Système : jessie redémarre aléatoirement
Voici les fichiers de log suite au redémarrage de la machine. rmq : le reboot intempestif à eu lieu à 16h42. puis j'ai attendu (sur l'invit de Luks -full disk encryption with luks-) quelques temps (~1h45) avant de finaliser le boot (ce qui explique des valeurs temporelles proches de ~6277 sec au lieu des valeurs proches de 0 comme habituellement). et l'arrivée sur le bureau a eu lieu vers 18h26 **a) /var/log/Xorg.0.log**
[  6277.440]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[  6277.440] X Protocol Version 11, Revision 0
[  6277.440] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[  6277.440] Current Operating System: Linux machine 4.7.0-0.bpo.1-amd64 #1 SMP Debian 4.7.8-1~bpo8+1 (2016-10-19) x86_64
[  6277.440] Kernel command line: BOOT_IMAGE=/vmlinuz-4.7.0-0.bpo.1-amd64 root=/dev/mapper/machine--vg-root ro quiet
[  6277.440] Build Date: 11 February 2015  12:32:02AM
[  6277.440] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[  6277.440] Current version of pixman: 0.32.6
[  6277.441]     Before reporting problems, check http://wiki.x.org
[  6277.441] Markers: (--) probed, (**) from config file, (==) default setting,
[  6277.441] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 17 18:26:38 2016
[  6277.458] (==) Using config file: "/etc/X11/xorg.conf"
[  6277.458] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  6277.480] (==) ServerLayout "Layout0"
[  6277.480] (**) |-->Screen "Screen0" (0)
[  6277.480] (**) |   |-->Monitor "Monitor0"
[  6277.496] (**) |   |-->Device "Device0"
[  6277.496] (**) |-->Input Device "Keyboard0"
[  6277.496] (**) |-->Input Device "Mouse0"
[  6277.496] (==) Automatically adding devices
[  6277.496] (==) Automatically enabling devices
[  6277.496] (==) Automatically adding GPU devices
[  6277.530] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[  6277.530]     Entry deleted from font path.
[  6277.532] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    /usr/share/fonts/X11/Type1,
    /usr/share/fonts/X11/100dpi,
    /usr/share/fonts/X11/75dpi,
    built-ins
[  6277.532] (==) ModulePath set to "/usr/lib/xorg/modules"
[  6277.532] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  6277.532] (WW) Disabling Keyboard0
[  6277.532] (WW) Disabling Mouse0
[  6277.532] (II) Loader magic: 0x557bea259d80
[  6277.532] (II) Module ABI versions:
[  6277.532]     X.Org ANSI C Emulation: 0.4
[  6277.532]     X.Org Video Driver: 18.0
[  6277.532]     X.Org XInput driver : 21.0
[  6277.532]     X.Org Server Extension : 8.0
[  6277.533] (II) xfree86: Adding drm device (/dev/dri/card0)
[  6277.534] (--) PCI:*(0:2:0:0) 10de:1380:1043:84dd rev 162, Mem @ 0xe2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00009000/128, BIOS @ 0x????????/131072
[  6277.534] (II) LoadModule: "glx"
[  6277.557] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[  6278.313] (II) Module glx: vendor="NVIDIA Corporation"
[  6278.313]     compiled for 4.0.2, module version = 1.0.0
[  6278.313]     Module class: X.Org Server Extension
[  6278.319] (II) NVIDIA GLX Module  367.57  Mon Oct  3 20:28:17 PDT 2016
[  6278.328] (II) LoadModule: "nvidia"
[  6278.339] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  6278.408] (II) Module nvidia: vendor="NVIDIA Corporation"
[  6278.408]     compiled for 4.0.2, module version = 1.0.0
[  6278.408]     Module class: X.Org Video Driver
[  6278.414] (II) NVIDIA dlloader X Driver  367.57  Mon Oct  3 20:03:48 PDT 2016
[  6278.414] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  6278.415] (++) using VT number 7
[  6278.415] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[  6278.415] (WW) xf86OpenConsole: setsid failed: Operation not permitted
[  6278.450] (II) Loading sub module "fb"
[  6278.450] (II) LoadModule: "fb"
[  6278.450] (II) Loading /usr/lib/xorg/modules/libfb.so
[  6278.456] (II) Module fb: vendor="X.Org Foundation"
[  6278.456]     compiled for 1.16.4, module version = 1.0.0
[  6278.456]     ABI class: X.Org ANSI C Emulation, version 0.4
[  6278.456] (II) Loading sub module "wfb"
[  6278.456] (II) LoadModule: "wfb"
[  6278.456] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  6278.468] (II) Module wfb: vendor="X.Org Foundation"
[  6278.468]     compiled for 1.16.4, module version = 1.0.0
[  6278.468]     ABI class: X.Org ANSI C Emulation, version 0.4
[  6278.468] (II) Loading sub module "ramdac"
[  6278.468] (II) LoadModule: "ramdac"
[  6278.468] (II) Module "ramdac" already built-in
[  6278.485] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  6278.485] (==) NVIDIA(0): RGB weight 888
[  6278.485] (==) NVIDIA(0): Default visual is TrueColor
[  6278.485] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  6278.487] (**) NVIDIA(0): Enabling 2D acceleration
[  6279.230] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[  6279.230] (--) NVIDIA(0):     CRT-0
[  6279.230] (--) NVIDIA(0):     DFP-0
[  6279.230] (--) NVIDIA(0):     DFP-1
[  6279.230] (--) NVIDIA(0):     DFP-2
[  6279.230] (--) NVIDIA(0):     DFP-3 (boot)
[  6279.232] (--) NVIDIA(0): CRT-0: disconnected
[  6279.232] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[  6279.235] (--) NVIDIA(0): DFP-0: disconnected
[  6279.235] (--) NVIDIA(0): DFP-0: Internal TMDS
[  6279.235] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[  6279.235] (--) NVIDIA(0): DFP-1: disconnected
[  6279.235] (--) NVIDIA(0): DFP-1: Internal TMDS
[  6279.235] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[  6279.236] (--) NVIDIA(0): DFP-2: disconnected
[  6279.236] (--) NVIDIA(0): DFP-2: Internal TMDS
[  6279.236] (--) NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
[  6279.237] (--) NVIDIA(0): DELL U2713HM (DFP-3): connected
[  6279.237] (--) NVIDIA(0): DELL U2713HM (DFP-3): Internal DisplayPort
[  6279.237] (--) NVIDIA(0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
[  6279.238] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 750 Ti (GM107-A) at PCI:2:0:0 (GPU-0)
[  6279.238] (--) NVIDIA(0): Memory: 2097152 kBytes
[  6279.238] (--) NVIDIA(0): VideoBIOS: 82.07.55.00.34
[  6279.238] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  6279.238] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[  6279.238] (**) NVIDIA(0):     device DELL U2713HM (DFP-3) (Using EDID frequencies has
[  6279.238] (**) NVIDIA(0):     been enabled on all display devices.)
[  6279.242] (==) NVIDIA(0):
[  6279.242] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[  6279.242] (==) NVIDIA(0):     will be used as the requested mode.
[  6279.259] (II) NVIDIA(0): Validated MetaModes:
[  6279.259] (II) NVIDIA(0):     "DFP-3:nvidia-auto-select"
[  6279.259] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1440
[  6279.287] (--) NVIDIA(0): DPI set to (108, 107); computed from "UseEdidDpi" X config
[  6279.287] (--) NVIDIA(0):     option
[  6279.287] (--) Depth 24 pixmap format is 32 bpp
[  6279.288] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[  6279.288] (II) NVIDIA:     access.
[  6279.343] (II) NVIDIA(0): Setting mode "DFP-3:nvidia-auto-select"
[  6279.434] (==) NVIDIA(0): Disabling shared memory pixmaps
[  6279.434] (==) NVIDIA(0): Backing store enabled
[  6279.434] (==) NVIDIA(0): Silken mouse enabled
[  6279.437] (**) NVIDIA(0): DPMS enabled
[  6279.437] (II) Loading sub module "dri2"
[  6279.437] (II) LoadModule: "dri2"
[  6279.438] (II) Module "dri2" already built-in
[  6279.438] (II) NVIDIA(0): [DRI2] Setup complete
[  6279.438] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  6279.441] (--) RandR disabled
[  6279.449] (II) SELinux: Disabled on system
[  6279.450] (II) Initializing extension GLX
[  6279.451] (II) Indirect GLX disabled.
