Impossible de réinstaller le paquet sans avoir internet sur ce PC
Les logs de syslog :
grep eth1
[quote]Jul 5 18:54:13 matrix kernel: [ 5.350641] udev[284]: renamed network interface eth0 to eth1
Jul 5 18:54:13 matrix kernel: [ 12.099918] eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
Jul 5 18:54:14 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
Jul 5 18:54:18 matrix arpwatch: bad interface eth1: eth1: no IPv4 address assigned - assuming unconfigured interface
Jul 5 18:54:18 matrix arpwatch: listening on eth1
Jul 5 18:54:20 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12
Jul 5 18:54:22 matrix ntpd[1324]: Listen normally on 4 eth1 fe80::20b:6aff:fe78:e38c UDP 123
Jul 5 18:54:22 matrix kernel: [ 22.416057] eth1: no IPv6 routers present
Jul 5 18:54:32 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 14
Jul 5 18:54:46 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 18:54:53 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10
Jul 5 18:55:03 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12
Jul 5 19:01:08 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5
Jul 5 19:01:13 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 11
Jul 5 19:01:24 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12
Jul 5 19:01:36 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 15
Jul 5 19:01:51 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10
Jul 5 19:02:01 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 8
Jul 5 19:07:04 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3
Jul 5 19:07:07 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
Jul 5 19:07:13 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 18
Jul 5 19:07:31 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 17
Jul 5 19:07:48 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 9
Jul 5 19:07:57 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 19:08:04 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 1
Jul 5 19:14:25 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4
Jul 5 19:14:29 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4
Jul 5 19:14:33 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5
Jul 5 19:14:38 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
Jul 5 19:14:44 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 19:14:51 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10
Jul 5 19:15:01 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 16
Jul 5 19:15:17 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 9
Jul 5 19:21:02 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4
Jul 5 19:21:06 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5
Jul 5 19:21:11 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 19:21:18 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 11
Jul 5 19:21:29 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10
Jul 5 19:21:39 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 19:21:46 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10
Jul 5 19:21:56 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 19:26:57 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5
Jul 5 19:27:02 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
Jul 5 19:27:08 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 15
Jul 5 19:27:23 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 15
Jul 5 19:27:38 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12
Jul 5 19:27:50 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 8
Jul 5 19:31:52 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4
Jul 5 19:31:56 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
Jul 5 19:32:03 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 19
Jul 5 19:32:22 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10
Jul 5 19:32:32 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 15
Jul 5 19:32:47 matrix dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
grep via-rhine
[quote]Jul 5 18:54:13 matrix kernel: [ 1.746794] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
Jul 5 18:54:13 matrix kernel: [ 1.746910] via-rhine 0000:00:12.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
grep 00:12.0
[quote]Jul 5 18:54:13 matrix kernel: [ 0.115740] pci 0000:00:12.0: reg 10 io port: [0xdc00-0xdcff]
Jul 5 18:54:13 matrix kernel: [ 0.115753] pci 0000:00:12.0: reg 14 32bit mmio: [0xdffffe00-0xdffffeff]
Jul 5 18:54:13 matrix kernel: [ 0.115814] pci 0000:00:12.0: supports D1 D2
Jul 5 18:54:13 matrix kernel: [ 0.115820] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 5 18:54:13 matrix kernel: [ 0.115828] pci 0000:00:12.0: PME# disabled
[quote=“fran.b”]apt-get install --reinstall «nom de ton noyau»
Il y a peut être des histoires de firmware mais je suis pessimiste quant à ta carte. Tu as éteins et rallumer l’appareil connectée à l’autre bout du cable?[/quote][/quote]
Le routeur a été re-booté, à plusieurs reprises d’ailleurs
