Raid 5 dégradé !
Ok, pour les logs /var/log/kern.log
Dec 26 15:49:33 raid6 kernel: [405984.975535] ata4.00: configured for UDMA/33
Dec 26 15:49:33 raid6 kernel: [405984.975566] ata4: EH complete
Dec 26 15:49:33 raid6 kernel: [405984.985738] ata4.00: exception Emask 0x50 SAct 0x80 SErr 0x400800 action 0x6 frozen
Dec 26 15:49:33 raid6 kernel: [405984.985750] ata4.00: irq_stat 0x08000000, interface fatal error
Dec 26 15:49:33 raid6 kernel: [405984.985757] ata4: SError: { HostInt Handshk }
Dec 26 15:49:33 raid6 kernel: [405984.985765] ata4.00: failed command: WRITE FPDMA QUEUED
Dec 26 15:49:33 raid6 kernel: [405984.985779] ata4.00: cmd 61/08:38:50:08:00/00:00:00:00:00/40 tag 7 ncq dma 4096 out
Dec 26 15:49:33 raid6 kernel: [405984.985779]          res 40/00:38:50:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
Dec 26 15:49:33 raid6 kernel: [405984.985786] ata4.00: status: { DRDY }
Dec 26 15:49:33 raid6 kernel: [405984.985796] ata4: hard resetting link
Dec 26 15:49:33 raid6 kernel: [405985.461619] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Dec 26 15:49:33 raid6 kernel: [405985.463333] ata4.00: configured for UDMA/33
Dec 26 15:49:33 raid6 kernel: [405985.463354] sd 3:0:0:0: [sdd] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Dec 26 15:49:33 raid6 kernel: [405985.463357] sd 3:0:0:0: [sdd] tag#7 Sense Key : Illegal Request [current]
Dec 26 15:49:33 raid6 kernel: [405985.463360] sd 3:0:0:0: [sdd] tag#7 Add. Sense: Unaligned write command
Dec 26 15:49:33 raid6 kernel: [405985.463363] sd 3:0:0:0: [sdd] tag#7 CDB: Write(10) 2a 00 00 00 08 50 00 00 08 00
Dec 26 15:49:33 raid6 kernel: [405985.463365] blk_update_request: I/O error, dev sdd, sector 2128
Dec 26 15:49:33 raid6 kernel: [405985.463375] blk_update_request: I/O error, dev sdd, sector 2128
Dec 26 15:49:33 raid6 kernel: [405985.463377] md: super_written gets error=-5
Dec 26 15:49:33 raid6 kernel: [405985.463382] md/raid:md127: Disk failure on sdd1, disabling device.
Dec 26 15:49:33 raid6 kernel: [405985.463382] md/raid:md127: Operation continuing on 2 devices.
Dec 26 15:49:33 raid6 kernel: [405985.463421] ata4: EH complete
Je n’arrive pas a interpréter les logs
erreur I/O c’est pas bon ça :confused:
“interface fatal error”, "ATA bus error"
On dirait que c’est lié à la liaison SATA. Donc le port de la carte mère ou le câble. Est-ce qu’il y a un autre port SATA libre pour brancher le disque ?
Arf, donc mon 1er disque était bon … (il va finir en spare) et ça explique
root@raid6:/home/raid6# mdadm --manage --add /dev/md127 /dev/sdd1
mdadm: Cannot open /dev/sdd1: Device or resource busy
Non je n’ai plus de place. J’ai 6 port au total et ils sont tous utilisés je vais changer de câble sata et l’alim du dd et surtout le brancher sur un autre port, es que il existe un logiciel comme memtest mais pour les connexion sata ?
A moins de tomber sur deux disques défectueux coup sur coup… Mais la probabilité que le défaut provienne d’un facteur commun est plus grande.
Je ne vois pas ce qui peut occuper la partition. Elle est bien marquée sortie du RAID ? Des messages dans les logs du noyau ?
Si tu n’as pas de port libre, ça veut dire que tu vas brancher un autre disque sur le port suspect, ce qui peut avoir des conséquences.
Par exemple si tu y branches un autre disque du RAID 5 et qu’il se fait éjecter avant la fin de la reconstruction, tu perds le RAID entier.
Je ne connais pas de logiciel pour tester les ports SATA, juste les disques (badblocks).
C’est a dire sortie du raid ? Une commande pour vérifier ?
Si je branche un disque qui n’est pas en raid le seul problème que je peu avoir c’est la perte de connexion et des erreur i/o ?
Je viens de faire la manip’ et l’attribution /dev/sdX ne se fait pas par l’UUID !? mon disque qui était en sdd et maintenant il est en sdc !
