD SES Device 1033 PQ: 0 ANSI: 6 Apr 29 09:54:29 paris kernel: [ 6387.314729] sd 2:0:0:0: Attached scsi generic sg2 type 0 Apr 29 09:54:29 paris kernel: [ 6387.315307] scsi 2:0:0:1: Attached scsi generic sg3 type 13 Apr 29 09:54:29 paris kernel: [ 6387.315925] sd 2:0:0:0: [sdb] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB) Apr 29 09:54:29 paris kernel: [ 6387.316388] sd 2:0:0:0: [sdb] Write Protect is off Apr 29 09:54:29 paris kernel: [ 6387.316398] sd 2:0:0:0: [sdb] Mode Sense: 53 00 10 08 Apr 29 09:54:29 paris kernel: [ 6387.316873] sd 2:0:0:0: [sdb] No Caching mode page found Apr 29 09:54:29 paris kernel: [ 6387.316908] sd 2:0:0:0: [sdb] Assuming drive cache: write through Apr 29 09:54:29 paris kernel: [ 6387.330651] sdb: sdb1 Apr 29 09:54:29 paris kernel: [ 6387.333012] sd 2:0:0:0: [sdb] Attached SCSI disk Apr 29 09:54:29 paris kernel: [ 6387.372120] ses 2:0:0:1: Attached Enclosure device Apr 29 09:55:06 paris kernel: [ 6423.754983] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! Apr 29 09:55:06 paris kernel: [ 6423.755467] FAT-fs (sdb1): bogus number of reserved sectors Apr 29 09:55:06 paris kernel: [ 6423.755508] FAT-fs (sdb1): Can't find a valid FAT filesystem Apr 29 09:55:33 paris ntfs-3g[4413]: Version 2014.2.15AR.2 integrated FUSE 28 Apr 29 09:55:33 paris ntfs-3g[4413]: Mounted /dev/sdb1 (Read-Write, label "wd_blk_1tb", NTFS 3.1) Apr 29 09:55:33 paris ntfs-3g[4413]: Cmdline options: rw Apr 29 09:55:33 paris ntfs-3g[4413]: Mount options: rw,allow_other,nonempty,relatime,fsname=/dev/sdb1,blkdev,blksize=4096 Apr 29 09:55:33 paris ntfs-3g[4413]: Ownership and permissions disabled, configuration type 7 Apr 29 09:57:11 paris ntfs-3g[4413]: Unmounting /dev/sdb1 (wd_blk_1tb) Apr 29 09:57:16 paris kernel: [ 6554.336820] usb 5-1: USB disconnect, device number 5 Apr 29 10:17:01 paris CRON[4698]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 10:27:15 paris kernel: [ 8352.732073] nouveau [ DRM] Calling LVDS script 6: Apr 29 10:27:15 paris kernel: [ 8352.732079] nouveau [ DRM] 0xD259: Parsing digital output script table Apr 29 11:17:01 paris CRON[5437]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 12:17:01 paris CRON[6176]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 13:17:01 paris CRON[6915]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 14:17:01 paris CRON[7654]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Apr 29 14:28:21 paris kernel: [22818.762362] nouveau [ DRM] Calling LVDS script 2: Apr 29 14:28:21 paris kernel: [22818.762369] nouveau [ DRM] 0xD2BA: Parsing digital output script table Apr 29 14:28:21 paris kernel: [22818.893372] nouveau [ DRM] Calling LVDS script 5: Apr 29 14:28:21 paris kernel: [22818.893377] nouveau [ DRM] 0xD24A: Parsing digital output script table Apr 29 14:38:48 paris kernel: [23446.068080] usb 5-1: new high-speed USB device number 6 using ehci-pci Apr 29 14:38:48 paris kernel: [23446.200969] usb 5-1: New USB device found, idVendor=0204, idProduct=6025 Apr 29 14:38:48 paris kernel: [23446.200983] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Apr 29 14:38:48 paris kernel: [23446.200999] usb 5-1: Product: Flash Disk Apr 29 14:38:48 paris kernel: [23446.201010] usb 5-1: Manufacturer: USB2.0 Apr 29 14:38:48 paris kernel: [23446.201020] usb 5-1: SerialNumber: 142267543726 Apr 29 14:38:48 paris kernel: [23446.201790] usb-storage 5-1:1.0: USB Mass Storage device detected Apr 29 14:38:48 paris kernel: [23446.202370] scsi3 : usb-storage 5-1:1.0 Apr 29 14:38:48 paris mtp-probe: checking bus 5, device 6: "/sys/devices/pci0000:00/0000:00:1d.7/usb5/5-1" Apr 29 14:38:48 paris mtp-probe: bus: 5, device: 6 was not an MTP device Apr 29 14:38:49 paris kernel: [23447.200746] scsi 3:0:0:0: Direct-Access USB2.0 Flash Disk 2.00 PQ: 0 ANSI: 2 Apr 29 14:38:49 paris kernel: [23447.201584] sd 3:0:0:0: Attached scsi generic sg2 type 0 Apr 29 14:38:49 paris kernel: [23447.202244] sd 3:0:0:0: [sdb] 502324 512-byte logical blocks: (257 MB/245 MiB) Apr 29 14:38:49 paris kernel: [23447.202545] sd 3:0:0:0: [sdb] Write Protect is off Apr 29 14:38:49 paris kernel: [23447.202554] sd 3:0:0:0: [sdb] Mode Sense: 0b 00 00 08 Apr 29 14:38:49 paris kernel: [23447.202785] sd 3:0:0:0: [sdb] No Caching mode page found Apr 29 14:38:49 paris kernel: [23447.203517] sd 3:0:0:0: [sdb] Assuming drive cache: write through Apr 29 14:38:49 paris kernel: [23447.207644] sdb: sdb1 Apr 29 14:38:49 paris kernel: [23447.210055] sd 3:0:0:0: [sdb] Attached SCSI removable disk Apr 29 14:39:21 paris kernel: [23479.633138] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Fin.
Vérifies le référencement des [mono]UUID=xxxx-xxxx-xxxx-xxx[/mono] sur la foi de [mono]$ ls -l /dev/disk/by-uuid[/mono] avec ton fichier [mono]fstab[/mono].
Sont-ils concordants ?
[quote=“darko”][code]# /etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
proc /proc proc defaults 0 0
/ was on /dev/sda2 during installation
UUID=bf5b31e0-4d64-48a7-8f3b-afd3d5f67521 / ext4 errors=remount-ro,nofail 0 1
/data was on /dev/sda6 during installation
UUID=bdff4606-001b-4481-9a86-abce6a3abc36 /data ext3 defaults,user_xattr,nofail 0 2
/win_d was on /dev/sda5 during installation
UUID=4CC3-12EB /win_d vfat utf8,umask=000 0 0
swap was on /dev/sda7 during installation
######UUID=0e642163-9765-4e66-ab5a-24e6b4221be8 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/sda3 /home reiserfs defaults,user_xattr 0 2
UUID=cd0b14c7-79b2-4ccc-9eef-06acecf516a1 /home reiserfs defaults,user_xattr,nofail 0 2[/code][/quote]
Comment se fait-il que la partition [mono]swap[/mono] soit commenter (#) ?
[mono]# swap was on /dev/sda7 during installation
######UUID=0e642163-9765-4e66-ab5a-24e6b4221be8 none swap sw 0 0[/mono]
[quote=“darko”]Ma version debian est la 8.0.
J’ai effectué les mises à jour lorsqu’elle m’ont été proposées par apt. Je l’ai fait en deux fois avec apt-get upgrade puis apt-get dist-upgrade[/quote]
Sauf erreur¹, tu es censé tourner sous [mono]systemd[/mono].
Cependant¹, [mono]grub[/mono] nous informe du contraire.
[quote]Apr 29 07:20:34 paris kernel: [ 0.000000] Kernel command line:
BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-686-pae root=UUID=bf5b31e0-4d64-48a7-8f3b-afd3d5f67521 ro quiet init=/lib/sysvinit/init[/quote]
Comment se fait-il ?
Après avoir visionner les logs plus ou moins en diagonale et d’un œil peu averti dans ce domaine, il en ressort :
[quote][ 65.416407] EXT4-fs (sda6): mounting ext3 file system using the ext4 subsystem
[ 65.574865] FAT-fs (sda5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.[/quote]
[quote]Apr 29 07:16:17 paris kernel: [ 712.804851] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Apr 29 07:16:22 paris kernel: [ 717.613827] device-mapper: table: 254:0: multipath: error getting device
Apr 29 07:16:22 paris kernel: [ 717.613872] device-mapper: ioctl: error adding target to table[/quote]
[quote]Apr 29 07:20:34 paris kernel: [ 42.852433] ata1: drained 200 bytes to clear DRQ
Apr 29 07:20:34 paris kernel: [ 42.852452] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
Apr 29 07:20:34 paris kernel: [ 42.852490] ata1.00: failed command: READ DMA
Apr 29 07:20:34 paris kernel: [ 42.852520] ata1.00: cmd c8/00:08:98:7f:8f/00:00:00:00:00/e2 tag 0 dma 4096 in
Apr 29 07:20:34 paris kernel: [ 42.852520] res 40/00:00:00:00:00/00:00:00:00:00/40 Emask 0x4 (timeout)
Apr 29 07:20:34 paris kernel: [ 42.852560] ata1.00: status: { DRDY }[/quote]
[quote]Apr 29 07:20:39 paris multipathd: SAMSUNG_HM160HC_S12TJD0PB42515: ignoring map
Apr 29 07:20:39 paris kernel: [ 63.933195] device-mapper: table: 254:0: multipath: error getting device
Apr 29 07:20:39 paris kernel: [ 63.933506] device-mapper: ioctl: error adding target to table[/quote]
Éventuellement, [mono]systemctl[/mono] nous retournerait-il une bride d’info ?
