Bonjour Pascal et les autres,
les divers réponses,
ce noyau vient de kernel.org
root@alph30:/proc/net# ls
anycast6 hci ip_mr_cache packet rt6_stats stat
arp icmp ip_mr_vif pnp rt_acct tcp
bnep icmp6 ipv6_route protocols rt_cache tcp6
connector if_inet6 l2cap psched sco udp
dev igmp mcfilter ptype snmp udp6
dev_mcast igmp6 mcfilter6 raw snmp6 udplite
dev_snmp6 ip6_flowlabel netfilter raw6 sockstat udplite6
fib_trie ip6_mr_cache netlink rfcomm sockstat6 unix
fib_triestat ip6_mr_vif netstat route softnet_stat wireless
root@alph30:/proc/net# cd netfilter
root@alph30:/proc/net/netfilter# ls
nf_log
root@alph30:/proc/net/netfilter# cd
root@alph30:~# modinfo iptable_nat
modinfo: ERROR: Module iptable_nat not found.
root@alph30:~# modinfo nf_nat
filename: /lib/modules/3.18.0/kernel/net/netfilter/nf_nat.ko
license: GPL
srcversion: B5E728474B05AB8C081DCFD
depends: nf_conntrack
intree: Y
vermagic: 3.18.0 SMP mod_unload modversions
signer: Magrathea: Glacier signing key
sig_key: 38:D4:A7:65:1C:6A:CE:6C:04:41:8E:21:8A:D2:08:CD:AC:03:8D:7B
sig_hashalgo: sha512
root@alph30:~# modinfo nf_nat_ipv4
filename: /lib/modules/3.18.0/kernel/net/ipv4/netfilter/nf_nat_ipv4.ko
alias: nf-nat-2
license: GPL
srcversion: 1FBA63297BD688832ABF236
depends: nf_nat,nf_conntrack
intree: Y
root@alph30:~# cd /usr/src/linux
root@alph30:/usr/src/linux# fgrep NAT .config
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_ARCH_HIBERNATION_HEADER=y
CONFIG_HIBERNATE_CALLBACKS=y
CONFIG_HIBERNATION=y
CONFIG_NF_NAT=m
CONFIG_NF_NAT_NEEDED=y
CONFIG_NF_NAT_PROTO_DCCP=m
CONFIG_NF_NAT_PROTO_UDPLITE=m
CONFIG_NF_NAT_PROTO_SCTP=m
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NFT_NAT=m
# CONFIG_NETFILTER_XT_NAT is not set
CONFIG_NF_NAT_IPV4=m
CONFIG_NFT_CHAIN_NAT_IPV4=m
CONFIG_NF_NAT_MASQUERADE_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PROTO_GRE=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
# CONFIG_IP_NF_NAT is not set
CONFIG_NF_NAT_IPV6=m
CONFIG_NFT_CHAIN_NAT_IPV6=m
# CONFIG_NF_NAT_MASQUERADE_IPV6 is not set
# CONFIG_IP6_NF_NAT is not set
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_VENDOR_NATSEMI=y
CONFIG_NATSEMI=m
CONFIG_NATIONAL_PHY=y
CONFIG_REGULATOR_ANATOP=m
CONFIG_INTEGRITY_SIGNATURE=y
CONFIG_CHECK_SIGNATURE=y
CONFIG_SIGNATURE=y
root@alph30
hier soir, j’ai refais un make menuconfig,
le NAT etait bien en module M
étonnant dans /proc/net je ne trouve pas d’ipv4 donc plus ip_forward et le reste
A+
JB1
