J’ai créer un patch avec la commande “svn diff > mesModifications.patch”, Je voudrais maintenant pouvoir appliquer le patch sans soucis, mais j’ai ce message
[code](Stripping trailing CRs from patch.)
can’t find file to patch at input line 5
Perhaps you should have used the -p or --strip option?
The text leading up to this was:
|Index: AE-go_GameServer/config/admin.properties
|— AE-go_GameServer/config/admin.properties (revision 847)
| +++ AE-go_GameServer/config/admin.properties (working copy) |
File to patch:
Je suis placer dans le dossier juste avant AE-go_GameServer.
Je ne sais pas quoi taper a coté de 'File to patch:'
Quoi que je tape, sa merde >__<
Voila le contenu de mon fichier patch :
[code]Index: AE-go_GameServer/config/admin.properties
@@ -17,6 +17,9 @@
Adds an item to your inventory
gameserver.administration.command.add=3
+# Add Kinah to player
+gameserver.administration.command.addkinah=3
Add target player skill
gameserver.administration.command.addskill=3
Index: AE-go_GameServer/data/scripts/system/handlers/admincommands/AddKinah.java
— AE-go_GameServer/data/scripts/system/handlers/admincommands/AddKinah.java (revision 847)
+++ AE-go_GameServer/data/scripts/system/handlers/admincommands/AddKinah.java (working copy)
@@ -0,0 +1,131 @@
- This file is part of aion-unique <aionunique.smfnew.com>.
- aion-unique is free software: you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version.
- aion-unique is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with aion-unique. If not, see http://www.gnu.org/licenses/.
+package admincommands;
+import java.text.DecimalFormat;
+import java.util.Collections;
+import com.aionemu.gameserver.configs.AdminConfig;
+import com.aionemu.gameserver.model.gameobjects.Item;
+import com.aionemu.gameserver.model.gameobjects.VisibleObject;
+import com.aionemu.gameserver.model.gameobjects.player.Inventory;
+import com.aionemu.gameserver.model.gameobjects.player.Player;
+import com.aionemu.gameserver.network.aion.serverpackets.SM_INVENTORY_UPDATE;
+import com.aionemu.gameserver.services.ItemService;
+import com.aionemu.gameserver.utils.PacketSendUtility;
+import com.aionemu.gameserver.utils.chathandlers.AdminCommand;
+import com.aionemu.gameserver.world.World;
+import com.google.inject.Inject;
+* @author sweetkr
+public class AddKinah extends AdminCommand
@Inject
private World world;
@Inject
private ItemService itemService;
public AddKinah()
super("Kinah"); -
@Override
public void executeCommand(Player admin, String[] params)
if(admin.getCommonData().getAdminRole() < AdminConfig.COMMAND_ADDKINAH) -
if (admin.getCommonData().getAdminRole() > 0) -
PacketSendUtility.sendMessage(admin, "You don't have enough rights to execute this command"); -
return; -
if (params.length < 1 || params.length > 2) -
PacketSendUtility.sendMessage(admin, "syntax: //Kinah <Quantity> [PlayerName]"); -
return ; -
int itemID = 182400001; -
int itemCount = 1; -
Item addedItem = null; -
try -
itemCount = Integer.parseInt(params[0]); -
catch (NumberFormatException e) -
PacketSendUtility.sendMessage(admin, "You have wrong Kinah Quantity. (Max: 2,147,483,647 Kinah)"); -
return; -
Player target = null; -
if (params.length == 2) -
target = world.findPlayer(params[1]); -
if (target == null) -
PacketSendUtility.sendMessage(admin, "player" + params[1] + "is on offline."); -
return; -
else -
VisibleObject o = admin.getTarget(); -
if (!(o instanceof Player) || o == null) -
target = admin; -
Item item = itemService.newItem(itemID,itemCount); -
Inventory inventory = target.getInventory(); -
addedItem = inventory.getKinahItem(); -
addedItem.increaseItemCount(itemCount); -
DecimalFormat decimalFormat = new DecimalFormat("###,###"); -
String result = decimalFormat.format(itemCount); -
PacketSendUtility.sendPacket(target, new SM_INVENTORY_UPDATE(Collections.singletonList(addedItem))); -
if(addedItem == null) -
PacketSendUtility.sendMessage(admin, "You can't add Kinah."); -
else -
if (target.equals(admin)) -
PacketSendUtility.sendMessage(admin, "You have acquired" + result + " Kinah."); -
else -
PacketSendUtility.sendMessage(admin, "You added" + result + "Kinah to player " + target.getName()); -
PacketSendUtility.sendMessage(target, "You have acquired " + result + " Kinah."); -
Index: AE-go_GameServer/src/com/aionemu/gameserver/configs/AdminConfig.java
— AE-go_GameServer/src/com/aionemu/gameserver/configs/AdminConfig.java (revision 847)
+++ AE-go_GameServer/src/com/aionemu/gameserver/configs/AdminConfig.java (working copy)
@@ -26,6 +26,9 @@@Property(key = “gameserver.administration.command.add”, defaultValue = “3”)
public static int COMMAND_ADD; -
@Property(key = “gameserver.administration.command.addkinah”, defaultValue = “3”)
public static int COMMAND_ADDKINAH;
@Property(key = “gameserver.administration.command.ai”, defaultValue = “3”)
public static int COMMAND_AI;
Que faire svp ?
