Par ailleurs, j’ai récupéré dmesg juste après avoir booté avec sysvinit. Peut-être y a-t-il quelque chose d’intéressant ?
dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.16.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.8.4 (Debian 4.8.4-1) ) #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24)
[ 0.000000] Disabled fast string operations
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003ffcffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000003ffd0000-0x000000003ffddfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000003ffde000-0x000000003fffffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb80000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: ASUSTeK Computer Inc. A6JC /A6JC , BIOS A6JCMAS.216 05/10/2006
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x3ffd0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [c00ff780]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x01bfffff]
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x36200000-0x363fffff]
[ 0.000000] [mem 0x36200000-0x363fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x34000000-0x361fffff]
[ 0.000000] [mem 0x34000000-0x361fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x33ffffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x33ffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x36400000-0x375fdfff]
[ 0.000000] [mem 0x36400000-0x373fffff] page 2M
[ 0.000000] [mem 0x37400000-0x375fdfff] page 4k
[ 0.000000] BRK [0x01798000, 0x01798fff] PGTABLE
[ 0.000000] BRK [0x01799000, 0x0179afff] PGTABLE
[ 0.000000] BRK [0x0179b000, 0x0179bfff] PGTABLE
[ 0.000000] BRK [0x0179c000, 0x0179cfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x3641c000-0x37205fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x000F79B0 000014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 0x3FFD0000 000038 (v01 A M I OEMRSDT 05000610 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x3FFD0200 000084 (v02 A M I OEMFACP 05000610 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x3FFD0460 007BCC (v01 A6JC0 A6JC0216 00000216 INTL 02002026)
[ 0.000000] ACPI: FACS 0x3FFDE000 000040
[ 0.000000] ACPI: APIC 0x3FFD0390 00005C (v01 A M I OEMAPIC 05000610 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x3FFD03F0 00003C (v01 A M I OEMMCFG 05000610 MSFT 00000097)
[ 0.000000] ACPI: BOOT 0x3FFD0430 000028 (v01 A M I OEMBOOT 05000610 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x3FFDE040 000046 (v01 A M I AMI_OEM 05000610 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 137MB HIGHMEM available.
[ 0.000000] 885MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 375fe000
[ 0.000000] low ram: 0 - 375fe000
[ 0.000000] BRK [0x0179d000, 0x0179dfff] PGTABLE
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] Normal [mem 0x01000000-0x375fdfff]
[ 0.000000] HighMem [mem 0x375fe000-0x3ffcffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[ 0.000000] node 0: [mem 0x00100000-0x3ffcffff]
[ 0.000000] On node 0 totalpages: 261998
[ 0.000000] free_area_init_node: node 0, pgdat c1658ec0, node_mem_map f5c1c020
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] Normal zone: 1740 pages used for memmap
[ 0.000000] Normal zone: 222718 pages, LIFO batch:31
[ 0.000000] HighMem zone: 276 pages used for memmap
[ 0.000000] HighMem zone: 35282 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] e820: [mem 0x40000000-0xfedfffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f75db000 s34752 r0 d22592 u57344
[ 0.000000] pcpu-alloc: s34752 r0 d22592 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260226
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-686-pae root=UUID=bf5b31e0-4d64-48a7-8f3b-afd3d5f67521 ro quiet init=/lib/sysvinit/init
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000375fe:0003ffd0)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 1016756K/1047992K available (4598K kernel code, 522K rwdata, 1448K rodata, 656K init, 460K bss, 31236K reserved, 141128K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xff600000 - 0xff800000 (2048 kB)
vmalloc : 0xf7dfe000 - 0xff5fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf75fe000 ( 885 MB)
.init : 0xc166d000 - 0xc1711000 ( 656 kB)
.data : 0xc147dc40 - 0xc166b880 (1975 kB)
.text : 0xc1000000 - 0xc147dc40 (4599 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5806000 soft=f5808000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1728.960 MHz processor
[ 0.004013] Calibrating delay loop (skipped), value calculated using timer frequency.. 3457.92 BogoMIPS (lpj=6915840)
[ 0.004018] pid_max: default: 32768 minimum: 301
[ 0.004036] ACPI: Core revision 20140424
[ 0.018401] ACPI: All ACPI Tables successfully acquired
[ 0.020047] Security Framework initialized
[ 0.020067] AppArmor: AppArmor disabled by boot time parameter
[ 0.020070] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.020096] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.020100] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.020515] Initializing cgroup subsys memory
[ 0.020525] Initializing cgroup subsys devices
[ 0.020539] Initializing cgroup subsys freezer
[ 0.020545] Initializing cgroup subsys net_cls
[ 0.020556] Initializing cgroup subsys blkio
[ 0.020565] Initializing cgroup subsys perf_event
[ 0.020569] Initializing cgroup subsys net_prio
[ 0.020606] Disabled fast string operations
[ 0.020610] CPU: Physical Processor ID: 0
[ 0.020612] CPU: Processor Core ID: 0
[ 0.020619] mce: CPU supports 6 MCE banks
[ 0.020631] CPU0: Thermal monitoring enabled (TM2)
[ 0.020644] Last level iTLB entries: 4KB 128, 2MB 0, 4MB 2
Last level dTLB entries: 4KB 128, 2MB 0, 4MB 8, 1GB 0
tlb_flushall_shift: 6
[ 0.020844] Freeing SMP alternatives memory: 20K (c1711000 - c1716000)
[ 0.025261] ftrace: allocating 20747 entries in 41 pages
[ 0.032124] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.032551] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.072945] smpboot: CPU0: Genuine Intel(R) CPU T2250 @ 1.73GHz (fam: 06, model: 0e, stepping: 08)
[ 0.076000] Performance Events: Core events, core PMU driver.
