[quote=“fluo”]Connecte toi à ton serveur smtp en tapant telnet localhost 25.
Puis après la réponse 220 localhost ESMTP Postfix (Debian/GNU) ,
tapes :
STARTTLS
pour la réponse. Et s’il y a erreur, posts les logs.[/quote]
heure de connexion = 19:07 (+/- 1mn)
220 rictux.fr ESMTP Postfix (Debian/GNU)
STARTTLS
454 4.7.0 TLS not available due to local problem
[mono]Nov 26 19:04:10 serveur postfix/smtpd[14359]: warning: TLS library problem: 14359:error:140DC002:SSL routines:SSL_CTX_use_certificate_chain_file:system lib:ssl_rsa.c:722:
Nov 26 19:04:10 serveur postfix/smtpd[14359]: connect from localhost.rictux.fr[127.0.0.1]
Nov 26 19:05:00 serveur postfix/smtpd[14359]: lost connection after CONNECT from localhost.rictux.fr[127.0.0.1]
Nov 26 19:05:00 serveur postfix/smtpd[14359]: disconnect from localhost.rictux.fr[127.0.0.1]
Nov 26 19:06:36 serveur postfix/smtpd[14359]: connect from localhost.rictux.fr[127.0.0.1]
Nov 26 19:08:32 serveur postfix/smtpd[14359]: lost connection after UNKNOWN from localhost.rictux.fr[127.0.0.1]
Nov 26 19:08:32 serveur postfix/cleanup[14362]: 0D8D51B9279: message-id=20131126180832.0D8D51B9279@rictux.fr
Nov 26 19:08:32 serveur postfix/smtpd[14359]: disconnect from localhost.rictux.fr[127.0.0.1]
Nov 26 19:08:32 serveur postfix/qmgr[14303]: 0D8D51B9279: from=double-bounce@rictux.fr, size=875, nrcpt=1 (queue active)
Nov 26 19:08:32 serveur postfix/local[14364]: 0D8D51B9279: to=ricardo@rictux.fr, orig_to=, relay=local, delay=0.19, delays=0.11/0.01/0/0.07, dsn=2.0.0, status=sent (delivered to maildir)
Nov 26 19:08:32 serveur postfix/qmgr[14303]: 0D8D51B9279: removed[/mono]
EDIT :
L’alerte est différente :
[code]Transcript of session follows.
Out: 220 rictux.fr ESMTP Postfix (Debian/GNU)
In: STARTTLS
Out: 454 4.7.0 TLS not available due to local problem
In:
Out: 500 5.5.2 Error: bad syntax
In: exit
Out: 502 5.5.2 Error: command not recognized
In: q
In: ???
In: ?
Session aborted, reason: lost connection
For other details, see the local mail logfile[/code]
