Activation/Desactivation du wifi Inopérant
je viens d’acheter un Acer 1830T.
je l’ai directement passé en SID. Tout fonctionne sauf Fn+F3 censé couper/activer le wifi/BT.
Le wifi fonctionne sans souci mais cette combinaison de touche non alors que toutes les autres hotkeys fonctionnent. J’ai essayé en déchargeant acer-wmi mais ça ne change rien.
Une idée ?
lscpi
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02) 00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02) 00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06) 00:1a.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05) 00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) 00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05) 00:1d.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5) 00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05) 00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05) 00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05) 00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05) 01:00.0 Ethernet controller: Atheros Communications AR8151 v1.0 Gigabit Ethernet (rev c0) 02:00.0 Network controller: Broadcom Corporation BCM43225 802.11b/g/n (rev 01) ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 05) ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 05) ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 05) ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 05) ff:02.2 Host bridge: Intel Corporation Core Processor Reserved (rev 05) ff:02.3 Host bridge: Intel Corporation Core Processor Reserved (rev 05)
lsmod
acer_wmi 21843 0 btrfs 473616 0 zlib_deflate 25466 1 btrfs crc32c 12656 1 libcrc32c 12426 1 btrfs ufs 61682 0 qnx4 13184 0 hfsplus 75370 0 hfs 45666 0 minix 27349 0 ntfs 166790 0 vfat 17165 0 msdos 17070 0 fat 45206 2 vfat,msdos jfs 140566 0 xfs 603567 0 reiserfs 198112 0 ext3 112254 0 jbd 41698 1 ext3 dm_mod 62468 0 hidp 21972 1 hid 72745 1 hidp acpi_cpufreq 12849 1 mperf 12411 1 acpi_cpufreq cpufreq_stats 12713 0 cpufreq_powersave 12454 0 cpufreq_userspace 12576 0 cpufreq_conservative 13147 0 parport_pc 22191 0 ppdev 12725 0 lp 17190 0 parport 31650 3 parport_pc,ppdev,lp rfcomm 32744 8 bnep 17424 2 binfmt_misc 12914 1 uinput 17392 1 fuse 61554 1 ext2 62796 1 loop 22479 0 snd_hda_codec_hdmi 22174 1 snd_hda_codec_realtek 283734 1 snd_hda_intel 25946 3 snd_hda_codec 67865 3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel snd_hwdep 13148 1 snd_hda_codec joydev 17138 0 snd_pcm 67276 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec lib80211_crypt_tkip 17179 0 i915 329754 7 uvcvideo 57386 0 snd_seq 44678 0 drm_kms_helper 26950 1 i915 btusb 17417 4 snd_timer 22658 2 snd_pcm,snd_seq wl 2522123 0 drm 166500 3 i915,drm_kms_helper snd_seq_device 13155 1 snd_seq videodev 66266 1 uvcvideo i2c_algo_bit 12834 1 i915 bluetooth 107224 28 hidp,rfcomm,bnep,btusb sparse_keymap 12760 1 acer_wmi snd 52324 15 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device lib80211 12990 2 lib80211_crypt_tkip,wl rfkill 19014 4 acer_wmi,bluetooth soundcore 13014 1 snd snd_page_alloc 12969 2 snd_hda_intel,snd_pcm i2c_i801 16870 0 media 18148 1 videodev v4l2_compat_ioctl32 16575 1 videodev i2c_core 23766 6 i915,drm_kms_helper,drm,videodev,i2c_algo_bit,i2c_i801 pcspkr 12579 0 intel_ips 17462 0 ac 12624 0 evdev 17475 17 battery 13109 0 psmouse 55199 0 serio_raw 12878 0 video 17553 1 i915 processor 27431 5 acpi_cpufreq button 12895 1 i915 wmi 13202 1 acer_wmi power_supply 13475 2 ac,battery ext4 317160 2 mbcache 12930 3 ext3,ext2,ext4 jbd2 65105 1 ext4 crc16 12343 2 bluetooth,ext4 usb_storage 43639 0 uas 13151 0 sd_mod 35644 4 crc_t10dif 12348 1 sd_mod ahci 25089 3 libahci 22616 1 ahci libata 151572 2 ahci,libahci ehci_hcd 39487 0 usbcore 127203 6 uvcvideo,btusb,usb_storage,uas,ehci_hcd atl1c 31796 0 scsi_mod 161557 4 usb_storage,uas,sd_mod,libata thermal 17330 0 thermal_sys 17939 3 video,processor,thermal
voilà ce que j’ai dans les logs quand je tente d’effecteur la combinaison de touches :
Jun 26 14:40:14 steelers kernel: [ 3030.343355] atkbd serio0: Unknown key pressed (translated set 2, code 0x93 on isa0060/serio0). Jun 26 14:40:14 steelers kernel: [ 3030.343361] atkbd serio0: Use 'setkeycodes e013 <keycode>' to make it known. Jun 26 14:40:15 steelers kernel: [ 3030.467857] keyboard: can't emulate rawmode for keycode 240 Jun 26 14:40:15 steelers kernel: [ 3030.467873] keyboard: can't emulate rawmode for keycode 240 Jun 26 14:40:15 steelers kernel: [ 3030.467878] acer_wmi: Unknown key number - 0x4 Jun 26 14:40:15 steelers kernel: [ 3030.512190] atkbd serio0: Unknown key released (translated set 2, code 0x93 on isa0060/serio0). Jun 26 14:40:15 steelers kernel: [ 3030.512197] atkbd serio0: Use 'setkeycodes e013 <keycode>' to make it known.
Je précise qu’en blacklistant acer_wmi, une première combinaison desactive le bluetooth et le TX Power de la carte Wifi. Mais elle continue d’être alimentée. Plusieurs pressions successives remettent tout OK.
Ca marche donc à peu près mais ce que je voudrais c’est desactiver la carte wifi totalement.
J’ai résolu le problème un suppprimant le pilote wl Broadcom et en installant firmware-brcm80211 qui sert le module brcmsmac.
Si ça peut servir à quelqu’un.