[ 0.076000] ... version: 1
[ 0.076000] ... bit width: 40
[ 0.076000] ... generic registers: 2
[ 0.076000] ... value mask: 000000ffffffffff
[ 0.076000] ... max period: 000000007fffffff
[ 0.076000] ... fixed-purpose events: 0
[ 0.076000] ... event mask: 0000000000000003
[ 0.076000] CPU 1 irqstacks, hard=f5942000 soft=f5944000
[ 0.076000] x86: Booting SMP configuration:
[ 0.076000] .... node #0, CPUs: #1
[ 0.008000] Initializing CPU#1
[ 0.008000] Disabled fast string operations
[ 0.085526] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.087600] x86: Booted up 1 node, 2 CPUs
[ 0.087603] smpboot: Total of 2 processors activated (6915.84 BogoMIPS)
[ 0.088150] devtmpfs: initialized
[ 0.088394] PM: Registering ACPI NVS region [mem 0x3ffde000-0x3fffffff] (139264 bytes)
[ 0.089820] pinctrl core: initialized pinctrl subsystem
[ 0.089820] NET: Registered protocol family 16
[ 0.089820] cpuidle: using governor ladder
[ 0.089820] cpuidle: using governor menu
[ 0.089820] ACPI: bus type PCI registered
[ 0.089820] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.089820] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.089820] PCI: not using MMCONFIG
[ 0.089820] PCI : PCI BIOS area is rw and x. Use pci=nobios if you want it NX.
[ 0.089820] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=5
[ 0.089820] PCI: Using configuration type 1 for base access
[ 0.089820] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.089820] mtrr: probably your BIOS does not setup all CPUs.
[ 0.089820] mtrr: corrected configuration.
[ 0.104077] ACPI: Added _OSI(Module Device)
[ 0.104081] ACPI: Added _OSI(Processor Device)
[ 0.104084] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.104087] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.109061] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.112850] ACPI: Dynamic OEM Table Load:
[ 0.112860] ACPI: SSDT 0xF59CA400 000382 (v01 AMI CPU1PM 00000001 INTL 02002026)
[ 0.113607] ACPI: Dynamic OEM Table Load:
[ 0.113613] ACPI BIOS Warning (bug): Incorrect checksum in table [SSDT] - 0xE5, should be 0x6C (20140424/tbprint-218)
[ 0.113620] ACPI: SSDT 0xF59CA000 000382 (v01 AMI CPU2PM 00000001 INTL 02002026)
[ 0.116552] ACPI: Interpreter enabled
[ 0.116577] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20140424/hwxface-580)
[ 0.116584] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20140424/hwxface-580)
[ 0.116606] ACPI: (supports S0 S3 S4 S5)
[ 0.116608] ACPI: Using IOAPIC for interrupt routing
[ 0.116640] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.119941] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.119947] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000) (size reduced!)
[ 0.119949] PCI: Using MMCONFIG for extended config space
[ 0.119976] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.121829] ACPI: Power Resource [GFAN] (off)
[ 0.128990] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.128999] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.129007] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.129161] acpi PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.129165] acpi PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.129169] acpi PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.129172] acpi PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[ 0.129176] acpi PNP0A08:00: host bridge window [mem 0x40000000-0xffffffff] (ignored)
[ 0.129180] PCI: root bus 00: using default resources
[ 0.129184] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.129454] PCI host bridge to bus 0000:00
[ 0.129459] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.129463] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.129466] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.129480] pci 0000:00:00.0: [8086:27a0] type 00 class 0x060000
[ 0.129648] pci 0000:00:01.0: [8086:27a1] type 01 class 0x060400
[ 0.129709] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.129780] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.129907] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.129933] pci 0000:00:1b.0: reg 0x10: [mem 0xfebfc000-0xfebfffff 64bit]
[ 0.130039] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.130112] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.130201] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.130313] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.130388] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.130475] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[ 0.130587] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.130663] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.130749] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.130805] pci 0000:00:1d.0: reg 0x20: [io 0xec00-0xec1f]
[ 0.130923] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.131006] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.131062] pci 0000:00:1d.1: reg 0x20: [io 0xe880-0xe89f]
[ 0.131178] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.131261] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.131317] pci 0000:00:1d.2: reg 0x20: [io 0xe800-0xe81f]
[ 0.131466] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.131522] pci 0000:00:1d.3: reg 0x20: [io 0xe480-0xe49f]
[ 0.131684] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.131711] pci 0000:00:1d.7: reg 0x10: [mem 0xfebfbc00-0xfebfbfff]
