Obtenir agenda icedove en français
Ça donne ceci apt-cache policy Fichiers du paquet : 100 /var/lib/dpkg/status release a=now 500 http://download.videolan.org/pub/debian/stable/ Packages release o=videolan,a=stable,n=stable,l=videolan,c= origin download.videolan.org 500 http://ftp.debian.org/debian/ wheezy-backports/main Translation-en 100 http://ftp.debian.org/debian/ wheezy-backports/main i386 Packages release v=,o=Debian Backports,a=wheezy-backports,n=wheezy-backports,l=Debian Backports,c=main origin ftp.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy-updates/non-free Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy-updates/main Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy-updates/contrib Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy-updates/non-free i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=non-free origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy-updates/contrib i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=contrib origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy-updates/main i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=main origin ftp.fr.debian.org 500 http://security.debian.org/ wheezy/updates/non-free Translation-en 500 http://security.debian.org/ wheezy/updates/main Translation-en 500 http://security.debian.org/ wheezy/updates/contrib Translation-en 500 http://security.debian.org/ wheezy/updates/non-free i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ wheezy/updates/contrib i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ wheezy/updates/main i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=main origin security.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy/non-free Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy/main Translation-fr 500 http://ftp.fr.debian.org/debian/ wheezy/main Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy/contrib Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy/non-free i386 Packages release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian,c=non-free origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy/contrib i386 Packages release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian,c=contrib origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy/main i386 Packages release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian,c=main origin ftp.fr.debian.org Paquets épinglés : Est-ce ok ?
Tu as zappé mon post avec le sources.list adéquat (le deuxième), Belzébuth ?
Bon, une précaution vaut mieux qu’une catastrophe, maintenant tout le monde peut être sûr que c’est ok.
Ah oui, tu as neutralisé [mono]Jessie[/mono] en [mono]/etc/apt/sources.list[/mono].
Ok.
Seul souci, ne comptes pas bénéficier des mises à jour de sécurité issues de [mono]Jessie[/mono] pour [mono]iceowl-l10n-fr[/mono] dans un pareil contexte.
Oui, et j’allais éditer mon message, car cette ligne du apt-cache policy
indique que le dépôt des versions stables de vlc selon l’équipe de vlc est ouvert, sans doute la version de Jessie. C’est un peu lourd en dépendances.
Pour info dz50, tu n’as peut-être pas eu de soucis avec ça, mais si tu as des problèmes futurs de mise à jour, ça viendra peut-être de là.
Oui, j’ai fait au plus simple (c’est un fichier de langue après tout), et j’allais éditer mon message, car cette ligne du apt-cache policy
indique que le dépôt des versions stables de vlc selon l’équipe de vlc est ouvert, sans doute la version de Jessie. C’est un peu lourd en dépendances…
Les [mono]priorités à 500[/mono]. (absence de [mono]pinning[/mono])
Son système est déjà impacté, les sources sont basées sur [mono]Wheezy[/mono] (oldstable) et [mono]download.videolan.org/pub/debian/stable/[/mono], qui dit [mono]stable[/mono] dit [mono]Jessie[/mono].
Je vais utiliser le PC sans faire de mise à jour “à part flashplugin”. Ou refaire une install si problème.
Non, c’est ridicule et ne serait pas digne de ce forum, n’y d’une [mono]Debian[/mono].
Deux fichiers [mono]preferences[/mono] (clefs en main) à mettre en places et ton système sera couvert.
Pour ce faire, tu remets en place les dépôts [mono]Jessie[/mono] puis lances un [mono]update[/mono].
Si ce n’est fait, réactives les dépôts [mono]videolan.org[/mono].
J’ai besoin des retours suivants.
Après l’[mono]update[/mono].
$ apt-cache policy icedove iceowl-l10n-fr iceowl-extension $ dpkg -l |grep iced $ dpkg -l |grep iceo $ apt-cache policy
Tu retires le dépôt videolan de ton sources.list (avec un #) comme précédemment. Tu retires puis tu réinstalles vlc:
aptitude purge vlc --purge aptitude update aptitude install vlc
Belzébuth a raison dans l’absolu, et c’est tout à son honneur et à sa compétence que d’y faire attention, mais a tort de faire paniquer en parlant de “système impacté” comme s’il était troué et pourri de partout. Si tu cherches à protéger ton ordinateur de la NSA, oui. Idem pour les mises à jour de sécurité d’un fichier langue.