[  6279.769] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[  6279.769] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  6279.769] (II) LoadModule: "evdev"
[  6279.769] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[  6279.791] (II) Module evdev: vendor="X.Org Foundation"
[  6279.791]     compiled for 1.16.0, module version = 2.9.0
[  6279.791]     Module class: X.Org XInput Driver
[  6279.791]     ABI class: X.Org XInput driver, version 21.0
[  6279.791] (II) Using input driver 'evdev' for 'Power Button'
[  6279.791] (**) Power Button: always reports core events
[  6279.791] (**) evdev: Power Button: Device: "/dev/input/event5"
[  6279.791] (--) evdev: Power Button: Vendor 0 Product 0x1
[  6279.791] (--) evdev: Power Button: Found keys
[  6279.791] (II) evdev: Power Button: Configuring as keyboard
[  6279.791] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input8/event5"
[  6279.791] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  6279.791] (**) Option "xkb_rules" "evdev"
[  6279.791] (**) Option "xkb_model" "pc105"
[  6279.791] (**) Option "xkb_layout" "fr"
[  6279.791] (**) Option "xkb_variant" "latin9"
[  6279.825] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[  6279.825] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  6279.825] (II) Using input driver 'evdev' for 'Power Button'
[  6279.825] (**) Power Button: always reports core events
[  6279.825] (**) evdev: Power Button: Device: "/dev/input/event4"
[  6279.825] (--) evdev: Power Button: Vendor 0 Product 0x1
[  6279.825] (--) evdev: Power Button: Found keys
[  6279.825] (II) evdev: Power Button: Configuring as keyboard
[  6279.825] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7/event4"
[  6279.825] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  6279.825] (**) Option "xkb_rules" "evdev"
[  6279.825] (**) Option "xkb_model" "pc105"
[  6279.825] (**) Option "xkb_layout" "fr"
[  6279.825] (**) Option "xkb_variant" "latin9"
[  6279.826] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/event2)
[  6279.826] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "evdev pointer catchall"
[  6279.826] (II) Using input driver 'evdev' for 'Logitech G500s Laser Gaming Mouse'
[  6279.826] (**) Logitech G500s Laser Gaming Mouse: always reports core events
[  6279.826] (**) evdev: Logitech G500s Laser Gaming Mouse: Device: "/dev/input/event2"
[  6279.880] (--) evdev: Logitech G500s Laser Gaming Mouse: Vendor 0x46d Product 0xc24e
[  6279.880] (--) evdev: Logitech G500s Laser Gaming Mouse: Found 20 mouse buttons
[  6279.880] (--) evdev: Logitech G500s Laser Gaming Mouse: Found scroll wheel(s)
[  6279.880] (--) evdev: Logitech G500s Laser Gaming Mouse: Found relative axes
[  6279.880] (--) evdev: Logitech G500s Laser Gaming Mouse: Found x and y relative axes
[  6279.880] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as mouse
[  6279.880] (II) evdev: Logitech G500s Laser Gaming Mouse: Adding scrollwheel support
[  6279.880] (**) evdev: Logitech G500s Laser Gaming Mouse: YAxisMapping: buttons 4 and 5
[  6279.880] (**) evdev: Logitech G500s Laser Gaming Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[  6279.880] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/usb3/3-1/3-1:1.0/0003:046D:C24E.0003/input/input5/event2"
[  6279.880] (II) XINPUT: Adding extended input device "Logitech G500s Laser Gaming Mouse" (type: MOUSE, id 8)
[  6279.880] (II) evdev: Logitech G500s Laser Gaming Mouse: initialized for relative axes.
[  6279.880] (**) Logitech G500s Laser Gaming Mouse: (accel) keeping acceleration scheme 1
[  6279.880] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration profile 0
[  6279.880] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration factor: 2.000
[  6279.880] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration threshold: 4
[  6279.880] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/mouse0)
[  6279.880] (II) No input driver specified, ignoring this device.
[  6279.880] (II) This device may have been added with another device file.
[  6279.880] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/event3)
[  6279.880] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[  6279.880] (II) Using input driver 'evdev' for 'Logitech G500s Laser Gaming Mouse'
[  6279.880] (**) Logitech G500s Laser Gaming Mouse: always reports core events
[  6279.880] (**) evdev: Logitech G500s Laser Gaming Mouse: Device: "/dev/input/event3"
[  6279.880] (--) evdev: Logitech G500s Laser Gaming Mouse: Found 1 mouse buttons
[  6279.880] (II) evdev: Logitech G500s Laser Gaming Mouse: Forcing relative x/y axes to exist.
[  6279.881] (--) evdev: Logitech G500s Laser Gaming Mouse: Found absolute axes
[  6279.881] (II) evdev: Logitech G500s Laser Gaming Mouse: Forcing absolute x/y axes to exist.
[  6279.881] (--) evdev: Logitech G500s Laser Gaming Mouse: Found keys
[  6279.881] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as mouse
[  6279.881] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as keyboard
[  6279.881] (II) evdev: Logitech G500s Laser Gaming Mouse: Adding scrollwheel support
[  6279.881] (**) evdev: Logitech G500s Laser Gaming Mouse: YAxisMapping: buttons 4 and 5
[  6279.881] (**) evdev: Logitech G500s Laser Gaming Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[  6279.881] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/usb3/3-1/3-1:1.1/0003:046D:C24E.0004/input/input6/event3"
[  6279.881] (II) XINPUT: Adding extended input device "Logitech G500s Laser Gaming Mouse" (type: KEYBOARD, id 9)
[  6279.881] (**) Option "xkb_rules" "evdev"
[  6279.881] (**) Option "xkb_model" "pc105"
[  6279.881] (**) Option "xkb_layout" "fr"
[  6279.881] (**) Option "xkb_variant" "latin9"
[  6279.881] (II) evdev: Logitech G500s Laser Gaming Mouse: initialized for relative axes.
[  6279.881] (WW) evdev: Logitech G500s Laser Gaming Mouse: ignoring absolute axes.
[  6279.881] (**) Logitech G500s Laser Gaming Mouse: (accel) keeping acceleration scheme 1
[  6279.881] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration profile 0
[  6279.881] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration factor: 2.000
[  6279.881] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration threshold: 4
[  6279.881] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event0)
[  6279.881] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[  6279.881] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
[  6279.881] (**) Logitech USB Keyboard: always reports core events
[  6279.881] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event0"
[  6279.881] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc326
[  6279.881] (--) evdev: Logitech USB Keyboard: Found keys
[  6279.881] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[  6279.881] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:06.0/usb4/4-1/4-1:1.0/0003:046D:C326.0001/input/input3/event0"
[  6279.881] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
[  6279.882] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event1)
[  6279.882] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[  6279.882] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
[  6279.882] (**) Logitech USB Keyboard: always reports core events
[  6279.882] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event1"
[  6279.882] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc326
[  6279.882] (--) evdev: Logitech USB Keyboard: Found 1 mouse buttons
[  6279.882] (--) evdev: Logitech USB Keyboard: Found scroll wheel(s)
[  6279.882] (--) evdev: Logitech USB Keyboard: Found relative axes
[  6279.882] (II) evdev: Logitech USB Keyboard: Forcing relative x/y axes to exist.
[  6279.882] (--) evdev: Logitech USB Keyboard: Found absolute axes
[  6279.882] (II) evdev: Logitech USB Keyboard: Forcing absolute x/y axes to exist.
[  6279.882] (--) evdev: Logitech USB Keyboard: Found keys
[  6279.882] (II) evdev: Logitech USB Keyboard: Configuring as mouse
[  6279.882] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[  6279.882] (II) evdev: Logitech USB Keyboard: Adding scrollwheel support
[  6279.882] (**) evdev: Logitech USB Keyboard: YAxisMapping: buttons 4 and 5
[  6279.882] (**) evdev: Logitech USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[  6279.882] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:06.0/usb4/4-1/4-1:1.1/0003:046D:C326.0002/input/input4/event1"
[  6279.882] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 11)
[  6279.882] (**) Option "xkb_rules" "evdev"
[  6279.882] (**) Option "xkb_model" "pc105"
[  6279.882] (**) Option "xkb_layout" "fr"
[  6279.882] (**) Option "xkb_variant" "latin9"
[  6279.882] (II) evdev: Logitech USB Keyboard: initialized for relative axes.
[  6279.882] (WW) evdev: Logitech USB Keyboard: ignoring absolute axes.
[  6279.882] (**) Logitech USB Keyboard: (accel) keeping acceleration scheme 1
[  6279.882] (**) Logitech USB Keyboard: (accel) acceleration profile 0
[  6279.882] (**) Logitech USB Keyboard: (accel) acceleration factor: 2.000
[  6279.882] (**) Logitech USB Keyboard: (accel) acceleration threshold: 4
[  6279.882] (II) config/udev: Adding input device HDA NVidia Rear Mic (/dev/input/event10)
[  6279.882] (II) No input driver specified, ignoring this device.
[  6279.882] (II) This device may have been added with another device file.
[  6279.883] (II) config/udev: Adding input device HDA NVidia Front Mic (/dev/input/event11)
[  6279.883] (II) No input driver specified, ignoring this device.
[  6279.883] (II) This device may have been added with another device file.
[  6279.883] (II) config/udev: Adding input device HDA NVidia Line (/dev/input/event12)
[  6279.883] (II) config/udev: Adding input device HDA NVidia Line Out Front (/dev/input/event13)
[  6279.883] (II) config/udev: Adding input device HDA NVidia Line Out Surround (/dev/input/event14)
[  6279.883] (II) config/udev: Adding input device HDA NVidia Line Out CLFE (/dev/input/event15)
[  6279.884] (II) config/udev: Adding input device HDA NVidia Line Out Side (/dev/input/event16)
[  6279.884] (II) No input driver specified, ignoring this device.