[ 0.131822] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.131892] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.131976] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.132111] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.132200] pci 0000:00:1f.0: [8086:27b9] type 00 class 0x060100
[ 0.132307] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.132317] pci 0000:00:1f.0: can't claim BAR 13 [io 0x0800-0x087f]: address conflict with ACPI CPU throttle [io 0x0810-0x0815]
[ 0.132325] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH6 GPIO
[ 0.132333] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0250 (mask 000f)
[ 0.132492] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.132511] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.132524] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.132537] pci 0000:00:1f.1: reg 0x18: [io 0x08f0-0x08f7]
[ 0.132550] pci 0000:00:1f.1: reg 0x1c: [io 0x08f8-0x08fb]
[ 0.132563] pci 0000:00:1f.1: reg 0x20: [io 0xffa0-0xffaf]
[ 0.132591] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.132594] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.132597] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.132601] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.132830] pci 0000:01:00.0: [10de:01d7] type 00 class 0x030000
[ 0.132852] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.132872] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.132891] pci 0000:01:00.0: reg 0x1c: [mem 0xfc000000-0xfcffffff 64bit]
[ 0.132914] pci 0000:01:00.0: reg 0x30: [mem 0xfbfe0000-0xfbffffff pref]
[ 0.133069] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.133081] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.133088] pci 0000:00:01.0: bridge window [mem 0xf9f00000-0xfdffffff]
[ 0.133094] pci 0000:00:01.0: bridge window [mem 0xbdf00000-0xddefffff 64bit pref]
[ 0.133231] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.133260] pci 0000:02:00.0: reg 0x10: [io 0xc800-0xc8ff]
[ 0.133300] pci 0000:02:00.0: reg 0x18: [mem 0xfe0ff000-0xfe0fffff 64bit]
[ 0.133346] pci 0000:02:00.0: reg 0x30: [mem 0xfe0e0000-0xfe0effff pref]
[ 0.133473] pci 0000:02:00.0: supports D1 D2
[ 0.133476] pci 0000:02:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.133585] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.133599] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.133605] pci 0000:00:1c.0: bridge window [io 0xc000-0xcfff]
[ 0.133611] pci 0000:00:1c.0: bridge window [mem 0xfe000000-0xfe0fffff]
[ 0.133789] pci 0000:03:00.0: [8086:4222] type 00 class 0x028000
[ 0.133855] pci 0000:03:00.0: reg 0x10: [mem 0xfe1ff000-0xfe1fffff]
[ 0.134289] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.134441] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.134468] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.134477] pci 0000:00:1c.3: bridge window [mem 0xfe100000-0xfe1fffff]
[ 0.134595] pci 0000:04:01.0: [1180:0476] type 02 class 0x060700
[ 0.134621] pci 0000:04:01.0: reg 0x10: [mem 0x00000000-0x00000fff]
[ 0.134659] pci 0000:04:01.0: supports D1 D2
[ 0.134662] pci 0000:04:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.134700] pci 0000:04:01.0: System wakeup disabled by ACPI
[ 0.134787] pci 0000:04:01.1: [1180:0552] type 00 class 0x0c0010
[ 0.134810] pci 0000:04:01.1: reg 0x10: [mem 0xfeaff800-0xfeafffff]
[ 0.134910] pci 0000:04:01.1: PME# supported from D0 D3hot D3cold
[ 0.134943] pci 0000:04:01.1: System wakeup disabled by ACPI
[ 0.135031] pci 0000:04:01.2: [1180:0822] type 00 class 0x080500
[ 0.135055] pci 0000:04:01.2: reg 0x10: [mem 0xfeaff400-0xfeaff4ff]
[ 0.135154] pci 0000:04:01.2: supports D1 D2
[ 0.135158] pci 0000:04:01.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.135271] pci 0000:04:01.3: [1180:0592] type 00 class 0x088000
[ 0.135295] pci 0000:04:01.3: reg 0x10: [mem 0xfeaff000-0xfeaff0ff]
[ 0.135394] pci 0000:04:01.3: supports D1 D2
[ 0.135398] pci 0000:04:01.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.135548] pci 0000:00:1e.0: PCI bridge to [bus 04-05] (subtractive decode)
[ 0.135555] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.135561] pci 0000:00:1e.0: bridge window [mem 0xfe200000-0xfeafffff]
[ 0.135570] pci 0000:00:1e.0: bridge window [mem 0xddf00000-0xdfefffff 64bit pref]
[ 0.135573] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.135577] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.135656] pci_bus 0000:05: busn_res: can not insert [bus 05-ff] under [bus 04-05] (conflicts with (null) [bus 04-05])
[ 0.135663] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 08
[ 0.135668] pci_bus 0000:05: busn_res: can not insert [bus 05-08] under [bus 04-05] (conflicts with (null) [bus 04-05])
[ 0.135674] pci_bus 0000:05: [bus 05-08] partially hidden behind transparent bridge 0000:04 [bus 04-05]
[ 0.135679] pci 0000:00:1e.0: bridge has subordinate 05 but max busn 08
[ 0.135715] pci_bus 0000:00: on NUMA node 0
[ 0.136311] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *11 12)
[ 0.136399] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 12)
[ 0.136485] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 7 12)
[ 0.136570] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 12)
[ 0.136655] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 12) *0, disabled.
