Ubuntu Pastebin
Paste from boot-repair at Sat, 11 Jan 2014 21:39:59 +0000
Download as text
Boot Info Script e7fc706 + Boot-Repair extra info [Boot-Info 12May2013]
============================= Boot Info Summary: ===============================
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos7)/boot/grub on this drive.
sda1: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows 8/2012: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files: /bootmgr /Windows/System32/winload.exe
sda3: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 13.10
Boot files: /boot/grub/grub.cfg /etc/fstab
/boot/grub/i386-pc/core.img
sda4: __________________________________________________________________________
File system: Extended Partition
Boot sector type: -
Boot sector info:
sda5: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda6: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sda7: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Debian GNU/Linux 7
Boot files: /boot/grub/grub.cfg /etc/fstab /boot/grub/core.img
sda8: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sda9: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista: NTFS
Operating System:
Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 * 2,048 718,847 716,800 7 NTFS / exFAT / HPFS
/dev/sda2 718,848 419,635,199 418,916,352 7 NTFS / exFAT / HPFS
/dev/sda3 419,635,200 472,150,410 52,515,211 83 Linux
/dev/sda4 472,150,411 976,766,975 504,616,565 f W95 Extended (LBA)
/dev/sda5 472,150,413 486,721,304 14,570,892 82 Linux swap / Solaris
/dev/sda6 486,721,368 539,157,464 52,436,097 83 Linux
/dev/sda7 539,160,576 581,171,199 42,010,624 83 Linux
/dev/sda8 581,173,248 623,106,047 41,932,800 83 Linux
/dev/sda9 623,108,096 976,766,975 353,658,880 7 NTFS / exFAT / HPFS
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/sda1 C66E245D6E24488F ntfs Réservé au système
/dev/sda2 D6042DB9042D9D8D ntfs Système
/dev/sda3 11c70a00-4720-4898-be4e-81aef0ffd2b4 ext4
/dev/sda5 e202df47-b222-4dcd-9c77-3177e6354b08 swap
/dev/sda6 5acd255f-189b-4ab9-b60d-bf43be0433ad ext4
/dev/sda7 f7d8285d-d521-4cf4-869c-7c5989d8679b ext4
/dev/sda8 d7c83be8-6901-4ef1-b722-49d878298677 ext4
/dev/sda9 3827AFFE4FE4FFCE ntfs
/dev/sr0 iso9660 Linux Secure 13.04 64bit
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/loop0 /rofs squashfs (ro,noatime)
/dev/sr0 /cdrom iso9660 (ro,noatime)
=========================== sda3/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos3'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos3 --hint-efi=hd0,msdos3 --hint-baremetal=ahci0,msdos3 11c70a00-4720-4898-be4e-81aef0ffd2b4
else
search --no-floppy --fs-uuid --set=root 11c70a00-4720-4898-be4e-81aef0ffd2b4
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=fr_FR
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-15-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-15-generic
submenu 'Options avancées pour Ubuntu' $menuentry_id_option 'gnulinux-advanced-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
menuentry 'Ubuntu, avec Linux 3.11.0-15-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-15-generic-advanced-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Chargement de Linux 3.11.0-15-generic…'
echo 'Chargement du disque mémoire initial…'
menuentry 'Ubuntu, avec Linux 3.11.0-15-generic (mode de dépannage)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-15-generic-recovery-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-15-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro recovery nomodeset
menuentry 'Ubuntu, avec Linux 3.11.0-14-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-14-generic-advanced-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Chargement de Linux 3.11.0-14-generic…'
linux /boot/vmlinuz-3.11.0-14-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-14-generic