Donc un mdadm --manage --add /dev/md127 /dev/sdc1 et la grappe se reconstruit, je ne dois pas retirer sdd1 de mdadm ou il détecte qu’il n’est plus utilisé ?
root@raid6:/home/raid6# cat /proc/mdstat
Personalities : [raid6] [raid5] [raid4] [linear] [multipath] [raid0] [raid1] [raid10]
md127 : active raid5 sdc1[4] sdf1[3] sdb1[1]
      1953260544 blocks super 1.2 level 5, 512k chunk, algorithm 2 [3/2] [_UU]
      [===>.................]  recovery = 18.7% (183251516/976630272) finish=102.0min speed=129620K/sec
      bitmap: 6/8 pages [24KB], 65536KB chunk
unused devices: <none>
Les numéros en [4,3,1] correspond a quoi ?
cat /proc/mdstat
mdadm --detail /dev/md127
« Le seul problème » ? Un disque qui ne répond plus ça peut quand même faire planter le système ou les applications en cours, corrompre les systèmes de fichiers montés depuis ce disque ! Il faut espérer que l’erreur n’est que transitoire.
Pas du tout. Quand on dit que l’utilisation des UUID sert à se prémunir des changements de noms intempestifs, ça ne veut pas dire que ça les empêche mais que ces changements sont sans incidence.
Généralement, l’ordre de nommage dépend des ports, mais ce n’est pas systématique.
Il n’y a rien à retirer, le nouveau /dev/sdd1 n’est pas membre du RAID comme tu peux le constater dans /proc/mdstat.
Ce sont les numéros des membres dans l’ensemble RAID. Chaque « nouveau » membre aura un nouveau numéro, y compris si c’est un ancien membre éjecté puis réintégré et resynchronisé. A ne pas confondre avec le rôle d’un disque actif qui décrit sa position dans l’ensemble RAID. Lorsqu’on remplace un disque actif, le nouveau a un nouveau numéro mais reprend le même rôle.
Dans la sortie de mdadm --detail, la colonne « Number » contient les numéros et la colonne « RaidDevice » contient les rôles.
Bonne année !
Bon je crois que c’est la carte maman qui est entrain de me lâcher :open_mouth:
Le raid a perdu un autre disque sdb, je l’ai ré-assembler et 40 minutes plus tard il avait quitter le raid et changer de lettre sdg !
Je vais changer de cm pour voir …
Bonne année.
Ce disque est branché sur quel port ? Celui sur lequel était branché le disque qui sautait ou encore un autre ?
Dans les suspects facteurs communs, il y a aussi l’alimentation du PC. J’ai eu beaucop plus de pannes d’alimentations que de cartes mères.
Effectivement c’était le port sata, j’ai inversé les disque et c’est le disque connecté sur le port en question qui était sortie de la grappe.
l’alim c’est une corsair vs 450 avec 6 disque + asrock 960 gc (celle qui bug) je l’ai remplacé par une intel D510MO donc je ne pense pas que ça soit l’alim.
Pour être honnête un support de fixation(en métal) a glissé et il a probablement fait un cour circuit sur les socket ram, je m’en suis rendu compte en démontant la cm il y a quelques semaines.
Vu qu’elle avait redémarrer sans problèmes je ne me suis pas posé de questions.
Tu sais donc ce qu’il te reste à faire pour éviter les ennuis : condamner ce port SATA défectueux.
Sur un support de barrette de RAM ou sur une barrette de RAM ?
Un court-circuit avec les contacts du du support de RAM, qui sont à l’intérieur du connecteur, me semble peu probable. Et surtout, je ne vois comment cela pourrait avoir causé la défaillance d’un port SATA en particulier. Il n’y a pas de liaison directe entre la RAM et les ports SATA.
voila comment j’ai retrouver la petite pièce sur les pin de la ram !
Sinon je déterre ce topic car avec la même machine mais plus la même config ( passage a un raid5 avec 3 disque de 2To) je me retrouve avec des disque qui sortent de la grappe ! le disque sortie est tout neuf ! je l’ai remonter dans le raid après avoir changer son port sata. La reconstruction c’est faite très rapidement (même pas 20 minutes).
C’est une carte mère compatible am2/am3 et j’ai suffisamment de ram en ddr2 et pas forcément l’envie de changer de carte mère (surtout que c’est difficile d’en trouver en ddr2) !
