Quelques logs :
le fichier pm-powersave.log [code]Invoking module /usr/share/laptop-mode-tools/modules/laptop-mode.
Adjusting 2.6 kernel parameters to enable laptop mode.
Executing: echo 2 > /proc/sys/vm/laptop_mode
Executing: echo 120000 > /proc/sys/vm/dirty_writeback_centisecs
Executing: echo 120000 > /proc/sys/vm/dirty_expire_centisecs
Executing: echo 60 > /proc/sys/vm/dirty_ratio
Executing: echo 1 > /proc/sys/vm/dirty_background_ratio
Remounting filesystems.
/dev/sda6 not found in PARTITIONS.
/ not found in PARTITIONS.
Checking /dev/sda6 against HD because PARTITIONS contains “auto”.
Considering /dev/sda.
/dev/sda6 contains /dev/sda, which is in HD, so we will remount it.
Original options: rw,relatime,errors=remount-ro,commit=1200
Updating /var/run/laptop-mode-tools/nolm-mountopts.
Reducing file system type.
Removing commit mount option from original options.
Executing: mount /dev/sda6 / -t ext4 -o remount,rw,relatime,errors=remount-ro,commit=1200,relatime
Executing: /sbin/blockdev --setfra 6144 /dev/sda6
none not found in PARTITIONS.
/sys/fs/fuse/connections not found in PARTITIONS.
Checking none against HD because PARTITIONS contains “auto”.
/sys/kernel/debug not found in PARTITIONS.
/sys/kernel/security not found in PARTITIONS.
/var/lib/ureadahead/debugfs not found in PARTITIONS.
Invoking module /usr/share/laptop-mode-tools/modules/lcd-brightness.
Invoking module /usr/share/laptop-mode-tools/modules/sched-mc-power-savings.
Scheduler power setting is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/start-stop-programs.
- Starting Common Unix Printing System: cupsd
…done.
shift: 28: can’t shift that many
- Enabling additional executable binary formats binfmt-support
…done.
Stopping /etc/laptop-mode/batt-stop/anacron
Rather than invoking init scripts through /etc/init.d, use the service(8)
utility, e.g. service anacron stop
Since the script you are attempting to invoke has been converted to an
Upstart job, you may also use the stop(8) utility, e.g. stop anacron
Stopping /etc/laptop-mode/batt-stop/atd
utility, e.g. service atd stop
Upstart job, you may also use the stop(8) utility, e.g. stop atd
Stopping /etc/laptop-mode/batt-stop/binfmt-support
- Disabling additional executable binary formats binfmt-support
…done.
Stopping /etc/laptop-mode/batt-stop/cron
utility, e.g. service cron stop
Upstart job, you may also use the stop(8) utility, e.g. stop cron
Stopping /etc/laptop-mode/batt-stop/cups
- Stopping Common Unix Printing System: cupsd
…done.
Stopping /etc/laptop-mode/batt-stop/polipo
Stopping /etc/laptop-mode/batt-stop/tor
START_SERVICES =
STOP_SERVICES =
Invoking module /usr/share/laptop-mode-tools/modules/syslog-conf.
Invoking module /usr/share/laptop-mode-tools/modules/terminal-blanking.
CONTROL_TERMINAL is disabled, skipping…
Invoking module /usr/share/laptop-mode-tools/modules/usb-autosuspend.
USB autosuspend is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/video-out.
video-out module is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/wireless-ipw-power.
Intel IPW Wireless power setting is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/wireless-iwl-power.
Intel IWL Wireless power setting is disabled.
Module /usr/local/lib/laptop-mode-tools/modules/* is not executable.
Module /usr/local/share/laptop-mode-tools/modules/* is not executable.
Module /etc/laptop-mode/modules/* is not executable.
success.
/usr/lib/pm-utils/power.d/sched-powersave true: *sched policy powersave ON
success.
/etc/pm/power.d/00-hdparm.sh true:
/dev/sda:
setting Advanced Power Management level to 0xfe (254)
APM_level = 254
success.
/usr/lib/pm-utils/power.d/95hdparm-apm true: success.
/usr/lib/pm-utils/power.d/anacron true: stop: Unknown instance:
success.
/usr/lib/pm-utils/power.d/laptop-mode true: Laptop Mode Tools 1.47
Determining power state from /sys/class/power_supply/AC/online.
Not trying other options, already found a power supply.
On battery power: Activating, because ENABLE_LAPTOP_MODE_ON_BATTERY is set.
Not on AC and we have battery information in /sys/class/power_supply/BAT – checking minimum battery charge.
/sys/class/power_supply/AC is of type Mains.
Not of type “Battery”, skipping.
/sys/class/power_supply/BAT0 is of type Battery.
Checking levels for /sys/class/power_supply/BAT0.
Present: 1.
Remaining charge: 1749000
Full capacity: 4400000
Laptop mode enabled, active
Invoking module /usr/share/laptop-mode-tools/modules/ac97-powersave.
AC97 audio power setting is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/battery-level-polling.