menuentry 'Ubuntu, avec Linux 3.11.0-14-generic (mode de dépannage)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-14-generic-recovery-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-14-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro recovery nomodeset
menuentry 'Ubuntu, avec Linux 3.11.0-13-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-13-generic-advanced-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Chargement de Linux 3.11.0-13-generic…'
linux /boot/vmlinuz-3.11.0-13-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-13-generic
menuentry 'Ubuntu, avec Linux 3.11.0-13-generic (mode de dépannage)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-13-generic-recovery-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-13-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro recovery nomodeset
menuentry 'Ubuntu, avec Linux 3.11.0-12-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-12-generic-advanced-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Chargement de Linux 3.11.0-12-generic…'
linux /boot/vmlinuz-3.11.0-12-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-12-generic
menuentry 'Ubuntu, avec Linux 3.11.0-12-generic (mode de dépannage)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.0-12-generic-recovery-11c70a00-4720-4898-be4e-81aef0ffd2b4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-12-generic root=UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin
menuentry 'Memory test (memtest86+, serial console 115200)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 8 (loader) (sur /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-chain-C66E245D6E24488F' {
insmod part_msdos
insmod ntfs
set root='hd0,msdos1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 C66E245D6E24488F
else
search --no-floppy --fs-uuid --set=root C66E245D6E24488F
fi
drivemap -s (hd0) ${root}
chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda3/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda3 during installation
UUID=11c70a00-4720-4898-be4e-81aef0ffd2b4 / ext4 errors=remount-ro 0 1
# /home was on /dev/sda6 during installation
UUID=5acd255f-189b-4ab9-b60d-bf43be0433ad /home ext4 defaults 0 2
# swap was on /dev/sda5 during installation
UUID=77c2553e-de24-447f-a79d-dd36c5da089e none swap sw 0 0
=================== sda3: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
218.305591583 = 234.403844096 boot/grub/grub.cfg 1
216.417339325 = 232.376348672 boot/grub/i386-pc/core.img 1
218.232368469 = 234.325221376 boot/vmlinuz-3.11.0-12-generic 1
202.032562256 = 216.930811904 boot/vmlinuz-3.11.0-13-generic 2
218.656250000 = 234.780360704 boot/vmlinuz-3.11.0-14-generic 2
217.020870209 = 233.024385024 boot/vmlinuz-3.11.0-15-generic 1
217.020870209 = 233.024385024 vmlinuz 1
217.020870209 = 233.024385024 vmlinuz.old 1
200.965335846 = 215.784886272 boot/initrd.img-3.11.0-12-generic 1
201.785652161 = 216.665694208 boot/initrd.img-3.11.0-13-generic 2
201.480964661 = 216.338538496 boot/initrd.img-3.11.0-14-generic 2
201.574218750 = 216.438669312 boot/initrd.img-3.11.0-15-generic 2
201.574218750 = 216.438669312 initrd.img 2
=========================== sda7/boot/grub/grub.cfg: ===========================
load_env
fi
set default="0"
set boot_once=true
fi
fi
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd0,msdos7)'
search --no-floppy --fs-uuid --set=root f7d8285d-d521-4cf4-869c-7c5989d8679b
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=fr_FR
insmod gettext
fi
set timeout=5
insmod part_msdos
insmod ext2
insmod png
if background_image /usr/share/images/desktop-base/joy-grub.png; then
set color_normal=white/black
set color_highlight=black/white
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-amd64' --class debian --class gnu-linux --class gnu --class os {
load_video
insmod gzio
insmod part_msdos
insmod ext2
echo 'Chargement de Linux 3.2.0-4-amd64 ...'
linux /boot/vmlinuz-3.2.0-4-amd64 root=UUID=f7d8285d-d521-4cf4-869c-7c5989d8679b ro quiet
echo 'Chargement du disque mémoire initial ...'
