Merci pour la réponse.
Voici ma liste de dépot
# Security
deb http://security.debian.org/ wheezy/updates main contrib non-free
deb-src http://security.debian.org/ wheezy/updates main contrib non-free
# Update
deb http://ftp.fr.debian.org/debian/ wheezy-updates main
deb-src http://ftp.fr.debian.org/debian/ wheezy-updates main
# Base
deb http://ftp.fr.debian.org/debian/ wheezy main non-free contrib
deb-src http://ftp.fr.debian.org/debian/ wheezy main non-free contrib
# Rétroportages
deb http://ftp.debian.org/debian/ wheezy-backports main contrib non-free
J’ai ensuite fait :
J’ai aussi installer le [mono]firmware-iwlwifi[/mono].
J’ai suivi ce tutoriel pour mettre le noyau 3.14 :
yourownlinux.com/2014/06/how … linux.html
Par contre lorsque j’installe les paquets voici ce qu’il me met :
sudo dpkg -i linux-headers-3.14.5-*.deb linux-image-3.14.5-*.deb
Selecting previously unselected package linux-headers-3.14.5-031405.
(Reading database ... 129393 files and directories currently installed.)
Unpacking linux-headers-3.14.5-031405 (from linux-headers-3.14.5-031405_3.14.5-031405.201405311735_all.deb) ...
Selecting previously unselected package linux-headers-3.14.5-031405-generic.
Unpacking linux-headers-3.14.5-031405-generic (from linux-headers-3.14.5-031405-generic_3.14.5-031405.201405311735_amd64.deb) ...
Selecting previously unselected package linux-image-3.14.5-031405-generic.
Unpacking linux-image-3.14.5-031405-generic (from linux-image-3.14.5-031405-generic_3.14.5-031405.201405311735_amd64.deb) ...
Done.
Setting up linux-headers-3.14.5-031405 (3.14.5-031405.201405311735) ...
dpkg: dependency problems prevent configuration of linux-headers-3.14.5-031405-generic:
linux-headers-3.14.5-031405-generic depends on libc6 (>= 2.14); however:
Version of libc6:amd64 on system is 2.13-38+deb7u3.
dpkg: error processing linux-headers-3.14.5-031405-generic (--install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-3.14.5-031405-generic:
linux-image-3.14.5-031405-generic depends on initramfs-tools (>= 0.36ubuntu6); however:
Package initramfs-tools is not installed.
dpkg: error processing linux-image-3.14.5-031405-generic (--install):
Errors were encountered while processing:
Le package initramfs-tools n’étant pas installé j’ai tenté de l’installer :
sudo apt-get install initramfs-tools
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
linux-headers-3.14.5-031405-generic : Depends: libc6 (>= 2.14) but 2.13-38+deb7u3 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Suite à ce message j’ai donc fait un [mono]apt-get -f install[/mono].
sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
initramfs-tools
The following packages will be REMOVED:
The following NEW packages will be installed:
initramfs-tools
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 91.3 kB of archives.
After this operation, 12.9 MB disk space will be freed.
Do you want to continue [Y/n]? y
Get:1 http://ftp.fr.debian.org/debian/ wheezy/main initramfs-tools all 0.109.1 [91.3 kB]
Fetched 91.3 kB in 0s (208 kB/s)
(Reading database ... 159209 files and directories currently installed.)
Removing linux-headers-3.14.5-031405-generic ...
Selecting previously unselected package initramfs-tools.
(Reading database ... 149636 files and directories currently installed.)
Unpacking initramfs-tools (from .../initramfs-tools_0.109.1_all.deb) ...
Processing triggers for man-db ...
Setting up initramfs-tools (0.109.1) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-3.14.5-031405-generic (3.14.5-031405.201405311735) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.14.5-031405-generic /boot/vmlinuz-3.14.5-031405-generic
update-initramfs: Generating /boot/initrd.img-3.14.5-031405-generic
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for module r8169
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.14.5-031405-generic /boot/vmlinuz-3.14.5-031405-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.14.5-031405-generic /boot/vmlinuz-3.14.5-031405-generic
Generating grub.cfg ...
Found background image: .background_cache.png
Found linux image: /boot/vmlinuz-3.14.5-031405-generic
Found initrd image: /boot/initrd.img-3.14.5-031405-generic
Found linux image: /boot/vmlinuz-3.2.0-4-amd64
Found initrd image: /boot/initrd.img-3.2.0-4-amd64
done
Une fois que je reboot et que je choisis le kernel 3.14 sur grub, je n’ai toujours pas la carte wifi d’activé. J’imagine que c’est lié à une mauvaise installation du noyau.
Je suis retourné sur le noyau 3.2 et j’ai désinstaller le 3.14 proprement en attendant que l’on m’explique m’on erreur d’installation.
Merci de votre aide,
Sorgan.
