Je rencontre un léger souci avec Transmission depuis l’extérieur.
Tout d’abord, j’ai installé transmission le plus simplement du monde, en LAN ça fonctionne sans souci.
Ensuite, j’ai fait une redirection sur ma box pour le port 9090 (port RPC de ma conf transmission).
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://www.example.com/blocklist",
"cache-size-mb": 4,
"dht-enabled": true,
"download-dir": "/var/lib/transmission-daemon/downloads",
"download-limit": 100,
"download-limit-enabled": 0,
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/root/Downloads",
"incomplete-dir-enabled": false,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 3,
"peer-congestion-algorithm": "",
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": false,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": 1,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{021f21203ddd90847c6c6d7b0deefc3aa496d8bdgqqp.6gD",
"rpc-port": 9090,
"rpc-url": "/transmission/",
"rpc-username": "transmission",
"rpc-whitelist": "127.0.0.1",
"rpc-whitelist-enabled": false,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true
De l’extérieur, si je tape mon IP publique X.X.X.X:9090, je n’ai pas de message d’erreur, tout est faisable.
Vous allez me dire : Où est le problème, tout fonctionne…
Là où les ennuis commencent, c’est avec Nginx. Tout comme beaucoup de tutos le précisent en tapant transmission + nginx dans Google, j’ai créé un site Nginx avec les paramètres suivants :
server {
listen 443;
ssl on;
ssl_certificate /certs/transmission/transmission.crt;
ssl_certificate_key /certs/transmission/transmission.key;
server_name mytorrents.com;
client_max_body_size 1G;
fastcgi_buffers 64 4K;
location /transmission {
proxy_pass http://127.0.0.1:9090/transmission;
location / {
proxy_pass http://127.0.0.1:9090/transmission/web/;
Et là, une fois le site activé, j’arrive bien sur la même page transmission.
Dans ce cas, le site est bien en HTTPS, et possède même un nom de domaine “mytorrents.com” !
Cela permet aussi que je ferme le port 9090 sur ma box et que j’ouvre le 443 pour multiples choses…
En revanche, un message d’erreur s’affiche, et impossible d’ajouter de torrents, beaucoup de boutons en bas n’ourvent pas les menus, etc…
http://hpics.li/0e2d0d5
J’ai essayé avec et sans HTTPS, sur des ports différents, j’ai même essayé d’ouvrir le port supplémentaire 51413, le peer-port de la conf transmission, mais pareil… j’ai également testé avec un peu plus de paramètres dans le virtualHost Nginx, mais cela n’a jamais rien changé.
Si quelqu’un a une toute petite idée
un peu étrange, n’est-ce pas ?