[  6279.884] (II) This device may have been added with another device file.
[  6279.884] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[  6279.884] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[  6279.884] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[  6279.884] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[  6279.888] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): connected
[  6279.888] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): Internal DisplayPort
[  6279.888] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
[  6291.288] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  6291.288] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  6291.291] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  6291.291] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  6291.291] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  6291.291] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  6291.291] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  6291.291] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  6291.292] (--) NVIDIA(GPU-0): DFP-2: disconnected
[  6291.292] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[  6291.292] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[  6291.293] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): connected
[  6291.293] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): Internal DisplayPort
[  6291.293] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
[  6291.296] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  6291.296] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  6291.298] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  6291.298] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  6291.298] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  6291.299] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  6291.299] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  6291.299] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  6291.299] (--) NVIDIA(GPU-0): DFP-2: disconnected
[  6291.299] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[  6291.299] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[  6291.300] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): connected
[  6291.300] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): Internal DisplayPort
[  6291.300] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
b) /var/log/Xorg.0.log.old
[    30.704]
[    30.704] X Protocol Version 11, Revision 0
[    30.704] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[    30.704] Current Operating System: Linux machine 4.7.0-0.bpo.1-amd64 #1 SMP Debian 4.7.8-1~bpo8+1 (2016-10-19) x86_64
[    30.704] Kernel command line: BOOT_IMAGE=/vmlinuz-4.7.0-0.bpo.1-amd64 root=/dev/mapper/machine--vg-root ro quiet
[    30.704] Build Date: 11 February 2015  12:32:02AM
[    30.704] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[    30.704] Current version of pixman: 0.32.6
[    30.704]     Before reporting problems, check http://wiki.x.org
[    30.704] Markers: (--) probed, (**) from config file, (==) default setting,
[    30.704] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 17 15:48:16 2016
[    30.722] (==) Using config file: "/etc/X11/xorg.conf"
[    30.722] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    30.744] (==) ServerLayout "Layout0"
[    30.744] (**) |-->Screen "Screen0" (0)
[    30.744] (**) |   |-->Monitor "Monitor0"
[    30.760] (**) |   |-->Device "Device0"
[    30.760] (**) |-->Input Device "Keyboard0"
[    30.760] (**) |-->Input Device "Mouse0"
[    30.760] (==) Automatically adding devices
[    30.760] (==) Automatically enabling devices
[    30.760] (==) Automatically adding GPU devices
[    30.790] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    30.790]     Entry deleted from font path.
[    30.794] (==) FontPath set to:
    built-ins
[    30.794] (==) ModulePath set to "/usr/lib/xorg/modules"
[    30.794] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    30.794] (WW) Disabling Keyboard0
[    30.794] (WW) Disabling Mouse0
[    30.794] (II) Loader magic: 0x558bb5b92d80
[    30.794] (II) Module ABI versions:
[    30.794]     X.Org ANSI C Emulation: 0.4
[    30.794]     X.Org Video Driver: 18.0
[    30.794]     X.Org XInput driver : 21.0
[    30.794]     X.Org Server Extension : 8.0
[    30.794] (II) xfree86: Adding drm device (/dev/dri/card0)
[    30.796] (--) PCI:*(0:2:0:0) 10de:1380:1043:84dd rev 162, Mem @ 0xe2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00009000/128, BIOS @ 0x????????/131072
[    30.796] (II) LoadModule: "glx"
[    30.820] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[    31.435] (II) Module glx: vendor="NVIDIA Corporation"
[    31.435]     compiled for 4.0.2, module version = 1.0.0
[    31.435]     Module class: X.Org Server Extension
[    31.441] (II) NVIDIA GLX Module  367.57  Mon Oct  3 20:28:17 PDT 2016
[    31.451] (II) LoadModule: "nvidia"
[    31.462] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    31.513] (II) Module nvidia: vendor="NVIDIA Corporation"
[    31.513]     compiled for 4.0.2, module version = 1.0.0
[    31.513]     Module class: X.Org Video Driver
[    31.520] (II) NVIDIA dlloader X Driver  367.57  Mon Oct  3 20:03:48 PDT 2016
[    31.520] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    31.521] (++) using VT number 7
[    31.521] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[    31.521] (WW) xf86OpenConsole: setsid failed: Operation not permitted
[    31.539] (II) Loading sub module "fb"
[    31.539] (II) LoadModule: "fb"
[    31.539] (II) Loading /usr/lib/xorg/modules/libfb.so
[    31.553] (II) Module fb: vendor="X.Org Foundation"
[    31.553]     compiled for 1.16.4, module version = 1.0.0
[    31.553]     ABI class: X.Org ANSI C Emulation, version 0.4
[    31.553] (II) Loading sub module "wfb"
[    31.553] (II) LoadModule: "wfb"
[    31.553] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    31.566] (II) Module wfb: vendor="X.Org Foundation"
[    31.566]     compiled for 1.16.4, module version = 1.0.0
[    31.566]     ABI class: X.Org ANSI C Emulation, version 0.4
[    31.566] (II) Loading sub module "ramdac"
[    31.566] (II) LoadModule: "ramdac"
[    31.566] (II) Module "ramdac" already built-in
[    31.578] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    31.578] (==) NVIDIA(0): RGB weight 888
[    31.578] (==) NVIDIA(0): Default visual is TrueColor
[    31.578] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    31.580] (**) NVIDIA(0): Enabling 2D acceleration
[    32.328] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[    32.328] (--) NVIDIA(0):     CRT-0
[    32.328] (--) NVIDIA(0):     DFP-0
[    32.328] (--) NVIDIA(0):     DFP-1
[    32.328] (--) NVIDIA(0):     DFP-2
[    32.328] (--) NVIDIA(0):     DFP-3 (boot)
[    32.331] (--) NVIDIA(0): CRT-0: disconnected
[    32.331] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[    32.333] (--) NVIDIA(0): DFP-0: disconnected
[    32.333] (--) NVIDIA(0): DFP-0: Internal TMDS
[    32.333] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[    32.333] (--) NVIDIA(0): DFP-1: disconnected
[    32.333] (--) NVIDIA(0): DFP-1: Internal TMDS
[    32.333] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    32.334] (--) NVIDIA(0): DFP-2: disconnected
[    32.334] (--) NVIDIA(0): DFP-2: Internal TMDS
[    32.334] (--) NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
[    32.335] (--) NVIDIA(0): DELL U2713HM (DFP-3): connected
[    32.335] (--) NVIDIA(0): DELL U2713HM (DFP-3): Internal DisplayPort
[    32.335] (--) NVIDIA(0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
[    32.336] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 750 Ti (GM107-A) at PCI:2:0:0 (GPU-0)
[    32.336] (--) NVIDIA(0): Memory: 2097152 kBytes
[    32.336] (--) NVIDIA(0): VideoBIOS: 82.07.55.00.34
[    32.336] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    32.336] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    32.336] (**) NVIDIA(0):     device DELL U2713HM (DFP-3) (Using EDID frequencies has
[    32.336] (**) NVIDIA(0):     been enabled on all display devices.)
[    32.339] (==) NVIDIA(0):
[    32.339] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    32.339] (==) NVIDIA(0):     will be used as the requested mode.
[    32.356] (II) NVIDIA(0): Validated MetaModes:
[    32.356] (II) NVIDIA(0):     "DFP-3:nvidia-auto-select"
[    32.356] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1440
[    32.376] (--) NVIDIA(0): DPI set to (108, 107); computed from "UseEdidDpi" X config
[    32.376] (--) NVIDIA(0):     option
[    32.376] (--) Depth 24 pixmap format is 32 bpp
[    32.377] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[    32.377] (II) NVIDIA:     access.
[    32.432] (II) NVIDIA(0): Setting mode "DFP-3:nvidia-auto-select"
[    32.523] (==) NVIDIA(0): Disabling shared memory pixmaps
[    32.523] (==) NVIDIA(0): Backing store enabled
[    32.523] (==) NVIDIA(0): Silken mouse enabled
[    32.525] (**) NVIDIA(0): DPMS enabled
[    32.525] (II) Loading sub module "dri2"
[    32.525] (II) LoadModule: "dri2"
[    32.525] (II) Module "dri2" already built-in
[    32.525] (II) NVIDIA(0): [DRI2] Setup complete
[    32.525] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    32.530] (--) RandR disabled
[    32.536] (II) SELinux: Disabled on system
[    32.538] (II) Initializing extension GLX
[    32.538] (II) Indirect GLX disabled.
