[3.16 Jessie] du grain à moudre!
suite à une MAJ, j’ai ceci:
Traitement des actions différées (« triggers ») pour udev (215-6) ...
 /var/cache/apt/archives/postgresql-9.4_9.4~rc1-1_amd64.deb
======  How can you help?  (doc: https://wiki.debian.org/how-can-i-help ) ======
New packages where help is needed, including orphaned ones (from WNPP):
 - abiword - https://bugs.debian.org/740678 - O (Orphaned)
 - cvs - https://bugs.debian.org/764397 - O (Orphaned)
 - dctrl-tools - https://bugs.debian.org/768834 - O (Orphaned)
 - meanwhile - https://bugs.debian.org/762509 - O (Orphaned)
 - t1utils - https://bugs.debian.org/765322 - RFA (Maintainer looking for adopter)
 - debhelper - https://bugs.debian.org/768507 - ITA (Someone working on adoption)
 - ejabberd - https://bugs.debian.org/767874 - RFH (Maintainer looking for help)
New bugs suitable for new contributors (tagged 'gift'):
 - apt - https://bugs.debian.org/173559 - apt-listchanges: show changes while downloading
 - eject - https://bugs.debian.org/766250 - eject: [kfreebsd] fails to open cdrom tray
New bugs affecting Debian infrastructure (tagged 'gift'):
 - qa.debian.org - https://bugs.debian.org/761119 - debsources: suite-based navigation
 - qa.debian.org - https://bugs.debian.org/761149 - debsources: allow redirects to package versions based on suite/codename
 - qa.debian.org - https://bugs.debian.org/761227 - debsources: add totals to all /stats tables
 - qa.debian.org - https://bugs.debian.org/761228 - debsources: make pie charts more readable
 - qa.debian.org - https://bugs.debian.org/761229 - debsources: make trend charts more readable
 - qa.debian.org - https://bugs.debian.org/761232 - debsources: release pages should mention release number and date
 - qa.debian.org - https://bugs.debian.org/762951 - debsources: increase/maximize test coverage
 - qa.debian.org - https://bugs.debian.org/763921 - debsources: detailed directory listing with file types and permissions
 - www.debian.org - https://bugs.debian.org/766923 - www.debian.org: Who's using Debian page - 2014 update
New packages removed from Debian 'testing' (the maintainer might need help):
 - gcc-4.6 - https://tracker.debian.org/pkg/gcc-4.6
 - cpp-4.6 - https://tracker.debian.org/pkg/gcc-4.6
 - libx32gcc-4.7-dev - https://tracker.debian.org/pkg/gcc-4.7
 - lib32gcc-4.7-dev - https://tracker.debian.org/pkg/gcc-4.7
 - gcc-4.7 - https://tracker.debian.org/pkg/gcc-4.7
 - g++-4.7 - https://tracker.debian.org/pkg/gcc-4.7
 - cpp-4.7 - https://tracker.debian.org/pkg/gcc-4.7
 - gcc-4.7-multilib - https://tracker.debian.org/pkg/gcc-4.7
 - python-wxgtk2.8 - https://tracker.debian.org/pkg/wxwidgets2.8
New packages going to be removed from Debian 'testing' (the maintainer might need help):
 - daemontools - https://tracker.debian.org/pkg/daemontools - removal on 2014-12-17 (bug: #767933)
 - kernel-package - https://tracker.debian.org/pkg/kernel-package - removal on 2014-12-02 (bug: #767857)
 - roundcube - https://tracker.debian.org/pkg/roundcube - removal on 2014-12-20
New packages waiting for sponsorship (reviews/tests are also useful):
 - libgetdata - https://bugs.debian.org/766828 - RFS: libgetdata/0.7.3-7 -- enable multiarch ahead of freeze
 - polkit-qt-1 - https://bugs.debian.org/765647 - RFS: polkit-qt-1/0.112.0-1 (new upstream, Qt 5 )
-----  Show old opportunities as well as new ones: how-can-i-help --old  -----
root@alpha30:~#
Vous feriez quoi?
A+
JB1
[quote=“jb1”]suite à une MAJ, j’ai ceci:
[mono]Traitement des actions différées (« triggers ») pour udev (215-6) …
/var/cache/apt/archives/postgresql-9.4_9.4~rc1-1_amd64.deb[/mono][/quote]
Viré cet intrus et les autres.
Bonsoir,
je ne suis pas plus avancé,
donc ton conseil “virer DEBIAN” pour être sur de ne rien oublier
Je vais tenter le reboot
A+
JB1
C’est toi qui vois …
Qu’il en soit ainsi. :033
Vires les paquets exotiques dont tu ne maîtrises pas les dépendances.
Bonsoir,
je vais faire,
je viens de rebooter, j’ai perdu le son
A+
JB1
c’est un .deb
A+
JB1
je viens de refaire apt-get update/upgrade,
j’ai:
root@alpha30:/home/jb1#
l’erreur 1 est un problème de droit "Opération not permitted"
A+
JB1
[quote=“jb1”]Des erreurs ont été rencontrées pendant l’exécution :
E: Sub-process /usr/bin/dpkg returned an error code (1)[/quote]
[mono]$ dpkg -l | grep postgresql-9.4[/mono]
[mono]# aptitude remove --purge postgresql-9.4.i[/i][/mono]
Et, autres …
merci pour tes actions,
la machine ne boote plus, même en recovery,
comme j’ai 2 autres passerelles sur des Linux différent, je laisse tombé Debian
pour l’instant
+1 pour le pb de son!
le dynamiteur de MAJ est passé par là!
dans ses actions de rétro pédalage
je regarderai les news malgré tout
A+
JB1
