Bonsoir,
Sur un Toshiba tecra R950 avec une debian stretch openbox j’ai le message suivant dans le processus de démarrage.
Pas d’autres remarques : arret, mise en veille ,redémarrage --> tout fonctionne correctement
Que faut il en penser?
jjr@debian:~$ su -
Mot de passe :
root@debian:~# dmesg | grep fail
[ 0.367425] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 1.593814] ACPI Error: [GTF0] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[ 1.594045] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.PRT0._SDD] (Node ffff8f8bea8c0348), AE_NOT_FOUND (20160831/psparse-543)
[ 1.594360] ACPI Error: [GTF0] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[ 1.594578] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.PRT0._GTF] (Node ffff8f8bea8c06e0), AE_NOT_FOUND (20160831/psparse-543)
[ 1.596933] ACPI Error: [GTF0] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[ 1.597184] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.PRT0._SDD] (Node ffff8f8bea8c0348), AE_NOT_FOUND (20160831/psparse-543)
[ 1.597498] ACPI Error: [GTF0] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[ 1.597717] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.PRT0._GTF] (Node ffff8f8bea8c06e0), AE_NOT_FOUND (20160831/psparse-543)