[    32.909] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[    32.909] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    32.909] (II) LoadModule: "evdev"
[    32.909] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    32.930] (II) Module evdev: vendor="X.Org Foundation"
[    32.930]     compiled for 1.16.0, module version = 2.9.0
[    32.930]     Module class: X.Org XInput Driver
[    32.930]     ABI class: X.Org XInput driver, version 21.0
[    32.930] (II) Using input driver 'evdev' for 'Power Button'
[    32.930] (**) Power Button: always reports core events
[    32.931] (**) evdev: Power Button: Device: "/dev/input/event5"
[    32.931] (--) evdev: Power Button: Vendor 0 Product 0x1
[    32.931] (--) evdev: Power Button: Found keys
[    32.931] (II) evdev: Power Button: Configuring as keyboard
[    32.931] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input8/event5"
[    32.931] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    32.931] (**) Option "xkb_rules" "evdev"
[    32.931] (**) Option "xkb_model" "pc105"
[    32.931] (**) Option "xkb_layout" "fr"
[    32.931] (**) Option "xkb_variant" "latin9"
[    32.972] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[    32.972] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    32.972] (II) Using input driver 'evdev' for 'Power Button'
[    32.972] (**) Power Button: always reports core events
[    32.972] (**) evdev: Power Button: Device: "/dev/input/event4"
[    32.972] (--) evdev: Power Button: Vendor 0 Product 0x1
[    32.972] (--) evdev: Power Button: Found keys
[    32.972] (II) evdev: Power Button: Configuring as keyboard
[    32.972] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7/event4"
[    32.972] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    32.972] (**) Option "xkb_rules" "evdev"
[    32.972] (**) Option "xkb_model" "pc105"
[    32.972] (**) Option "xkb_layout" "fr"
[    32.972] (**) Option "xkb_variant" "latin9"
[    32.973] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/event2)
[    32.973] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "evdev pointer catchall"
[    32.973] (II) Using input driver 'evdev' for 'Logitech G500s Laser Gaming Mouse'
[    32.973] (**) Logitech G500s Laser Gaming Mouse: always reports core events
[    32.973] (**) evdev: Logitech G500s Laser Gaming Mouse: Device: "/dev/input/event2"
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Vendor 0x46d Product 0xc24e
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Found 20 mouse buttons
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Found scroll wheel(s)
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Found relative axes
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Found x and y relative axes
[    33.028] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as mouse
[    33.028] (II) evdev: Logitech G500s Laser Gaming Mouse: Adding scrollwheel support
[    33.028] (**) evdev: Logitech G500s Laser Gaming Mouse: YAxisMapping: buttons 4 and 5
[    33.028] (**) evdev: Logitech G500s Laser Gaming Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    33.028] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/usb3/3-1/3-1:1.0/0003:046D:C24E.0003/input/input5/event2"
[    33.028] (II) XINPUT: Adding extended input device "Logitech G500s Laser Gaming Mouse" (type: MOUSE, id 8)
[    33.028] (II) evdev: Logitech G500s Laser Gaming Mouse: initialized for relative axes.
[    33.028] (**) Logitech G500s Laser Gaming Mouse: (accel) keeping acceleration scheme 1
[    33.028] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration profile 0
[    33.028] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration factor: 2.000
[    33.028] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration threshold: 4
[    33.028] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/mouse0)
[    33.028] (II) No input driver specified, ignoring this device.
[    33.028] (II) This device may have been added with another device file.
[    33.028] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/event3)
[    33.028] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[    33.028] (II) Using input driver 'evdev' for 'Logitech G500s Laser Gaming Mouse'
[    33.028] (**) Logitech G500s Laser Gaming Mouse: always reports core events
[    33.028] (**) evdev: Logitech G500s Laser Gaming Mouse: Device: "/dev/input/event3"
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Found 1 mouse buttons
[    33.028] (II) evdev: Logitech G500s Laser Gaming Mouse: Forcing relative x/y axes to exist.
[    33.028] (--) evdev: Logitech G500s Laser Gaming Mouse: Found absolute axes
[    33.029] (II) evdev: Logitech G500s Laser Gaming Mouse: Forcing absolute x/y axes to exist.
[    33.029] (--) evdev: Logitech G500s Laser Gaming Mouse: Found keys
[    33.029] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as mouse
[    33.029] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as keyboard
[    33.029] (II) evdev: Logitech G500s Laser Gaming Mouse: Adding scrollwheel support
[    33.029] (**) evdev: Logitech G500s Laser Gaming Mouse: YAxisMapping: buttons 4 and 5
[    33.029] (**) evdev: Logitech G500s Laser Gaming Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    33.029] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/usb3/3-1/3-1:1.1/0003:046D:C24E.0004/input/input6/event3"
[    33.029] (II) XINPUT: Adding extended input device "Logitech G500s Laser Gaming Mouse" (type: KEYBOARD, id 9)
[    33.029] (**) Option "xkb_rules" "evdev"
[    33.029] (**) Option "xkb_model" "pc105"
[    33.029] (**) Option "xkb_layout" "fr"
[    33.029] (**) Option "xkb_variant" "latin9"
[    33.029] (II) evdev: Logitech G500s Laser Gaming Mouse: initialized for relative axes.
[    33.029] (WW) evdev: Logitech G500s Laser Gaming Mouse: ignoring absolute axes.
[    33.029] (**) Logitech G500s Laser Gaming Mouse: (accel) keeping acceleration scheme 1
[    33.029] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration profile 0
[    33.029] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration factor: 2.000
[    33.029] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration threshold: 4
[    33.029] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event0)
[    33.029] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    33.029] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
[    33.029] (**) Logitech USB Keyboard: always reports core events
[    33.029] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event0"
[    33.029] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc326
[    33.029] (--) evdev: Logitech USB Keyboard: Found keys
[    33.029] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[    33.029] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:06.0/usb4/4-1/4-1:1.0/0003:046D:C326.0001/input/input3/event0"
[    33.029] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
[    33.030] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event1)
[    33.030] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    33.030] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
[    33.030] (**) Logitech USB Keyboard: always reports core events
[    33.030] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event1"
[    33.030] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc326
[    33.030] (--) evdev: Logitech USB Keyboard: Found 1 mouse buttons
[    33.030] (--) evdev: Logitech USB Keyboard: Found scroll wheel(s)
[    33.030] (--) evdev: Logitech USB Keyboard: Found relative axes
[    33.030] (II) evdev: Logitech USB Keyboard: Forcing relative x/y axes to exist.
[    33.030] (--) evdev: Logitech USB Keyboard: Found absolute axes
[    33.030] (II) evdev: Logitech USB Keyboard: Forcing absolute x/y axes to exist.
[    33.030] (--) evdev: Logitech USB Keyboard: Found keys
[    33.030] (II) evdev: Logitech USB Keyboard: Configuring as mouse
[    33.030] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[    33.030] (II) evdev: Logitech USB Keyboard: Adding scrollwheel support
[    33.030] (**) evdev: Logitech USB Keyboard: YAxisMapping: buttons 4 and 5
[    33.030] (**) evdev: Logitech USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    33.030] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:06.0/usb4/4-1/4-1:1.1/0003:046D:C326.0002/input/input4/event1"
[    33.030] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 11)
[    33.030] (**) Option "xkb_rules" "evdev"
[    33.030] (**) Option "xkb_model" "pc105"
[    33.030] (**) Option "xkb_layout" "fr"
[    33.030] (**) Option "xkb_variant" "latin9"
[    33.030] (II) evdev: Logitech USB Keyboard: initialized for relative axes.
[    33.030] (WW) evdev: Logitech USB Keyboard: ignoring absolute axes.
[    33.030] (**) Logitech USB Keyboard: (accel) keeping acceleration scheme 1
[    33.030] (**) Logitech USB Keyboard: (accel) acceleration profile 0
[    33.030] (**) Logitech USB Keyboard: (accel) acceleration factor: 2.000
[    33.030] (**) Logitech USB Keyboard: (accel) acceleration threshold: 4
[    33.030] (II) config/udev: Adding input device HDA NVidia Rear Mic (/dev/input/event10)
[    33.030] (II) No input driver specified, ignoring this device.
[    33.030] (II) This device may have been added with another device file.
[    33.031] (II) config/udev: Adding input device HDA NVidia Front Mic (/dev/input/event11)
[    33.031] (II) No input driver specified, ignoring this device.
[    33.031] (II) This device may have been added with another device file.
[    33.031] (II) config/udev: Adding input device HDA NVidia Line (/dev/input/event12)
[    33.031] (II) config/udev: Adding input device HDA NVidia Line Out Front (/dev/input/event13)
[    33.031] (II) config/udev: Adding input device HDA NVidia Line Out Surround (/dev/input/event14)
[    33.031] (II) config/udev: Adding input device HDA NVidia Line Out CLFE (/dev/input/event15)
[    33.032] (II) config/udev: Adding input device HDA NVidia Line Out Side (/dev/input/event16)
[    33.032] (II) No input driver specified, ignoring this device.
[    33.032] (II) This device may have been added with another device file.
[    33.032] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[    33.032] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[    33.032] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[    33.032] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    33.036] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): connected
[    33.036] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): Internal DisplayPort
[    33.036] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
[   470.404] (--) NVIDIA(GPU-0): CRT-0: disconnected
[   470.404] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[   470.407] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   470.407] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   470.407] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   470.407] (--) NVIDIA(GPU-0): DFP-1: disconnected
[   470.407] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[   470.407] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[   470.407] (--) NVIDIA(GPU-0): DFP-2: disconnected
[   470.407] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[   470.407] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[   470.408] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): connected
[   470.408] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): Internal DisplayPort
[   470.408] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
[   470.411] (--) NVIDIA(GPU-0): CRT-0: disconnected
[   470.411] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[   470.414] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   470.414] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   470.414] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   470.414] (--) NVIDIA(GPU-0): DFP-1: disconnected
[   470.414] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[   470.414] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[   470.414] (--) NVIDIA(GPU-0): DFP-2: disconnected
[   470.414] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[   470.414] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[   470.415] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): connected
[   470.415] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): Internal DisplayPort
[   470.415] (--) NVIDIA(GPU-0): DELL U2713HM (DFP-3): 960.0 MHz maximum pixel clock
c) /var/log/syslog (j’ai supprimé ce qui est trop antérieur à 16h40)
Dec 17 16:02:51 machine systemd[1]: Starting Cleanup of Temporary Directories...
Dec 17 16:02:51 machine systemd[1]: Started Cleanup of Temporary Directories.
Dec 17 16:08:44 machine kernel: [ 1258.356351] Key type dns_resolver registered
Dec 17 16:08:44 machine kernel: [ 1258.407969] NFS: Registering the id_resolver key type
Dec 17 16:08:44 machine kernel: [ 1258.407984] Key type id_resolver registered
Dec 17 16:08:44 machine kernel: [ 1258.407986] Key type id_legacy registered
Dec 17 16:17:01 machine CRON[1342]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Dec 17 16:18:38 machine kernel: [ 1852.679884] perf: interrupt took too long (2512 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
Dec 17 16:26:37 machine kernel: [ 2331.563648] perf: interrupt took too long (3146 > 3140), lowering kernel.perf_event_max_sample_rate to 63500
Dec 17 16:40:44 machine kernel: [ 3178.268068] perf: interrupt took too long (3936 > 3932), lowering kernel.perf_event_max_sample_rate to 50750
Dec 17 18:26:37 machine rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="752" x-info="http://www.rsyslog.com"] start
Dec 17 18:26:38 machine kernel: [    0.000000] Linux version 4.7.0-0.bpo.1-amd64 (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP Debian 4.7.8-1~bpo8+1 (2016-10-19)
Dec 17 18:26:38 machine kernel: [    0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.7.0-0.bpo.1-amd64 root=/dev/mapper/machine--vg-root ro quiet
Dec 17 18:26:38 machine kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Dec 17 18:26:38 machine systemd-modules-load[276]: Inserted module 'coretemp'
Dec 17 18:26:38 machine kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 17 18:26:38 machine kernel: [    0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
Dec 17 18:26:38 machine kernel: [    0.000000] x86/fpu: Using 'eager' FPU context switches.
Dec 17 18:26:38 machine kernel: [    0.000000] e820: BIOS-provided physical RAM map:
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
Dec 17 18:26:38 machine systemd-modules-load[276]: Inserted module 'it87'
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bfeeffff] usable
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x00000000bfef0000-0x00000000bfef2fff] ACPI NVS
Dec 17 18:26:38 machine systemd[1]: Mounted POSIX Message Queue File System.
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x00000000bfef3000-0x00000000bfefffff] ACPI data
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000e1ffffff] reserved
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
Dec 17 18:26:38 machine systemd[1]: Mounted Huge Pages File System.
Dec 17 18:26:38 machine kernel: [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000023fffffff] usable
Dec 17 18:26:38 machine kernel: [    0.000000] NX (Execute Disable) protection: active
Dec 17 18:26:38 machine kernel: [    0.000000] SMBIOS 2.4 present.
Dec 17 18:26:38 machine systemd[1]: Mounted Debug File System.
Dec 17 18:26:38 machine kernel: [    0.000000] DMI: Gigabyte Technology Co., Ltd. GA-E7AUM-DS2H/GA-E7AUM-DS2H, BIOS F2 12/17/2008
Dec 17 18:26:38 machine kernel: [    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 17 18:26:38 machine systemd[1]: Started Create Static Device Nodes in /dev.
Dec 17 18:26:38 machine kernel: [    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 17 18:26:38 machine kernel: [    0.000000] e820: last_pfn = 0x240000 max_arch_pfn = 0x400000000
Dec 17 18:26:38 machine kernel: [    0.000000] MTRR default type: uncachable
Dec 17 18:26:38 machine kernel: [    0.000000] MTRR fixed ranges enabled:
Dec 17 18:26:38 machine kernel: [    0.000000]   00000-9FFFF write-back
Dec 17 18:26:38 machine kernel: [    0.000000]   A0000-BFFFF uncachable
Dec 17 18:26:38 machine systemd[1]: Starting udev Kernel Device Manager...
Dec 17 18:26:38 machine kernel: [    0.000000]   C0000-CDFFF write-protect
Dec 17 18:26:38 machine kernel: [    0.000000]   CE000-FFFFF uncachable
Dec 17 18:26:38 machine kernel: [    0.000000] MTRR variable ranges enabled:
Dec 17 18:26:38 machine kernel: [    0.000000]   0 base 000000000 mask F00000000 write-back
Dec 17 18:26:38 machine kernel: [    0.000000]   1 base 0C0000000 mask FC0000000 uncachable
Dec 17 18:26:38 machine kernel: [    0.000000]   2 base 100000000 mask F00000000 write-back
Dec 17 18:26:38 machine systemd[1]: Started udev Kernel Device Manager.
Dec 17 18:26:38 machine kernel: [    0.000000]   3 base 200000000 mask FC0000000 write-back
Dec 17 18:26:38 machine kernel: [    0.000000]   4 base 0BFF00000 mask FFFF00000 uncachable
Dec 17 18:26:38 machine systemd[1]: Starting LSB: Set preliminary keymap...
Dec 17 18:26:38 machine kernel: [    0.000000]   5 disabled
Dec 17 18:26:38 machine kernel: [    0.000000]   6 disabled
Dec 17 18:26:38 machine kernel: [    0.000000]   7 disabled
Dec 17 18:26:38 machine kernel: [    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
Dec 17 18:26:38 machine kernel: [    0.000000] e820: update [mem 0xbff00000-0xffffffff] usable ==> reserved
Dec 17 18:26:38 machine systemd-modules-load[276]: Inserted module 'nvidia_drm'
Dec 17 18:26:38 machine kernel: [    0.000000] e820: last_pfn = 0xbfef0 max_arch_pfn = 0x400000000
Dec 17 18:26:38 machine systemd[1]: Started Load Kernel Modules.
Dec 17 18:26:38 machine kernel: [    0.000000] found SMP MP-table at [mem 0x000f4b90-0x000f4b9f] mapped at [ffff8800000f4b90]
Dec 17 18:26:38 machine kernel: [    0.000000] Base memory trampoline at [ffff880000098000] 98000 size 24576
Dec 17 18:26:38 machine kernel: [    0.000000] BRK [0x2e74e000, 0x2e74efff] PGTABLE
Dec 17 18:26:38 machine kernel: [    0.000000] BRK [0x2e74f000, 0x2e74ffff] PGTABLE
Dec 17 18:26:38 machine kernel: [    0.000000] BRK [0x2e750000, 0x2e750fff] PGTABLE
Dec 17 18:26:38 machine systemd[1]: Mounted FUSE Control File System.
Dec 17 18:26:38 machine kernel: [    0.000000] BRK [0x2e751000, 0x2e751fff] PGTABLE
Dec 17 18:26:38 machine kernel: [    0.000000] BRK [0x2e752000, 0x2e752fff] PGTABLE
Dec 17 18:26:38 machine kernel: [    0.000000] BRK [0x2e753000, 0x2e753fff] PGTABLE
Dec 17 18:26:38 machine systemd[1]: Mounted Configuration File System.
Dec 17 18:26:38 machine kernel: [    0.000000] RAMDISK: [mem 0x35d42000-0x36e98fff]
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: Early table checksum verification disabled
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: RSDP 0x00000000000F64D0 000014 (v00 GBT   )
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: RSDT 0x00000000BFEF3040 000038 (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: FACP 0x00000000BFEF30C0 000074 (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: DSDT 0x00000000BFEF3180 0079C9 (v01 GBT    GBTUACPI 00001000 MSFT 03000000)
Dec 17 18:26:38 machine systemd[1]: Starting Apply Kernel Variables...
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: FACS 0x00000000BFEF1800 000040
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: HPET 0x00000000BFEFACC0 000038 (v01 GBT    GBTUACPI 42302E31 GBTU 00000098)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: MCFG 0x00000000BFEFAD40 00003C (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: APIC 0x00000000BFEFABC0 000098 (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: SSDT 0x00000000BFEFB6A0 0003AB (v01 PmRef  CpuPm    00003000 INTL 20040311)
Dec 17 18:26:38 machine systemd[1]: Started Apply Kernel Variables.
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: Local APIC address 0xfee00000
Dec 17 18:26:38 machine kernel: [    0.000000] No NUMA configuration found
Dec 17 18:26:38 machine kernel: [    0.000000] Faking a node at [mem 0x0000000000000000-0x000000023fffffff]
Dec 17 18:26:38 machine systemd-udevd[365]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:04.0/usb3/3-1 3 2': No such file or directory
Dec 17 18:26:38 machine kernel: [    0.000000] NODE_DATA(0) allocated [mem 0x23fff6000-0x23fffafff]
Dec 17 18:26:38 machine kernel: [    0.000000] Zone ranges:
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Dec 17 18:26:38 machine systemd-udevd[366]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:06.0/usb4/4-1 4 2': No such file or directory
Dec 17 18:26:38 machine kernel: [    0.000000]   Normal   [mem 0x0000000100000000-0x000000023fffffff]
Dec 17 18:26:38 machine kernel: [    0.000000]   Device   empty
Dec 17 18:26:38 machine kernel: [    0.000000] Movable zone start for each node
Dec 17 18:26:38 machine keyboard-setup[301]: Setting preliminary keymap...done.
Dec 17 18:26:38 machine kernel: [    0.000000] Early memory node ranges
Dec 17 18:26:38 machine kernel: [    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
Dec 17 18:26:38 machine kernel: [    0.000000]   node   0: [mem 0x0000000000100000-0x00000000bfeeffff]
Dec 17 18:26:38 machine kernel: [    0.000000]   node   0: [mem 0x0000000100000000-0x000000023fffffff]
Dec 17 18:26:38 machine systemd[1]: Started LSB: Set preliminary keymap.
Dec 17 18:26:38 machine kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000023fffffff]
Dec 17 18:26:38 machine kernel: [    0.000000] On node 0 totalpages: 2096781
Dec 17 18:26:38 machine systemd[1]: Starting Remount Root and Kernel File Systems...
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA zone: 64 pages used for memmap
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA zone: 21 pages reserved
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA zone: 3997 pages, LIFO batch:0
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA32 zone: 12220 pages used for memmap
Dec 17 18:26:38 machine systemd[1]: Found device LVM PV oZ4DBy-F1aE-uNUq-K1wc-AE1r-sBRD-ZNWULY on /dev/dm-0.
Dec 17 18:26:38 machine kernel: [    0.000000]   DMA32 zone: 782064 pages, LIFO batch:31
Dec 17 18:26:38 machine kernel: [    0.000000]   Normal zone: 20480 pages used for memmap
Dec 17 18:26:38 machine kernel: [    0.000000]   Normal zone: 1310720 pages, LIFO batch:31
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: PM-Timer IO Port: 0x1008
Dec 17 18:26:38 machine systemd[1]: Started Remount Root and Kernel File Systems.
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
Dec 17 18:26:38 machine systemd[1]: Starting Local File Systems (Pre).
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
Dec 17 18:26:38 machine kernel: [    0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 17 18:26:38 machine systemd[1]: Reached target Local File Systems (Pre).
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
Dec 17 18:26:38 machine systemd[1]: Starting system-lvm2\x2dpvscan.slice.
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: IRQ0 used by override.
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: IRQ9 used by override.
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: IRQ14 used by override.
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: IRQ15 used by override.
Dec 17 18:26:38 machine kernel: [    0.000000] Using ACPI (MADT) for SMP configuration information
Dec 17 18:26:38 machine kernel: [    0.000000] ACPI: HPET id: 0x10de8201 base: 0xfeff0000
Dec 17 18:26:38 machine kernel: [    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0xbfef0000-0xbfef2fff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0xbfef3000-0xbfefffff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0xbff00000-0xdfffffff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xe1ffffff]
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0xe2000000-0xfebfffff]
Dec 17 18:26:38 machine systemd[1]: Created slice system-lvm2\x2dpvscan.slice.
Dec 17 18:26:38 machine kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xffffffff]
Dec 17 18:26:38 machine kernel: [    0.000000] e820: [mem 0xbff00000-0xdfffffff] available for PCI devices
Dec 17 18:26:38 machine kernel: [    0.000000] Booting paravirtualized kernel on bare hardware
Dec 17 18:26:38 machine kernel: [    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
Dec 17 18:26:38 machine kernel: [    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
Dec 17 18:26:38 machine kernel: [    0.000000] percpu: Embedded 34 pages/cpu @ffff88023fc00000 s99608 r8192 d31464 u524288
Dec 17 18:26:38 machine systemd[1]: Starting LVM2 PV scan on device 254:0...
Dec 17 18:26:38 machine kernel: [    0.000000] pcpu-alloc: s99608 r8192 d31464 u524288 alloc=1*2097152
Dec 17 18:26:38 machine kernel: [    0.000000] pcpu-alloc: [0] 0 1 2 3
Dec 17 18:26:38 machine systemd[1]: Found device ST3250310AS 5.
Dec 17 18:26:38 machine systemd[1]: Starting Cryptography Setup for sda5_crypt...
Dec 17 18:26:38 machine systemd-cryptsetup[379]: Volume sda5_crypt already active.
Dec 17 18:26:38 machine systemd[1]: Started Cryptography Setup for sda5_crypt.
Dec 17 18:26:38 machine systemd[1]: Started LVM2 PV scan on device 254:0.
Dec 17 18:26:38 machine systemd[1]: Starting Sound Card.
Dec 17 18:26:38 machine systemd[1]: Reached target Sound Card.
Dec 17 18:26:38 machine systemd[1]: Found device /dev/mapper/machine--vg-home.
Dec 17 18:26:38 machine systemd[1]: Starting File System Check on /dev/mapper/machine--vg-home...
Dec 17 18:26:38 machine systemd[1]: Found device ST3250310AS 1.
Dec 17 18:26:38 machine systemd[1]: Starting File System Check on /dev/disk/by-uuid/eeed43d1-e849-4109-8e72-705f9e0accc3...
Dec 17 18:26:38 machine systemd-fsck[392]: /dev/mapper/machine--vg-home : récupération du journal
Dec 17 18:26:38 machine systemd[1]: Found device /dev/mapper/machine--vg-var.
Dec 17 18:26:38 machine systemd[1]: Starting File System Check on /dev/mapper/machine--vg-var...
Dec 17 18:26:38 machine systemd-fsck[393]: /dev/sda1 n'a pas été démonté proprement, vérification forcée.
Dec 17 18:26:38 machine systemd-fsck[397]: /dev/mapper/machine--vg-var : récupération du journal
Dec 17 18:26:38 machine kernel: [    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2063996
Dec 17 18:26:38 machine kernel: [    0.000000] Policy zone: Normal
Dec 17 18:26:38 machine systemd[1]: Found device /dev/mapper/machine--vg-tmp.
Dec 17 18:26:38 machine kernel: [    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-4.7.0-0.bpo.1-amd64 root=/dev/mapper/machine--vg-root ro quiet
Dec 17 18:26:38 machine kernel: [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Dec 17 18:26:38 machine kernel: [    0.000000] Calgary: detecting Calgary via BIOS EBDA area
Dec 17 18:26:38 machine systemd[1]: Starting File System Check on /dev/mapper/machine--vg-tmp...
Dec 17 18:26:38 machine kernel: [    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
Dec 17 18:26:38 machine kernel: [    0.000000] Memory: 8157680K/8387124K available (6032K kernel code, 1169K rwdata, 2804K rodata, 1368K init, 808K bss, 229444K reserved, 0K cma-reserved)
Dec 17 18:26:38 machine kernel: [    0.000000] Hierarchical RCU implementation.
Dec 17 18:26:38 machine kernel: [    0.000000]     Build-time adjustment of leaf fanout to 64.
Dec 17 18:26:38 machine kernel: [    0.000000]     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
Dec 17 18:26:38 machine kernel: [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
Dec 17 18:26:38 machine kernel: [    0.000000] NR_IRQS:33024 nr_irqs:456 16
Dec 17 18:26:38 machine kernel: [    0.000000] spurious 8259A interrupt: IRQ7.
Dec 17 18:26:38 machine systemd[1]: Found device /dev/mapper/machine--vg-swap_1.
Dec 17 18:26:38 machine kernel: [    0.000000] Console: colour VGA+ 80x25
Dec 17 18:26:38 machine kernel: [    0.000000] console [tty0] enabled
Dec 17 18:26:38 machine systemd[1]: Activating swap /dev/mapper/machine--vg-swap_1...
Dec 17 18:26:38 machine kernel: [    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Dec 17 18:26:38 machine kernel: [    0.000000] hpet clockevent registered
Dec 17 18:26:38 machine kernel: [    0.000000] tsc: Fast TSC calibration using PIT
Dec 17 18:26:38 machine kernel: [    0.000000] tsc: Detected 2999.981 MHz processor
Dec 17 18:26:38 machine kernel: [    0.004013] Calibrating delay loop (skipped), value calculated using timer frequency.. 5999.96 BogoMIPS (lpj=11999924)
Dec 17 18:26:38 machine systemd-fsck[401]: /dev/mapper/machine--vg-tmp : récupération du journal
Dec 17 18:26:38 machine kernel: [    0.004016] pid_max: default: 32768 minimum: 301
Dec 17 18:26:38 machine kernel: [    0.004035] ACPI: Core revision 20160422
Dec 17 18:26:38 machine kernel: [    0.013485] ACPI: 2 ACPI AML tables successfully acquired and loaded
Dec 17 18:26:38 machine systemd-fsck[401]: /dev/mapper/machine--vg-tmp : propre, 20/96256 fichiers, 22400/385024 blocs
Dec 17 18:26:38 machine kernel: [    0.013488]
Dec 17 18:26:38 machine kernel: [    0.013550] Security Framework initialized
Dec 17 18:26:38 machine kernel: [    0.013553] Yama: disabled by default; enable with sysctl kernel.yama.*
Dec 17 18:26:38 machine kernel: [    0.013563] AppArmor: AppArmor disabled by boot time parameter
Dec 17 18:26:38 machine kernel: [    0.014042] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Dec 17 18:26:38 machine systemd[1]: Started File System Check on /dev/mapper/machine--vg-tmp.
Dec 17 18:26:38 machine kernel: [    0.019047] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Dec 17 18:26:38 machine kernel: [    0.021424] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
Dec 17 18:26:38 machine kernel: [    0.021435] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
Dec 17 18:26:38 machine kernel: [    0.021943] CPU: Physical Processor ID: 0
Dec 17 18:26:38 machine kernel: [    0.021945] CPU: Processor Core ID: 0
Dec 17 18:26:38 machine kernel: [    0.021948] mce: CPU supports 6 MCE banks
Dec 17 18:26:38 machine systemd[1]: Mounting /tmp...
Dec 17 18:26:38 machine kernel: [    0.021956] CPU0: Thermal monitoring enabled (TM2)
Dec 17 18:26:38 machine kernel: [    0.021961] process: using mwait in idle threads
Dec 17 18:26:38 machine kernel: [    0.021967] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
Dec 17 18:26:38 machine systemd[1]: Activated swap /dev/mapper/machine--vg-swap_1.
Dec 17 18:26:38 machine kernel: [    0.021968] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
Dec 17 18:26:38 machine kernel: [    0.022316] Freeing SMP alternatives memory: 24K (ffffffffae67c000 - ffffffffae682000)
Dec 17 18:26:38 machine kernel: [    0.028005] ftrace: allocating 24781 entries in 97 pages
Dec 17 18:26:38 machine kernel: [    0.036084] smpboot: Max logical packages: 1
Dec 17 18:26:38 machine kernel: [    0.036086] smpboot: APIC(0) Converting physical 0 to logical package 0
Dec 17 18:26:38 machine kernel: [    0.036534] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Dec 17 18:26:38 machine systemd[1]: Starting Swap.
Dec 17 18:26:38 machine kernel: [    0.080000] smpboot: CPU0: Intel(R) Core(TM)2 Quad CPU    Q9650  @ 3.00GHz (family: 0x6, model: 0x17, stepping: 0xa)
Dec 17 18:26:38 machine kernel: [    0.080000] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.
Dec 17 18:26:38 machine kernel: [    0.080000] ... version:                2
Dec 17 18:26:38 machine kernel: [    0.080000] ... bit width:              40
Dec 17 18:26:38 machine kernel: [    0.080000] ... generic registers:      2
Dec 17 18:26:38 machine systemd[1]: Reached target Swap.
Dec 17 18:26:38 machine kernel: [    0.080000] ... value mask:             000000ffffffffff
Dec 17 18:26:38 machine systemd[1]: Mounted /tmp.
Dec 17 18:26:38 machine kernel: [    0.080000] ... max period:             000000007fffffff
Dec 17 18:26:38 machine kernel: [    0.080000] ... fixed-purpose events:   3
Dec 17 18:26:38 machine kernel: [    0.080000] ... event mask:             0000000700000003
Dec 17 18:26:38 machine kernel: [    0.080000] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
Dec 17 18:26:38 machine systemd[1]: Started udev Wait for Complete Device Initialization.
Dec 17 18:26:38 machine kernel: [    0.080000] x86: Booting SMP configuration:
Dec 17 18:26:38 machine kernel: [    0.080000] .... node  #0, CPUs:      #1 #2 #3
Dec 17 18:26:38 machine systemd[1]: Starting Activation of LVM2 logical volumes...
Dec 17 18:26:38 machine kernel: [    0.318031] x86: Booted up 1 node, 4 CPUs
Dec 17 18:26:38 machine kernel: [    0.318031] smpboot: Total of 4 processors activated (23999.43 BogoMIPS)
Dec 17 18:26:38 machine kernel: [    0.332105] devtmpfs: initialized
Dec 17 18:26:38 machine systemd[1]: Starting Copy rules generated while the root was ro...
Dec 17 18:26:38 machine kernel: [    0.332105] x86/mm: Memory block size: 128MB
Dec 17 18:26:38 machine kernel: [    0.344027] PM: Registering ACPI NVS region [mem 0xbfef0000-0xbfef2fff] (12288 bytes)
Dec 17 18:26:38 machine kernel: [    0.344121] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Dec 17 18:26:38 machine kernel: [    0.356016] pinctrl core: initialized pinctrl subsystem
Dec 17 18:26:38 machine systemd[1]: Started Copy rules generated while the root was ro.
Dec 17 18:26:38 machine kernel: [    0.368134] NET: Registered protocol family 16
Dec 17 18:26:38 machine kernel: [    0.380003] cpuidle: using governor ladder
Dec 17 18:26:38 machine kernel: [    0.388002] cpuidle: using governor menu
Dec 17 18:26:38 machine kernel: [    0.388040] ACPI: bus type PCI registered
Dec 17 18:26:38 machine kernel: [    0.388043] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 17 18:26:38 machine kernel: [    0.408083] PCI: MMCONFIG for domain 0000 [bus 00-1f] at [mem 0xe0000000-0xe1ffffff] (base 0xe0000000)
Dec 17 18:26:38 machine systemd-fsck[392]: /dev/mapper/machine--vg-home : propre, 192641/12214272 fichiers, 40641379/48827392 blocs
Dec 17 18:26:38 machine kernel: [    0.408087] PCI: MMCONFIG at [mem 0xe0000000-0xe1ffffff] reserved in E820
Dec 17 18:26:38 machine systemd[1]: Started File System Check on /dev/mapper/machine--vg-home.
Dec 17 18:26:38 machine kernel: [    0.408096] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
Dec 17 18:26:38 machine kernel: [    0.408190] PCI: Using configuration type 1 for base access
Dec 17 18:26:38 machine kernel: [    0.408464] mtrr: your CPUs had inconsistent fixed MTRR settings
Dec 17 18:26:38 machine kernel: [    0.408465] mtrr: probably your BIOS does not setup all CPUs.
Dec 17 18:26:38 machine systemd[1]: Mounting /home...
Dec 17 18:26:38 machine kernel: [    0.408466] mtrr: corrected configuration.
Dec 17 18:26:38 machine kernel: [    0.420054] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Dec 17 18:26:38 machine systemd-fsck[397]: /dev/mapper/machine--vg-var : propre, 4855/610800 fichiers, 301928/2441216 blocs
Dec 17 18:26:38 machine kernel: [    0.452082] ACPI: Added _OSI(Module Device)
Dec 17 18:26:38 machine kernel: [    0.452084] ACPI: Added _OSI(Processor Device)
Dec 17 18:26:38 machine kernel: [    0.452086] ACPI: Added _OSI(3.0 _SCP Extensions)
Dec 17 18:26:38 machine systemd[1]: Started File System Check on /dev/mapper/machine--vg-var.
Dec 17 18:26:38 machine kernel: [    0.452087] ACPI: Added _OSI(Processor Aggregator Device)
Dec 17 18:26:38 machine kernel: [    0.454500] ACPI: Dynamic OEM Table Load:
Dec 17 18:26:38 machine kernel: [    0.454506] ACPI: SSDT 0xFFFF880235C9C400 00022A (v01 PmRef  Cpu0Ist  00003000 INTL 20040311)
Dec 17 18:26:38 machine kernel: [    0.454856] ACPI: Dynamic OEM Table Load:
Dec 17 18:26:38 machine systemd[1]: Mounting /var...
Dec 17 18:26:38 machine kernel: [    0.454860] ACPI: SSDT 0xFFFF880235C92A00 000152 (v01 PmRef  Cpu1Ist  00003000 INTL 20040311)
Dec 17 18:26:38 machine kernel: [    0.455195] ACPI: Dynamic OEM Table Load:
Dec 17 18:26:38 machine kernel: [    0.455199] ACPI: SSDT 0xFFFF880235C92800 000152 (v01 PmRef  Cpu2Ist  00003000 INTL 20040311)
Dec 17 18:26:38 machine kernel: [    0.455534] ACPI: Dynamic OEM Table Load:
Dec 17 18:26:38 machine kernel: [    0.455538] ACPI: SSDT 0xFFFF880235C92600 000152 (v01 PmRef  Cpu3Ist  00003000 INTL 20040311)
Dec 17 18:26:38 machine kernel: [    0.456397] ACPI: Interpreter enabled
Dec 17 18:26:38 machine systemd[1]: Mounted /home.
Dec 17 18:26:38 machine kernel: [    0.456412] ACPI: (supports S0 S3 S4 S5)
Dec 17 18:26:38 machine kernel: [    0.456414] ACPI: Using IOAPIC for interrupt routing
Dec 17 18:26:38 machine systemd[1]: Mounted /var.
Dec 17 18:26:38 machine kernel: [    0.456434] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Dec 17 18:26:38 machine kernel: [    0.466323] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Dec 17 18:26:38 machine kernel: [    0.466330] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
Dec 17 18:26:38 machine kernel: [    0.466462] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PCIeCapability]
Dec 17 18:26:38 machine systemd[1]: Started Various fixups to make systemd work better on Debian.
Dec 17 18:26:38 machine kernel: [    0.466526] acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[ j’ai tronqué la sortie parce qu’il y a trop de caractères…]
d) les dernières lignes de /var/log/kern.log :
C’est à la fois une manière élégante et une optimisation !
Pourquoi ?
Parce que quand tu écris “cat … | grep” … tu agis en deux temps, un premier pour concaténer puis lire le fichier et le retourner en sortie vers la commande grep … qui elle même est capable de lire directement un fichier pour faire le même traitement demandé dans la première commande :wink:
En fait, en général, quand tu veux faire une recherche dans un fichier, la commande grep suffit … pas besoin de chercher à le lire autrement … et parfois, il y a des commandes bien plus puissantes, et moins gourmandes, telles que ‘awk’, ‘sed’, etc …
voici un exemple d une CM sous debian , retour de lspci (j ai de l asus ,asrock , msi en 775 )
ici c est la machine avec un Q9550 et une CM Asus P5K-VM
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 02)
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 02)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02)
00:1a.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92)
00:1f.0 ISA bridge: Intel Corporation 82801IB (ICH9) LPC Interface Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801IB (ICH9) 4 port SATA Controller [AHCI mode] (rev 02)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2)
01:00.1 Audio device: NVIDIA Corporation Device 0fbc (rev a1)
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
03:00.0 IDE interface: JMicron Technology Corp. JMB368 IDE controller
05:02.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
ma premiere question a tu ce probléme depuis l installation de debian ?
cette carte mère a tourner déja avec un autre OS ?
je pense peut etre a un probléme avec les chipsets “Nvidia” et debian
dans le bios (mode acpi )passer de S5 en S0 uniquement par exemple
supprimer toutes les options de veilles (disque dur , écran et autres dans le bios )
regarder si le mode sata est en AHCI (et pas IDE )
ps: ne pas toucher au mode acpi (sinon le pc risque de ne plus démarrer ) tu est a priori en "acpi2"
regarder si tu n a pas une mise a jour du bios disponible pour cette carte mère
ps: si le problème est apparu trés longtemps aprés l installation de debian mes remarques sont moins pertinentes
nota: voir un cpu intel sur une plate-forme nvidia …
j avoue etre a court d idées , c est une plate-forme normalement trés stable et bien pris en charge par debian
au niveau materiel tu peut aussi regarder l etat des condensateurs chimiques de la carte mère (gonflés et peut etre qui ont coulés )
voila quelques idées en vrac
lien cpu 9650 => http://ark.intel.com/fr/products/35428/Intel-Core2-Quad-Processor-Q9650-12M-Cache-3_00-GHz-1333-MHz-FSB
tu utilise de la ddr2 1333 ?
le chipset nvidia ne chauffe pas trop ? ( sur la plateforme intel il chauffe beaucoup surtout avec les quad core en 1333 ) , tu peut le vérifier avec un refroidissement externe voir si les reboot sont toujours présent
pour cette génération le chipset "nordbrige " supporte la DDR , le PCIe et le processeur .
ce qui n est plus le cas maintenant (un seul chipset et fonctionnement trés différent )
Hello,
@robert2a :
1/ j’ai ce problème depuis que j’ai installé Jessie dessus (en “fresh install”, pas en “update from wheezy”)
(une netinst dont la somme de controle est OK)
(je vais également tenter une install depuis un cd complet et pas depuis une netinst)
2/ Ce problème n’est strictement pas présent sous Wheezy.
(mais je souhaite rester sous Jessie quand même)
(enfin, quoique je pense que je vais être obligé de repasser sous wheezy)
(en tout cas, je ne souhaite pas passer en stretch ni sid)
3/ je vais checker le bios et vous tiens au courant.
4/ les options du bios relatives à la mise en veille sont déjà désactivées.
5/ le mode sata est bien en AHCI
6/ cpu intel sur plate-forme nvidia => problèmes ?
7/ pour la ram, j’utilise de la : DDR2 800MHz
7’/ ma CM est : gigabyte e7aum ds2h.
8/ j’utilise conky pour du monitoring, et toutes (cpu#, chip, socket_cpu) les températures sont honnêtes (<30°C en idle).
9/ offtopic : admettons, qu’il s’agisse d’un problème logiciel lié à Jessie.
Comment puis-je le sousmettre, vu que je n’ai pas le début de l’ombre d’une piste… (les logs sont vierges d’infos exploitables).
-> des paquets *-debug peuvent-ils être utiles ?
Une question me vient à l’esprit… tu as installé Jessie à la place de Wheezy ou bien tu l’as installé en dual-boot?
hello,
@GOGI :
il s’agit d’une installation “toute neuve” et Jessie est seule sur la machine.
(et il ne reste plus aucune de trace de wheezy car j’ai fait une install avec “full disk encrytion” (crypto root avec luks et sa phase d’écriture d’effacement / écriture aléatoire sur le disque)).
Tu as encrypté le disque entier? Quel partitionnement? As-tu utilisé LVM pour l’installation? Un moyen facile de faire un dual-boot?
Parce que si ça marchait bien avec Wheezy et que ça déconne avec Jessie, je serai tenté de te dire de réinstaller une Wheezy en dur en dual-boot, et de faire le test en les lançant une à une puis voir ce qui se passe, au moins ça écartera le côté matériel si ça marche avec Wheezy et pas avec Jessie… (bien sûr entre-temps le côté hardware tu n’y touches pas hein… :smiley: ).
C’est pénible comme méthode et ça va prendre du temps.
hello
@GOGI
yes, disque entier dédié à l’installation de jessie (“utilisation d’un disque entier avec LVM chiffré”).
Mais effectivement je peux branché un 2nd disque dur dans la machine, faire l’install de wheezy sur ce nouveau disque et mettre à jour grub pour avoir le dualboot wheezy/jessie.
En revanche, j’aurai des différences notables par rapport à jessie :
  • sysvinit au lieu se systemd (par défaut, mais remplaçable par ce dernier)
  • drivers graphiques en 340.x max (issus des bpo-wheezy)
  • install de steam “hors dépots” (nécessité de “créer un chroot jessie”, d’après la page https://wiki.debian.org/fr/Steam, mais là, j’ai peur de retomber dans le présent problème…)
boaf, de toute manière, j’ai pas beaucoup d’autres solutions…
je lance le bignou et je vous tiens au courant.
A++
LVM over LUKS ou LUKS over LVM? Je présume que tu as choisi la 1ère option, c’est à dire que tu as crée un conteneur LUKS d’abord, puis tu as crée ton “schéma” LVM" dans ce conteneur…
Oui mais l’idéal serait d’installer Wheezy côte-à-côte avec Jessie sur le même disque, pour écarter définitivement le côté matériel… Si la place sur le disque le permet tu devrais puvoir facilement remanier ton ensemble LVM pour faire une petite place pour Wheezy.
Pour l’instant on cherche avec cette manip à écarter un problème matériel, ce que tu cites ici ce sont des problème d’ordre logiciel.
Non, c’était une erreur de ma part de penser que la bascule serait automatique.
C’est juste que la pile graphique comprend : linux, mesa et Xorg/wayland.
C’est pourquoi, si on passe l’un en bpo, autant passer les deux autres.
Vérifier si d’autres paquets mesa doivent passer en bpo.
Debian – Détails du paquet source mesa dans jessie-backports
désolé pour cette longue absence, j’ai été quelque peu pris depuis un mois…
pour en revenir à ce sujet,
j’ai partiellement résolu le problème (en fait j’ai contourné le problème) :
1/ sur la machine concernée par le problème : j’ai fait un reinstall fraîche de wheezy
et depuis plus aucun problème (j’ai aussi changé de carte graphique -> geforce gt640, mais c’est non discriminant pour ce problème - j’ai fait des tests entre-temps)
2/ j’ai inséré la geforce 750ti dans une nouvelle machine (nouvelle carte mère à base de chipset H61) en installant jessie. et sur cette machine non plus le problème n’apparait pas.
En guise de conclusion, je pencherais donc pour une incompatibilité entre Jessie (et son ecosystème logiciel) et mon écosystème matériel : CM avec le chipset MCP79 (+chip graphique 9400 intégré) de chez nvidia + …
PS : dois-je changer le titre du post en quelque chose genre [partiellement résolu] , [contourné] , [abandonné] ou autre ?
Lien erroné ?
hello
comment ça ? (-> “lien erroné” ?)
non non, mon dernier post est bien la conclusion de mes péripéties sur ce sujet (“jessie redémarre aléatoirement”).
@josephtux
désolé, je viens de voir que ta question ne m’était pas adressée.
(j’ai un peu de mal avec l’interface du forum)…