Il semble y avoir un souci avec le disque Sata, j’avais eu ce genre de choses résolu en changeant de noyau. Rien ne t’empêche de garder le noyau 3.2, sinon il faut regarder pourquoi un souci existe sur le disque SATA (microcode manquant?) Quelle est la situation exacte lorsque tu démarres sur ce noyau?
Salut Belzébuth, merci de t’être penché sur mon problème.
Je te réponds pas-à-pas, parce que je suis pas au niveau du tout.
[quote]Vérifies le référencement des UUID=xxxx-xxxx-xxxx-xxx sur la foi de $ ls -l /dev/disk/by-uuid avec ton fichier fstab.
Sont-ils concordants ?[/quote]
Les UUID de fstab et ceux obtenus en appelant ls -l /dev/disk/by-uuid/ sont identiques.
J’ai fait ça sur le conseil d’un utilisateur du forum Debian en anglais. J’ai également rajouté les options nofail à toutes les lignes. Ça m’a permis de booter en mode “normal” ce que je ne pouvais pas faire avant (mot de passe non reconnu en console root, puis plus rien, alors que maintenant j’arrive jusqu’au login normal, et que mes deux mdp - utilisateurs et root - fonctionnent). Le système était bien cassé avant cette modification.
D’accord. Note que je n’ai fait aucune modif moi-même. Je suppose que c’est un problème !
Malheureusement :
$ systemctl list-units -tmount Failed to get D-Bus connection: Unknown error -1
Qu’est-ce que je pourrais essayer de faire ?
Et au fait, je précise que je ne sais absolument pas ce qu’est multipath, et que je n’ai aucun paquet multipath* installé.
Fran.b : J’ai des erreurs également quand je boot sur le noyau 3.2. Comment pourrais-je isoler le log de boot du noyau 3.2 et du 3.16, pour le poster ici ?
On m’a demandé quelque chose sur le forum anglophone, qui est peut-être intéressant :
ls -l /sbin/init >>>lrwxrwxrwx 1 root root 20 Apr 17 18:37 /sbin/init -> /lib/systemd/systemd
cat /proc/cmdline >>>BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-686-pae root=UUID=bf5b31e0-4d64-48a7-8f3b-afd3d5f67521 ro quiet init=/lib/sysvinit/init
Moi je ne comprends rien, mais est-ce que ça pourrait montrer une redondance/incompatibilité entre 2 programmes faisant la même chose, systemd et sysvinit ?
Bon, essaye de bouter en faisant comme suit:
  • Au menu du boot, tu tapes sur «e»
  • Tu vas sur la ligne contenant «root=UUID=bf5b31e0-4d64-48a7-8f3b-afd3d5f67521 ro quiet»
  • avec les flèches et en faisant attention que tu es en qwerty, tu remplaces
init=/lib/sysvinit/initparinit=/sbin/init et tu tapes sur F10
fran.b,
D’accord. Par contre je pense que je n’ai pas compris la manip demandée, quand je tape “e” au démarrage pour avoir le menu grub, je ne vois nulle part de ligne init=/lib/sysvinit/init Je ne dois pas comprendre quelque chose, je poste une photo de mon écran de boot///grub. Peux-tu m’expliquer quoi faire ?
avec les flèches tu te déplaces sur les lignes jusqu’à la ligne linux, tu vires le quiet et met init=/sbin/init puis tu tapes sur F10
D’accord.
