problème KDE login
[quote]ton logiciel marche bien[/quote]Tu veux bien dire que t’arrives sans pb à ouvrir un session graphique sous windowmaker ? C’est que le pb vient alors de kde.
Que raconte le log de kdm: #cat /var/log/kdm.log ?
Voila les logs :
(II) Module “i2c” already built-in
NTSC PAL
finished output detect: 0
finished output detect: 1
finished all detect
before xf86InitialConfiguration
in RADEONProbeOutputModes
after xf86InitialConfiguration
(II) Module “ramdac” already built-in
Entering TV Save
Save TV timing tables
saveTimingTables: reading timing tables
TV Save done
init memmap
init common
init crtc1
init pll1
freq: 146250000
best_freq: 146250000
best_feedback_div: 65
best_ref_div: 6
best_post_div: 2
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
restore dac
expected keysym, got circumflex: line 257 of fr
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
[config/hal] couldn’t initialise context: (null) ((null))
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore Timing Tables
Restore TV standard
Leaving Restore TV
FreeFontPath: FPE “/usr/share/fonts/X11/misc” refcount is 2, should be 1; fixing.
Entering TV Save
TV Save done
init memmap
init common
init crtc1
init pll1
freq: 146250000
best_ref_div: 6
best_post_div: 2
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
restore dac
Error: No Symbols named “latin9” in the include file "us"
Exiting
Abandoning symbols file "default"
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore TV standard
Leaving Restore TV
Entering TV Save
TV Save done
init memmap
init common
init crtc1
init pll1
freq: 146250000
best_ref_div: 6
best_post_div: 2
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
restore dac
Exiting
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore TV standard
Leaving Restore TV
Entering TV Save
TV Save done
init memmap
init common
init crtc1
init pll1
freq: 146250000
best_ref_div: 6
best_post_div: 2
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
restore dac
Exiting
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore TV standard
Leaving Restore TV
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny2)
Current Operating System: Linux server 2.6.26-2-686 #1 SMP Wed May 12 21:56:10 UTC 2010 i686
Build Date: 08 June 2009 09:12:57AM
    Before reporting problems, check [wiki.x.org](http://wiki.x.org)
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jun 20 13:57:25 2010
(==) Using config file: “/etc/X11/xorg.conf”
(WW) RADEON: No matching Device section for instance (BusID PCI:2:0:1) found
(II) Module “ddc” already built-in
NTSC PAL
(EE) RADEON(0): No connected devices found!
finished all detect
(EE) RADEON(0): Using VGA default
Entering TV Save
TV Save done
init memmap
init common
init crtc1
init pll1
freq: 80140000
best_freq: 80140909
best_feedback_div: 653
best_ref_div: 55
best_post_div: 4
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
restore dac
Merci de ton aide
bon, des erreurs, mais pas des erreurs fatales de ce côté.
Et que renvoie grep EE /var/log/Xorg.0.log ?
server:~# grep EE /var/log/Xorg.0.log
(II) Loading extension MIT-SCREEN-SAVER
Tu confirmes que tu peux ouvrir une session graphique avec windowmaker ?
Montre un peu ton xorg.conf: $cat /etc/X11/xorg.conf
Oui je fait clic droit et j’ai les menus qui marche
server:~# cat /etc/X11/xorg.conf
xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Je ne pense pas que tu ais installé les drivers prorio de ta carte graphique. Tu n’as donc pas l’accélération 3D (que renvoie $ glxinfo | grep direct), mais ça ne devrait pas bloquer le lancement de kde. Le pb doit être ailleurs.
On va essayer modifier un peu ton xorg.conf. Mais avt, on le copie pour garder l’original:
et ajoute à /etc/X11/xorg.conf:
Section "Device" Identifier "Builtin Default vesa Device 0" Driver "vesa" EndSection
Et réessaye.
Si ça ne marche pas, on installera les drivers proprio de ta ATI.
Re ,
Voila : # xorg.conf (X.Org X Window System server configuration file)
package.
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Device"
EndSection
Section "Monitor"
EndSection
Section "Screen"
EndSection
Section "Device"
Driver "vesa"
EndSection
Mais toujours rien …
Toujours rien, c’est à dire: t’as redémarré X ou l’ordi, et t’as quoi comme erreur qd t’essayes de lancer kde ?
Ba rien j’ai l’écran avec l’image debian bleu après le login c’est tout .
Ok.
