oula… vous êtes parano ou quoi ? j’ai fait des copier/coller de tout en mentionnant à quoi ça correspondait, ya quoi de louche ?
root@dev:/home/myz# find /etc/apt -name '*.list*' -exec bash -c 'echo -e "\n$1\n"; nl -ba "$1"' _ '{}' \;
/etc/apt/sources.list
1 #
2
3 # deb cdrom:[Debian GNU/Linux 8 _Jessie_ - Official Snapshot amd64 LIVE/INSTALL Binary 20150426-18:45]/ jessie contrib main non-free
4
5 #deb cdrom:[Debian GNU/Linux 8 _Jessie_ - Official Snapshot amd64 LIVE/INSTALL Binary 20150426-18:45]/ jessie contrib main non-free
6
7 # Line commented out by installer because it failed to verify:
8 #deb http://security.debian.org/ jessie/updates main contrib non-free
9 # Line commented out by installer because it failed to verify:
10 #deb-src http://security.debian.org/ jessie/updates main contrib non-free
11 #deb http://ftp.fr.debian.org/debian/ jessie main contrib
12 #deb http://security.debian.org/ jessie/updates main contrib non-free
13 #deb http://ftp.fr.debian.org/debian/ jessie-proposed-updates main contrib non-free
14 #deb http://www.deb-multimedia.org jessie main non-free
15
16 deb http://ftp.fr.debian.org/debian/ jessie main non-free contrib
17 deb http://security.debian.org/ jessie/updates main contrib non-free
18 deb http://ftp.fr.debian.org/debian/ jessie-updates main contrib non-free
19
/etc/apt/sources.list.d
nl: /etc/apt/sources.list.d: est un dossier
/etc/apt/sources.list~
root@dev:/home/myz# find /etc/apt -name '*pref*' -exec bash -c 'echo -e "\n$1\n"; nl -ba "$1"' _ '{}' \;
/etc/apt/preferences.d
nl: /etc/apt/preferences.d: est un dossier
root@dev:/home/myz# lspci -v
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Device 2452
Flags: bus master, fast devsel, latency 0, IRQ 64
Memory at f6400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at <unassigned> [disabled]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: i915
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 09)
Subsystem: Intel Corporation Device 2010
Flags: bus master, fast devsel, latency 0, IRQ 60
Memory at f7414000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Kernel driver in use: snd_hda_intel
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 67
Memory at f7400000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 66
Memory at f741d000 (64-bit, non-prefetchable) [size=32]
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: mei_me
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 68
Memory at f7410000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [100] Virtual Channel
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: f7300000-f73fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Device 2452
Capabilities: [a0] Power Management version 3
Capabilities: [100] #00
Capabilities: [200] L1 PM Substates
Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 2 (rev e4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: f6800000-f71fffff
Prefetchable memory behind bridge: 00000000f2100000-00000000f2afffff
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: f7200000-f72fffff
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: f5000000-f60fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f741b000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci-pci
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 65
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f741a000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
Flags: medium devsel, IRQ 18
Memory at f7419000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
00:1f.6 Signal processing controller: Intel Corporation 8 Series Thermal (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 4
Memory at f7418000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
01:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
Subsystem: Intel Corporation Wireless-N 7260
Flags: bus master, fast devsel, latency 0, IRQ 69
Memory at f7300000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number ac-7b-a1-ff-ff-44-78-43
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] Vendor Specific Information: ID=cafe Rev=1 Len=014 <?>
Kernel driver in use: iwlwifi
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader (rev 01)
Physical Slot: 1
Flags: bus master, fast devsel, latency 0, IRQ 61
Memory at f6800000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 00-00-00-01-00-4c-e0-00
Capabilities: [150] Latency Tolerance Reporting
Capabilities: [158] L1 PM Substates
Kernel driver in use: rtsx_pci
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 62
I/O ports at d000 [size=256]
Memory at f7204000 (64-bit, non-prefetchable) [size=4K]
Memory at f7200000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
Capabilities: [170] Latency Tolerance Reporting
Capabilities: [178] L1 PM Substates
Kernel driver in use: r8169
04:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 63
Memory at f5000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at c000 [size=128]
Expansion ROM at f6000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: nouveau
pour le probleme de pilotes j’ai eu pareil sur ma tour avec une carte mere AM1 / AMD A8 et une carte video ATI R7 => pas de réseau et pas de video avec la debian officiel CD1
