Voici le résultat de /var/log/gdm/:0.log
[code]X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny4)
Current Operating System: Linux bart 2.6.26-2-686 #1 SMP Wed Sep 21 04:35:47 UTC 2011 i686
Build Date: 03 August 2011 08:51:41PM
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Feb 3 11:45:06 2012
(==) Using config file: “/etc/X11/xorg.conf”
(II) Module “i2c” already built-in
(II) Module “ddc” already built-in
(II) Module “ramdac” already built-in
expected keysym, got circumflex: line 257 of fr
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
FreeFontPath: FPE “/usr/share/fonts/X11/misc” refcount is 2, should be 1; fixing.
Error: No Symbols named “latin9” in the include file "us"
Exiting
Abandoning symbols file "default"
Je vois aussi des :0.log.1 jusqu’à :0.log.4 qui ont le même contenu :
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Feb 3 11:44:20 2012