initrd /boot/initrd.img-3.2.0-4-amd64
menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-amd64 (mode de dépannage)' --class debian --class gnu-linux --class gnu --class os {
load_video
insmod gzio
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-3.2.0-4-amd64 root=UUID=f7d8285d-d521-4cf4-869c-7c5989d8679b ro single
menuentry "Windows 8 (loader) (on /dev/sda1)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(hd0,msdos1)'
chainloader +1
menuentry "Ubuntu (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos3)'
menuentry "Ubuntu, avec Linux 3.11.0-15-generic (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-15-generic (mode de dépannage) (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-14-generic (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-14-generic (mode de dépannage) (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-13-generic (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-13-generic (mode de dépannage) (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-12-generic (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-12-generic (mode de dépannage) (on /dev/sda3)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
if [ -f $prefix/custom.cfg ]; then
fi
=============================== sda7/etc/fstab: ================================
# / was on /dev/sda7 during installation
UUID=f7d8285d-d521-4cf4-869c-7c5989d8679b / ext4 errors=remount-ro 0 1
# /home was on /dev/sda8 during installation
UUID=d7c83be8-6901-4ef1-b722-49d878298677 /home ext4 defaults 0 2
UUID=e202df47-b222-4dcd-9c77-3177e6354b08 none swap sw 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
=================== sda7: Location of files loaded by Grub: ====================
269.218963623 = 289.071661056 boot/grub/grub.cfg 1
261.296401978 = 280.564875264 boot/grub/core.img 1
257.434284210 = 276.417957888 boot/vmlinuz-3.2.0-4-amd64 1
257.434284210 = 276.417957888 vmlinuz 1
260.021484375 = 279.195942912 boot/initrd.img-3.2.0-4-amd64 2
=============================== StdErr Messages: ===============================
File descriptor 8 (/proc/3918/mounts) leaked on lvscan invocation. Parent PID 13956: bash
File descriptor 14 (/usr/share/icons/ubuntu-mono-dark/places/16/user-home.svg) leaked on lvscan invocation. Parent PID 13956: bash
No volume groups found
ADDITIONAL INFORMATION :
=================== log of boot-repair 2014-01-11__21h39 ===================
boot-repair version : 3.199~ppa2~raring
boot-sav version : 3.199~ppa2~raring
glade2script version : 3.2.2~ppa45~raring
boot-sav-extra version : 3.199~ppa2~raring
boot-repair is executed in live-session (Linux-Secure-Remix-64bit 20may2013, raring, Ubuntu, x86_64)
ls: cannot access /home/usr/.config: No such file or directory
CPU op-mode(s): 32-bit, 64-bit
file=/cdrom/preseed/ubuntu.seed boot=casper initrd=/casper/initrd.lz quiet splash -- debian-installer/language=fr keyboard-configuration/layoutcode?=fr keyboard-configuration/variantcode?=oss
=================== os-prober:
/dev/sda1:Windows 8 (loader):Windows:chain
/dev/sda3:Ubuntu 13.10 (13.10):Ubuntu:linux
/dev/sda7:Debian GNU/Linux (7.3):Debian:linux
=================== blkid:
/dev/loop0: TYPE="squashfs"
/dev/sda1: LABEL="RM-CM-)servM-CM-) au systM-CM-(me" UUID="C66E245D6E24488F" TYPE="ntfs"
/dev/sda2: LABEL="SystM-CM-(me" UUID="D6042DB9042D9D8D" TYPE="ntfs"
/dev/sda3: UUID="11c70a00-4720-4898-be4e-81aef0ffd2b4" TYPE="ext4"
/dev/sda5: UUID="e202df47-b222-4dcd-9c77-3177e6354b08" TYPE="swap"
/dev/sda6: UUID="5acd255f-189b-4ab9-b60d-bf43be0433ad" TYPE="ext4"
/dev/sda7: UUID="f7d8285d-d521-4cf4-869c-7c5989d8679b" TYPE="ext4"
/dev/sda8: UUID="d7c83be8-6901-4ef1-b722-49d878298677" TYPE="ext4"
/dev/sda9: UUID="3827AFFE4FE4FFCE" TYPE="ntfs"
/dev/sr0: LABEL="Linux Secure 13.04 64bit" TYPE="iso9660"
1 disks with OS, 3 OS : 2 Linux, 0 MacOS, 1 Windows, 0 unknown type OS.
Windows not detected by os-prober on sda2.
Warning: extended partition does not start at a cylinder boundary.
DOS and Linux will interpret the contents differently.