Sinon et si tout fonctionne, soit tranquille. Retire le dépôt vlc (et si possible la version de vlc en jessie) et tu pourras faire tes maj sans problème.
Vas-y de ta diatribe, Belzébuth, annonce l’enfer et mon incompétence, et n’en parlons plus.
J’attends simplement, les retours demandés, à partir de là, je lui concocte les (deux) fichiers [mono]preferences[/mono] qui vont bien et basta, ce sera réglé.
PS: nul besoin (en l’état) de supprimer [mono]vlc[/mono].
[quote]Si ce n’est fait, réactives les dépôts videolan.org[/quote]Quoi t’est-ce ?
Les souces.list [code]#################################
jessie
deb http://ftp.fr.debian.org/debian/ jessie main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ jessie main contrib non-free
jessie security
deb http://security.debian.org/ jessie/updates main contrib non-free
deb-src http://security.debian.org/ jessie/updates main contrib non-free
jessie-update
deb http://ftp.fr.debian.org/debian/ jessie-updates main contrib non-free
jessie backports
deb http://ftp.debian.org/debian/ jessie-backports main
jessie multimedia
#deb http://www.deb-multimedia.org/debian jessie main non-free
stretch
#deb http://ftp.fr.debian.org/debian/ stretch main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ stretch main contrib non-free
##multimedia
deb http://www.deb-multimedia.org stretch main non-free
##Sid et experimental
##sid
#deb http://ftp.fr.debian.org/debian/ unstable main
##experimental
#deb http://ftp.fr.debian.org/debian/ experimental main
#iceweasel jessie depot mozilla
#deb http://mozilla.debian.net/ jessie-backports iceweasel-release
Les retours après l’update apt-cache policy icedove iceowl-l10n-fr iceowl-extension icedove: Installé : 38.5.0-1~deb7u1 Candidat : 38.5.0-1~deb8u1 Table de version : 38.5.0-1~deb8u1 0 500 http://security.debian.org/ jessie/updates/main i386 Packages *** 38.5.0-1~deb7u1 0 500 http://security.debian.org/ wheezy/updates/main i386 Packages 100 /var/lib/dpkg/status 31.7.0-1~deb8u1 0 500 http://ftp.fr.debian.org/debian/ jessie/main i386 Packages 31.3.0-1~deb7u1 0 500 http://ftp.fr.debian.org/debian/ wheezy/main i386 Packages iceowl-l10n-fr: Installé : 4.0.0.1-1~deb8u1 Candidat : 4.0.0.1-1~deb8u1 Table de version : *** 4.0.0.1-1~deb8u1 0 500 http://security.debian.org/ jessie/updates/main i386 Packages 100 /var/lib/dpkg/status 3.3-1 0 500 http://ftp.fr.debian.org/debian/ jessie/main i386 Packages iceowl-extension: Installé : 38.5.0-1~deb7u1 Candidat : 38.5.0-1~deb8u1 Table de version : 38.5.0-1~deb8u1 0 500 http://security.debian.org/ jessie/updates/main i386 Packages *** 38.5.0-1~deb7u1 0 500 http://security.debian.org/ wheezy/updates/main i386 Packages 100 /var/lib/dpkg/status 31.7.0-1~deb8u1 0 500 http://ftp.fr.debian.org/debian/ jessie/main i386 Packages 31.3.0-1~deb7u1 0 500 http://ftp.fr.debian.org/debian/ wheezy/main i386 Packages
dpkg -l |grep iced ii icedove 38.5.0-1~deb7u1 i386 mail/news client with RSS and integrated spam filter support ii icedove-l10n-fr 1:38.0.1-1~deb7u1 all French language package for Icedove ii icedtea-6-jre-cacao:i386 6b36-1.13.8-1~deb7u1 i386 Alternative JVM for OpenJDK, using Cacao ii icedtea-6-jre-jamvm:i386 6b36-1.13.8-1~deb7u1 i386 Alternative JVM for OpenJDK, using JamVM ii icedtea-netx:i386 1.4-3~deb7u2 i386 NetX - implementation of the Java Network Launching Protocol (JNLP) ii icedtea-netx-common 1.4-3~deb7u2 all NetX - implementation of the Java Network Launching Protocol (JNLP)