[ 0.136741] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 12)
[ 0.136826] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 *6 7 12)
[ 0.136911] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 12)
[ 0.137229] ACPI: Enabled 4 GPEs in block 00 to 1F
[ 0.137329] ACPI : EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 0.137460] vgaarb: setting as boot device: PCI:0000:01:00.0
[ 0.137460] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.137460] vgaarb: loaded
[ 0.137460] vgaarb: bridge control possible 0000:01:00.0
[ 0.137460] PCI: Using ACPI for IRQ routing
[ 0.137460] PCI: pci_cache_line_size set to 64 bytes
[ 0.137460] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.137460] e820: reserve RAM buffer [mem 0x3ffd0000-0x3fffffff]
[ 0.137460] hpet clockevent registered
[ 0.137460] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.137460] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.137460] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.140031] Switched to clocksource hpet
[ 0.150423] pnp: PnP ACPI init
[ 0.150450] ACPI: bus type PNP registered
[ 0.150595] system 00:00: [mem 0xfed13000-0xfed19fff] has been reserved
[ 0.150601] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.150752] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.150848] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.150964] pnp 00:03: Plug and Play ACPI device, IDs SYN0a06 SYN0a00 SYN0002 PNP0f03 PNP0f13 PNP0f12 (active)
[ 0.151214] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.151220] system 00:04: [io 0x0800-0x087f] could not be reserved
[ 0.151224] system 00:04: [io 0x0480-0x04bf] has been reserved
[ 0.151228] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.151232] system 00:04: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.151237] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.151379] system 00:05: [mem 0xffb80000-0xffbfffff] has been reserved
[ 0.151384] system 00:05: [mem 0xfff80000-0xffffffff] has been reserved
[ 0.151388] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.151515] system 00:06: [mem 0xffc00000-0xfff7ffff] has been reserved
[ 0.151520] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.151656] system 00:07: [io 0x0400-0x041f] has been reserved
[ 0.151661] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.151665] system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.151669] system 00:07: [mem 0xfec10000-0xfec17fff] has been reserved
[ 0.151673] system 00:07: [mem 0xfec28000-0xfec2ffff] has been reserved
[ 0.151678] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.151799] system 00:08: [mem 0xe0000000-0xe3ffffff] has been reserved
[ 0.151804] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.152150] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.152155] system 00:09: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.152159] system 00:09: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.152163] system 00:09: [mem 0x00100000-0x3fffffff] could not be reserved
[ 0.152168] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.152377] pnp: PnP ACPI: found 10 devices
[ 0.152380] ACPI: bus type PNP unregistered
[ 0.152387] PnPBIOS: Disabled by ACPI PNP
[ 0.191396] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000
[ 0.191410] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.191415] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000
[ 0.191438] pci 0000:00:1f.0: BAR 13: [io 0x0800-0x087f] has bogus alignment
[ 0.191443] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.191447] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.191451] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.191461] pci 0000:00:1c.0: BAR 15: assigned [mem 0x40000000-0x401fffff 64bit pref]
[ 0.191466] pci 0000:00:1c.3: BAR 15: assigned [mem 0x40200000-0x403fffff 64bit pref]
[ 0.191472] pci 0000:00:1c.3: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.191476] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.191482] pci 0000:00:01.0: bridge window [mem 0xf9f00000-0xfdffffff]
[ 0.191487] pci 0000:00:01.0: bridge window [mem 0xbdf00000-0xddefffff 64bit pref]
[ 0.191493] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.191498] pci 0000:00:1c.0: bridge window [io 0xc000-0xcfff]
[ 0.191505] pci 0000:00:1c.0: bridge window [mem 0xfe000000-0xfe0fffff]
[ 0.191511] pci 0000:00:1c.0: bridge window [mem 0x40000000-0x401fffff 64bit pref]
[ 0.191520] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.191524] pci 0000:00:1c.3: bridge window [io 0x1000-0x1fff]
[ 0.191532] pci 0000:00:1c.3: bridge window [mem 0xfe100000-0xfe1fffff]
[ 0.191538] pci 0000:00:1c.3: bridge window [mem 0x40200000-0x403fffff 64bit pref]
[ 0.191550] pci 0000:04:01.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000
[ 0.191553] pci 0000:04:01.0: res[16]=[mem 0x04000000-0x03ffffff] get_res_add_size add_size 4000000
[ 0.191557] pci 0000:04:01.0: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size 100
[ 0.191561] pci 0000:04:01.0: res[14]=[io 0x0100-0x00ff] get_res_add_size add_size 100
[ 0.191569] pci 0000:04:01.0: BAR 0: assigned [mem 0x44000000-0x44000fff]
[ 0.191579] pci 0000:04:01.0: BAR 15: assigned [mem 0xe4000000-0xe7ffffff pref]
[ 0.191587] pci 0000:04:01.0: BAR 16: assigned [mem 0x48000000-0x4bffffff]
[ 0.191591] pci 0000:04:01.0: BAR 13: assigned [io 0xd000-0xd0ff]