=================== sda3/etc/default/grub :
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
=================== sda3/etc/grub.d/ :
drwxr-xr-x 2 root root 4096 nov. 2 16:21 grub.d
total 72
-rwxr-xr-x 1 root root 7850 oct. 10 17:48 00_header
-rwxr-xr-x 1 root root 5949 août 15 08:26 05_debian_theme
-rwxr-xr-x 1 root root 11479 oct. 10 17:48 10_linux
-rwxr-xr-x 1 root root 10258 oct. 10 17:48 20_linux_xen
-rwxr-xr-x 1 root root 1798 juin 17 2013 20_memtest86+
-rwxr-xr-x 1 root root 11531 oct. 10 17:48 30_os-prober
-rwxr-xr-x 1 root root 1426 oct. 10 17:48 30_uefi-firmware
-rwxr-xr-x 1 root root 214 oct. 10 17:48 40_custom
-rwxr-xr-x 1 root root 216 oct. 10 17:48 41_custom
-rw-r--r-- 1 root root 483 oct. 10 17:48 README
=================== sda7/etc/default/grub :
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
=================== sda7/etc/grub.d/ :
drwxr-xr-x 2 root root 4096 janv. 11 17:44 grub.d
total 52
-rwxr-xr-x 1 root root 6728 juil. 3 2013 00_header
-rwxr-xr-x 1 root root 5407 juil. 3 2013 05_debian_theme
-rwxr-xr-x 1 root root 5977 juil. 3 2013 10_linux
-rwxr-xr-x 1 root root 6335 juil. 3 2013 20_linux_xen
-rwxr-xr-x 1 root root 6522 juil. 3 2013 30_os-prober
-rwxr-xr-x 1 root root 214 juil. 3 2013 40_custom
-rwxr-xr-x 1 root root 95 juil. 3 2013 41_custom
-rw-r--r-- 1 root root 483 juil. 3 2013 README
=================== UEFI/Legacy mode:
This live-session is not in EFI-mode.
SecureBoot maybe enabled.
=================== PARTITIONS & DISKS:
sda1 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, is-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, bootmgr, is-winboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, not-far, /mnt/boot-sav/sda1.
sda2 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, is-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, bootmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, /mnt/boot-sav/sda2.
sda3 : sda, not-sepboot, grubenv-ok grub2, grub-pc , update-grub, 64, with-boot, is-os, not--efi--part, fstab-without-boot, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, apt-get, grub-install, with--usr, fstab-without-usr, not-sep-usr, standard, farbios, /mnt/boot-sav/sda3.
sda6 : sda, maybesepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, /mnt/boot-sav/sda6.
sda7 : sda, not-sepboot, grubenv-ok grub2, grub-pc , update-grub, 64, with-boot, is-os, not--efi--part, fstab-without-boot, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, apt-get, grub-install, with--usr, fstab-without-usr, not-sep-usr, standard, farbios, /mnt/boot-sav/sda7.
sda8 : sda, maybesepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, /mnt/boot-sav/sda8.
sda9 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, /mnt/boot-sav/sda9.
sda : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, has-os, 2048 sectors * 512 bytes
=================== parted -l:
Model: ATA ST500LM012 HN-M5 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Number Start End Size Type File system Flags
1 1049kB 368MB 367MB primary ntfs boot
2 368MB 215GB 214GB primary ntfs
3 215GB 242GB 26.9GB primary ext4
4 242GB 500GB 258GB extended lba