J’ai donc mis en place une alerte mail (et en plus un renvoi des mail vers sms pour être plus réactif !) cependant je n’ai pas reçu le premier mail de fail de disque, j’ai reboot et la reconstruction a été envoyer mais pas quand elle était terminé …
Donc visiblement les port sata commence a partir en vrille :confused: existe t-il un logiciel comme memetest pour tester la qualité des port sata>disque ?
Qu’es qu’il me reste comme solution : rajouter une carte pci sata ? (j’en ai une noname qui a 2 port sata mais des débit pas top).
Je pense que tes ports SATA n’ont pas de problème,
vu que c’est au niveau de la RAM que le court-cirtcuit s’est produit.
Vu que le court-circuit concernait les soudures des contacts d’un support de barrettes RAM,
tu devrais faire un memtest sur ta machine en y installant qu’une seule barrette RAM à la fois
et en recommençant le memtest après avoir déplacé la barrette sur chaque support.
S’il y a un problème, il sera vite détecté, tu n’aura pas besoin d’attendre de faire tous les tests,
mais teste quand même chaque barrette indépendamment des autres, au cas où…
Il se peut que tu ais une barette RAM HS ou/et quelques ports I/O du contrôleur de gestion RAM HS
En faisant ce test, tu devrais arriver à déterminer la barrette RAM qui est HS
ou/et le connecteur RAM dont certains ports I/O sont HS.
Avec un peu de chance, ce ne sera qu’une barrette RAM HS.
Avec un peu moins de chance, ce sera une barrette RAM+ quelques ports d’un buffer I/O du contrôleur de RAM
Avec beaucoup moins de chance, ce sera le circuit de contrôle de la RAM, et là, malheureusement…
Mais je ne crois pas trop à cette dernière hypothèse , car il y a la plupart du temps des circuits électroniques intermédiaires entre la barrette et le circuit électronique contrôleur, et c’est ce circuit intermédiaire (buffer I/O) qui a sans doute pas supporté (ou pas) le court-circuit ou/et la barrette RAM qui était sur le connecteur concerné.
J’ai fait des memetest avec plusieurs barrettes et aucuns problèmes, es que ça peut entraîner des problèmes au niveau des port sata ? Quel log regarder pour avoir l’info ?
edit:
Comme expliqué plus haut j’ai changer de port sata et il vient encore de passer en (F) !
un bout de dmesg :
[   21.565042] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[   25.698894] ip_tables: (C) 2000-2006 Netfilter Core Team
[  187.960817] md: recovery of RAID array md126
[  730.527076] perf: interrupt took too long (2528 2500), lowering kernel.perf_event_max_sample_rate to 79000
[ 1022.283666] perf: interrupt took too long (3215 3160), lowering kernel.perf_event_max_sample_rate to 62000
[ 1174.370465] md: md126: recovery done.
[ 5740.362307] perf: interrupt took too long (4034 4018), lowering kernel.perf_event_max_sample_rate to 49500
[25857.968592] ata3.00: exception Emask 0x50 SAct 0x40000007 SErr 0x480800 action 0x6 frozen
[25857.968599] ata3.00: irq_stat 0x08000000, interface fatal error
[25857.968603] ata3: SError: { HostInt 10B8B Handshk }
[25857.968607] ata3.00: failed command: WRITE FPDMA QUEUED
[25857.968613] ata3.00: cmd 61/00:00:00:4c:26/04:00:dd:00:00/40 tag 0 ncq dma 524288 out
                        res 40/00:00:00:4c:26/00:00:dd:00:00/40 Emask 0x50 (ATA bus error)
[25857.968616] ata3.00: status: { DRDY }
[25857.968618] ata3.00: failed command: WRITE FPDMA QUEUED
[25857.968623] ata3.00: cmd 61/00:08:00:50:26/04:00:dd:00:00/40 tag 1 ncq dma 524288 out
[25857.968625] ata3.00: status: { DRDY }
[25857.968627] ata3.00: failed command: WRITE FPDMA QUEUED
[25857.968632] ata3.00: cmd 61/00:10:00:54:26/04:00:dd:00:00/40 tag 2 ncq dma 524288 out
[25857.968634] ata3.00: status: { DRDY }
[25857.968636] ata3.00: failed command: WRITE FPDMA QUEUED
[25857.968641] ata3.00: cmd 61/00:f0:00:48:26/04:00:dd:00:00/40 tag 30 ncq dma 524288 out
[25857.968643] ata3.00: status: { DRDY }
[25857.968648] ata3: hard resetting link
[25858.444550] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[25858.446236] ata3.00: configured for UDMA/133
[25858.446274] ata3: EH complete