[ 0.191595] pci 0000:04:01.0: BAR 14: assigned [io 0xd400-0xd4ff]
[ 0.191599] pci 0000:04:01.0: CardBus bridge to [bus 05-08]
[ 0.191602] pci 0000:04:01.0: bridge window [io 0xd000-0xd0ff]
[ 0.191609] pci 0000:04:01.0: bridge window [io 0xd400-0xd4ff]
[ 0.191615] pci 0000:04:01.0: bridge window [mem 0xe4000000-0xe7ffffff pref]
[ 0.191621] pci 0000:04:01.0: bridge window [mem 0x48000000-0x4bffffff]
[ 0.191627] pci 0000:00:1e.0: PCI bridge to [bus 04-05]
[ 0.191632] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.191639] pci 0000:00:1e.0: bridge window [mem 0xfe200000-0xfeafffff]
[ 0.191645] pci 0000:00:1e.0: bridge window [mem 0xddf00000-0xdfefffff 64bit pref]
[ 0.191655] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.191658] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.191662] pci_bus 0000:01: resource 1 [mem 0xf9f00000-0xfdffffff]
[ 0.191666] pci_bus 0000:01: resource 2 [mem 0xbdf00000-0xddefffff 64bit pref]
[ 0.191669] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.191673] pci_bus 0000:02: resource 1 [mem 0xfe000000-0xfe0fffff]
[ 0.191676] pci_bus 0000:02: resource 2 [mem 0x40000000-0x401fffff 64bit pref]
[ 0.191680] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.191683] pci_bus 0000:03: resource 1 [mem 0xfe100000-0xfe1fffff]
[ 0.191687] pci_bus 0000:03: resource 2 [mem 0x40200000-0x403fffff 64bit pref]
[ 0.191691] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.191694] pci_bus 0000:04: resource 1 [mem 0xfe200000-0xfeafffff]
[ 0.191698] pci_bus 0000:04: resource 2 [mem 0xddf00000-0xdfefffff 64bit pref]
[ 0.191701] pci_bus 0000:04: resource 4 [io 0x0000-0xffff]
[ 0.191704] pci_bus 0000:04: resource 5 [mem 0x00000000-0xffffffff]
[ 0.191708] pci_bus 0000:05: resource 0 [io 0xd000-0xd0ff]
[ 0.191711] pci_bus 0000:05: resource 1 [io 0xd400-0xd4ff]
[ 0.191715] pci_bus 0000:05: resource 2 [mem 0xe4000000-0xe7ffffff pref]
[ 0.191718] pci_bus 0000:05: resource 3 [mem 0x48000000-0x4bffffff]
[ 0.191789] NET: Registered protocol family 2
[ 0.192146] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.192175] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.192224] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.192265] TCP: reno registered
[ 0.192269] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.192282] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.192367] NET: Registered protocol family 1
[ 0.193251] pci 0000:01:00.0: Video device with shadowed ROM
[ 0.193278] PCI: CLS 32 bytes, default 64
[ 0.193350] Unpacking initramfs...
[ 0.637015] Freeing initrd memory: 14248K (f641c000 - f7206000)
[ 0.637135] Simple Boot Flag at 0x52 set to 0x1
[ 0.637392] microcode: CPU0 sig=0x6e8, pf=0x20, revision=0x39
[ 0.637406] microcode: CPU1 sig=0x6e8, pf=0x20, revision=0x39
[ 0.637538] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.638036] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.638096] audit: initializing netlink subsys (disabled)
[ 0.638126] audit: type=2000 audit(1431614081.636:1): initialized
[ 0.638624] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.638650] zbud: loaded
[ 0.638800] VFS: Disk quotas dquot_6.5.2
[ 0.638825] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.638915] msgmni has been set to 1738
[ 0.639485] alg: No test for stdrng (krng)
[ 0.639524] bounce: pool size: 64 pages
[ 0.639549] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.639625] io scheduler noop registered
[ 0.639629] io scheduler deadline registered
[ 0.639691] io scheduler cfq registered (default)
[ 0.639979] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.640186] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X
[ 0.640294] pcieport 0000:00:1c.3: enabling device (0106 -> 0107)
[ 0.640392] pcieport 0000:00:1c.3: irq 42 for MSI/MSI-X
[ 0.640554] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.640589] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.640628] intel_idle: does not run on family 6 model 14
[ 0.640695] GHES: HEST is not enabled!
[ 0.640728] isapnp: Scanning for PnP cards...
[ 0.994244] isapnp: No Plug & Play device found
[ 0.994376] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.995127] Linux agpgart interface v0.103
[ 0.995568] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.997707] i8042: Detected active multiplexing controller, rev 1.1
[ 0.998868] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.998876] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.998934] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.998985] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.999034] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.999278] mousedev: PS/2 mouse device common for all mice
[ 0.999364] rtc_cmos 00:01: RTC can wake from S4
[ 0.999554] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 0.999587] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.999613] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.000221] TCP: cubic registered
[ 1.000272] NET: Registered protocol family 10
[ 1.000627] mip6: Mobile IPv6
[ 1.000632] NET: Registered protocol family 17
[ 1.000640] mpls_gso: MPLS GSO support
[ 1.000921] Using IPI No-Shortcut mode
[ 1.001152] registered taskstats version 1
[ 1.001788] rtc_cmos 00:01: setting system clock to 2015-05-14 14:34:42 UTC (1431614082)
[ 1.001875] PM: Hibernation image not present or could not be loaded.
