dmidecode 2.9
SMBIOS 2.31 present.
29 structures occupying 902 bytes.
Table at 0x000DC010.
Handle 0x0000, DMI type 0, 20 bytes
BIOS Information
Vendor: PHOENIX FirstBIOS
Version: V2.60
Release Date: 01/03/2005
Address: 0xE4170
Runtime Size: 114320 bytes
ROM Size: 512 kB
Characteristics:
ISA is supported
PCI is supported
PC Card (PCMCIA) is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
ACPI is supported
USB legacy is supported
AGP is supported
Smart battery is supported
BIOS boot specification is supported
Handle 0x0001, DMI type 1, 25 bytes
System Information
Manufacturer: Acer
Product Name:
Version: Null
Serial Number: Null
UUID: 2217B671-FA44-F3EA-E50D-00023F0C4840
Wake-up Type: Power Switch
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Manufacturer:
Product Name:
Version: Null
Serial Number:
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Manufacturer: No Enclosure
Type: Other
Lock: Not Present
Version: N/A
Serial Number: None
Asset Tag: No Asset Tag
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: 52 U
Number Of Power Cords: 18
Contained Elements: 0
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: WMT478/NWD
Type: Central Processor
Family: Pentium 4
Manufacturer: Intel
ID: 34 0F 00 00 FF FB EB BF
Signature: Type 0, Family 15, Model 3, Stepping 4
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (Fast floating-point save and restore)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Hyper-threading technology)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: D0
Voltage: 1.8 V
External Clock: 200 MHz
Max Speed: 1600 MHz
Current Speed: 3200 MHz
Status: Populated, Enabled
Upgrade: Slot 1
L1 Cache Handle: 0x0008
L2 Cache Handle: 0x0009
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0005, DMI type 5, 20 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 1024 MB
Maximum Total Memory Size: 2048 MB
Supported Speeds:
70 ns
60 ns
Supported Memory Types:
DIMM
SDRAM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 2
0x0006
0x0007
Enabled Error Correcting Capabilities:
Unknown
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: M1
Bank Connections: 0 1
Current Speed: Unknown
Type: DIMM SDRAM
Installed Size: 256 MB (Double-bank Connection)
Enabled Size: 256 MB (Double-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: M2
Bank Connections: 2 3
Type: DIMM SDRAM
Error Status: OK
Handle 0x0008, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Back
Installed Size: 16 KB
Maximum Size: 16 KB
Supported SRAM Types:
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Asynchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Handle 0x0009, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Socketed, Level 2
Installed Size: 1024 KB
Maximum Size: 512 KB
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Burst
Speed: Unknown
Handle 0x000A, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3 Cache
Configuration: Enabled, Socketed, Level 3
Burst
Pipeline Burst
Asynchronous
Speed: Unknown
Handle 0x000B, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J2A1
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Reference Designator: COM 1
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J3A1
Internal Connector Type: 25 Pin Dual Inline (pin 26 cut)
External Reference Designator: Parallel
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: Circular DIN-8 male
Port Type: Keyboard Port
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: PS/2 Mouse
Handle 0x000F, DMI type 9, 13 bytes
System Slot Information
Designation: PCI Slot #1 - J5B1
Type: 32-bit PCI
Current Usage: Unknown
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x0010, DMI type 10, 6 bytes
On Board Device Information
Type: Sound
Status: Disabled
Description: ADI1886
Handle 0x0011, DMI type 11, 5 bytes
OEM Strings
String 1: This is the Intel 915G
String 2: Customer Reference Board
Handle 0x0012, DMI type 12, 5 bytes
System Configuration Options
Option 1: Jumper settings can be described here.
Handle 0x0013, DMI type 15, 29 bytes
System Event Log
Area Length: 0 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Invalid, Not Full
Change Token: 0x000000AB
Header Format: Type 1
Supported Log Type Descriptors: 3
Descriptor 1: POST error
Data Format 1: POST results bitmap
Descriptor 2: Single-bit ECC memory error
Data Format 2: Multiple-event
Descriptor 3: Multi-bit ECC memory error
Data Format 3: Multiple-event
Handle 0x0014, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 4 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0015, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0014
Error Information Handle: No Error
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: J6G1
Bank Locator: DIMM 0
Type: DDR
Type Detail: Synchronous
Speed: 133 MHz (7.5 ns)
Manufacturer: Not Specified
Handle 0x0016, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: J6H1
Bank Locator: DIMM 2
Type: DDR
Handle 0x0017, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0001FFFFFFF
Range Size: 512 MB
Physical Array Handle: 0x0014
Partition Width: 0
Handle 0x0018, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x0000FFFFFFF
Range Size: 256 MB
Physical Device Handle: 0x0015
Memory Array Mapped Address Handle: 0x0017
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x0019, DMI type 20, 19 bytes
Starting Address: 0x00010000000
Range Size: 256 MB
Physical Device Handle: 0x0016
Handle 0x001A, DMI type 32, 20 bytes
System Boot Information
Status:
Handle 0x001B, DMI type 127, 4 bytes
End Of Table
Handle 0x001C, DMI type 127, 4 bytes
End Of Table
root@Rwk-portable:~# lsusb
Bus 001 Device 004: ID 03f0:b402 Hewlett-Packard photosmart 7700 series
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 004: ID 0424:223a Standard Microsystems Corp. 8-in-1 Card Reader
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 04f3:0210 Elan Microelectronics Corp. AM-400 Hama Optical Mouse
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
root@Rwk-portable:~# lspci
00:00.0 Host bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL Memory Controller Hub (rev 04)
00:01.0 PCI bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL PCI Express Root Port (rev 04)
00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03)
00:1d.3 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d3)
00:1e.2 Multimedia audio controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC’97 Audio Controller (rev 03)
00:1e.3 Modem: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC’97 Modem Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: ATI Technologies Inc M24 1P [Radeon Mobility X600]
0a:00.0 FireWire (IEEE 1394): Texas Instruments TSB43AB21 IEEE-1394a-2000 Controller (PHY/Link)
0a:01.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5788 Gigabit Ethernet (rev 03)
0a:02.0 Ethernet controller: Linksys, A Division of Cisco Systems [AirConn] INPROCOMM IPN 2220 Wireless LAN Adapter (rev 01)
0a:04.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller (rev 01)
root@Rwk-portable:~# dmesg /var/log/messages |grep acpi
[ 0.000000] ACPI: If « acpi_apic_instance=2 » works better, notify linux-acpi@vger.kernel.org
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
