C’est ma faute, j’ai mal lui ta ligne
Et si ça coince
$ mkisofs -o /home/chris/save.iso -v -R -J home/chris/Save
$ wodim -v speed=1 dev=/dev/hdc /home/chris/save.iso
en deux étapes donc
Et si ça coince
en deux étapes donc
Première étape, pas de problèmes.
Par contre, la deuxième :
wodim: No write mode specified.
wodim: Asuming -tao mode.
wodim: Future versions of wodim may have different drive dependent defaults.
TOC Type: 1 = CD-ROM
scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Wodim version: 1.1.6
SCSI buffer size: 64512
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'LITE-ON '
Identification : 'DVDRW SHW-16H5S '
Revision : 'LS0R'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x002B (DVD+R/DL)
Profile: 0x001B (DVD+R)
Profile: 0x001A (DVD+RW)
Profile: 0x0016 (DVD-R/DL layer jump recording)
Profile: 0x0015 (DVD-R/DL sequential recording)
Profile: 0x0014 (DVD-RW sequential recording) (current)
Profile: 0x0013 (DVD-RW restricted overwrite) (current)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0010 (DVD-ROM)
Profile: 0x000A (CD-RW)
Profile: 0x0009 (CD-R)
Profile: 0x0008 (CD-ROM)
Using generic SCSI-3/mmc DVD-R(W) driver (mmc_mdvd).
Driver flags : SWABAUDIO BURNFREE
Supported modes: PACKET SAO
Drive buf size : 1182464 = 1154 KB
Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
communication breaks or freezes immediately after that.
FIFO size : 12582912 = 12288 KB
Track 01: data 758 MB
Total size: 871 MB (86:17.60) = 388320 sectors
Lout start: 871 MB (86:19/45) = 388320 sectors
Current Secsize: 2048
HINT: use dvd+rw-mediainfo from dvd+rw-tools for information extraction.
Blocks total: 2297888 Blocks current: 2297888 Blocks remaining: 1909568
Speed set to 2770 KB/s
Starting to write CD/DVD at speed 2.0 in real unknown mode for single session.
Last chance to quit, starting real write i 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Errno: 0 (Success), reserve track scsi sendcmd: no error
CDB: 53 00 00 00 00 00 05 EC E0 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 2C 00 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x2C Qual 0x00 (command sequence error) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.004s timeout 40s
wodim: Cannot open new session.
Writing time: 0.041s
wodim: fifo had 192 puts and 0 gets.
wodim: fifo was 0 times empty and 0 times full, min fill was 100%.
Hum «cmd finished after 0.004s timeout 40s
wodim: Cannot open new session.»
Ton DVD est vierge?
Pour éviter de cramer un DVD pour rien, rajoute -dummy dans les options à wodim, ça fera comme si ça gravait un DVD mais sans le faire réellement.
[quote=“fran.b”]Hum «cmd finished after 0.004s timeout 40s
Ton DVD est vierge?[/quote]
En théorie, oui c’est un “RW” sur lequel je fais un :growisofs -Z /dev/hdc=/dev/zero
Pour éviter de cramer un DVD pour rien, rajoute -dummy dans les options à wodim, ça fera comme si ça gravait un DVD mais sans le faire réellement.[/quote]
Mais ca ne grave rien, la procédure se lance, le graveur est en mode “gravure” mais y’a rien dessus … et aucuns messages d’erreurs !!!
debian:/home/chris/Documents# growisofs -dvd-compat -Z /dev/hdc -J -R /home/chris/Save/
Executing 'genisoimage -J -R /home/chris/Save/ | builtin_dd of=/dev/hdc obs=32k seek=0'
I: -input-charset not specified, using utf-8 (detected in locale settings)
genisoimage: Unexpected joliet directory length 234 expected: 238 ''
/dev/hdc: "Current Write Speed" is 2.0x1352KBps.
0.60% done, estimate finish Sat Dec 15 18:38:47 2007
1.20% done, estimate finish Sat Dec 15 18:36:02 2007
1.80% done, estimate finish Sat Dec 15 18:36:02 2007
............ je passe les autres lignes ..............
99.55% done, estimate finish Sat Dec 15 18:35:19 2007
Total translation table size: 0
Total rockridge attributes bytes: 1243
Total directory bytes: 6752
Path table size(bytes): 54
Max brk space used 0
833725 extents written (1628 MB)
builtin_dd: 833728*2KB out @ average 2.0x1352KBps
/dev/hdc: flushing cache
/dev/hdc: reloading tray
Ok ca fonctionne maintenant :smt003 .
Donc j’ai dans 1° temps fais un growisofs -Z /dev/hdc=/dev/zero
ensuite j’ai gravé par la commande : growisofs -Z /dev/hdc -J -R /home/chris/Save/
Celle-ci permet de ré-écrire par-dessus des données déjà écrite sur le DVD-RW.
Reste à me faire un petit script pour automatiser tout ca
Merci pour l’aide apportée et le temps passé ![]()
Pour effacer:
wodim dev=/dev/hdc blank=all
(ou blank=fast si tu es pressé)
Je reviens à la charge, car à la mano y’a aucuns problèmes, mais lancer par la crontab, il se passe rien …
la crontab :
26 12 * * * sh /home/chris/Documents/grav_save.sh
Le script :
Précise le path en entête du fichier, ne met pas sh mais /bin/sh, rajoute à la fin “> /var/log/out.log 2>&1”, termine le crontab par une ligne vide.
De cette façon ? :
Si tel est le cas, ca ne fonctionne pas .
Il y a quelque chose dans le /var/log/out.log ??
Par ailleurs, précise le PATH ou met les chemins complets dans ton script grave.sh.
Oui, ceci :
:-( /dev/hdc: media is not recognized as recordable DVD: 0
[quote=“fran.b”]
Par ailleurs, précise le PATH ou met les chemins complets dans ton script grave.sh.[/quote]
Tu avais mis un DVD dans /dev/hdc?? Parce que le script s’est éxécuté mais n’a pas trouvé de DVD…
Oui, je viens recommencer, pareil…
La crontab, à qui appartient-elle? Le script est lancé par root?
root et root
mes autres script fonctionnent dans la même config, il n’y à que celui là…
Et si tu mets
directement dans la crontab, ça donne quoi?
Marche pas non plus !
et quand tu tapes directement la commande, tout va bien?!!??
Oui, et même parfaitement d’ailleur …
Essaye en rajoutant l’option
dans ta ligne de commande.
