bon, je sait pas si je l’ai dit mais j’ai trois distribution sur mon ordi: 2 debian testing et un ubuntu studio. pour se qui est de faire de l’acquisition video, je n’arrive avec aucune de ces trois. par contre l’appareil photo est reconnu par la ubuntu studio (qui dispose d’un noyau 2.6.27-9-generic).
alors j’ai decider de faire un “tail -f /var/log/messages”… au cas où, si ça peut aider, ça donne ça:
[quote]Jan 25 15:26:05 MAYHEM kernel: [ 439.316025] usb 2-8: new high speed USB device using ehci_hcd and address 3
Jan 25 15:26:05 MAYHEM kernel: [ 439.451109] usb 2-8: configuration #1 chosen from 1 choice
Jan 25 15:26:05 MAYHEM kernel: [ 439.505800] usbcore: registered new interface driver libusual
Jan 25 15:26:05 MAYHEM kernel: [ 439.519150] Initializing USB Mass Storage driver…
Jan 25 15:26:05 MAYHEM kernel: [ 439.522401] scsi6 : SCSI emulation for USB Mass Storage devices
Jan 25 15:26:05 MAYHEM kernel: [ 439.523445] usbcore: registered new interface driver usb-storage
Jan 25 15:26:05 MAYHEM kernel: [ 439.524140] USB Mass Storage support registered.
Jan 25 15:26:10 MAYHEM kernel: [ 444.526025] scsi scan: INQUIRY result too short (5), using 36
Jan 25 15:26:10 MAYHEM kernel: [ 444.526035] scsi 6:0:0:0: Direct-Access PENTAX DIGITAL_CAMERA 1.00 PQ: 0 ANSI: 0
Jan 25 15:26:10 MAYHEM kernel: [ 444.527658] sd 6:0:0:0: [sdb] 4019201 512-byte hardware sectors (2058 MB)
Jan 25 15:26:10 MAYHEM kernel: [ 444.528919] sd 6:0:0:0: [sdb] Write Protect is off
Jan 25 15:26:10 MAYHEM kernel: [ 444.531518] sd 6:0:0:0: [sdb] 4019201 512-byte hardware sectors (2058 MB)
Jan 25 15:26:10 MAYHEM kernel: [ 444.532894] sd 6:0:0:0: [sdb] Write Protect is off
Jan 25 15:26:10 MAYHEM kernel: [ 444.532907] sdb: sdb1
Jan 25 15:26:10 MAYHEM kernel: [ 444.535585] sd 6:0:0:0: [sdb] Attached SCSI removable disk
Jan 25 15:26:10 MAYHEM kernel: [ 444.535685] sd 6:0:0:0: Attached scsi generic sg2 type 0
Jan 25 15:26:10 MAYHEM kernel: [ 444.706508] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:10 MAYHEM kernel: [ 444.706517] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:10 MAYHEM kernel: [ 444.706521] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:10 MAYHEM kernel: [ 444.718506] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:10 MAYHEM kernel: [ 444.718514] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:10 MAYHEM kernel: [ 444.718516] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 444.744511] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 444.744519] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 444.744523] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 444.756505] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 444.756512] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 444.756515] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 444.768505] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 444.768512] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 444.768514] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 444.788508] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 444.788516] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 444.788520] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 444.800637] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 444.800648] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 444.800651] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 445.068513] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 445.068523] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 445.068527] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 445.086511] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 445.086521] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 445.086524] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:11 MAYHEM kernel: [ 445.114513] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:11 MAYHEM kernel: [ 445.114523] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:11 MAYHEM kernel: [ 445.114527] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:41 MAYHEM kernel: [ 475.229200] usb 2-8: reset high speed USB device using ehci_hcd and address 3
Jan 25 15:26:41 MAYHEM kernel: [ 475.368527] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:41 MAYHEM kernel: [ 475.368535] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:41 MAYHEM kernel: [ 475.368538] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:41 MAYHEM kernel: [ 475.386520] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:41 MAYHEM kernel: [ 475.386527] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:41 MAYHEM kernel: [ 475.386530] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:41 MAYHEM kernel: [ 475.415520] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:41 MAYHEM kernel: [ 475.415528] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:41 MAYHEM kernel: [ 475.415531] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
Jan 25 15:26:41 MAYHEM kernel: [ 475.432525] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
Jan 25 15:26:41 MAYHEM kernel: [ 475.432530] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 25 15:26:41 MAYHEM kernel: [ 475.432533] sd 6:0:0:0: [sdb] Add. Sense: Logical unit not supported
sinon je vais peut etre essayer d’installer de nouvelle version de dvgrab ou des ancienne version des noyau si jamais ça peut changer la donne…
edit: En faite, il y a un truc qui me turlupine: que j’ai la nouvelle ou l’ancienne pile firewire, cela ne change rien au fait qu’un fichier devrai apparaitre dans /dev/ lorsque je branche ma caméra, non? hors la le seul fichier succeptible d’y correspondre se nomme raw1394 et il est présent que ma caméra soit connecter ou non… est-ce possible ma carte firewire ne soit pas reconnu? comment le vérifier?
