Acer orbicam ?
Tout nouveau sur Lenny, pas très vieux sur linux, je voulais savoir comment faire détecter ma webcam par les applications qui l’utilisent.
J’ai un portable acer serie 5600 avec webcam intégrée.
Merci de votre réponse
Ivanchti
Que donne
lspci -v
et
lsusb
bonjour,
lspci -v donne :
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
Subsystem: Acer Incorporated [ALI] Device 0102
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information <?>
Kernel modules: intel-agp
00:01.0 PCI bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express PCI Express Root Port (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: c8100000-c81fffff
Prefetchable memory behind bridge: 00000000d0000000-00000000d7ffffff
Capabilities: [88] Subsystem: Acer Incorporated [ALI] Device 0102
Capabilities: [80] Power Management version 2
Capabilities: [90] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel <?>
Capabilities: [140] Root Complex Link <?>
Kernel driver in use: pcieport-driver
Kernel modules: shpchp
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at c8000000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [130] Root Complex Link <?>
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: 50000000-500fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Capabilities: [90] Subsystem: Acer Incorporated [ALI] Device 0102
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link <?>
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at 1800 [size=32]
Kernel driver in use: uhci_hcd
Kernel modules: uhci-hcd
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 1820 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 1840 [size=32]
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 1860 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02) (prog-if 20 [EHCI])
Memory at c8004000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [58] Debug port: BAR=1 offset=00a0
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=0a, subordinate=0e, sec-latency=56
I/O behind bridge: 00003000-00003fff
Memory behind bridge: c8300000-c83fffff
Capabilities: [50] Subsystem: Acer Incorporated [ALI] Device 0102
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
Kernel modules: iTCO_wdt, intel-rng
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at 1880 [size=16]
Kernel driver in use: PIIX_IDE
Kernel modules: piix
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
Flags: medium devsel, IRQ 19
I/O ports at 18e0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c-i801
01:00.0 VGA compatible controller: ATI Technologies Inc M52 [Mobility Radeon X1300] (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at d0000000 (32-bit, prefetchable) [size=128M]
I/O ports at 2000 [size=256]
Memory at c8100000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at c8120000 [disabled] [size=128K]
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
02:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection (rev 02)
Subsystem: Intel Corporation PRO/Wireless 3945ABG Network Connection
Flags: fast devsel, IRQ 16
Memory at 50000000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [c8] Power Management version 2
Capabilities: [d0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [e0] Express Legacy Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting <?>
Capabilities: [140] Device Serial Number 07-db-4b-ff-ff-02-13-00
Kernel driver in use: iwl3945
Kernel modules: iwl3945
0a:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Flags: bus master, medium devsel, latency 32, IRQ 17
I/O ports at 3000 [size=256]
Memory at c8300000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: 8139too
Kernel modules: 8139too, 8139cp
0a:09.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
Flags: bus master, medium devsel, latency 168, IRQ 20
Memory at c8301000 (32-bit, non-prefetchable) [size=4K]
Bus: primary=0a, secondary=0b, subordinate=0e, sec-latency=176
Memory window 0: 50400000-507ff000 (prefetchable)
Memory window 1: 54000000-57fff000
I/O window 0: 00003400-000034ff
I/O window 1: 00003800-000038ff
16-bit legacy interface ports at 0001
Kernel driver in use: yenta_cardbus
Kernel modules: yenta_socket
0a:09.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
Flags: bus master, medium devsel, latency 57, IRQ 20
Memory at c8302000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [44] Power Management version 2
Kernel driver in use: tifm_7xx1
Kernel modules: tifm_7xx1
0a:09.3 SD Host controller: Texas Instruments PCIxx12 SDA Standard Compliant SD Host Controller (prog-if 01)
Subsystem: Acer Incorporated [ALI] Device 0094
Memory at c8300400 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: sdhci
Kernel modules: sdhci
lsusb donne
Bus 005 Device 002: ID 046d:0896 Logitech, Inc. OrbiCam
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
merci de l’aide à venir !
ivanchti
hello,
je me permets de relancer le sujet. Si quelqun peut me venir en aide!
merci d’avance
Ivanchti
(bien fait de relancer, j’avais oublié)
Ta webcam est géré par le module gspca_vc032x (sur les 2.6.27 et + en tout cas), que donne
modprobe gspca_vc032x
(regarde les messages donnés par dmesg et à la fin de /var/log/syslog après insertion du module) mais théoriquement il a du se charger tout seul…
bonsoir,
voilà ce que j’ai
ivan:/home/ivanchti# modprobe gspca_vc032x
FATAL: Module gspca_vc032x not found.
merci d’avance
ivanchti
Quel noyau?
$ uname -r
2.6.26-2-686
merci d’avance
Ivanchti
Damned, il te faut recompiler le noyau en y intégrant le support de ce module ou recompiler le module pour ce noyau…
bonjour,
c’est compliqué et risqué ?
Non, pas tellement, cf http://forum.debian-fr.org/viewtopic.php?f=8&t=1806
