A vendre sheevaplug sur ebay, neuve n’ayant jamais servie, commandée et livrée en novembre 2011 sur le site anglais newit.co.uk (commandée pour faire fonctionner ma station météo, mais finalement achat d’un mini pc à la place de la sheevaplug) - 110 Euros.
Livrée avec câble d’alimentation et câble réseau (compatible prise de courant française) et avec une carte mémoire de 4go comprenant le logiciel de météo météohub en version d’évaluation.
Caractéristiques techniques
Processeur Marvell Kirkwood
Architecture ARM v5
1,2 GHz
Mémoire
512 Mo de DDR26
512 Mo de Mémoire Flash
Connectivité
USB 2.0
Lecteur de carte SD
Ethernet Gigabit
Consommation électrique
au repos
~3 Watts (Cos Phi ~ 0.4)
~7.5 VA
avec un hub usb: 2 clés USB + 1 clé Wifi + 1 clé carte son
~6 Watts (Cos Phi ~ 0.45)
~12 VA
This a specialist configuration for meteorological applications.
We have configured these units to boot from the SD card on which we have pre installed a demo version of the Meteohub software; this is a specialist configuration for meteorological applications. Please check the prices and license conditions at the Meteohub website.
The configuration boots from an Integral 4Gb SLC 30MB/s Class 10 SD card. This is a premium SD card and the SLC feature provides greater speed and longer lifetime.
See also: Meteohub website
The SheevaPlug is a development platform, targeted for use as a plug computer, and designed to run network-based software services. It features a Kirkwood Series processor with an embedded Marvell Sheeva 1.2 GHz CPU equipped with 512 MB of FLASH and 512 MB of DRAM. Connection to the home network is via Gigabit Ethernet, and offers desktop class performance, and can be used to replace a PC-based home server for many applications. Needless to say, very low power usage, extremely small foot print, and very low cost of ownership make this Plug Computer an attractive option for businesses of any size, hobbyists and professionals alike.
The Kit Contains:
SheevaPlug
Power adapter
Power cable
Cat 5 network cable
USB 2.0 A to Mini B Lead