[25858.450340] ata3.00: exception Emask 0x50 SAct 0x1c0 SErr 0x400800 action 0x6 frozen
[25858.450349] ata3.00: irq_stat 0x08000000, interface fatal error
[25858.450354] ata3: SError: { HostInt Handshk }
[25858.450359] ata3.00: failed command: WRITE FPDMA QUEUED
[25858.450368] ata3.00: cmd 61/00:30:00:54:26/04:00:dd:00:00/40 tag 6 ncq dma 524288 out
                        res 40/00:40:00:4c:26/00:00:dd:00:00/40 Emask 0x50 (ATA bus error)
[25858.450373] ata3.00: status: { DRDY }
[25858.450377] ata3.00: failed command: WRITE FPDMA QUEUED
[25858.450385] ata3.00: cmd 61/00:38:00:50:26/04:00:dd:00:00/40 tag 7 ncq dma 524288 out
[25858.450389] ata3.00: status: { DRDY }
[25858.450392] ata3.00: failed command: WRITE FPDMA QUEUED
[25858.450400] ata3.00: cmd 61/00:40:00:4c:26/04:00:dd:00:00/40 tag 8 ncq dma 524288 out
[25858.450404] ata3.00: status: { DRDY }
[25858.450409] ata3: hard resetting link
[25858.920582] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[25858.922407] ata3.00: configured for UDMA/133
[25858.922458] ata3: EH complete
[25958.822667] ata3.00: exception Emask 0x50 SAct 0x74000 SErr 0x400800 action 0x6 frozen
[25958.822681] ata3.00: irq_stat 0x08000000, interface fatal error
[25958.822690] ata3: SError: { HostInt Handshk }
[25958.822699] ata3.00: failed command: READ FPDMA QUEUED
[25958.822716] ata3.00: cmd 60/08:70:28:2b:e6/00:00:d7:00:00/40 tag 14 ncq dma 4096 in
                        res 40/00:90:00:44:78/00:00:5f:00:00/40 Emask 0x50 (ATA bus error)
[25958.822725] ata3.00: status: { DRDY }
[25958.822732] ata3.00: failed command: WRITE FPDMA QUEUED
[25958.822747] ata3.00: cmd 61/00:80:00:3c:78/04:00:5f:00:00/40 tag 16 ncq dma 524288 out
[25958.822754] ata3.00: status: { DRDY }
[25958.822760] ata3.00: failed command: WRITE FPDMA QUEUED
[25958.822775] ata3.00: cmd 61/00:88:00:40:78/04:00:5f:00:00/40 tag 17 ncq dma 524288 out
[25958.822782] ata3.00: status: { DRDY }
[25958.822788] ata3.00: failed command: WRITE FPDMA QUEUED
[25958.822802] ata3.00: cmd 61/00:90:00:44:78/04:00:5f:00:00/40 tag 18 ncq dma 524288 out
[25958.822809] ata3.00: status: { DRDY }
[25958.822821] ata3: hard resetting link
[25959.298651] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[25959.301071] ata3.00: configured for UDMA/133
[25959.301129] ata3: EH complete
[26102.835864] ata3: limiting SATA link speed to 1.5 Gbps
[26102.835869] ata3.00: exception Emask 0x50 SAct 0x4400000 SErr 0x400800 action 0x6 frozen
[26102.835875] ata3.00: irq_stat 0x08000000, interface fatal error
[26102.835878] ata3: SError: { HostInt Handshk }
[26102.835882] ata3.00: failed command: READ FPDMA QUEUED
[26102.835888] ata3.00: cmd 60/08:b0:e0:16:e6/00:00:d7:00:00/40 tag 22 ncq dma 4096 in
                        res 40/00:d0:00:04:27/00:00:dd:00:00/40 Emask 0x50 (ATA bus error)
[26102.835891] ata3.00: status: { DRDY }
[26102.835894] ata3.00: failed command: WRITE FPDMA QUEUED
[26102.835899] ata3.00: cmd 61/00:d0:00:04:27/04:00:dd:00:00/40 tag 26 ncq dma 524288 out
[26102.835901] ata3.00: status: { DRDY }
[26102.835907] ata3: hard resetting link
[26103.311907] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26103.313781] ata3.00: configured for UDMA/133
[26103.313823] ata3: EH complete
[26103.314123] ata3.00: exception Emask 0x50 SAct 0x30000000 SErr 0x400800 action 0x6 frozen
[26103.314134] ata3.00: irq_stat 0x08000000, interface fatal error
[26103.314142] ata3: SError: { HostInt Handshk }
[26103.314151] ata3.00: failed command: WRITE FPDMA QUEUED
[26103.314169] ata3.00: cmd 61/00:e0:00:04:27/04:00:dd:00:00/40 tag 28 ncq dma 524288 out
                        res 40/00:e8:e0:16:e6/00:00:d7:00:00/40 Emask 0x50 (ATA bus error)
[26103.314178] ata3.00: status: { DRDY }
[26103.314184] ata3.00: failed command: READ FPDMA QUEUED
[26103.314200] ata3.00: cmd 60/08:e8:e0:16:e6/00:00:d7:00:00/40 tag 29 ncq dma 4096 in
[26103.314208] ata3.00: status: { DRDY }
[26103.314217] ata3: hard resetting link
[26103.791878] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26103.793682] ata3.00: configured for UDMA/133
[26103.793721] ata3: EH complete