5 242GB 249GB 7460MB logical linux-swap(v1)
6 249GB 276GB 26.8GB logical ext4
7 276GB 298GB 21.5GB logical ext4
8 298GB 319GB 21.5GB logical ext4
9 319GB 500GB 181GB logical ntfs
Error: /dev/sr0: unrecognised disk label
=================== parted -lm:
BYT;
/dev/sda:500GB:scsi:512:4096:msdos:ATA ST500LM012 HN-M5;
1:1049kB:368MB:367MB:ntfs::boot;
2:368MB:215GB:214GB:ntfs::;
3:215GB:242GB:26.9GB:ext4::;
4:242GB:500GB:258GB:::lba;
5:242GB:249GB:7460MB:linux-swap(v1)::;
6:249GB:276GB:26.8GB:ext4::;
7:276GB:298GB:21.5GB:ext4::;
8:298GB:319GB:21.5GB:ext4::;
9:319GB:500GB:181GB:ntfs::;
=================== mount:
/cow on / type overlayfs (rw)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
/dev/sr0 on /cdrom type iso9660 (ro,noatime)
/dev/loop0 on /rofs type squashfs (ro,noatime)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
gvfsd-fuse on /run/user/ubuntu/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=ubuntu)
/dev/sda1 on /mnt/boot-sav/sda1 type fuseblk (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sda2 on /mnt/boot-sav/sda2 type fuseblk (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sda3 on /mnt/boot-sav/sda3 type ext4 (rw)
/dev/sda6 on /mnt/boot-sav/sda6 type ext4 (rw)
/dev/sda7 on /mnt/boot-sav/sda7 type ext4 (rw)
/dev/sda8 on /mnt/boot-sav/sda8 type ext4 (rw)
/dev/sda9 on /mnt/boot-sav/sda9 type fuseblk (rw,nosuid,nodev,allow_other,blksize=4096)
=================== ls:
/sys/block/sda (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight power queue range removable ro sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 size slaves stat subsystem trace uevent
/sys/block/sr0 (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight power queue range removable ro size slaves stat subsystem trace uevent
/dev (filtered): alarm ashmem autofs binder block bsg btrfs-control bus cdrom cdrw char console core cpu cpu_dma_latency disk dri dvd dvdrw ecryptfs fb0 fd full fuse hidraw0 hpet input kmsg kvm log mapper mcelog mei mem net network_latency network_throughput null oldmem port ppp psaux ptmx pts random rfkill rtc rtc0 sda sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sg0 sg1 shm snapshot snd sr0 stderr stdin stdout uinput urandom v4l vga_arbiter vhost-net video0 watchdog watchdog0 zero
ls /dev/mapper: control
=================== hexdump -n512 -C /dev/sda1
00000000 eb 52 90 4e 54 46 53 20 20 20 20 00 02 08 00 00 |.R.NTFS .....|
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 08 00 00 |........?.......|
00000020 00 00 00 00 80 00 80 00 ff ef 0a 00 00 00 00 00 |................|
00000030 aa 74 00 00 00 00 00 00 02 00 00 00 00 00 00 00 |.t..............|
00000040 f6 00 00 00 01 00 00 00 8f 48 24 6e 5d 24 6e c6 |.........H$n]$n.|
00000050 00 00 00 00 fa 33 c0 8e d0 bc 00 7c fb 68 c0 07 |.....3.....|.h..|
00000060 1f 1e 68 66 00 cb 88 16 0e 00 66 81 3e 03 00 4e |..hf......f.>..N|
00000070 54 46 53 75 15 b4 41 bb aa 55 cd 13 72 0c 81 fb |TFSu..A..U..r...|
00000080 55 aa 75 06 f7 c1 01 00 75 03 e9 dd 00 1e 83 ec |U.u.....u.......|
00000090 18 68 1a 00 b4 48 8a 16 0e 00 8b f4 16 1f cd 13 |.h...H..........|
000000a0 9f 83 c4 18 9e 58 1f 72 e1 3b 06 0b 00 75 db a3 |.....X.r.;...u..|