[ 1.002293] Freeing unused kernel memory: 656K (c166d000 - c1711000)
[ 1.002352] Write protecting the kernel text: 4600k
[ 1.002417] Write protecting the kernel read-only data: 1452k
[ 1.002419] NX-protecting the kernel data: 3592k
[ 1.015739] systemd-udevd[60]: starting version 215
[ 1.016386] random: systemd-udevd urandom read with 0 bits of entropy available
[ 1.030341] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.038108] ACPI: bus type USB registered
[ 1.038165] usbcore: registered new interface driver usbfs
[ 1.038187] usbcore: registered new interface driver hub
[ 1.038271] usbcore: registered new device driver usb
[ 1.039080] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.039535] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.039747] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.039758] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 1.039770] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.039827] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ec00
[ 1.039888] ehci-pci: EHCI PCI platform driver
[ 1.040172] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.040177] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.040180] usb usb1: Product: UHCI Host Controller
[ 1.040184] usb usb1: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.040187] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.040419] hub 1-0:1.0: USB hub found
[ 1.040431] hub 1-0:1.0: 2 ports detected
[ 1.040751] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.040762] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 1.040772] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.040812] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e880
[ 1.041087] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.041091] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.041094] usb usb2: Product: UHCI Host Controller
[ 1.041097] usb usb2: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.041100] usb usb2: SerialNumber: 0000:00:1d.1
[ 1.041354] hub 2-0:1.0: USB hub found
[ 1.041367] hub 2-0:1.0: 2 ports detected
[ 1.041479] ACPI: Fan [FN00] (off)
[ 1.041671] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.041681] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 1.041690] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.041728] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e800
[ 1.041798] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.041801] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.041805] usb usb3: Product: UHCI Host Controller
[ 1.041808] usb usb3: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.041811] usb usb3: SerialNumber: 0000:00:1d.2
[ 1.042004] hub 3-0:1.0: USB hub found
[ 1.042014] hub 3-0:1.0: 2 ports detected
[ 1.042466] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.042476] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
[ 1.042487] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 1.042526] uhci_hcd 0000:00:1d.3: irq 22, io base 0x0000e480
[ 1.042597] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.042601] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.042604] usb usb4: Product: UHCI Host Controller
[ 1.042607] usb usb4: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.042610] usb usb4: SerialNumber: 0000:00:1d.3
[ 1.042806] hub 4-0:1.0: USB hub found
[ 1.042816] hub 4-0:1.0: 2 ports detected
[ 1.043851] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.043861] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.043880] ehci-pci 0000:00:1d.7: debug port 1
[ 1.047785] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[ 1.048157] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfebfbc00
[ 1.056596] SCSI subsystem initialized
[ 1.059144] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.059156] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.059420] r8169 0000:02:00.0: irq 43 for MSI/MSI-X
[ 1.059729] r8169 0000:02:00.0 eth0: RTL8168b/8111b at 0xf7e0c000, 00:17:31:cf:01:90, XID 18000000 IRQ 43
[ 1.059734] r8169 0000:02:00.0 eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 1.062987] sdhci: Secure Digital Host Controller Interface driver
[ 1.062992] sdhci: Copyright(c) Pierre Ossman
[ 1.063372] sdhci-pci 0000:04:01.2: SDHCI controller found [1180:0822] (rev 17)
[ 1.064489] sdhci-pci 0000:04:01.2: Will use DMA mode even though HW doesn't fully claim to support it.
[ 1.064496] mmc0: no vqmmc regulator found
[ 1.064498] mmc0: no vmmc regulator found
[ 1.065496] sdhci-pci 0000:04:01.2: Will use DMA mode even though HW doesn't fully claim to support it.
[ 1.065769] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.065847] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.065851] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.065854] usb usb5: Product: EHCI Host Controller
[ 1.065857] usb usb5: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
[ 1.065860] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.066074] hub 5-0:1.0: USB hub found
[ 1.066085] hub 5-0:1.0: 8 ports detected
[ 1.066489] libata version 3.00 loaded.
[ 1.078577] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.078582] ACPI: Thermal Zone [THRM] (75 C)
[ 1.078735] mmc0: SDHCI controller on PCI [0000:04:01.2] using DMA
[ 1.088141] hub 1-0:1.0: USB hub found
[ 1.088156] hub 1-0:1.0: 2 ports detected
[ 1.112112] hub 2-0:1.0: USB hub found
[ 1.112136] hub 2-0:1.0: 2 ports detected
[ 1.136102] hub 3-0:1.0: USB hub found
[ 1.136116] hub 3-0:1.0: 2 ports detected
[ 1.140076] firewire_ohci 0000:04:01.1: added OHCI v1.0 device as card 0, 4 IR + 4 IT contexts, quirks 0x11
[ 1.160107] hub 4-0:1.0: USB hub found
[ 1.160121] hub 4-0:1.0: 2 ports detected
[ 1.160435] ata_piix 0000:00:1f.1: version 2.13
[ 1.162212] scsi0 : ata_piix
[ 1.162382] scsi1 : ata_piix
[ 1.162478] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.162481] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.162683] ata2: port disabled--ignoring
[ 1.334177] ata1.00: ATA-8: SAMSUNG HM160HC, LQ100-10, max UDMA/100
[ 1.334182] ata1.00: 312581808 sectors, multi 16: LBA48
[ 1.334190] ata1.01: ATAPI: HL-DT-ST DVDRAM GMA-4082N, HJ02, max UDMA/33
[ 1.350054] ata1.00: configured for UDMA/100
[ 1.364241] ata1.01: configured for UDMA/33
[ 1.366715] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HM160HC 0-10 PQ: 0 ANSI: 5
[ 1.370615] scsi 0:0:1:0: CD-ROM HL-DT-ST DVDRAM GMA-4082N HJ02 PQ: 0 ANSI: 5
[ 1.391378] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.391385] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 1.391389] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.391591] sd 0:0:0:0: [sda] Write Protect is off
[ 1.391596] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.391609] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 1.391630] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.392333] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.392606] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 1.432045] usb 5-7: new high-speed USB device number 3 using ehci-pci
[ 1.531089] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
[ 1.550849] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.582338] usb 5-7: New USB device found, idVendor=0402, idProduct=5602
[ 1.582344] usb 5-7: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.582348] usb 5-7: Product: USB2.0 Camera
[ 1.636047] tsc: Refined TSC clocksource calibration: 1728.999 MHz
[ 1.640130] firewire_core 0000:04:01.1: created device fw0: GUID 00e01800035ca992, S400
[ 1.948040] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.123069] usb 2-1: New USB device found, idVendor=046d, idProduct=c016
[ 2.123076] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.123079] usb 2-1: Product: Optical USB Mouse
[ 2.123082] usb 2-1: Manufacturer: Logitech
[ 2.127683] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.141988] usbcore: registered new interface driver usbhid
[ 2.141993] usbhid: USB HID core driver
[ 2.143595] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:1d.1/usb2/2-1/2-1:1.0/0003:046D:C016.0001/input/input5
[ 2.143730] hid-generic 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.1-1/input0
[ 2.246310] PM: Starting manual resume from disk
[ 2.246318] PM: Hibernation image partition 8:7 present
[ 2.246320] PM: Looking for hibernation image.