Battery level polling is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/bluetooth.
Invoking module /usr/share/laptop-mode-tools/modules/configuration-file-control.
Swapping out configuration files.
/etc/rsyslog.conf is a symlink.
Pointing config file /etc/rsyslog.conf to /etc/rsyslog.conf-batt.
Sending SIGHUP to all syslogd processes.
Sending SIGHUP to all syslog-ng processes.
Sending SIGHUP to all rsyslogd processes.
Invoking module /usr/share/laptop-mode-tools/modules/cpufreq.
Invoking module /usr/share/laptop-mode-tools/modules/dpms-standby.
CONTROL_DPMS_STANDBY is disabled, skipping…
Invoking module /usr/share/laptop-mode-tools/modules/ethernet.
Ethernet module is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/hal-polling.
Invoking module /usr/share/laptop-mode-tools/modules/hdparm.
Setting powermanagement on drives to 254.
Querying /dev/sda media type using device name: type ‘disk’ on bus ‘scsi’ detected
Executing: hdparm -B 254 /dev/sda
/dev/sda:
APM_level = 254
Setting spindown timeout on drives to 30 seconds.
(hdparm configuration value = 6.)
Executing: hdparm -S 6 /dev/sda
/dev/sda:
setting standby to 6 (30 seconds)
Setting write cache on drives to 1.
Executing: hdparm -W 1 /dev/sda
/dev/sda:
setting drive write-caching to 1 (on)
write-caching = 1 (on)
Invoking module /usr/share/laptop-mode-tools/modules/intel-hda-powersave.
Intel HDA audio power setting is disabled.
Invoking module /usr/share/laptop-mode-tools/modules/intel-sata-powermgmt.
Intel SATA link power saving disabled.
…done.
…done.
…done.
…done.
START_SERVICES =
STOP_SERVICES =
success.
/usr/lib/pm-utils/power.d/sched-powersave true: **sched policy powersave ON
success.[/code]
et pm-suspend.log
[code]Initial commandline parameters:
Fri Apr 2 16:49:41 CEST 2010: Running hooks for suspend.
/etc/pm/sleep.d/00-hdparm.sh suspend suspend:
/dev/sda:
APM_level = 254
success.
/usr/lib/pm-utils/sleep.d/000record suspend suspend: success.
/usr/lib/pm-utils/sleep.d/00auto-quirk suspend suspend: Adding quirks from HAL: --quirk-dpms-on --quirk-dpms-suspend --quirk-vbe-post --quirk-vbemode-restore --quirk-vbestate-restore --quirk-vga-mode-3
success.
/usr/lib/pm-utils/sleep.d/00logging suspend suspend: Linux nil 2.6.31-20-generic #58-Ubuntu SMP Fri Mar 12 04:38:19 UTC 2010 x86_64 GNU/Linux
Module Size Used by
binfmt_misc 10220 1
ppdev 8232 0
snd_hda_codec_realtek 277860 1
arc4 2144 2
ecb 3296 2
joydev 13088 0
iptable_filter 3872 0
snd_hda_intel 31880 2
snd_hda_codec 87584 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 9352 1 snd_hda_codec
snd_pcm_oss 44704 0
snd_mixer_oss 18976 1 snd_pcm_oss
snd_pcm 93160 3 snd_hda_intel,snd_hda_codec,snd_pcm_oss
snd_seq_dummy 3460 0
jmb38x_ms 11300 0
uvcvideo 65260 0
videodev 43360 1 uvcvideo
v4l1_compat 16644 2 uvcvideo,videodev
v4l2_compat_ioctl32 13344 1 videodev
rtl8187 53604 0
mac80211 210040 1 rtl8187
eeprom_93cx6 2528 1 rtl8187
cfg80211 109144 2 rtl8187,mac80211
ip_tables 21200 1 iptable_filter
x_tables 25832 1 ip_tables
snd_seq_oss 33440 0
psmouse 57124 0
serio_raw 6596 0
memstick 12528 1 jmb38x_ms
sdhci_pci 8928 0
sdhci 20484 1 sdhci_pci
led_class 5256 2 rtl8187,sdhci
fglrx 2234552 30
uinput 10368 0
coretemp 7072 0
sis190 21060 0
mii 6368 1 sis190
snd_seq_midi 8192 0
snd_rawmidi 27296 1 snd_seq_midi
snd_seq_midi_event 8448 2 snd_seq_oss,snd_seq_midi
snd_seq 60608 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 26992 2 snd_pcm,snd_seq
snd_seq_device 8308 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 77096 16 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore 9088 1 snd
snd_page_alloc 10928 2 snd_hda_intel,snd_pcm
lp 11908 0
parport 40528 2 ppdev,lp
video 23612 0
output 3680 1 video
sis_agp 8608 0
total used free shared buffers cached
Mem: 2055804 939740 1116064 0 155792 344040
-/+ buffers/cache: 439908 1615896
Swap: 6024332 0 6024332
success.
/usr/lib/pm-utils/sleep.d/00powersave suspend suspend: success.