[26103.794703] ata3.00: exception Emask 0x50 SAct 0xc SErr 0x400800 action 0x6 frozen
[26103.794715] ata3.00: irq_stat 0x08000000, interface fatal error
[26103.794723] ata3: SError: { HostInt Handshk }
[26103.794732] ata3.00: failed command: READ FPDMA QUEUED
[26103.794749] ata3.00: cmd 60/08:10:e0:16:e6/00:00:d7:00:00/40 tag 2 ncq dma 4096 in
                        res 40/00:18:00:04:27/00:00:dd:00:00/40 Emask 0x50 (ATA bus error)
[26103.794758] ata3.00: status: { DRDY }
[26103.794765] ata3.00: failed command: WRITE FPDMA QUEUED
[26103.794780] ata3.00: cmd 61/00:18:00:04:27/04:00:dd:00:00/40 tag 3 ncq dma 524288 out
[26103.794788] ata3.00: status: { DRDY }
[26103.794798] ata3: hard resetting link
[26104.271857] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26104.273619] ata3.00: configured for UDMA/133
[26104.273648] ata3: EH complete
[26104.273896] ata3.00: exception Emask 0x50 SAct 0xc0 SErr 0x400801 action 0x6 frozen
[26104.273902] ata3.00: irq_stat 0x08000000, interface fatal error
[26104.273907] ata3: SError: { RecovData HostInt Handshk }
[26104.273912] ata3.00: failed command: WRITE FPDMA QUEUED
[26104.273922] ata3.00: cmd 61/00:30:00:04:27/04:00:dd:00:00/40 tag 6 ncq dma 524288 out
                        res 40/00:38:e0:16:e6/00:00:d7:00:00/40 Emask 0x50 (ATA bus error)
[26104.273926] ata3.00: status: { DRDY }
[26104.273930] ata3.00: failed command: READ FPDMA QUEUED
[26104.273938] ata3.00: cmd 60/08:38:e0:16:e6/00:00:d7:00:00/40 tag 7 ncq dma 4096 in
[26104.273942] ata3.00: status: { DRDY }
[26104.273948] ata3: hard resetting link
[26104.747871] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26104.749400] ata3.00: configured for UDMA/133
[26104.749443] ata3: EH complete
[26104.751373] ata3.00: limiting speed to UDMA/100:PIO4
[26104.751378] ata3.00: exception Emask 0x50 SAct 0x1000000 SErr 0x400800 action 0x6 frozen
[26104.751384] ata3.00: irq_stat 0x08000000, interface fatal error
[26104.751388] ata3: SError: { HostInt Handshk }
[26104.751392] ata3.00: failed command: WRITE FPDMA QUEUED
[26104.751398] ata3.00: cmd 61/00:c0:00:04:27/04:00:dd:00:00/40 tag 24 ncq dma 524288 out
                        res 40/00:c0:00:04:27/00:00:dd:00:00/40 Emask 0x50 (ATA bus error)
[26104.751401] ata3.00: status: { DRDY }
[26104.751406] ata3: hard resetting link
[26105.227781] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26105.229235] ata3.00: configured for UDMA/100
[26105.229258] ata3: EH complete
[26105.229494] ata3.00: exception Emask 0x50 SAct 0x10000000 SErr 0x400800 action 0x6 frozen
[26105.229499] ata3.00: irq_stat 0x08000000, interface fatal error
[26105.229501] ata3: SError: { HostInt Handshk }
[26105.229505] ata3.00: failed command: WRITE FPDMA QUEUED
[26105.229511] ata3.00: cmd 61/00:e0:00:04:27/04:00:dd:00:00/40 tag 28 ncq dma 524288 out
                        res 40/00:e0:00:04:27/00:00:dd:00:00/40 Emask 0x50 (ATA bus error)
[26105.229514] ata3.00: status: { DRDY }
[26105.229518] ata3: hard resetting link
[26105.703872] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26105.706258] ata3.00: configured for UDMA/100
[26105.706327] sd 2:0:0:0: [sdc] tag#28 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[26105.706331] sd 2:0:0:0: [sdc] tag#28 Sense Key : Illegal Request [current]
[26105.706335] sd 2:0:0:0: [sdc] tag#28 Add. Sense: Unaligned write command
[26105.706340] sd 2:0:0:0: [sdc] tag#28 CDB: Write(10) 2a 00 dd 27 04 00 00 04 00 00
[26105.706342] print_req_error: I/O error, dev sdc, sector 3710321664
[26105.706461] ata3: EH complete
[26105.716023] ata3.00: limiting speed to UDMA/33:PIO4
[26105.716036] ata3.00: exception Emask 0x50 SAct 0x100 SErr 0x400800 action 0x6 frozen
[26105.716045] ata3.00: irq_stat 0x08000000, interface fatal error
[26105.716050] ata3: SError: { HostInt Handshk }
[26105.716059] ata3.00: failed command: WRITE FPDMA QUEUED
[26105.716070] ata3.00: cmd 61/08:40:10:08:00/00:00:00:00:00/40 tag 8 ncq dma 4096 out
                        res 40/00:40:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[26105.716075] ata3.00: status: { DRDY }