[ 2.246637] PM: Image not found (code -22)
[ 2.246640] PM: Hibernation image not present or could not be loaded.
[ 2.409090] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.636092] Switched to clocksource tsc
[ 2.995212] random: nonblocking pool is initialized
[ 4.326646] systemd-udevd[302]: starting version 215
[ 6.396938] tsc: Marking TSC unstable due to TSC halts in idle
[ 6.396949] ACPI: acpi_idle registered with cpuidle
[ 6.397138] Switched to clocksource hpet
[ 6.576650] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input6
[ 6.577911] ACPI: Lid Switch [LID]
[ 6.578010] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7
[ 6.578016] ACPI: Power Button [PWRB]
[ 6.578103] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input8
[ 6.578107] ACPI: Sleep Button [SLPB]
[ 6.578196] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input9
[ 6.578201] ACPI: Power Button [PWRF]
[ 6.655386] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 6.823515] ACPI: AC Adapter [AC0] (on-line)
[ 6.872095] asus_laptop: Asus Laptop Support version 0.42
[ 6.872270] asus_laptop: A6JC model detected
[ 6.876160] input: Asus Laptop extra buttons as /devices/platform/asus_laptop/input/input10
[ 7.087855] yenta_cardbus 0000:04:01.0: CardBus bridge found [1043:1237]
[ 7.119859] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 7.120127] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input11
[ 7.124064] ACPI: Battery Slot [BAT0] (battery present)
[ 7.252870] yenta_cardbus 0000:04:01.0: ISA IRQ mask 0x0cb8, PCI irq 17
[ 7.252883] yenta_cardbus 0000:04:01.0: Socket status: 30000006
[ 7.252892] pci_bus 0000:04: Raising subordinate bus# of parent bus (#04) from #05 to #08
[ 7.252910] yenta_cardbus 0000:04:01.0: pcmcia: parent PCI bridge window: [io 0xd000-0xdfff]
[ 7.252919] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xd000-0xdfff:
[ 7.254342] excluding 0xd000-0xd0ff 0xd3b0-0xd3df 0xd400-0xd4ff 0xd7b0-0xd7df 0xdbb0-0xdbdf 0xdfb0-0xdfdf
[ 7.259078] yenta_cardbus 0000:04:01.0: pcmcia: parent PCI bridge window: [mem 0xfe200000-0xfeafffff]
[ 7.259087] pcmcia_socket pcmcia_socket0: cs: memory probe 0xfe200000-0xfeafffff:
[ 7.259114] excluding 0xfea70000-0xfeafffff
[ 7.259125] yenta_cardbus 0000:04:01.0: pcmcia: parent PCI bridge window: [mem 0xddf00000-0xdfefffff 64bit pref]
[ 7.259133] pcmcia_socket pcmcia_socket0: cs: memory probe 0xddf00000-0xdfefffff:
[ 7.259154] excluding 0xddf00000-0xdfefffff
[ 7.452518] r592: driver successfully loaded
[ 7.983298] intel_rng: FWH not detected
[ 8.038330] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x00000800-0x0000084f (\GPIS) (20140424/utaddress-258)
[ 8.038349] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x00000800-0x0000084f (\PMIO) (20140424/utaddress-258)
[ 8.038361] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.038370] ACPI Warning: SystemIO range 0x000004b0-0x000004bf conflicts with OpRegion 0x00000480-0x000004bf (\GPIO) (20140424/utaddress-258)
[ 8.038382] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.038387] ACPI Warning: SystemIO range 0x00000480-0x000004af conflicts with OpRegion 0x00000480-0x000004bf (\GPIO) (20140424/utaddress-258)
[ 8.038398] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.038404] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 8.201275] cfg80211: Calling CRDA to update world regulatory domain
[ 8.242912] leds_ss4200: no LED devices found
[ 8.539733] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, in-tree:s
[ 8.539742] iwl3945: Copyright(c) 2003-2011 Intel Corporation
[ 8.539835] iwl3945 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 8.559219] input: PC Speaker as /devices/platform/pcspkr/input/input16
[ 8.593496] iwl3945 0000:03:00.0: Tunable channels: 13 802.11bg, 23 802.11a channels
[ 8.593503] iwl3945 0000:03:00.0: Detected Intel Wireless WiFi Link 3945ABG
[ 8.593571] iwl3945 0000:03:00.0: irq 44 for MSI/MSI-X
[ 8.641859] snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
[ 8.773760] psmouse serio4: synaptics: Touchpad model: 1, fw: 6.1, id: 0xa3a0b3, caps: 0xa04713/0x10008/0x0, board id: 3655, fw id: 30712
[ 8.812166] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input15
[ 8.951635] ieee80211 phy0: Selected rate control algorithm 'iwl-3945-rs'
[ 8.963610] sound hdaudioC0D0: autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:hp
