quote="Yannou90"
Pour l’utilisateur courant
En root pour root …
(…)[/quote]
C’est visiblement en root que je backup :
pi@Rasppy ~ $ crontab -e
no crontab for pi - using an empty one
No modification made
Et via root, j’ai modifié ainsi donc :
[code]
Edit this file to introduce tasks to be run by cron.
Each task to run has to be defined through a single line
indicating with different fields when the task will be run
and what command to run for the task
To define the time you can provide concrete values for
minute (m), hour (h), day of month (dom), month (mon),
and day of week (dow) or use ‘*’ in these fields (for ‘any’).#
Notice that tasks will be started based on the cron’s system
daemon’s notion of time and timezones.
Output of the crontab jobs (including errors) is sent through
email to the user the crontab file belongs to (unless redirected).
For example, you can run a backup of all your user accounts
at 5 a.m every week with:
0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
For more information see the manual pages of crontab(5) and cron(8)
m h dom mon dow command
30 2 * * 1 /home/pi/runSDCardBackup.sh[/code]
Cela s’activera automatiquement, aucun besoin de relancer un truc ?