[26105.716089] ata3: hard resetting link
[26106.191829] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26106.193668] ata3.00: configured for UDMA/33
[26106.193693] ata3: EH complete
[26106.193920] ata3.00: exception Emask 0x50 SAct 0x40000 SErr 0x400800 action 0x6 frozen
[26106.193930] ata3.00: irq_stat 0x08000000, interface fatal error
[26106.193939] ata3: SError: { HostInt Handshk }
[26106.193949] ata3.00: failed command: WRITE FPDMA QUEUED
[26106.193967] ata3.00: cmd 61/08:90:10:08:00/00:00:00:00:00/40 tag 18 ncq dma 4096 out
                        res 40/00:90:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[26106.193975] ata3.00: status: { DRDY }
[26106.193985] ata3: hard resetting link
[26106.671781] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26106.673346] ata3.00: configured for UDMA/33
[26106.673363] ata3: EH complete
[26106.673567] ata3.00: exception Emask 0x50 SAct 0x200000 SErr 0x400800 action 0x6 frozen
[26106.673572] ata3.00: irq_stat 0x08000000, interface fatal error
[26106.673575] ata3: SError: { HostInt Handshk }
[26106.673579] ata3.00: failed command: WRITE FPDMA QUEUED
[26106.673586] ata3.00: cmd 61/08:a8:10:08:00/00:00:00:00:00/40 tag 21 ncq dma 4096 out
                        res 40/00:a8:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[26106.673590] ata3.00: status: { DRDY }
[26106.673594] ata3: hard resetting link
[26107.147840] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26107.149702] ata3.00: configured for UDMA/33
[26107.149738] ata3: EH complete
[26107.150002] ata3.00: exception Emask 0x50 SAct 0x40 SErr 0x400801 action 0x6 frozen
[26107.150014] ata3.00: irq_stat 0x08000000, interface fatal error
[26107.150023] ata3: SError: { RecovData HostInt Handshk }
[26107.150032] ata3.00: failed command: WRITE FPDMA QUEUED
[26107.150049] ata3.00: cmd 61/08:30:10:08:00/00:00:00:00:00/40 tag 6 ncq dma 4096 out
                        res 40/00:30:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[26107.150058] ata3.00: status: { DRDY }
[26107.150069] ata3: hard resetting link
[26107.627945] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26107.629405] ata3.00: configured for UDMA/33
[26107.629429] ata3: EH complete
[26107.629642] ata3.00: exception Emask 0x50 SAct 0x200 SErr 0x400800 action 0x6 frozen
[26107.629647] ata3.00: irq_stat 0x08000000, interface fatal error
[26107.629650] ata3: SError: { HostInt Handshk }
[26107.629654] ata3.00: failed command: WRITE FPDMA QUEUED
[26107.629660] ata3.00: cmd 61/08:48:10:08:00/00:00:00:00:00/40 tag 9 ncq dma 4096 out
                        res 40/00:48:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[26107.629662] ata3.00: status: { DRDY }
[26107.629667] ata3: hard resetting link
[26108.103746] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26108.105217] ata3.00: configured for UDMA/33
[26108.105240] ata3: EH complete
[26108.105450] ata3.00: exception Emask 0x50 SAct 0x2000 SErr 0x400800 action 0x6 frozen
[26108.105455] ata3.00: irq_stat 0x08000000, interface fatal error
[26108.105458] ata3: SError: { HostInt Handshk }
[26108.105462] ata3.00: failed command: WRITE FPDMA QUEUED
[26108.105468] ata3.00: cmd 61/08:68:10:08:00/00:00:00:00:00/40 tag 13 ncq dma 4096 out
                        res 40/00:68:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[26108.105470] ata3.00: status: { DRDY }
[26108.105474] ata3: hard resetting link
[26108.575757] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[26108.577302] ata3.00: configured for UDMA/33
[26108.577338] sd 2:0:0:0: [sdc] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[26108.577346] sd 2:0:0:0: [sdc] tag#13 Sense Key : Illegal Request [current]
[26108.577353] sd 2:0:0:0: [sdc] tag#13 Add. Sense: Unaligned write command
[26108.577360] sd 2:0:0:0: [sdc] tag#13 CDB: Write(10) 2a 00 00 00 08 10 00 00 08 00
[26108.577364] print_req_error: I/O error, dev sdc, sector 2064
[26108.577386] print_req_error: I/O error, dev sdc, sector 2064
[26108.577392] md: super_written gets error=10
[26108.577403] md/raid:md126: Disk failure on sdc1, disabling device.