[ 8.963620] sound hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.963626] sound hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.963632] sound hdaudioC0D0: mono: mono_out=0x0
[ 8.963637] sound hdaudioC0D0: dig-out=0x1e/0x0
[ 8.963641] sound hdaudioC0D0: inputs:
[ 8.963646] sound hdaudioC0D0: Mic=0x18
[ 8.963651] sound hdaudioC0D0: Line=0x1a
[ 8.963657] sound hdaudioC0D0: CD=0x1c
[ 9.001075] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af:
[ 9.002184] excluding 0x170-0x177 0x1f0-0x1f7 0x370-0x377
[ 9.003034] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff:
[ 9.003325] excluding 0x3f0-0x3f7 0x400-0x41f 0x480-0x4bf 0x4d0-0x4d7
[ 9.003618] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff:
[ 9.003856] excluding 0x820-0x87f
[ 9.004166] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7:
[ 9.004884] clean.
[ 9.004942] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff:
[ 9.004957] excluding 0xc0000-0xcffff 0xe0000-0xfffff
[ 9.005026] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff:
[ 9.005067] clean.
[ 9.005112] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff:
[ 9.005152] clean.
[ 9.005195] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff:
[ 9.005935] clean.
[ 9.197548] [drm] Initialized drm 1.1.0 20060810
[ 9.295429] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/hdaudioC0D0/input17
[ 9.635892] iTCO_vendor_support: vendor-support=0
[ 9.662702] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 9.662795] iTCO_wdt: Found a ICH7-M or ICH7-U TCO device (Version=2, TCOBASE=0x0860)
[ 9.663201] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.976437] nvidia: module license 'NVIDIA' taints kernel.
[ 10.976446] Disabling lock debugging due to kernel taint
[ 11.007147] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 11.007721] [drm] Initialized nvidia-drm 0.0.0 20140818 for 0000:01:00.0 on minor 0
[ 11.007733] NVRM: loading NVIDIA UNIX x86 Kernel Module 304.125 Mon Dec 1 19:55:52 PST 2014
[ 11.016299] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 11.760121] media: Linux media interface: v0.10
[ 11.849260] Linux video capture interface: v2.00
[ 11.951945] gspca_main: v2.14.0 registered
[ 12.394089] gspca_main: ALi m5602-2.14.0 probing 0402:5602
[ 12.473736] gspca_m5602: Detected an ov9650 sensor
[ 12.538742] usbcore: registered new interface driver ALi m5602
[ 43.876428] ata1: drained 192 bytes to clear DRQ
[ 43.876448] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 43.876512] ata1.00: failed command: READ DMA EXT
[ 43.876576] ata1.00: cmd 25/00:00:a8:19:2a/00:02:01:00:00/e0 tag 0 dma 262144 in
res 40/00:fe:00:00:00/00:00:00:00:00/40 Emask 0x4 (timeout)
[ 43.876646] ata1.00: status: { DRDY }
[ 43.932055] ata1: soft resetting link
[ 44.122142] ata1.00: configured for UDMA/100
[ 44.136291] ata1.01: configured for UDMA/33
[ 44.138607] ata1.00: device reported invalid CHS sector 0
[ 44.138623] ata1: EH complete
[ 54.722726] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 57.703917] lp: driver loaded but no devices found
[ 57.717243] ppdev: user-space parallel port driver
[ 57.796954] loop: module loaded
[ 57.809629] REISERFS (device sda3): found reiserfs format "3.6" with standard journal
[ 57.809642] REISERFS (device sda3): using ordered data mode
[ 57.809644] reiserfs: using flush barriers
[ 57.809981] REISERFS (device sda3): journal params: device sda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 57.810472] REISERFS (device sda3): checking transaction log (sda3)
[ 57.841315] fuse init (API version 7.23)
[ 57.896417] REISERFS (device sda3): Using r5 hash to sort names
[ 58.677381] r8169 0000:02:00.0 eth0: link down
[ 58.677409] r8169 0000:02:00.0 eth0: link down
[ 58.677436] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 59.680947] RPC: Registered named UNIX socket transport module.
[ 59.680953] RPC: Registered udp transport module.
[ 59.680955] RPC: Registered tcp transport module.
[ 59.680958] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 59.694838] FS-Cache: Loaded
[ 59.730266] FS-Cache: Netfs 'nfs' registered for caching
[ 59.785271] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 60.700675] r8169 0000:02:00.0 eth0: link up
[ 60.700691] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 60.851934] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input18