dpkg -l |grep iced ii icedove 38.5.0-1~deb7u1 i386 mail/news client with RSS and integrated spam filter support ii icedove-l10n-fr 1:38.0.1-1~deb7u1 all French language package for Icedove ii icedtea-6-jre-cacao:i386 6b36-1.13.8-1~deb7u1 i386 Alternative JVM for OpenJDK, using Cacao ii icedtea-6-jre-jamvm:i386 6b36-1.13.8-1~deb7u1 i386 Alternative JVM for OpenJDK, using JamVM ii icedtea-netx:i386 1.4-3~deb7u2 i386 NetX - implementation of the Java Network Launching Protocol (JNLP) ii icedtea-netx-common 1.4-3~deb7u2 all NetX - implementation of the Java Network Launching Protocol (JNLP) root@X:/home/z# dpkg -l |grep iceo ii calendar-google-provider 38.5.0-1~deb7u1 all Google Calendar support for lightning- and iceowl-extension ii iceowl-extension 38.5.0-1~deb7u1 i386 Calendar Extension for Thunderbird/Icedove ii iceowl-l10n-fr 4.0.0.1-1~deb8u1 all French language package for iceowl-extension
apt-cache policy Fichiers du paquet : 100 /var/lib/dpkg/status release a=now 500 http://download.videolan.org/pub/debian/stable/ Packages release o=videolan,a=stable,n=stable,l=videolan,c= origin download.videolan.org 500 http://ftp.debian.org/debian/ wheezy-backports/main Translation-en 100 http://ftp.debian.org/debian/ wheezy-backports/main i386 Packages release v=,o=Debian Backports,a=wheezy-backports,n=wheezy-backports,l=Debian Backports,c=main origin ftp.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy-updates/non-free Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy-updates/main Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy-updates/contrib Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy-updates/non-free i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=non-free origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy-updates/contrib i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=contrib origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy-updates/main i386 Packages release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian,c=main origin ftp.fr.debian.org 500 http://security.debian.org/ wheezy/updates/non-free Translation-en 500 http://security.debian.org/ wheezy/updates/main Translation-en 500 http://security.debian.org/ wheezy/updates/contrib Translation-en 500 http://security.debian.org/ wheezy/updates/non-free i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ wheezy/updates/contrib i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ wheezy/updates/main i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=main origin security.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy/non-free Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy/main Translation-fr 500 http://ftp.fr.debian.org/debian/ wheezy/main Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy/contrib Translation-en 500 http://ftp.fr.debian.org/debian/ wheezy/non-free i386 Packages release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian,c=non-free origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy/contrib i386 Packages release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian,c=contrib origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ wheezy/main i386 Packages release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian,c=main origin ftp.fr.debian.org 500 http://ftp.debian.org/debian/ jessie-backports/main Translation-en 100 http://ftp.debian.org/debian/ jessie-backports/main i386 Packages release o=Debian Backports,a=jessie-backports,n=jessie-backports,l=Debian Backports,c=main origin ftp.debian.org 500 http://ftp.fr.debian.org/debian/ jessie-updates/non-free Translation-en 500 http://ftp.fr.debian.org/debian/ jessie-updates/main Translation-en 500 http://ftp.fr.debian.org/debian/ jessie-updates/contrib Translation-en 500 http://ftp.fr.debian.org/debian/ jessie-updates/non-free i386 Packages release o=Debian,a=stable-updates,n=jessie-updates,l=Debian,c=non-free origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ jessie-updates/contrib i386 Packages