               md/raid:md126: Operation continuing on 2 devices.
[26108.577455] ata3: EH complete
[33154.778553] md: recovery of RAID array md126
[33154.789552] ata3.00: exception Emask 0x50 SAct 0x4000 SErr 0x400801 action 0x6 frozen
[33154.789559] ata3.00: irq_stat 0x08000000, interface fatal error
[33154.789563] ata3: SError: { RecovData HostInt Handshk }
[33154.789566] ata3.00: failed command: WRITE FPDMA QUEUED
[33154.789572] ata3.00: cmd 61/08:70:10:08:00/00:00:00:00:00/40 tag 14 ncq dma 4096 out
                        res 40/00:70:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[33154.789575] ata3.00: status: { DRDY }
[33154.789580] ata3: hard resetting link
[33155.264949] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[33155.266680] ata3.00: configured for UDMA/33
[33155.266720] ata3: EH complete
[33155.266980] ata3.00: exception Emask 0x50 SAct 0x10000 SErr 0x400800 action 0x6 frozen
[33155.266992] ata3.00: irq_stat 0x08000000, interface fatal error
[33155.267000] ata3: SError: { HostInt Handshk }
[33155.267009] ata3.00: failed command: WRITE FPDMA QUEUED
[33155.267027] ata3.00: cmd 61/08:80:10:08:00/00:00:00:00:00/40 tag 16 ncq dma 4096 out
                        res 40/00:80:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[33155.267036] ata3.00: status: { DRDY }
[33155.267045] ata3: hard resetting link
[33155.736923] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[33155.738558] ata3.00: configured for UDMA/33
[33155.738587] ata3: EH complete
[33155.738829] ata3.00: exception Emask 0x50 SAct 0x100000 SErr 0x400800 action 0x6 frozen
[33155.738836] ata3.00: irq_stat 0x08000000, interface fatal error
[33155.738839] ata3: SError: { HostInt Handshk }
[33155.738844] ata3.00: failed command: WRITE FPDMA QUEUED
[33155.738851] ata3.00: cmd 61/08:a0:10:08:00/00:00:00:00:00/40 tag 20 ncq dma 4096 out
                        res 40/00:a0:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[33155.738855] ata3.00: status: { DRDY }
[33155.738860] ata3: hard resetting link
[33156.212928] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[33156.215114] ata3.00: configured for UDMA/33
[33156.215150] ata3: EH complete
[33156.215393] ata3.00: exception Emask 0x50 SAct 0x800000 SErr 0x400800 action 0x6 frozen
[33156.215403] ata3.00: irq_stat 0x08000000, interface fatal error
[33156.215411] ata3: SError: { HostInt Handshk }
[33156.215420] ata3.00: failed command: WRITE FPDMA QUEUED
[33156.215437] ata3.00: cmd 61/08:b8:10:08:00/00:00:00:00:00/40 tag 23 ncq dma 4096 out
                        res 40/00:b8:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[33156.215445] ata3.00: status: { DRDY }
[33156.215456] ata3: hard resetting link
[33156.697032] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[33156.698749] ata3.00: configured for UDMA/33
[33156.698796] ata3: EH complete
[33156.699058] ata3.00: exception Emask 0x50 SAct 0x1 SErr 0x400800 action 0x6 frozen
[33156.699068] ata3.00: irq_stat 0x08000000, interface fatal error
[33156.699077] ata3: SError: { HostInt Handshk }
[33156.699087] ata3.00: failed command: WRITE FPDMA QUEUED
[33156.699104] ata3.00: cmd 61/08:00:10:08:00/00:00:00:00:00/40 tag 0 ncq dma 4096 out
                        res 40/00:00:10:08:00/00:00:00:00:00/40 Emask 0x50 (ATA bus error)
[33156.699113] ata3.00: status: { DRDY }
[33156.699123] ata3: hard resetting link
[33157.173159] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[33157.175476] ata3.00: configured for UDMA/33