000000b0 0f 00 c1 2e 0f 00 04 1e 5a 33 db b9 00 20 2b c8 |........Z3... +.|
000000c0 66 ff 06 11 00 03 16 0f 00 8e c2 ff 06 16 00 e8 |f...............|
000000d0 4b 00 2b c8 77 ef b8 00 bb cd 1a 66 23 c0 75 2d |K.+.w......f#.u-|
000000e0 66 81 fb 54 43 50 41 75 24 81 f9 02 01 72 1e 16 |f..TCPAu$....r..|
000000f0 68 07 bb 16 68 52 11 16 68 09 00 66 53 66 53 66 |h...hR..h..fSfSf|
00000100 55 16 16 16 68 b8 01 66 61 0e 07 cd 1a 33 c0 bf |U...h..fa....3..|
00000110 0a 13 b9 f6 0c fc f3 aa e9 fe 01 90 90 66 60 1e |.............f`.|
00000120 06 66 a1 11 00 66 03 06 1c 00 1e 66 68 00 00 00 |.f...f.....fh...|
00000130 00 66 50 06 53 68 01 00 68 10 00 b4 42 8a 16 0e |.fP.Sh..h...B...|
00000140 00 16 1f 8b f4 cd 13 66 59 5b 5a 66 59 66 59 1f |.......fY[ZfYfY.|
00000150 0f 82 16 00 66 ff 06 11 00 03 16 0f 00 8e c2 ff |....f...........|
00000160 0e 16 00 75 bc 07 1f 66 61 c3 a1 f6 01 e8 09 00 |...u...fa.......|
00000170 a1 fa 01 e8 03 00 f4 eb fd 8b f0 ac 3c 00 74 09 |............<.t.|
00000180 b4 0e bb 07 00 cd 10 eb f2 c3 0d 0a 41 20 64 69 |............A di|
00000190 73 6b 20 72 65 61 64 20 65 72 72 6f 72 20 6f 63 |sk read error oc|
000001a0 63 75 72 72 65 64 00 0d 0a 42 4f 4f 54 4d 47 52 |curred...BOOTMGR|
000001b0 20 69 73 20 63 6f 6d 70 72 65 73 73 65 64 00 0d | is compressed..|
000001c0 0a 50 72 65 73 73 20 43 74 72 6c 2b 41 6c 74 2b |.Press Ctrl+Alt+|
000001d0 44 65 6c 20 74 6f 20 72 65 73 74 61 72 74 0d 0a |Del to restart..|
000001e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001f0 00 00 00 00 00 00 8a 01 a7 01 bf 01 00 00 55 aa |..............U.|
00000200
=================== hexdump -n512 -C /dev/sda2
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 f8 0a 00 |........?.......|
00000020 00 00 00 00 80 00 80 00 ff 27 f8 18 00 00 00 00 |.........'......|
00000030 00 00 0c 00 00 00 00 00 04 00 00 00 00 00 00 00 |................|
00000040 f6 00 00 00 01 00 00 00 8d 9d 2d 04 b9 2d 04 d6 |..........-..-..|
00000050 60 a6 c4 63 fa 33 c0 8e d0 bc 00 7c fb 68 c0 07 |`..c.3.....|.h..|
00000180 b4 0e bb 07 00 cd 10 eb f2 c3 0d 0a 45 72 72 65 |............Erre|
00000190 75 72 20 6c 65 63 74 75 72 65 20 64 69 73 71 75 |ur lecture disqu|
000001a0 65 00 0d 0a 42 4f 4f 54 4d 47 52 20 63 6f 6d 70 |e...BOOTMGR comp|
000001b0 72 65 73 73 82 00 0d 0a 43 74 72 6c 2b 41 6c 74 |ress....Ctrl+Alt|
000001c0 2b 53 75 70 70 72 20 70 6f 75 72 20 72 65 64 82 |+Suppr pour red.|
000001d0 6d 61 72 72 65 72 0d 0a 00 73 74 61 72 74 0d 0a |marrer...start..|
000001f0 00 00 00 00 00 00 8a 01 a2 01 b6 01 00 00 55 aa |..............U.|
00000200
=================== hexdump -n512 -C /dev/sda9
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 e0 23 25 |........?.....#%|
00000020 00 00 00 00 80 00 80 00 ff 67 14 15 00 00 00 00 |.........g......|
00000030 04 00 00 00 00 00 00 00 7f 46 51 01 00 00 00 00 |.........FQ.....|
00000040 f6 00 00 00 01 00 00 00 ce ff e4 4f fe af 27 38 |...........O..'8|
00000080 55 aa 75 06 f7 c1 01 00 75 03 e9 d2 00 1e 83 ec |U.u.....u.......|
000000d0 40 00 2b c8 77 ef b8 00 bb cd 1a 66 23 c0 75 2d |@.+.w......f#.u-|
000000f0 68 07 bb 16 68 70 0e 16 68 09 00 66 53 66 53 66 |h...hp..h..fSfSf|
00000100 55 16 16 16 68 b8 01 66 61 0e 07 cd 1a e9 6a 01 |U...h..fa.....j.|
00000110 90 90 66 60 1e 06 66 a1 11 00 66 03 06 1c 00 1e |..f`..f...f.....|
00000120 66 68 00 00 00 00 66 50 06 53 68 01 00 68 10 00 |fh....fP.Sh..h..|
00000130 b4 42 8a 16 0e 00 16 1f 8b f4 cd 13 66 59 5b 5a |.B..........fY[Z|
00000140 66 59 66 59 1f 0f 82 16 00 66 ff 06 11 00 03 16 |fYfY.....f......|
00000150 0f 00 8e c2 ff 0e 16 00 75 bc 07 1f 66 61 c3 a0 |........u...fa..|
00000160 f8 01 e8 08 00 a0 fb 01 e8 02 00 eb fe b4 01 8b |................|
00000170 f0 ac 3c 00 74 09 b4 0e bb 07 00 cd 10 eb f2 c3 |..<.t...........|
00000180 0d 0a 41 20 64 69 73 6b 20 72 65 61 64 20 65 72 |..A disk read er|
00000190 72 6f 72 20 6f 63 63 75 72 72 65 64 00 0d 0a 42 |ror occurred...B|
000001a0 4f 4f 54 4d 47 52 20 69 73 20 6d 69 73 73 69 6e |OOTMGR is missin|
000001b0 67 00 0d 0a 42 4f 4f 54 4d 47 52 20 69 73 20 63 |g...BOOTMGR is c|
000001c0 6f 6d 70 72 65 73 73 65 64 00 0d 0a 50 72 65 73 |ompressed...Pres|
000001d0 73 20 43 74 72 6c 2b 41 6c 74 2b 44 65 6c 20 74 |s Ctrl+Alt+Del t|
000001e0 6f 20 72 65 73 74 61 72 74 0d 0a 00 00 00 00 00 |o restart.......|
000001f0 00 00 00 00 00 00 00 00 80 9d b2 ca 00 00 55 aa |..............U.|
00000200
=================== df -Th:
Filesystem Type Size Used Avail Use% Mounted on
/cow overlayfs 1.9G 27M 1.9G 2% /
udev devtmpfs 1.9G 12K 1.9G 1% /dev
tmpfs tmpfs 384M 864K 383M 1% /run
/dev/sr0 iso9660 782M 782M 0 100% /cdrom
/dev/loop0 squashfs 738M 738M 0 100% /rofs
none tmpfs 4.0K 0 4.0K 0% /sys/fs/cgroup
tmpfs tmpfs 1.9G 944K 1.9G 1% /tmp
none tmpfs 5.0M 0 5.0M 0% /run/lock
none tmpfs 1.9G 76K 1.9G 1% /run/shm
none tmpfs 100M 28K 100M 1% /run/user
/dev/sda1 fuseblk 350M 295M 56M 85% /mnt/boot-sav/sda1
/dev/sda2 fuseblk 200G 23G 178G 12% /mnt/boot-sav/sda2
/dev/sda3 ext4 25G 4.5G 19G 20% /mnt/boot-sav/sda3
/dev/sda6 ext4 25G 1.5G 22G 7% /mnt/boot-sav/sda6
/dev/sda7 ext4 20G 2.9G 16G 16% /mnt/boot-sav/sda7
/dev/sda8 ext4 20G 67M 19G 1% /mnt/boot-sav/sda8
/dev/sda9 fuseblk 169G 110M 169G 1% /mnt/boot-sav/sda9
=================== fdisk -l:
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0xaa0b9521
/dev/sda1 * 2048 718847 358400 7 HPFS/NTFS/exFAT
/dev/sda2 718848 419635199 209458176 7 HPFS/NTFS/exFAT
/dev/sda3 419635200 472150410 26257605+ 83 Linux
/dev/sda4 472150411 976766975 252308282+ f W95 Ext'd (LBA)
Partition 4 does not start on physical sector boundary.
/dev/sda5 472150413 486721304 7285446 82 Linux swap / Solaris
Partition 5 does not start on physical sector boundary.
/dev/sda6 486721368 539157464 26218048+ 83 Linux
/dev/sda7 539160576 581171199 21005312 83 Linux
/dev/sda8 581173248 623106047 20966400 83 Linux
/dev/sda9 623108096 976766975 176829440 7 HPFS/NTFS/exFAT
=================== Default settings
Recommended-Repair
This setting would reinstall the grub2 of sda3 into the MBR of sda.
Additional repair would be performed: unhide-bootmenu-10s fix-windows-boot
=================== Settings chosen by the user
Boot-Info
This setting will not act on the MBR.
Aucun changement n'a été effectué sur cet ordinateur.
Download as text
