Authentification dovecot ldap
Bonjour a tous:
Alors voila je suis en stage et je dois mettre en place un service de mail.
Pour ce faire nous avons opté pour3 les 3 programmes suivant:
onpenLDAP
Dovecot
Postfix
Pour le moment j’ai mis en place openLDAP et Dovecot.
Je voudrais authentifier un utilisateur sur dovecot en passant par openldap.
Pour tester ma config je fait un telnet:
login test@flo-debian.gescom test
. NO Temporary authentication failure.
Dans les fichiers log:
Feb 25 12:27:18 Flo-Debian dovecot: auth(default): ldap(test@flo-debian.gescom,127.0.0.1): ldap_search((& (objectClass=mailAccount)(mail=test@flo-debian.gescom)(mailenable=OK))) failed: No such object
fichier de config:
ldap.conf:
host localhost
base dc=flo-debian,dc=gescom
dovecot-ldap:
LDAP protocol version to use. Likely 2 or 3.
ldap_version = 3
LDAP base. %variables can be used here.
base = dc=flo-debian, dc=gescom
Dereference: never, searching, finding, always
#deref = never
Search scope: base, onelevel, subtree
#scope = subtree
User attributes are given in LDAP-name=dovecot-internal-name list. The
internal names are:
uid - System UID
gid - System GID
home - Home directory
mail - Mail location
There are also other special fields which can be returned, see
wiki.dovecot.org/UserDatabase/ExtraFields
user_attrs = mailbox=home
Filter for user lookup. Some variables can be used (see
wiki.dovecot.org/Variables for full list):
%u - username
%n - user part in user@domain, same as %u if there’s no domain
%d - domain part in user@domain, empty if user there’s no domain
user_filter = (&(objectClass=mailAccount)(mail=%u)(mailenable=OK)))
Password checking attributes:
user: Virtual user name (user@domain), if you wish to change the
user-given username to something else
password: Password, may optionally start with {type}, eg. {crypt}
wiki.dovecot.org/PasswordDatabase/ExtraFields
pass_attrs = mail=user,userPassword=password
If you wish to avoid two LDAP lookups (passdb + userdb), you can use
userdb prefetch instead of userdb ldap in dovecot.conf. In that case you’ll
also have to include user_attrs in pass_attrs field prefixed with “userdb_”
string. For example:
#pass_attrs = uid=user,userPassword=password,homeDirectory=userdb_home,uidNumber=userdb_uid,gidNumber=userdb_gid
Filter for password lookups
pass_filter = (&(objectClass=mailAccount)(mail=%u)(mailenable=OK))
Default password scheme. “{scheme}” before password overrides this.
List of supported schemes is in: wiki.dovecot.org/Authentication
#default_pass_scheme = CRYPT
You can use same UID and GID for all user accounts if you really want to.
If the UID/GID is still found from LDAP reply, it overrides these values.
user_global_uid = vmail
user_global_gid = mail
Je suis sur une debian lenny
l’utilisateur test a ete ajouté
Comment réussir a authentifier au près de ldap ?
Merci pour votre aidre
Xillion