[33157.175527] ata3: EH complete
[33157.176004] ata3.00: exception Emask 0x50 SAct 0x100 SErr 0x400800 action 0x6 frozen
[33157.176014] ata3.00: irq_stat 0x08000000, interface fatal error
[33157.176020] ata3: SError: { HostInt Handshk }
[33157.176028] ata3.00: failed command: WRITE FPDMA QUEUED
[33157.176035] ata3.00: cmd 61/08:40:10:08:00/00:00:00:00:00/40 tag 8 ncq dma 4096 out
[33157.176039] ata3.00: status: { DRDY }
[33157.176102] ata3: hard resetting link
[33157.648921] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[33157.650777] ata3.00: configured for UDMA/33
[33157.650816] sd 2:0:0:0: [sdc] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[33157.650824] sd 2:0:0:0: [sdc] tag#8 Sense Key : Illegal Request [current]
[33157.650831] sd 2:0:0:0: [sdc] tag#8 Add. Sense: Unaligned write command
[33157.650839] sd 2:0:0:0: [sdc] tag#8 CDB: Write(10) 2a 00 00 00 08 10 00 00 08 00
[33157.650843] print_req_error: I/O error, dev sdc, sector 2064
[33157.650865] print_req_error: I/O error, dev sdc, sector 2064
[33157.650871] md: super_written gets error=10
[33157.650882] md/raid:md126: Disk failure on sdc1, disabling device.
[33157.650996] ata3: EH complete
[33157.752811] md: md126: recovery interrupted.
root@raid7:/home/raid7#
J’ai essayer de ré-ajouter le disque avec :
mdadm --manage --set-faulty /dev/md126 /dev/sdc1
mdadm --manage --remove /dev/md126 /dev/sdc1
mdadm --add /dev/md126 /dev/sdc1
mais ça n’a pas marché.
**ata3: hard resetting link**
sur des topic ils conseillent de changer de câble : je reboot avec un nouveau câble sata pour voir
J’ai du mal à distinguer la forme de la pièce et on dirait qu’elle est collée au circuit imprimé ? Comment est-ce possible pour du métal ? Elle ne peut pas être simplement posée et tenir dessus car il s’agit de la face inférieure de la carte mère qui est soit dessous soit verticale selon le boîter.
En tout cas, je ne vois vraiment pas le rapport entre cela et les erreurs du SATA au niveau électronique. S’il y avait des erreurs mémoire, memtest les détecterait et cela n’affecterait pas que le SATA.
@PascalHambourg
Je pense que c’est l’enrobage de la pièce métallique qui,
ayant fondu suite à la surchauffe provoquée par le passage du courant dans la pièce métallique,
a servit de colle.
Mais ce n’est que mon essai d’interprétation de l’image
qui est assez floue à ce niveau.
Ahaha c’est pas collé sur le circuit je l’avais reposé la pour la photo (car c’est comme ça que je l’avais retrouvé) : c’est un petit support qui permet de mettre les vis de la cm sur la tôle.
Bon depuis le changement de cable pas eu d’erreur mais c’est pas dis que ça soit ça non plus …
Je répète ma question : comment diable cette pièce tenait-elle contre la face inférieure de la carte mère qui est soit verticale, soit orientée vers le bas ? Coincée entre la carte mère et la plaque de fond du boîtier (j’ai eu une vis comme ça une fois) ?
cette pièce permet de pouvoir visser la cm sur la tole : c’est la jonction entre les deux : tole > piece qui s’emboîte dedans > cm > vis.
J’ai du oublier de viser une vis dessus et la pièce a dû glisser vue que la cm est verticale.
Je ne connaissais pas ce type de fixation. Si je comprends bien, cela joue le rôle d’une entretoise ou d’un espaceur, en moins bien. Les entretoises sont vissées à la tôle et ne risquent pas de bouger si on ne met pas de vis dessus, et les espaceurs sont en matière plastique.
Oui c’est ça :
sauf que c’est en métal :confused:
