Je viens de tester. (Ajout de splash i8042.reset i8042.nomux i8042.nopnp i8042.noloop à la fin de la ligne linux, qui finissait déjà par quiet.)
Pas de changement
Pas de changement
https://www.mjmwired.net/kernel/Documentation/kernel-parameters.txt#2713
dit
1496 i8042.debug [HW] Toggle i8042 debug mode
1497 i8042.unmask_kbd_data
1498 [HW] Enable printing of interrupt data from the KBD port
1499 (disabled by default, and as a pre-condition
1500 requires that i8042.debug=1 be enabled)
1501 i8042.direct [HW] Put keyboard port into non-translated mode
1502 i8042.dumbkbd [HW] Pretend that controller can only read data from
1503 keyboard and cannot control its state
1504 (Don't attempt to blink the leds)
1505 i8042.noaux [HW] Don't check for auxiliary (== mouse) port
1506 i8042.nokbd [HW] Don't check/create keyboard port
1507 i8042.noloop [HW] Disable the AUX Loopback command while probing
1508 for the AUX port
1509 i8042.nomux [HW] Don't check presence of an active multiplexing
1510 controller
1511 i8042.nopnp [HW] Don't use ACPIPnP / PnPBIOS to discover KBD/AUX
1512 controllers
1513 i8042.notimeout [HW] Ignore timeout condition signalled by controller
1514 i8042.reset [HW] Reset the controller during init, cleanup and
1515 suspend-to-ram transitions, only during s2r
1516 transitions, or never reset
1517 Format: { 1 | Y | y | 0 | N | n }
1518 1, Y, y: always reset controller
1519 0, N, n: don't ever reset controller
1520 Default: only on s2r transitions on x86; most other
1521 architectures force reset to be always executed
1522 i8042.unlock [HW] Unlock (ignore) the keylock
1523 i8042.kbdreset [HW] Reset device connected to KBD port
essai avec uniquement i8042.debug , ça te donneras peut-etre des infos pour résoudre ton problème
D’ac. Du coup je boot avec le paramètre i8042.debug et je fais comment ensuite pour obtenir ces infos ?
(J’ai testé un live Xubuntu 16.04 LTS par curiosité. Pas de touchpad et problèmes d’extinction. Exactement comme Debian.
toutes les infos seront dans les fichiers log dans /var/log/… ou en utilisant la commande
journalctl -b
bonjour
à tout hasard (ca m’est arrivé une fois)
Regarde cà http://www.commentcamarche.net/forum/affich-26398603-le-touchpad-de-toshiba-ne-fonctionne-plus
On peut ptet en déduire que Caribou ferait bien de vérifier tous ses raccourcis clavier.
@ricardo : Déjà testé le raccourci clavier malheureusement : https://debian-facile.org/viewtopic.php?pid=231748#p231748
@grandtoubab : OK merci ! Je risque de ne pas t’envoyer ça avant la semaine prochaine par contre.
@grandtoubab j’ai le retour demandé ! Enfin il est très long donc voilà une partie qui semble utile à mon problème :
août 09 19:57:57 debian kernel: i8042: [468170] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468178] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468186] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468194] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468202] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468210] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468218] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468225] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468233] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468241] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:57 debian kernel: i8042: [468249] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:58 debian kernel: i8042: [468257] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:58 debian kernel: i8042: [468264] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:58 debian kernel: i8042: [468272] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:58 debian kernel: i8042: [468280] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:58 debian kernel: i8042: [468288] ** <- i8042 (interrupt, 0, 1)
août 09 19:57:58 debian kernel: i8042: [468296] ** <- i8042 (interrupt, 0, 1)
août 09 19:26:59 debian kernel: i8042: [271] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [271] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [271] 00 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [272] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [272] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [272] e8 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [273] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [273] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [273] 02 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [274] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [274] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [274] e8 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [275] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [275] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [275] 00 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [276] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [276] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [276] e9 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [279] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [279] 33 <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [279] 80 <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [279] 4d <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [280] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [280] e6 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [281] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [281] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [281] e8 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [282] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [282] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [282] 00 -> i8042 (parameter)
août 09 19:26:59 debian kernel: i8042: [283] fa <- i8042 (interrupt, 1, 12)
août 09 19:26:59 debian kernel: i8042: [283] d4 -> i8042 (command)
août 09 19:26:59 debian kernel: i8042: [283] e8 -> i8042 (parameter)
ça ne m’inspire rien du tout. On ne dirait pas des messages d’erreurs mais des messages de fonctionnement normal.
C’est fou
Je vais finir par le rendre à son propriétaire et lui dire d’acheter une souris je crois…