release o=Debian,a=stable-updates,n=jessie-updates,l=Debian,c=contrib origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ jessie-updates/main i386 Packages release o=Debian,a=stable-updates,n=jessie-updates,l=Debian,c=main origin ftp.fr.debian.org 500 http://security.debian.org/ jessie/updates/non-free Translation-en 500 http://security.debian.org/ jessie/updates/main Translation-en 500 http://security.debian.org/ jessie/updates/contrib Translation-en 500 http://security.debian.org/ jessie/updates/non-free i386 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ jessie/updates/contrib i386 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ jessie/updates/main i386 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=main origin security.debian.org 500 http://ftp.fr.debian.org/debian/ jessie/non-free Translation-en 500 http://ftp.fr.debian.org/debian/ jessie/main Translation-fr 500 http://ftp.fr.debian.org/debian/ jessie/main Translation-en 500 http://ftp.fr.debian.org/debian/ jessie/contrib Translation-en 500 http://ftp.fr.debian.org/debian/ jessie/non-free i386 Packages release v=8.2,o=Debian,a=stable,n=jessie,l=Debian,c=non-free origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ jessie/contrib i386 Packages release v=8.2,o=Debian,a=stable,n=jessie,l=Debian,c=contrib origin ftp.fr.debian.org 500 http://ftp.fr.debian.org/debian/ jessie/main i386 Packages release v=8.2,o=Debian,a=stable,n=jessie,l=Debian,c=main origin ftp.fr.debian.org Paquets épinglés :
[quote=“dz50”]
Quoi t’est-ce ?[/quote]
[quote=“dz50”]root@X:/home/z# cat /etc/apt/sources.list.d/* deb http://download.videolan.org/pub/debian/stable/ / deb-src http://download.videolan.org/pub/debian/stable/ / deb http://download.videolan.org/pub/debian/stable/ / deb-src http://download.videolan.org/pub/debian/stable/ /[/quote]
Ci-dessus, il y a doublon (mais, pas d’erreur notifier durant l’update à ce sujet) , serait une erreur de copier/coller ?
* edit *
J’ai passé les 3 commandes. cat /etc/apt/sources.list.d/* deb http://download.videolan.org/pub/debian/stable/ / deb-src http://download.videolan.org/pub/debian/stable/ / deb http://download.videolan.org/pub/debian/stable/ / deb-src http://download.videolan.org/pub/debian/stable/ / root@X:/home/z# ls -la /etc/apt/sources.list.d/ total 16 drwxr-xr-x 2 root root 4096 janv. 10 19:22 . drwxr-xr-x 6 root root 4096 janv. 17 10:28 .. -rw-r--r-- 1 root root 112 janv. 13 16:18 libdvdcss.list -rw-r--r-- 1 root root 112 janv. 13 16:18 libdvdcss.list.save root@X:/home/z# dpkg -l |grep vlc ii libvlc5 2.0.3-5+deb7u2+b1 i386 multimedia player and streamer library ii libvlccore5 2.0.3-5+deb7u2+b1 i386 base library for VLC and its modules ii vlc 2.0.3-5+deb7u2+b1 i386 multimedia player and streamer ii vlc-data 2.0.3-5+deb7u2 all Common data for VLC ii vlc-nox 2.0.3-5+deb7u2+b1 i386 multimedia player and streamer (without X support) ii vlc-plugin-notify 2.0.3-5+deb7u2+b1 i386 LibNotify plugin for VLC ii vlc-plugin-pulse 2.0.3-5+deb7u2+b1 i386 PulseAudio plugin for VLC
Comme tu peux le constater, la 1ère cde renvoie bien un doublon. Si tout est ok, je pense qu’il faut neutraliser les sources.list jessie, puis faire un update.
[quote=“dz50”]root@X:/home/z# dpkg -l |grep vlc [...] ii vlc 2.0.3-5+deb7u2+b1 i386 multimedia player and streamer ii vlc-data 2.0.3-5+deb7u2 all Common data for VLC ii vlc-nox 2.0.3-5+deb7u2+b1 i386 multimedia player and streamer (without X support) ii vlc-plugin-notify 2.0.3-5+deb7u2+b1 i386 LibNotify plugin for VLC ii vlc-plugin-pulse 2.0.3-5+deb7u2+b1 i386 PulseAudio plugin for VLC[/quote]
Inutile de retoucher à [mono]vlc[/mono] et ses copains, ils sont issus de Wheezy et non pas de [mono]videolan[/mono]. Ne touches à rien.