/usr/lib/pm-utils/sleep.d/01PulseAudio suspend suspend: success.
/etc/pm/sleep.d/10_grub-common suspend suspend: success.
/etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend: success.
/usr/lib/pm-utils/sleep.d/49bluetooth suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/55NetworkManager suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/55wicd suspend suspend: success.
/usr/lib/pm-utils/sleep.d/75modules suspend suspend: success.
/usr/lib/pm-utils/sleep.d/90clock suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend: success.
/usr/lib/pm-utils/sleep.d/95anacron suspend suspend: stop: Unknown instance:
success.
/usr/lib/pm-utils/sleep.d/95led suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/96laptop-mode suspend suspend: success.
/usr/lib/pm-utils/sleep.d/98smart-kernel-video suspend suspend: success.
/usr/lib/pm-utils/sleep.d/99video suspend suspend: kernel.acpi_video_flags = 0
success.
/etc/pm/sleep.d/action_wpa suspend suspend: success.
Fri Apr 2 16:49:51 CEST 2010: performing suspend
Fri Apr 2 16:51:34 CEST 2010: Awake.
Fri Apr 2 16:51:34 CEST 2010: Running hooks for resume
/etc/pm/sleep.d/action_wpa resume suspend: success.
/usr/lib/pm-utils/sleep.d/99video resume suspend: success.
/usr/lib/pm-utils/sleep.d/98smart-kernel-video resume suspend: success.
/usr/lib/pm-utils/sleep.d/96laptop-mode resume suspend: Laptop Mode Tools 1.47
On AC power: Deactivating, because ENABLE_LAPTOP_MODE_ON_AC is not set.
Laptop mode enabled, not active
Pointing config file /etc/rsyslog.conf to /etc/rsyslog.conf-nolm-ac.
/dev/sda:
APM_level = 254
Setting spindown timeout on drives to 7200 seconds.
(hdparm configuration value = 244.)
Executing: hdparm -S 244 /dev/sda
/dev/sda:
setting standby to 244 (2 hours)
/dev/sda:
Executing: echo 0 > /proc/sys/vm/laptop_mode
Adjusting 2.6 kernel parameters to disable laptop mode.
Executing: echo 500 > /proc/sys/vm/dirty_writeback_centisecs
Executing: echo 3000 > /proc/sys/vm/dirty_expire_centisecs
Executing: echo 40 > /proc/sys/vm/dirty_ratio
Executing: echo 10 > /proc/sys/vm/dirty_background_ratio
Original options: rw,errors=remount-ro
No saved mount options, so apparently we never remounted this filesystem during this session.
Not remounting.
Executing: /sbin/blockdev --setfra 256 /dev/sda6
proc not found in PARTITIONS.
/proc not found in PARTITIONS.
Checking proc against HD because PARTITIONS contains “auto”.
/sys not found in PARTITIONS.
udev not found in PARTITIONS.
/dev not found in PARTITIONS.
Checking udev against HD because PARTITIONS contains “auto”.
/dev/pts not found in PARTITIONS.
/dev/shm not found in PARTITIONS.
/var/run not found in PARTITIONS.
/var/lock not found in PARTITIONS.
/lib/init/rw not found in PARTITIONS.
binfmt_misc not found in PARTITIONS.
/proc/sys/fs/binfmt_misc not found in PARTITIONS.
Checking binfmt_misc against HD because PARTITIONS contains “auto”.
gvfs-fuse-daemon not found in PARTITIONS.
/home/pierre/.gvfs not found in PARTITIONS.
Checking gvfs-fuse-daemon against HD because PARTITIONS contains “auto”.
START_SERVICES =
STOP_SERVICES =
success.
/usr/lib/pm-utils/sleep.d/95led resume suspend: not applicable.
/usr/lib/pm-utils/sleep.d/95anacron resume suspend: success.
/usr/lib/pm-utils/sleep.d/94cpufreq resume suspend: success.
/usr/lib/pm-utils/sleep.d/90clock resume suspend: not applicable.
/usr/lib/pm-utils/sleep.d/75modules resume suspend: success.
/usr/lib/pm-utils/sleep.d/55wicd resume suspend: success.
/usr/lib/pm-utils/sleep.d/55NetworkManager resume suspend: not applicable.
/usr/lib/pm-utils/sleep.d/49bluetooth resume suspend: not applicable.
/etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend: success.
/etc/pm/sleep.d/10_grub-common resume suspend: success.
/usr/lib/pm-utils/sleep.d/01PulseAudio resume suspend: success.
/usr/lib/pm-utils/sleep.d/00powersave resume suspend: success.
/usr/lib/pm-utils/sleep.d/00logging resume suspend: success.
/usr/lib/pm-utils/sleep.d/00auto-quirk resume suspend: success.
/usr/lib/pm-utils/sleep.d/000record resume suspend: success.
/etc/pm/sleep.d/00-hdparm.sh resume suspend:
/dev/sda:
APM_level = 254
success.
Fri Apr 2 16:51:42 CEST 2010: Finished.
