Problème d’oiption dans le noyau:
«If you are compiling a kernel which will never run on a machine with
more than 960 megabytes of total physical RAM, answer “off” here (default
choice and suitable for most users). This will result in a "3GB/1GB"
split: 3GB are mapped so that each process sees a 3GB virtual memory
space and the remaining part of the 4GB virtual memory space is used
by the kernel to permanently map as much physical memory as
possible.
If the machine has between 1 and 4 Gigabytes physical RAM, then
answer “4GB” here.
If more than 4 Gigabytes is used then answer “64GB” here. This
selection turns Intel PAE (Physical Address Extension) mode on.
PAE implements 3-level paging on IA32 processors. PAE is fully
supported by Linux, PAE mode is implemented on all recent Intel
processors (Pentium Pro and better). NOTE: If you say “64GB” here,
then the kernel will not boot on CPUs that don’t support PAE!»
Essaye en passant “mem=1536M” comme option avec lilo/grub.
Sinon, que donne ls -l /proc/kcore disais je? (C’est la taille réellement vu par le noyau)
