Oui donc pas mal d’erreur dans le log (d’ailleur, je “connais” un peu grep, mais je n’ai pas trouvé à quoi servait le EE?)
/var/log/Xorg.0.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.0.log:[ 18.836] (II) Loading extension MIT-SCREEN-SAVER
/var/log/Xorg.0.log:[ 18.966] (EE) Failed to load module "nv" (module does not exist, 0)
/var/log/Xorg.0.log:[ 19.213] (EE) [drm] failed to open device
/var/log/Xorg.0.log:[ 19.214] (EE) open /dev/fb0: No such file or directory
/var/log/Xorg.0.log:[ 19.766] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
/var/log/Xorg.1.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.1.log:[ 2333.742] (II) Loading extension MIT-SCREEN-SAVER
/var/log/Xorg.1.log:[ 2333.750] (EE) Failed to load module "nv" (module does not exist, 0)
/var/log/Xorg.1.log:[ 2334.275] (EE) [drm] failed to open device
/var/log/Xorg.1.log:[ 2334.275] (EE) open /dev/fb0: No such file or directory
/var/log/Xorg.1.log:[ 2334.702] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
/var/log/Xorg.2.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.2.log:[ 26.125] (II) Loading extension MIT-SCREEN-SAVER
/var/log/Xorg.2.log:[ 26.137] (EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
/var/log/Xorg.2.log:[ 26.137] (EE) NVIDIA: system's kernel log for additional error messages.
/var/log/Xorg.2.log:[ 26.137] (EE) Failed to load module "nvidia" (module-specific error, 0)
/var/log/Xorg.2.log:[ 26.137] (EE) No drivers available.
/var/log/Xorg.3.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.3.log:[ 26.153] (II) Loading extension MIT-SCREEN-SAVER
/var/log/Xorg.3.log:[ 26.165] (EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
/var/log/Xorg.3.log:[ 26.165] (EE) NVIDIA: system's kernel log for additional error messages.
/var/log/Xorg.3.log:[ 26.165] (EE) Failed to load module "nvidia" (module-specific error, 0)
/var/log/Xorg.3.log:[ 26.165] (EE) No drivers available.
/var/log/Xorg.4.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.4.log:[ 26.178] (II) Loading extension MIT-SCREEN-SAVER
/var/log/Xorg.4.log:[ 26.187] (EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
/var/log/Xorg.4.log:[ 26.187] (EE) NVIDIA: system's kernel log for additional error messages.
/var/log/Xorg.4.log:[ 26.187] (EE) Failed to load module "nvidia" (module-specific error, 0)
/var/log/Xorg.4.log:[ 26.187] (EE) No drivers available.
/var/log/Xorg.5.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.5.log:[ 26.199] (II) Loading extension MIT-SCREEN-SAVER
/var/log/Xorg.5.log:[ 26.207] (EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
/var/log/Xorg.5.log:[ 26.207] (EE) NVIDIA: system's kernel log for additional error messages.
/var/log/Xorg.5.log:[ 26.207] (EE) Failed to load module "nvidia" (module-specific error, 0)
/var/log/Xorg.5.log:[ 26.207] (EE) No drivers available.
tu en penses quoi?
A la base, la personne qui avait mon ordi m’avait dit que je pouvais avoir des problème avec Nvidia, mais que la carte graphique de la carte mère était tout de même pas mal… Sauf que lorsque j’utilise un logiciel du genre gimp, j’ai tout de suite des problèmes (que je n’avais pas sous squeeze…)
