De retour, j’avais éteint et donc après un rallumage :smt002 , j’ai recherché encore dans le dmesg et j’ai trouvé ça à la fin :
Je crois comprendre que côté routeur, ça fonctionne
mais pour le reste, il parle de firmware problématique :
J’essaie le changement dont tu parles _ ==> -
[quote]80.984455] iwlagn 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 80.984594] iwlagn 0000:04:00.0: restoring config space at offset 0x1 (was 0x100102, writing 0x100106)
[ 80.984685] iwlagn 0000:04:00.0: irq 4345 for MSI/MSI-X
[ 80.984747] iwlagn 0000:04:00.0: firmware: requesting iwlwifi-5000-1.ucode
[ 81.003421] iwlagn: iwlwifi-5000-1.ucode firmware file req failed: Reason -2
[ 81.003489] iwlagn: Could not read microcode: -2
[ 81.003589] iwlagn 0000:04:00.0: PCI INT A disabled
[ 81.004144] tg3 0000:08:00.0: irq 4345 for MSI/MSI-X
[ 81.169787] iwlagn 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 81.169933] iwlagn 0000:04:00.0: restoring config space at offset 0x1 (was 0x100102, writing 0x100106)
[ 81.170025] iwlagn 0000:04:00.0: irq 4344 for MSI/MSI-X
[ 81.170084] iwlagn 0000:04:00.0: firmware: requesting iwlwifi-5000-1.ucode
[ 81.173217] iwlagn: iwlwifi-5000-1.ucode firmware file req failed: Reason -2
[ 81.173285] iwlagn: Could not read microcode: -2
[ 81.173380] iwlagn 0000:04:00.0: PCI INT A disabled
[ 82.707452] tg3: eth0: Link is up at 100 Mbps, full duplex.
[ 82.707516] tg3: eth0: Flow control is off for TX and off for RX.
[ 85.404466] NET: Registered protocol family 10
[ 85.404903] lo: Disabled Privacy Extensions
[ 95.472100] eth0: no IPv6 routers present
[ 143.756826] iwlagn 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 143.756964] iwlagn 0000:04:00.0: restoring config space at offset 0x1 (was 0x100102, writing 0x100106)
[ 143.757071] iwlagn 0000:04:00.0: irq 4344 for MSI/MSI-X
[ 143.757127] iwlagn 0000:04:00.0: firmware: requesting iwlwifi-5000-1.ucode
[ 143.760341] iwlagn: iwlwifi-5000-1.ucode firmware file req failed: Reason -2
[ 143.760408] iwlagn: Could not read microcode: -2
[ 143.760506] iwlagn 0000:04:00.0: PCI INT A disabled
lol c’est ce que j’avais dit depuis le tout debut
c’est un probleme de firmware il te faut (juste) installer le firmware
mais perso je sais pas ou le trouver
[quote=“Junichirô”]Je croyais que c’était une broadcom. Apparemment, ça l’air plus compliqué; mais j’ai trouvé cela: http://wiki.debian.org/iwlagn
Il semble qu’il faille un kernel 2.6.27 ou 28.
Bon, il est 9h1/4, je vais manger.[/quote]
Voilà ce que je donnais comme lien dès la première page du fil.
Oui, excuse-moi de ne pas avoir cité l’auteur de la trouvaille mais c’est en relisant tout que je suis retombé sur ton post.
Voilà, rendu à Cesar :smt002
Voila, y’a des mots que je comprends mais dont je connais pas la traduction exacte, j’ai fait au mieux, d’autres corrigeront si j’ai pas totalement bon. Mais c’est pas de l’anglais tres technique et super complique je trouve, d’habitude j’ai bien plus de mal sur les tutos linux.
size=50 Oui, je sais, c’est pas comme ca que je vais t’apprendre a pecher. [/size]
pas de problème pour la pêche, il y a 60 ans, je tenais ma première canne. :smt002
merci pour la traduction, j’avais à peu près compris la même chose mais en 1/4 heure de lecture.
Je vais attendre l’avis de Fran pour ne pas faire quelque chose d’inutile.
[quote] -s, --simulate
En mode ligne de commande, affiche la liste des actions qui seraient réalisées, mais ne les lance pas réellement. Il nest pas
nécessaire davoir les privilèges dadministration. Dans linterface visuelle, ouvre toujours le cache en mode lecture seule
que vous soyez administrateur ou non.
OK, je lance ça cet AM.
Pour l’instant, je me fais chier avec la MAJ de NVIDIA sur le P4 avec le noyau 2.6.28.
Y trouve pas les headers.
C’est une autre histoire et sans importance car ça fonctionne quand m^ avec le 2.6.26.