Il suffit de supprimer le fichier [mono]save[/mono].
Non, ce n’est pas le but. Les dépôts Wheezy et Jessie doivent et resteront actifs.
Les fichiers suivants sont à créer, nous en profiterons pour ajuster les droits.
[code]# touch /etc/apt/preferences
chmod -v 644 /etc/apt/preferences[/code]
Copies/colles ce qui suit.
[code]Package: *
Pin: release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security
Pin-Priority: 990
Package: *
Pin: release o=Debian,a=oldstable-updates,n=wheezy-updates,l=Debian
Pin-Priority: 990
Package: *
Pin: release v=7.9,o=Debian,a=oldstable,n=wheezy,l=Debian
Pin-Priority: 990
Package: *
Pin: release o=Debian Backports,a=wheezy-backports,n=wheezy-backports,l=Debian Backports
Pin-Priority: 980
Package: *
Pin: release o=Debian,a=stable,l=Debian-Security
Pin-Priority: 800
Package: *
Pin-Priority: 800
Package: *
Pin: release o=Debian,a=stable-updates,n=jessie-updates,l=Debian
Pin-Priority: 800
Package: *
Pin: release o=Debian Backports,a=jessie-backports,n=jessie-backports,l=Debian Backports
Pin-Priority: 790[/code]
[code]# touch /etc/apt/preferences.d/videolan.pref
chmod -v 644 /etc/apt/preferences.d/videolan.pref[/code]
Copies/colles.
Package: * Pin: release o=videolan,a=stable,n=stable,l=videolan Pin-Priority: 400
[code]# touch /etc/apt/preferences.d/iceowl.pref
chmod -v 644 /etc/apt/preferences.d/iceowl.pref[/code]
Copies/colles.
Package: iceowl-l10n-fr Pin: release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security Pin-Priority: 1001
Tu relances un [mono]update[/mono] (tu n’installes rien pour le moment et ne lances pas d’upgrade non plus) afin de vérifier tout cela.
Ces retours, stp.
Une [mono]simulation[/mono] (option [mono]-s[/mono]) d’upgrade et full-upgrade depuis ton comptes utilisateur.
$ aptitude -s upgrade $ aptitude -s full-upgrade
Jusque là ça va. root@X:/home/z# touch /etc/apt/preferences root@X:/home/z# chmod -v 644 /etc/apt/preferences le mode de « /etc/apt/preferences » a été conservé à 0644 (rw-r--r--).
Mais pour la suite, Copier soit mais coller où ?
À la suite (?) et dans les fichiers nouvellement créaient.
Soit :
cat /etc/apt/preferences.d/videolan.pref Package: * Pin: release o=videolan,a=stable,n=stable,l=videolan Pin-Priority: 400
cat /etc/apt/preferences.d/iceowl.pref Package: iceowl-l10n-fr Pin: release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security Pin-Priority: 1001
[quote]Code:
chmod -v 644 /etc/apt/preferences[/quote]
A la suite de ces commandes, je trouve 3 fichiers vides : Préférences - PréférencesPack age: - PréférencesPin: Dans lequel dois-je coller ce qui suit ? [code]Package: *
Pin-Priority: 990
Package: *
Pin-Priority: 990
Package: *
Pin-Priority: 990
Package: *
Pin-Priority: 980
Package: *
Pin-Priority: 800
Package: *
Pin-Priority: 800
Package: *
Pin-Priority: 800
Package: *
Là, c’est le pompon, la goutte d’eau quoi … on nettoie tout cela et [mono]on oublie[/mono] !
Pour ce faire, donnes moi les retours suivants.
$ ls -la /etc/apt/ $ ls -la /etc/apt/sources.list.d/ $ cat /etc/apt/sources.list $ ls -la /etc/apt/sources.list.d/ $ cat /etc/apt/sources.list.d/* $ cat /etc/apt/preferences $ ls -la /etc/apt/preferences.d/ $ cat /etc/apt/preferences.d/*
À la suite de quoi, je te donnerai les lignes de commandes pour [mono]nettoyer tout ce merdier[/mono], ensuite, [mono]tu[/mono] corrigeras ton fichier sources.list et [mono]tu vireras[/mono] les dépôts Jessie.
Ce que cela donne. [code]ls -la /etc/apt/
total 56
drwxr-xr-x 6 root root 4096 janv. 19 14:49 .
drwxr-xr-x 127 root root 12288 janv. 19 17:33 …
drwxr-xr-x 2 root root 4096 janv. 10 13:21 apt.conf.d
-rw-r–r-- 1 root root 99 janv. 9 12:37 listchanges.conf
-rw-r–r-- 1 root root 0 janv. 19 15:21 preferences
drwxr-xr-x 2 root root 4096 janv. 19 15:20 preferences.d
-rw-r–r-- 1 root root 0 janv. 19 14:49 preferencesPackage:
-rw-r–r-- 1 root root 0 janv. 19 14:46 preferencesPin:
-rw-r–r-- 1 root root 1837 janv. 19 14:45 sources.list
-rw-r–r-- 1 root root 0 janv. 9 11:32 sources.list~
drwxr-xr-x 2 root root 4096 janv. 19 11:29 sources.list.d
-rw-r–r-- 1 root root 1076 janv. 13 16:18 sources.list.save
-rw------- 1 root root 1200 janv. 9 14:14 trustdb.gpg
-rw------- 1 root root 1359 janv. 9 14:14 trusted.gpg
-rw------- 1 root root 1359 janv. 9 14:14 trusted.gpg~
drwxr-xr-x 2 root root 4096 janv. 9 14:14 trusted.gpg.d
total 12
drwxr-xr-x 2 root root 4096 janv. 19 11:29 .
drwxr-xr-x 6 root root 4096 janv. 19 14:49 …
-rw-r–r-- 1 root root 112 janv. 13 16:18 libdvdcss.list
jessie
jessie security
jessie-update
jessie backports
jessie multimedia
stretch
##multimedia
##sid
##experimental
wheezy
deb http://ftp.fr.debian.org/debian/ wheezy main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ wheezy main contrib non-free
wheezy multimedia
#deb http://www.deb-multimedia.org wheezy main non-free
wheezy security
deb http://security.debian.org/ wheezy/updates main contrib non-free
#wheezy-update
deb http://ftp.fr.debian.org/debian/ wheezy-updates main contrib non-free
wheezy backports
deb http://ftp.debian.org/debian/ wheezy-backports main
iceweasel sur wheezy
#deb http://mozilla.debian.net/ wheezy-backports iceweasel-release
total 12
root@X:/home/z# cat /etc/apt/preferences
root@X:/home/z# ls -la /etc/apt/preferences.d/
total 16
drwxr-xr-x 2 root root 4096 janv. 19 15:20 .
-rw-r–r-- 1 root root 104 janv. 19 15:21 iceowl.pref
-rw-r–r-- 1 root root 81 janv. 19 15:19 videolan.pref
root@X:/home/z# cat /etc/apt/preferences.d/*
Pin-Priority: 1001Package: *
[quote=“dz50”]ls -la /etc/apt/
-rw-r–r-- 1 root root 0 janv. 19 15:21 [mono]preferences[/mono]
-rw-r–r-- 1 root root 0 janv. 19 14:49 [mono]preferencesPackage:[/mono]
-rw-r–r-- 1 root root 0 janv. 19 14:46 [mono]preferencesPin:[/mono]
[…][/quote]
[code]# rm -i /etc/apt/preferencesPackage:
rm -i /etc/apt/preferencesPin:[/code]
[code]# rm -i /etc/apt/preferences.d/iceowl.pref
rm -i /etc/apt/preferences.d/videolan.pref[/code]
Voilà, vires les dépôts Jessie et relances un update.
Basta.