Redonne moi stp #grep EE /var/log/Xorg.0.log
puis $dpkg -l |grep kde
et enfin $apt-cache policy kdebase
C’est bizarre, t’es en stable, t’as le driver vesa, kde devrait se lancer…quels scripts as-tu rajouté au démarrage (tu parlais de ça au début) ?
re ,
server:~# dpkg -l |grep kde
rc atlantikdesigner 4:3.5.9-2 gme board designer for Atlantik
ii kde-i18n-fr 4:3.5.10-2 Fench (fr) internationalized (i18n) files for KDE
ii kdeadmin 4:3.5.9-2 sstem administration tools from the official KDE release
ii kdeadmin-kfile-plugins 4:3.5.9-2 KE file metainfo plugins for deb and rpm files
ii kdeartwork 4:3.5.9-3 temes, styles and more from the official KDE release
ii kdeartwork-emoticons 4:3.5.9-3 eoticon collections for KDE chat clients
ii kdeartwork-misc 4:3.5.9-3 vrious multimedia goodies released with KDE
ii kdeartwork-style 4:3.5.9-3 wdget styles released with KDE
ii kdeartwork-theme-icon 4:3.5.9-3 ion themes released with KDE
ii kdeartwork-theme-window 4:3.5.9-3 wndow decoration themes released with KDE
ii kdebase-bin 4:3.5.9.dfsg.1-6+lenny1 cre binaries for the KDE base module
ii kdebase-bin-kde3 4:3.5.9.dfsg.1-6+lenny1 cre binaries for the KDE base module
ii kdebase-data 4:3.5.9.dfsg.1-6+lenny1 sared data files for the KDE base module
ii kdebase-kio-plugins 4:3.5.9.dfsg.1-6+lenny1 cre I/O slaves for KDE
ii kdeeject 4:3.5.9.dfsg.1-6+lenny1 sript used by KDE to eject removable media
ii kdegraphics 4:3.5.9-3+lenny3 gaphics apps from the official KDE release
ii kdegraphics-kfile-plugins 4:3.5.9-3+lenny3 KE metainfo plugins for graphic files
ii kdelibs-data 4:3.5.10.dfsg.1-0lenny4 cre shared data for all KDE applications
ii kdelibs4c2a 4:3.5.10.dfsg.1-0lenny4 cre libraries and binaries for all KDE applications
ii kdelirc 4:3.5.9-2 ifrared control for KDE
ii kdemultimedia 4:3.5.9-2 mltimedia apps from the official KDE release
ii kdemultimedia-kappfinder-data 4:3.5.9-2 mltimedia data for kappfinder
ii kdemultimedia-kfile-plugins 4:3.5.9-2 a/avi/m3u/mp3/ogg/wav plugins for kfile
ii kdemultimedia-kio-plugins 4:3.5.9-2 eables the browsing of audio CDs under Konqueror
rc kdepasswd 4:3.5.9.dfsg.1-6+lenny1 pssword changer for KDE
ii kdepim 4:3.5.9-5 Prsonal Information Management apps from the official KDE rel
ii kdepim-kfile-plugins 4:3.5.9-5 KE File dialog plugins for palm and vcf files
ii kdepim-kio-plugins 4:3.5.9-5 KE pim I/O Slaves
ii kdepim-kresources 4:3.5.9-5 KE pim resource plugins
ii kdepim-wizards 4:3.5.9-5 KE server configuration wizards
rc kdeprint 4:3.5.9.dfsg.1-6+lenny1 pint system for KDE
ii kdesktop 4:3.5.9.dfsg.1-6+lenny1 mscellaneous binaries and files for the KDE desktop
ii kdessh 4:3.5.9-2 sh frontend for KDE
ii kdesudo 2.4-1.1 sdo frontend for KDE
ii kdeutils 4:3.5.9-2 gneral purpose utilities from the official KDE release
ii kdewallpapers 4:3.5.9-3 wllpapers released with KDE
rc libkdeedu3 4:3.5.9-2 lbrary for use with KDE educational apps
rc libkdegames1 4:3.5.10-1 KE games library and common files
ii libkdepim1a 4:3.5.9-5 KE PIM library
ii liblockdev1 1.0.3-1.2+b1 Rn-time shared library for locking devices
rc network-manager-kde 1:0.2.2-2 KE systray applet for controlling NetworkManager
ii openoffice.org-kde 1:2.4.1+dfsg-1+lenny7 KE Integration for OpenOffice.org (Widgets, Dialogs, Addressb
server:~# apt-cache policy kdebase
kdebase:
Installé : (aucun)
Candidat : 4:3.5.9.dfsg.1-6+lenny1
Table de version :
4:3.5.9.dfsg.1-6+lenny1 0
500 security.debian.org lenny/updates/main Packages
