Bonjour.
J’ai résolu mon problème de gestion de l’acpi de cette manière :
Modification des deux fichiers suivants :
[code]# cat /etc/modules
/etc/modules: kernel modules to load at boot time.
This file contains the names of kernel modules that should be loaded
at boot time, one per line. Lines beginning with “#” are ignored.
Parameters can be specified after the module name.
apm power_off=1
#loop
et
# cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" acpi=force apm=power_off
#GRUB_CMDLINE_LINUX_DEFAULT="quiet"
#GRUB_CMDLINE_LINUX="acpi=off"
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Suivi d’un update-grub
Pas obligatoire mais pour gérer la mise en veille avec le bouton power, dans mon cas :
# cat /etc/acpi/powerbtn-acpi-support.sh
#!/bin/sh
# This script initiates a shutdown when the power putton has been
# pressed. Loosely based on the sample that ships with the acpid package.
# If the acpid sample is present as a real config file (as it was in earlier
# versions of acpid), we skip this script. (Purging and reinstalling acpid
# resolves this situation, or simply deleting /etc/acpi/events/powerbtn.)
if [ -f /etc/acpi/events/powerbtn -o -f /etc/acpi/events/powerbtn.dpkg-bak ] ; then
logger Acpi-support not handling power button, acpid handler exists at /etc/acpi/events/powerbtn or /etc/acpi/events/powerbtn.dpkg-bak.
exit 0
fi
[ -e /usr/share/acpi-support/policy-funcs ] || exit 0
. /usr/share/acpi-support/policy-funcs
if CheckPolicy; then
exit 0
fi
if [ -x /etc/acpi/powerbtn.sh ] ; then
# Compatibility with old config script from acpid package
elif [ -x /etc/acpi/powerbtn.sh.dpkg-bak ] ; then
# which is still around because it was changed by the admin
else
# # Normal handling.
# /sbin/shutdown -h -P now "Power button pressed"
# Mise en veille
#/usr/sbin/pm-suspend
fi
A+
