Bon, je pense que le problème provient de quelque part ici:
tail -f /var/log/syslog | grep CRON
Sep 8 12:33:27 ns3 /usr/sbin/cron[20380]: (CRON) INFO (pidfile fd = 3)
Sep 8 12:33:27 ns3 /usr/sbin/cron[20381]: (CRON) STARTUP (fork ok)
Sep 8 12:33:27 ns3 /usr/sbin/cron[20381]: (CRON) INFO (Skipping @reboot jobs -- not system startup)
Sep 8 12:34:01 ns3 /USR/SBIN/CRON[20511]: (root) CMD ([ -d /usr/share/dtc/admin ] && cd /usr/share/dtc/admin && nice -n+20 /usr/share/dtc/admin/rrdtool.sh 2>&1 >> /var/log/dtc.log)
Sep 8 12:34:01 ns3 /USR/SBIN/CRON[20512]: (root) CMD (/usr/local/rtm/bin/rtm 45 > /dev/null 2> /dev/null)
Sep 8 12:35:01 ns3 /USR/SBIN/CRON[20761]: (root) CMD (/usr/local/rtm/bin/rtm 45 > /dev/null 2> /dev/null)
Sep 8 12:35:01 ns3 /USR/SBIN/CRON[20762]: (root) CMD ( [ -d /usr/share/dtc/admin ] && cd /usr/share/dtc/admin && /usr/bin/php /usr/share/dtc/admin/stat_total_active_prods.php 2>&1 >> /var/log/dtc.log)
Sep 8 12:35:01 ns3 /USR/SBIN/CRON[20763]: (root) CMD ([ -d /usr/share/dtc/admin ] && cd /usr/share/dtc/admin && nice -n+20 /usr/share/dtc/admin/rrdtool.sh 2>&1 >> /var/log/dtc.log)
Sep 8 12:35:01 ns3 /USR/SBIN/CRON[20764]: (root) CMD ([ -x /usr/lib/sysstat/sa1 ] && { [ -r "$DEFAULT" ] && . "$DEFAULT" ; [ "$ENABLED" = "true" ] && exec /usr/lib/sysstat/sa1 $SA1_OPTIONS 1 1 ; })
Sep 8 12:36:02 ns3 /USR/SBIN/CRON[21045]: (root) CMD (/usr/local/rtm/bin/rtm 45 > /dev/null 2> /dev/null)
Sep 8 12:36:02 ns3 /USR/SBIN/CRON[21047]: (root) CMD ([ -d /usr/share/dtc/admin ] && cd /usr/share/dtc/admin && nice -n+20 /usr/share/dtc/admin/rrdtool.sh 2>&1 >> /var/log/dtc.log)
J’utilise un panel d’hébergement qui génère et déclenche différentes actions.
Sur l’extrait que j’ai fais, on retrouve
root 20381 0.0 0.0 47232 2076 ? Ss 12:33 0:00 /usr/sbin/cron
root 21774 0.0 0.0 57872 1556 ? D 12:39 0:00 /USR/SBIN/CRON
root 21814 0.0 0.0 57872 1556 ? Ss 12:39 0:00 /USR/SBIN/CRON
Donc 2 process “/USR/SBIN/CRON” qui ne se terminerons jamais.
Je ne parviens pas à voir pourquoi ces process restent en attentent, je ne vois pas d’erreus