4:3.5.9.dfsg.1-6 0
500 cdrom://[Debian GNU/Linux 5.0.4 Lenny - Official i386 kde-CD Binary-1 20100131-19:55] lenny/main Packages
500 ftp.fr.debian.org lenny/main Packages
script : iptables
on supprime tous
iptables -P INPUT DROP
iptables -P OUTPUT DROP
iptables -P FORWARD DROP
#on autorise le mumble
iptables -A INPUT -p udp --dport 64739 -j ACCEPT
iptables -A INPUT -p tcp --dport 64739 -j ACCEPT
iptables -A OUTPUT -p udp --dport 64739 -j ACCEPT
iptables -A OUTPUT -p tcp --dport 64739 -j ACCEPT
#on autorise ssh
iptables -A INPUT -p tcp -i eth0 --dport 22 -j ACCEPT
iptables -A OUTPUT -p tcp -o eth0 --sport 22 -j ACCEPT
iptables -A INPUT -i lo -j ACCEPT
iptables -A OUTPUT -o lo -j ACCEPT
On permet toutes les connexions sur le LAN depuis le firewall
iptables -A INPUT -i eth0 -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -A OUTPUT -o eth0 -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
#on autorise les pings
iptables -A OUTPUT -p icmp -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
iptables -A INPUT -p icmp -j ACCEPT
script pour lancer un logiciel au démarrage:
#!/bin/sh
su admin -c /home/murmur/clone/murmur.x86 ;
echo “Le fichier c’est bien exécuter”
exit 0
gné ? T’as pas kdebase d’installé ?
Bah installe déjà celui là: #aptitude install kdebase
Et réessaye. Il manque peut-être d’autres paquets…à vérifier.
[edit]t’as pas kdelibs d’installé non plus: #aptitude install kdelibs. Mais comment t’as installé kde ?[/edit]
J’ai installer KDE avec le cd au moment de l’installation .
étrange. Bon, installe déjà les 2 paquets cités au-dessus, et réessaye.
Re ,
Sa marche très bien aucun message d’erreur ou autre ! il y a d’autre paquet a installer ou pas ? sinon merci de ton aide :038 bravo
Merci encore !!
la base de kde 3.5 c’est:
* qt : la boîte à objets graphiques utilisés par toutes les applications KDE.
* arts : le serveur de son utilisé par toutes les applications KDE.
* kdelibs : les bibliothèques partagées qui sont nécessaires à toutes les applications KDE.
* kdebase : la console (kconsole), le centre de contrôle (kcontrol), la barre des tâches (kicker) et le gestionnaire de fichiers (konqueror).
Et les paquets optionnels:
* kdeaccessibility : divers programmes d’accessibilité tels qu’un synthétiseur de voix.
* kdeaddons : divers plugins pour kate, kicker, knewsTicker, konqueror et noatun.
* kdeadmin : des programmes d’administration du système.
* kdeartwork : des wallpapers, thèmes, styles et sons additionnels.
* kdebindings : divers bindings pour d’autres langues, y compris Java, Perl, Python …
* kdeedu : des programmes éducatifs et amusants pour les plus jeunes utilisateurs.
* kdegames : divers jeux comme kmahjongg, ksnake, kasteroids, et kpatience.
* kdegraphics : divers programmes graphiques comme le lecteur de PS, le lecteur de DVI et un programme de dessin.
* kdemultimedia : des applications multimédia comme kscd, noatun et kmix.
* kdenetwork : des applications pour le réseau comme Kopete, KGet.
* kdepim : des outils de gestion d’informations personnelles comme kmail, knode.
* kdesdk : des outils et des applications pour developper KDE.
* kdetoys : des jouets.
* kdeutils : divers outils comme kcalc, kwrite, kate.
* kdevelop : un IDE pour KDE et QT.
* kdewebdev : des applications de developpement web tel Quanta.
(trouvé sur trustonme)
Au fait, je serais toi, je reprendrais l’ancien xorg.conf qui utilise les drivers libres de ton ati, voir si ça marche.
et passe en résolu le topic.
