Est-ce que quelque chose de changer avec SSHd et /etc/hosts.deny ?
Je n’arrivais pas à me connecter à une de mes machines en SSH :
Sur la machine cliente :
nicolas@chlore:~$ ssh iode.***.net -v
OpenSSH_6.4, OpenSSL 1.0.1e 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to iode.microniko.net [2001:910:107d:fd11:205:5dff:fedf:1c79] port 22.
debug1: Connection established.
debug1: identity file /home/nicolas/.ssh/id_rsa type -1
debug1: identity file /home/nicolas/.ssh/id_rsa-cert type -1
debug1: identity file /home/nicolas/.ssh/id_dsa type 2
debug1: Checking blacklist file /usr/share/ssh/blacklist.DSA-1024
debug1: Checking blacklist file /etc/ssh/blacklist.DSA-1024
debug1: identity file /home/nicolas/.ssh/id_dsa-cert type -1
debug1: identity file /home/nicolas/.ssh/id_ecdsa type -1
debug1: identity file /home/nicolas/.ssh/id_ecdsa-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.4p1 Debian-1
ssh_exchange_identification: read: Connection reset by peer
Sur le serveur (/var/log/auth.log) :
Feb 17 15:45:53 iode sshd[3435]: warning: /etc/hosts.deny, line 19: can't verify hostname: getaddrinfo(chlore.***.net, AF_INET6) failed
Feb 17 15:45:53 iode sshd[3435]: refused connect from 2001:910:107d:xxx:xxx:xxx:xxx:xx (2001:910:107d:xx:xx:xx:xx:xx)
Et en enlevant ALL: PARANOID de /etc/hosts.deny sur le serveur, je peux me connecter… J’ai une autre machine avec ALL: PARANOID dans /etc/hosts.deny et je peux m’y connecter…
C’est bizarre, non ?!