Je pense que ça a “marché” :
J’ai trois possibilités de boot par noyau. Pour le 3.16, ça donne :
-3.16.0-4-686-pae, avec pour seules option “ro quiet”. Rien ne se passe si je spécifie “init=/sbin/init”, j’ai toujours la même erreur au boot ;
-3.16.0-4-686-pae (sysvinit), avec effectivement une ligne init=/lib/sysvinit/init indiquée sur l’écran grub. Si je la remplace par “init=/sbin/init” effectivement le boot se passe sans erreur (en fait une fois sur deux en gros) ;
  • et bon 3.16.0-4-686-pae (recovery mode).
Qu’est-ce que je peux faire maintenant ?
C’est effectivement un souci entre l’init via systemd et le vieux. Je ne connais pas assez systemd pour t’aider.
D’accord. Comme solution il me reste la réinstallation, en gros ?
Non, on va essayé de voir. Bon, quand tu lances par init=/sbin/init, tu dis que ça marche une fois sur 2, sois plus précis. Que se passe-t-il exactement? as tu des logs?
pourquoi un noyau pae?
tu peux essayer un "standard"
packages.debian.org/fr/jessie/kernel/
linux-image-3.16.0-4-586 (3.16.7-ckt9-3~deb8u1) [security]
Linux 3.16 for older PCs
linux-image-3.16.0-4-amd64 (3.16.7-ckt9-3~deb8u1) [security]
Linux 3.16 for 64-bit PCs
Fran.b,
C’est assez bizard : j’avais booté une première fois avec succès avec l’entrée “-3.16.0-4-686-pae (sysvinit)”, en passant l’option “init=/sbin/init”. Quand j’ai réessayé en supprimant en plus l’option “quiet”, je suis retombé sur l’erreur de départ :
[quote](1 of 4) a start job is running for dev-disk-by\X2du[/quote] Quand j’ai réssayé en mode “quiet”, j’ai à nouveau pu booter sans message d’erreur (???). La modification “init=/sbin/init” ne produit par contre aucun résultat quand on la passe au boot “normal”, “-3.16.0-4-686-pae” (non sysvinit donc), qui n’a pas d’option, ni init=/lib/sysvinit/init, ni init=/sbin/init dans la config grub.
L’écran de boot, avec ce fameux message d’erreur, je ne sais pas ou le retrouver. Ça correspond au dsmeg que j’ai posté le 28 à 1:49, mais je ne retrouve pas le message d’erreur, tel quel en tout cas. Tu saurais comment je pourrais faire une copie direct du “vrai” log de boot ? Autrement je peux sortir tous les logs que tu/vous voulez, je ne sais juste pas lesquels poster.
Grand Toubab,
Je pensais avoir choisi le noyau par défaut lorsque j’avais installé ce système, je ne savais même pas que ça n’était pas le choix standard. Je veux bien changer de noyau, mais est-ce que cela peut résoudre mon problème ? J’ai toujours mon noyau précédent, 3.2.0-4-686-pae, qui fonctionnait parfaitement avant l’upgrade, et qui me renvoie désormais les mêmes erreurs que le nouveau.
[quote=“darko”]Grand Toubab,
Je pensais avoir choisi le noyau par défaut lorsque j’avais installé ce système, je ne savais même pas que ça n’était pas le choix standard. Je veux bien changer de noyau, mais est-ce que cela peut résoudre mon problème ? J’ai toujours mon noyau précédent, 3.2.0-4-686-pae, qui fonctionnait parfaitement avant l’upgrade, et qui me renvoie désormais les mêmes erreurs que le nouveau.[/quote]
Le pae sert si on a une RAM > 4 GB sur un processeur 32 bits
doc.ubuntu-fr.org/kernel_32bits_pae
Avant Jessie ce n’était pas systemd pour l’init du système
As tu bidouillé ta fstab ou débranché des disques?
Cf
debian-user-french.debian.narkiv … n-sysvinit
Grand Toubab,
Merci pour l’info sur les noyaux. J’ai bien un processeur 32 bit, mais uniquement 1024 MB de RAM, je m’en souviendrai. Cela dit, je pense que le problème n’est pas là, puisque j’utilise des noyaux pae sur cet ordinateur depuis un moment.
Oui, j’ai vu que systemd était une nouveauté.
J’ai un peu modifié de fstab après cette panne, je l’ai posté ici (Mar Avr 28, 2015 10:36 pm). Comme je l’ai dit l’option nofail ne sert que provisoirement à pouvoir booter, pareil pour la suppression du swap (un conseil qu’on m’a donné sur le forum anglophone, je ne sais pas ce que ça vaut).
Autrement non, je ne pense pas que quoi que ce soit soit débranché, c’est juste un portable, avec rien de spécial dans le fstab genre disque externe ou quoi que ce soit.
